DG-ANT-20DP-BG-B
DG-ANT-20DP-BG-B
    DIGIINTERNATIONAL
    ANTENNA 2.4GHZ DIPOLE 2DBI 25PK
DG-ANT-20DP-BG-B 数据手册
ConnectCore™ 9P 9215, Wi-9P 9215, and 3G 9P 9215 Hardware Reference 90000879_R Updated on: 5/22/14 ©2013 Digi International Inc. All rights reserved. Digi, Digi International, the Digi logo, a Digi International Company, Digi JumpStart Kit, ConnectCore, NET+, NET+OS, NS9215, XBee, and Digi ESP are trademarks or registered trademarks of Digi International, Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. Information in this document is subject to change without notice and does not represent a commitment on the part of Digi International. Digi provides this document “as is,” without warranty of any kind, either expressed or implied, including, but not limited to, the implied warranties of fitness or merchantability for a particular purpose. Digi may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. This product could include technical inaccuracies or typographical errors. Changes are periodically made to the information herein; these changes may be incorporated in new editions of the publication. Using this Guide ....................................................................... This guide provides information about the Digi ConnectCore 9P 9215 Family of embedded core modules. Conventions used in this guide This table describes the typographic conventions used in this guide: This convention Is used for italic type Emphasis, new terms, variables, and document titles. monospaced type Filenames, pathnames, and code examples. Digi information .................................................................................. Documentation updates Please always check the product specific section on the Digi support website for the most current revision of this document: www.digiembedded.com/support/. Customer support For more information about your Digi product(s), or for customer service and technical support, contact Digi international. To contact Digi International by Mail Use Digi International 1101 Bren Road East Minnetonka, MN 55343 U.S.A. 3 World Wide Web http://www.digiembedded.com/support/ email http://www.digiembedded.com/support/ Telephone (U.S.) (952) 912-3444 or (877) 912-3444 Telephone (other locations) +1 (952) 912-3444 or (877) 912-3444 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Contents ....................................................................... Customer support .................................................................... 3 C h a p t e r 1 : A b o u t t h e M o d u l e . . . . . . . . . . . . . . . . . . . . . . . 12 About the Software ................................................................. 13 Digi Embedded Linux and NET+OS ................................................ 14 Module pinout .......................................................................14 Pinout legend: Type ........................................................... 14 X1 pinout ........................................................................ 14 X2 pinout ........................................................................ 17 Configuration pins — CPU ..........................................................25 Default module CPU configuration .......................................... 25 Configuration pins — Module ......................................................25 Identification of the module ................................................. 25 Module pin configuration ..................................................... 26 Clock generation ....................................................................27 Clock frequencies .............................................................. 27 Changing the CPU speed ...................................................... 28 Boot process .........................................................................28 Chip selects ..........................................................................29 Chip select memory map ..................................................... 29 SDRAM banks .........................................................................29 Multiplexed GPIO pins ..............................................................30 Pin notes ......................................................................... 30 GPIO multiplex table .......................................................... 30 www.digiembedded.com 4 Contents Module LEDs ..........................................................................35 ConnectCore 9P 9215 LEDs .................................................... 35 ConnectCore Wi-9P 9215 LEDs ................................................ 35 External interrupts ............................................................ 36 Interfaces .............................................................................37 10/100 Mbps Ethernet port ................................................... 37 UART ............................................................................. 