FG4103
FG4103
    LAIRD(莱尔德)
    ANT WIRELESS UHF 410-420MHZ 44"
FG4103 数据手册
410-420 MHz 3 dBd Gain Omnidirectional Antenna FG4103 FIBERGLASS BASE STATION ANTENNAS FEATURE INDUSTRY LEADING DESIGN COMPONENTS THAT PERFORM IN EXTREME CONDITIONS The FG4103 omnidirectional base station antenna incorporates a collinear design that is enclosed in high density fiberglass, which is covered with a protective ultraviolet inhibiting coating. The radiating elements are carefully phased to provide maximum gain in the horizontal plane. The mounting sleeves are tuned to eliminate RF currents from the transmission line, resulting in a “cold” sleeve that allows for greater freedom in mounting. The antenna’s high quality and well-focused beam provides the best efficiency with highest gain . FEATURES MARKETS • High gain 3 dBd (5dBi) • Omnidirectional outdoor antenna applications • Every FG fiberglass base antenna is tested on a network analyzer before shipping to assure the best performance • Custom UV protection coating • Durable gold anodized sleeve and cap with N-female connector ELECTRICAL SPECIFICATIONS Model Frequency Range (MHz) Peak Gain used in commercial, public safety, and government applications around the globe • Typical applications include land based and marine radio and voice and data transmission MECHANICAL SPECIFICATIONS FG4103 410 - 420 MHz 5 dBi Elevation Beamwidth at Half-Power 40 Deg Azimuth Beamwidth at Half-Power 360 Deg Height 44 in (190.5 cm) Diameter 1.31 in (3.33 cm) Weight 2.34 lbs (1.06 kg) Operational Temp -31o F to +176o F -35o C to +80o C Storage Temp -31o F to +176o F -35o C to +80o C Rated Wind Velocity 125 mph (210 kph) Rated Wind Velocity w/0.5" radial ice 85 mph (137 kph) TECHNICAL DATA Pattern Maximum Power Nominal Polarization VSWR Termination Mounting Information Cable Length Outdoor Rated Color Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Radome Material Omni-Directional 100 Watts 50 Ohm Vertical
FG4103 价格&库存
很抱歉,暂时无法提供与“FG4103”相匹配的价格&库存,您可以联系我们找货
