PAV69278PO-30D43F
PAV69278PO-30D43F
    LAIRD(莱尔德)
    700MHz, 850MHz, 900MHz, 1.8GHz, 1.9GHz, 2.1GHz, 2.4GHz, 2.6GHz AWS, GSM, LTE, PCS, UMTS Panel RF Ant...
PAV69278PO-30D43F 数据手册
698-­‐960  MHz/1710-­‐2700  MHz   LTE Vertical Low PIM Directional Panel Antenna PAV69278PO LTE MULTIBAND LOW PIM  DIRECTIONAL  PANEL  ANTENNA   The  PAV69278O is  a  Low PIM, Multiband,  high  gain  directional  panel  antenna  with  vertical  polarization   that  covers  the   698-960  MHz/1710-2700  MHz,  LTE700/Cellular/PCS/AWS/  MDS  and  global  GSM900/GSM1800/UMTS/LTE2600 bands. The  radiation  patterns  are  uniform  and  symmetrical,   providing  high level signal density into defined coverage zones. This  antenna  will  greatly  enhance  the  performance  of   LTE  systems  and  is  ideal  for  indoor or outdoor  applications.  The   antenna includes a wall mounting bracket,  anchors  and  bolts. The antenna can also be mast mounted with bracket adapter and clamps. FEATURES APPLICATIONS • Performance  optimized  using  Laird proprietary  RF   • In-building  or Outdoor Wireless  Networks. • Wireless  Terminal,  Point of Sale, and  Machine optimization  tools. to Machine. • Low PIM performance minimizes interference and • Automatic  meter  reading. • Commercial and industrial  security. improves in-building wireless network coverage and capacity. • Mounted with standard bracket or mast mounted with bracket adapter & clamps. • Multiple  connector  &  coax  options available. • IP67 rated for dust, dirt & water ingress. PAV69278PO PARAMETER Frequency Bands, MHz   Peak Gain, dBi (Typ) Peak Gain, dBi (Max)   VSWR, Typ VSWR, Max PIM, 3rd Order, 2 x 20W (Typ) PIM, 3rd Order, 2 x 20W (Max) SPECIFICATIONS 698-806 824-894 880-960 1710-1880 1850-1990 1910-2170 2300-2500 2500-2700 7.6 8.4 7.6 7.1 8.7 7.0 8.3 8.2 7.8 8.7 7.6 7.8 7.8 8.8 8.8 8.8
PAV69278PO-30D43F 价格&库存
很抱歉,暂时无法提供与“PAV69278PO-30D43F”相匹配的价格&库存,您可以联系我们找货