37 SPI ................................................................................ 37 I2C bus ........................................................................... 38 RTC ............................................................................... 38 WLAN ............................................................................. 38 ADC ............................................................................... 38 FIM ................................................................................ 38 External Address/Data Bus ................................................... 38 Antenna .......................................................................... 39 ConnectCore Wi-9P 9215 WLAN ................................................... 39 WLAN Antenna Switch .............................................................. 40 Power .................................................................................40 Power supply .................................................................... 40 Internal voltage ................................................................ 40 Digi Plug-and-Play Firmware ...................................................... 41 Module pinout ........................................................................41 Pinout legend: Type ........................................................... 41 X1 pinout ........................................................................ 41 X2 pinout ........................................................................ 44 Configuration pins — Module ......................................................49 Module pin configuration Dipswitch S4 ..................................... 49 Connector X2 Pins Available for a Python Application ........................50 Multiplexed GPIO Pins ..............................................................51 Module LEDs ..........................................................................54 External Interrupts ............................................................ 54 Interfaces .............................................................................55 10/100 Mbps Ethernet port ................................................... 55 UART ............................................................................. 55 5 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... RTC ............................................................................... 56 WLAN ............................................................................. 56 WWAN ............................................................................ 56 FIM ................................................................................ 56 USB Host ......................................................................... 57 Antenna .......................................................................... 57 ConnectCore Wi-9P 9215 WLAN .................................................. 58 WLAN Antenna Switch ............................................................. 58 ConnectCore 3G 9P 9215 WWAN ................................................. 59 Power ................................................................................. 61 Power supply .................................................................... 61 Internal voltage ................................................................. 61 C h a p t e r 2 : A b o u t t h e D e v e l o p m e n t B o a r d . . . . . . . . . 62 What’s on the Development Board? ............................................. 62 ConnectCore 3G 9P 9215 Specifics............................................... 63 User interface ........................................................................64 Switches and Pushbuttons .........................................................65 Reset control, S3 ................................................................... 65 Power switch, S2 ................................................................... 65 User pushbuttons, S6 and S7 ...................................................... 66 Legend for multi-pin switches .................................................... 66 Module configuration switches, S4 ............................................... 66 Wake-up button, S8 ................................................................ 66 Serial Port B MEI configuration switches, S1 ................................... 67 Jumpers ...............................................................................68 Jumper functions ................................................................... 69 Battery and Battery Holder ........................................................69 LEDs ...................................................................................70 WLAN LED LE7 ....................................................................... 