MA650.A.AB.002
MA650.A.AB.002
    TAOGLASLIMITED
    MA650.A.AB.002
MA650.A.AB.002 数据手册
Spartan Antenna 2-in-1 MA650 Part No: MA650.A.AB.002 Features: Cellular 850/900/1700/1800/2100MHz GSM/CDMA/UMTS/HSPA GPS/GLONASS/GALILEO – 5dBiC IP67 Waterproof High Efficiency / Peak Gain Outdoor Antenna Advanced RF Design and Materials Heavy Duty – Integrated Metal Base/ Ground-plane Standard 10 meters low loss cables Custom cables and connectors available CE Certified RoHS & REACH Compliant SPE-12-8-032-J 1. Introduction 3 2. Specifications 4 3. Cellular Antenna Characteristics 6 4. Cellular Radiation Patterns 8 5. GPS/GLONASS/GALILEO Antenna Characteristics 10 6. GPS/GLONASS/GALILEO Radiation Patterns 12 7. Mechanical Drawing 14 8. Installation Guide 15 9. Packaging 16 Changelog 17 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-032-J www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction MA650 antenna is a low profile, heavy-duty, fully IP67 waterproof external M2M antenna for use in 1.The Spartan Introduction telematics, transportation and remote monitoring applications. With a standard length of 10 meters of very low loss cable it is specially designed suitable for e-Bus or train telematics applications where long cable lengths are needed. MA650 antenna is unique in the market because it combines 2in1 GPS/GALILEO, Cellular (3G and 2G) 1.The Spartan Introduction antennas in a heavy-duty structure with high efficiency in a low profile compact format. The antenna screws down permanently onto a roof or metal panel and can be pole or wall-mounted. The antennas are designed to be isolated from each other to prevent cross-interference. 1.For industries Introduction such as commercial vehicle telematics, remote monitoring, smart meter systems, construction equipment, at only 40mm high, the Spartan provides an unobtrusive, robust, rugged antenna that is durable even in extreme environments. 1. Introduction SPE-12-8-032-J www.taoglas.com 3 2. Specifications 3. GNSS Frequency Bands Covered Antenna L1Characteristics2. Specifications L2 L5 L6 GPS/QZSS 3. 1227.6MHz 1176.45MHz 1278.75MHz ■ □ □ □ L5R L3PT L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ □ □ ■ ■ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz E1 1575.42MHz □ □ ■ Antenna Characteristics 1176.45MHz 1201.5MHz GLONASS Galileo 4. 1575.42MHz Antenna □Radiation□Patterns3. Antenna □ □ B1 BeiDou Characteristics2. 1561MHz Compass 3. □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ Antenna □Characteristics2. □ SBAS 3. B2 B3 Specifications 1207.14MHz 1268.52MHz Specifications ■ Antenna □Characteristics GNSS Electrical Frequency (MHz) 4. 1575.42 Antenna Radiation Patterns3.Antenna VSWR (max.) Radiation Efficiency Characteristics 1602 2:1Max 50% Peak Gain 4 ±1 dBic typ. Polarization Linear 4. Impedance Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna 50Ω Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-032-J Specifications www.taoglas.com 4 LNA and Filter Electrical Properties Frequency (MHz) 1575.42 1602 Impedance 50 Ω VSWR 2:1 Max DC Power Input 3.3V 4V 5V Gain @3.3V 28dB 28dB 28dB Noise Figure 1.50dB 1.55dB 1.62dB Power Consumption 8mA 10mA 13mA Band Attenuation ±50MHz ±70MHz ±100MHz Cellular Electrical Band Frequency (MHz) Efficiency (%) Average Gain (dB) Peak Gain (dBi) GSM 850 824~894 29 -5.8 -0.5 GSM 900 880~960 28 -5.6 -0.5 DCS 1710~1880 30 -5.4 -1.0 PCS 1850~1990 27.9 -5.3 -0.5 UMTS 1920~2170 28 -5.5 -0.8 Impedance VSWR Polarization 50Ω
MA650.A.AB.002 价格&库存
很抱歉,暂时无法提供与“MA650.A.AB.002”相匹配的价格&库存,您可以联系我们找货
