33-3740-00-00-3000
33-3740-00-00-3000
    TALLYSMANWIRELESS
    高增益多星座天线,覆盖BeiDou B1, Galileo E1, GPS L1频段(1557到1606 MHz)。采用Tallysman独特的Accutenna技术,提供全带宽内的真圆极化信号接收,...
33-3740-00-00-3000 数据手册
A Tallysman Accutenna® TW3740 / TW3742 High Gain Multi-Constellation Antenna The TW3740 / TW3742 is a precision high gain GNSS antenna covering the BeiDou B1, Galileo E1, GPS L1, GLONASS L1 and SBAS (WAAS, EGNOS, QZSS & MSAS) frequency band (1557 to 1606 MHz). It employs Tallysman’s unique Accutenna® technology providing truly circular polarized signal reception through the entire bandwidth of the antenna, thereby providing superior multipath signal rejection. It is especially designed for precision timing, industrial, agricultural, military, and other precision applications. The TW3740 features a three stage Low Noise Amplifier, comprised of one input LNA per feed, a mid section SAW to filter the combined output, and a final output gain stage. The TW3742 adds an additional pre-filter to provide extra strong protection from near frequency and strong harmonic signals. TW3740 / TW3742 Conical radome pictured here. Flat radome also available. Also available in White The TW3740/ TW3742 is housed in a permanent mount metal base with two nickel coated nuts and a weatherproof enclosure. Two options for mounting are available: an L-bracket (P/N#23-0040-0) or a pipe mount (P/N#23-0065-0). Applications • • • • • • • High Accuracy & Mission Critical Global Positioning Timing applications Precision Agriculture, Mining & Construction Military & Security Avionics Law Enforcement & Public Safety Fleet Management & Asset Tracking Features Benefits • • • • • • • • • • • • • • • Accutenna® technology Great axial ratio: 1 dB typ. Low noise LNA: 1 dB High rejection SAW filter High gain LNA: 40 dB typ. Low current: 19 mA typ. Wide voltage input range: 2.5 to 16 VDC IP67 weather proof housing Circular polarisation throughout the full bandwidth Superior multipath signal rejection Excellent signal to noise ratio Great out of band signal rejection Increased system accuracy Ideal for harsh environments RoHS and REACH compliant TW3740 / TW3742 Multi-Constellation Antenna Specifications Vcc = 3V, over full bandwidth, T=25°C Antenna Architecture 2 dB Bandwidth Antenna Gain (with 100mm ground plane) Axial Ratio (over full bandwidth) Dual, Quadrature Feeds 47 MHz 4.25 dBic 32 dB (TW3740) >50dB (TW3742) >35 dB >70 dB
33-3740-00-00-3000 价格&库存
很抱歉,暂时无法提供与“33-3740-00-00-3000”相匹配的价格&库存,您可以联系我们找货