70 www.digiembedded.com 6 Contents Power LEDs, LE3 and LE4 ..........................................................70 User LEDs, LE5 and LE6 .............................................................71 Serial status LEDs ...................................................................71 Status LEDs Serial Port D LEDs ....................................................71 Status LEDs Serial Port B LEDs .....................................................71 Serial UART Ports .................................................................... 72 Serial port D, RS232 .................................................................73 Serial port A, TTL interface .......................................................73 Serial port A, XBee socket .........................................................74 Serial port C, TTL interface .......................................................75 Serial port B, MEI interface ........................................................76 I2C Interface ......................................................................... 77 I2C header ............................................................................77 I2C digital I/O expansion ...........................................................78 SPI Interface ......................................................................... 79 Pin allocation ........................................................................80 Current Measurement Option ..................................................... 81 How the CMO works .................................................................81 JTAG Interface ....................................................................... 82 Standard JTAG ARM connector, X13 ..............................................83 PoE module connectors - IEEE802.3af ........................................... 84 The 802.3af PoE Application Kit ..................................................85 X9 ......................................................................................85 X26 .....................................................................................85 POE_GND .............................................................................86 Power Jack, X24 .....................................................................86 7 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Ethernet Interface ..................................................................87 RJ-45 pin allocation, X19 .......................................................... 88 LEDs ................................................................................... 88 WLAN Interface ......................................................................89 WWAN Interface .....................................................................90 SIM Installation ...................................................................... 91 Peripheral (Expansion) Headers ...................................................92 Peripheral application header, X33 .............................................. 93 Module and Test Connectors ......................................................94 Module connectors ................................................................. 94 Test connectors ..................................................................... 94 X10 pinout ........................................................................... 95 X11 pinout ........................................................................... 96 X20 pinout ........................................................................... 97 X21 pinout ........................................................................... 98 Appendix A:Specifications ........................................................99 Mechanical Information ............................................................99 ConnectCore 9P 9215 .............................................................. 99 ConnectCore Wi-9P 9215 .......................................................... 99 ConnectCore 3G 9P 9215 ......................................................... 100 Network Interface ................................................................. 100 Ethernet ............................................................................. 100 WLAN Interface .................................................................... 100 WWAN Interface ................................................................... 102 Environmental Information ...................................................... 104 ConnectCore 9P 9215 ............................................................. 104 www.digiembedded.com 8 Contents ConnectCore Wi-9P 9215 & ConnectCore 3G 9P 9215 ....................... 104 Thermal Specifications ........................................................... 105 Additional design suggestions ................................................... 107 Safety Statements ................................................................. 108 Power Requirements .............................................................. 109 ConnectCore 9P 9215 ............................................................. 109 ConnectCore Wi-9P 9215......................................................... 