YF880012-61NF
YF880012-61NF
    LAIRD(莱尔德)
    920MHz Yagi, 7-Element RF Antenna 880MHz ~ 960MHz 12.2dBi Connector, N Female Bracket Mount
YF880012-61NF 数据手册
DIRECTIONAL YAGI ANTENNAS YF880012 DIRECTIONAL 12 dBi YAGI ANTENNA Laird's patent pending premium series directional Yagi antennas are either fully gold, or fully black, anodized for corrosion resistance. All UHF and above frequency antennas feature internal matching to assure broad bandwidth and resistance to severe weather conditions. There is no gamma match to ice up, corrode or detune. Our engineering staff has optimized the product family for forward gain by computer analysis and then field-tested each for conformance. Patent Pending FEATURES AND BENEFITS: APPLICATIONS: • All UHF and higher frequency antennas feature 360° welds around each element and an end-ofboom N connector feed with an internal transmission line feeding the driven element. • Point-to-point and multi-point / directional outdoor antennas applications used by private organizations and government agencies around the globe. • Every Yagi is tuned on a network analyzer for best power match and lowest VSWR. • All Yagi antennas ship complete with a high quality cast aluminum mounting kit that includes stainless steel hardware and allows vertical or horizontal orientation during installation. • Typical applications include transportation such as railroad switching, remote locations reporting examples that include oil fields, weather conditions and, meter data transmissions for utilities. • The antenna has an ingress protection rating of IP67. PARAMETER SPECIFICATIONS Model Number YF880012-61NF Frequency Range 880 – 960 MHz Peak Gain, dBi (Max) 12.2 VSWR, Max < 1.5:1 Nominal Impedance 50Ω Polarization Linear Azimuth 3 dB Beamwidth 54o Elevation 3 dB Beamwidth 47o Front-to-Back Ratio 20 dB Max Power (Ambient 25oC) Antenna Dimension (LxWxT) Americas: +1.847 839.6925 IAS-AmericasEastSales@lairdtech.com Europe: +44.(0).1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com Middle East and Africa: +44.(0).1628.858941 IAS-MEASales@lairdtech.com www.lairdtech.com 200 Watts 610 x 168 x 79 mm (24.0" x 6.61" x 3.11") Cable Type, Exposed Length RG213, 48.8 cm (19.2 in) Connector Type N, female Weight 0.68 kg ( 1.5 lbs); w/brackets 1.37 kg (3.02 lbs) Wind Operational 160 km/h (100 mph) Wind Survival 220 km/h (136 mph) Operating Temperature -30oC to +70oC Storage Temperature -40oC to +85oC Ingression Protection IP67 DIRECTIONAL YAGI ANTENNAS YF880012 RADIATION PATTERNS AZIMUTH PATTERNS 890 MHz 925 MHz 960 MHz ELEVATION PATTERNS Laird warrants to the original end user customer of its products that its products are free from defects in material andworkmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. ANT-DS-YF890012 0516 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
YF880012-61NF 价格&库存
很抱歉,暂时无法提供与“YF880012-61NF”相匹配的价格&库存,您可以联系我们找货
