VLT69273B11G-518A
VLT69273B11G-518A
    LAIRD(莱尔德)
    ANTENNADOMERPSMASMAMALE
VLT69273B11G-518A 数据手册
Vehicular 3-Port MultibandAntenna VLT69273x11G 698-960 / 1710-2700 / 2300-2700 / 4900-6000 MHz + GPS ANTENNA The Laird vehicular 3-port multiband antenna covers the 698-960/1710-2700 MHz, 2300-2700/ 4900-6000 MHz as well as GPS (1575.42 MHz) frequency ranges. Configured with 2-port, dual-band elements in addition to 1-port with integrated GPS. Connector options include SMA male connectors for 3G/4G LTE and GPS ports with an RSMA male connector for the WiFi port. The housing incorporates a low-profile, rugged design that meets IP67 standards. The antenna also features high impact, UV-resistant polycarbonate plastic available in black or white. SPECIFICATIONS PARAMETER Model Number PERFORMANCE VLT69273B11G-518A (Black) No. of Ports Frequency Bands (MHz) VLT69273W11G-518A (White) 3 (1 port 3G/4G LTE, 1-port WiFi, 1-port GPS) 3G/4G Port WiFi Port 698-960 MHz 1710-2700 MHz 2300-2700 MHz 4900-6000 MHz Peak Gain * dBi 2.6 Max Gain +/- 30 above horizon N/A VSWR* Typical < 1.9:1 4.7 4.9 6.0 N/A N/A 5.7 < 1.6:1 < 1.6:1 < 1.6:1 VSWR * Max < 2.0:1 Port-to-Port Isolation > 22 dB Nominal Impedance Polarization Azimuth Beam Width Input Power, Max Operating Temperature Dimensions (dia. x hgt) Weight RF Connector Cable (exposed length) Radome / Baseplate Material Material Compliance IP Dust & Water Ingress Rating 50 Ohm Vertical Linear Omnidirectional 50 Watt (ambient temp. of 25°C / 77°F -30° C to +70° C (-22°F to +158°F) 132 mm x 75 mm (5.2" x 2.9") 0.74 kg (1.63 lb) SMA-Male (3G/4G port) RSMA-Male (WiFi port) LMR195M- 518.2 cm (17 ft) PC, UL94 - V0 Rating, UV Stable (Black & White) ROHS compliant IP67 *Measured on 1 ft. (30.48 cm) diameter ground plane Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Vehicular 3-Port MultibandAntenna VLT69273x11G GPS ANTENNA SPECIFICATIONS PERFORMANCE PARAMETER Frequency Band 1575.42 MHz (GPS L1) Band Width 6 MHz (Typical) 27 dB ± 3 dBc Amplier Gain 50 Ohm Nominal Impedance < 1.5:1 Output VSWR DC Voltage 2.7 - 12 Vdc 20 mA (Nominal); 30 mA ( -40°C - +85°C) DC Current > 40 dB rejection @ ± 50 MHz from center frequency Out-of-Band Signal Rejection Intermodulation@ CW Mode (-40°C - +85°C) Int1 Int2 IM3 Power, dBm -10(1842.8 MHz) -10(2110 MHz) Power, dBm -10(829.58 MHz) -10(2405 MHz) -100(1575.6 MHz) -100(1575.42 MHz) Power, dBm -10(755.42 MHz) -10(820 MHz) -100(1575.42 MHz) Input 1 dB Compression @ 750 MHz, 2000 MHz & 3500 MHz RF Connector Cable (exposed length) > 10 dBm (-40°C - +85°C) SMA-Male RG174-518.2 cm (17ft) PART NUMBERS PART NUMBER VLT69273B11G-518A 1-Port 4G/LTE, 1-Port GPS: SMA Male; 1 Port WiFi:RSMA Male(Black) VLT69273W11G-518A 1-Port 4G/LTE, 1-Port GPS: SMA Male; 1 Port WiFi:RSMA Male(White) ANT-DS-VLT69273x11G 070815 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
VLT69273B11G-518A 价格&库存
很抱歉,暂时无法提供与“VLT69273B11G-518A”相匹配的价格&库存,您可以联系我们找货