109 ConnectCore 3G 9P 9215......................................................... 109 IEEE802.11 a/b/g WLAN .......................................................... 110 WWAN Activity ..................................................................... 110 ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 Typical Power Save Current/Power Measurements ............................................ 111 ConnectCore 9P 9215 ............................................................. 111 ConnectCore Wi-9P 9215......................................................... 111 ConnectCore 3G 9P 9215 Typical Power Save Current /Power Measurements .................................................. 112 ConnectCore 3G 9P 9215......................................................... 112 Typical Module Current/Power Measurements ............................... 113 ConnectCore 9P 9215 ............................................................. 113 ConnectCore Wi-9P 9215......................................................... 113 Layout Recommendation ......................................................... 114 ConnectCore 9P 9215 ............................................................. 114 Top, bottom and side views ..................................................... 114 Extended Footprint Option ...................................................... 115 ConnectCore Wi-9P 9215......................................................... 116 Top view ............................................................................ 116 Bottom view ........................................................................ 117 9 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Side view ............................................................................ 117 ConnectCore 3G 9P 9215 ......................................................... 118 Topview ............................................................................. 118 Bottom view ........................................................................ 119 Side view ............................................................................ 119 Reset and Edge Sensitive Input Timing Requirements ....................... 120 ConnectCore Wi-9P 9215 Antenna Specifications: 2 dBi Dipole ............ 121 Attributes ........................................................................... 121 Dimensions .......................................................................... 121 Antenna strength (radiation pattern) diagram ................................ 122 ConnectCore Wi-9P 9215 Antenna Specifications: 5.5 dBi Dipoles ........ 123 Attributes ........................................................................... 123 Dimensions .......................................................................... 123 Radiation pattern: H-Plane (2.0 and 5.0 GHz) ................................ 124 Radiation pattern: E-plane (2.0 and 5.0 GHz) ................................ 125 ConnectCore 3G 9P 9215 Cellular Antenna .................................... 126 Attributes ........................................................................... 126 Dimensions .......................................................................... 126 ConnectCore 3G 9P 9215 GPS Antenna ......................................... 127 Attributes ........................................................................... 127 Appendix B: Certifications ...................................................... 128 FCC Part 15 Class B ............................................................... 128 Radio Frequency Interface (RFI) (FCC 15.105) ................................ 128 Labeling Requirements (FCC 15.19) ............................................ 129 RF Exposure ........................................................................ 129 Modifications (FCC 15.21) ........................................................ 129 www.digiembedded.com 10 Contents Industry Canada ................................................................... 129 Indoor/Outdoor .................................................................... 130 Declaration of Conformity ....................................................... 130 Qualcomm Gobi 3000 Module Certifications .................................. 131 International EMC Standards .................................................... 132 Appendix C: Change Log ........................................................ 133 Revison B ........................................................................... 133 Revision C .......................................................................... 133 Revision D .......................................................................... 133 Revision E ........................................................................... 134 Revision F ........................................................................... 134 Revision G .......................................................................... 134 Revision H .......................................................................... 134 Revision I ........................................................................... 134 Revision J ........................................................................... 134 Revision K .......................................................................... 134 Revsion L ........................................................................... 134 Revision M .......................................................................... 135 Revision N .......................................................................... 135 Revision P .......................................................................... 135 Revision R .......................................................................... 135 11 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference About the Module C H A P T E R 1 T he ConnectCore 9P 9215 Family of modules delivers powerful network-enabled core processor solutions with up to 16 MB of NOR flash, up to 32 MB SDRAM, a rich set of integrated peripherals, and superior design flexibility. At the heart of the modules is a Digi 32-bit ARM9-based Digi NS9215 processor running at 150 MHz. Key features include 10/100 Mbit Ethernet, two on-chip Flexible Interface Modules (FIMs), 256-bit AES accelerator, power management modes with dynamic clock scaling, and a rich set of on-chip peripherals. Based on Digi 802.11 baseband technology, the ConnectCore Wi-9P 9215 also provides an additional 802.11a/b/g interface with enterprise-grade WPA2/802.11i support. The ConnectCore 3G 9P 9215 module allows you to instantly add intelligent cellular communication to your products. Built on leading Qualcomm Gobi 3000 technology, the module delivers a precertified embedded cellular connectivity solution without the traditional carrier/network limitations. Selecting cellular network technology and carriers is now a matter of software configuration and service provisioning, any time. The unique FIMs on the Digi NS9215 processor are two independent 300 MHz DRPIC165X processor cores that allow customers to dynamically select applicationspecific interfaces in software. The growing list of supported interfaces includes UART, SD/SDIO, CAN bus, USB-device low-speed, 1-Wire®, USB device low-speed, parallel bus interface, and others. Utilizing the Digi NET+™ ARM processor and secure 802.11a/b/g WLAN technology, the family of ConnectCore 9P 9215 modules offers the industry’s only networkenabled core module with true long-term product availability to meet the extended life cycle requirements of embedded product designs. www.digiembedded.com 12 Chapter 1 For further information about the Digi NS9215, see the Digi NS9215 Hardware Reference Manual. About the Software .................................................................................. The ConnectCore 9P 9215 Family of modules comes in distinct flavors of software: Embedded Development Firmware; or the Digi Plug-and-Play Firmware (ConnectCore Wi-9P 9215 only.) The Embedded Development Firmware is used for the NET+OS® or Digi Embedded Linux Development systems. These modules require a developer to load system software, compile and debug their applications using the Digi ESP™ Development Environment. In this environment, applications are developed in ANSI C and use the various libraries and services to create custom applications, with resolution down to the device driver. In the Digi Plug-and-Play Firmware, the firmware is fixed. These modules require either some minor configuration or the loading and launching of Python applications that alter the general behavior of the system. In this environment, fast turn around and minimal development should be expected, however, the level of customization is limited to the Python API and/or the configuration methods. The information within this chapter is broken down into two sections based on software type. For embedded NET+OS or Digi Embedded Linux users see page 14; for Digi Plug-and-Play Firmware users see page 41. 13 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Digi Embedded Linux and NET+OS .................................................................................. This section describes the features and functionality of modules utilizing embedded NET+OS or Digi Embedded Linux Development Environments only. If you are using a module that utilizes Digi Plug-and-Play Firmware see page 41. Once you have read through all of the embedded NET+OS / Digi Embedded Linux related sections, proceed to Chapter 2. Module pinout The module has two 80 pin connectors, X1 and X2. The following tables describe each pin, its properties, and its use on the Development Board. Pinout legend: Type I Input O Output I/O Input or output P Power X1 pinout X1 pin number Type Module Functionality Comments 1 P GND 2 P GND 3 I RSTIN# 10k pull-up on module 4 O SRESET# Output of the reset controller push pull with 470R current limiting resistor www.digiembedded.com 5 O RSTOUT# Output of logical AND function between NS9215 RESET_DONE and NS9215 RESET_OUT# 6 I TCK JTAG - 10k pull-up on module 7 I TMS JTAG - 10k pull-up on module 8 I TDI JTAG - 10k pull-up on module 9 O TDO JTAG - 10k pull-up on module 10 I TRST# JTAG - 2k2 pull-down on module 11 O RTCK JTAG - Optional 12 I OCD_EN# 10k pull-up on module 13 I LITTLE# / BIG ENDIAN 2k2 series resistor on module 14 Chapter 1 X1 pin number Type Module Functionality Comments 14 I WLAN_DISABLE# Normally connected to X2-15 15 I SW_CONF0 2k2 series resistor on module 16 I SW_CONF1 2k2 series resistor on module 17 I SW_CONF2 2k2 series resistor on module 18 I SW_CONF3 2k2 series resistor on module 19 O LED_WWAN# Reserved 20 P GND 21 I/O BD0 Buffered Data - only active when either CS0# or CS2# is active NS9215 D[31:16] 15 22 I/O BD1 23 I/O BD2 24 I/O BD3 25 I/O BD4 26 I/O BD5 27 I/O BD6 28 I/O BD7 29 I/O BD8 30 I/O BD9 31 I/O BD10 32 I/O BD11 33 I/O BD12 34 I/O BD13 35 I/O BD14 36 I/O BD15 37 P GND 38 O BAO 39 O BA1 40 O BA2 41 O BA3 42 O BA4 43 O BA5 44 O BA6 45 O BA7 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Buffered Address always active ..... www.digiembedded.com X1 pin number Type Module Functionality Comments 46 O BA8 47 O BA9 48 O BA10 49 O BA11 50 O BA12 51 O BA13 52 O BA14 53 O BA15 54 O BA16 55 O GND 56 O EXT_OE# 57 O EXT_WE# 58 O EXT_CSO# 59 O EXT_CS2# 60 O BE2# NS9215 BE2# 61 O BE3# NS9215 BE3# 62 I EXT_WAIT# 10k pull-up on module 63 O EXT_CLK# Connected over a 22R resistor to NS9215 CLK_OUT1 pin 64 P GND 65 I ETH_TPIN 66 O ETH_ACTIVITY# 67 I ETH_TPIP 68 O ETH_LINK# 69 O ETH_TPON 70 O ETH_TPOP 71 P GND 72 P USB_VBUS Power / See Note 1 73 I USB_OC# See Note 1 74 I/O USB_P See Note 1 75 I/O USB_N See Note 1 76 O USB_PWR# See Note 1 77 I Reserved Low active signal with 330R resistor on module Low active signal with 330R resistor on module 16 Chapter 1 X1 pin number Type Module Functionality 78 P VRTC Comments Backup Battery for RTC, for 3V cell. Can be left floating, if RTC backup not needed. 79 P VLIO Mobile: Power from Li-Ion Battery (2.5V-5.5V) Non-Mobile: connected to 3.3V 80 P GND Note 1: ConnectCore 3G 9P 9215 USB circuit only. X2 pinout The following table shows the GPIO multiplexing capabilities for the Embedded Development Firmware module. X2 pin number Type Module Functionality I/O Multiplexing 1 P GND 2 P GND 3 I/O DCDA# DCDA# SPI_EN# DMA0_DONE GPIO0 PIC_0_GEN_IO[0] XBEE_ON_SLEEP# GPIO0 Comments SPI_EN 4 I/O CTSA# CTSA# GPIO1 EIRQ0 EIRQ0 - Reserved on wireless variant PIC_0_GEN_IO[1] GPIO1 5 I/O DSRA# DSRA# GPIO2 EIRQ1 XBEE_RESET# PIC_0_GEN_IO[2] GPIO2 6 I/O RXDA RXDA SPI_RXD DMA0_PDEN GPIO3 PIC_0_GEN_IO[3] GPIO3 SPI_RX 7 I/O RIA# RIA# ERIQ2 EIRQ2 GPIO4 Timer6_in GPIO4 SPI_CLK 17 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Note: This pin is used to force execution of a backup image for NET+OS, and should not be pulled down at start-up if used with NET+OS. ..... X2 pin number Type Module Functionality I/O Multiplexing 8 I/O RTSA# RTSA# SPI_CLK RS485CTLA GPIO5 EIRQ3 Comments Timer6_Out GPIO5 SPI_CLK 9 I/O DTRA# DTRA# GPIO6 TXCLKA SLEEP_RQ DMA0_REQ Timer7_In GPIO6 PIC_DBG_DATA_OUT 10 I/O TXDA TXDA SPI_TXD Timer8_In GPIO7 Timer7_Out GPIO7 SPI_TX 11 I/O DCDC# DCDC# TXCLKC DMA1_DONE GPIO8 Timer8_Out GPIO8 SPIB_EN 12 I/O CTSC# CTSC# GPIO9 I2C_SCK EIRQ0 - Reserved on wireless variant EIRQ0 GPIO9 PIC_DBG_DATA_IN 13 I/O DSRC# DSRC# GPIO10 QDCI EIRQ1 GPIO10 PIC_DBG_CLK 14 I/O RXDC RXDC GPIO11 DMA1_DP EIRQ2 GPIO11 SPI_RXboot www.digiembedded.com 18 Chapter 1 X2 pin number Type Module Functionality I/O Multiplexing Comments 15 I/O RIC# RIC# RXCLKC RXCLKC GPIO12 I2C_SDA When booting, NS9215 RIC# signal is default configured as Output, RST_DONE. To avoid input/output conflicts, put a series resistor on this signal if necessary. RST_DONE GPIO12 SPI_CLK 16 I/O RTSC# RTSC# RXCLKC QDCQ GPIO13 Ext Timer Event Out Ch 9 GPIO13 SPI_CLKboot 17 I/O DTRC# DTRC# TXCLKC TXCLKC GPIO14 DMA1_REQ PIC_0_CAN_RXD GPIO14 SPI_TXDboot 18 I/O TXDC TXDC GPIO15 Timer9_In PIC_0_CAN_TXD GPIO15 SPI_ENboot 19 I/O DCDB# DCDB# GPIO51 PIC_0_BUS_1[8] PIC_1_BUS_1[8] GPIO51 20 I/O CTSB# CTSB# GPIO52 PIC_0_BUS_1[9] PIC_1_BUS_1[9] GPIO52 21 I/O DSRB# DSRB# GPIO53 PIC_0_BUS_1[10] PIC_1_BUS_1[10] GPIO53 22 I/O RXDB RXDB GPIO54 PIC_0_BUS_1[11] PIC_1_BUS_1[11] GPIO54 19 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... X2 pin number Type Module Functionality I/O Multiplexing 23 I/O RIB# RIB# GPIO55 PIC_0_BUS_1[12] Comments PIC_1_BUS_1[12] GPIO55 24 I/O RTSB# RTSB# GPIO56 RS485CTLB PIC_0_BUS_1[13] PIC_1_BUS_1[13] GPIO56 25 I/O DTRB# TXCLKB GPIO57 DTRB# PIC_0_BUS_1[14] PIC_1_BUS_1[14] GPIO57 26 I/O TXDB TXDB GPIO58 PIC_0_BUS_1[15] PIC_1_BUS_1[15] GPIO58 27 I/O DCDD# DCDD# GPIO59 PIC_0_BUS_1[16] PIC_1_BUS_1[16] GPIO59 28 I/O CTSD# CTSD# GPIO60 PIC_0_BUS_1[17] PIC_1_BUS_1[17] GPIO60 29 I/O DSRD# DSRD# GPIO61 PIC_0_BUS_1[18] PIC_1_BUS_1[18] GPIO61 30 I/O RXDDD RXDD GPIO62 PIC_0_BUS_1[19] PIC_1_BUS_1[19] GPIO62 31 I/O RID# RID# GPIO63 PIC_0_BUS_1[20] PIC_1_BUS_1[20] GPIO63 www.digiembedded.com 20 Chapter 1 X2 pin number Type Module Functionality I/O Multiplexing 32 I/O RTSD# RTSD# GPIO64 RS485CTLD PIC_0_BUS_1[21] PIC_1_BUS_1[21] GPIO64 33 I/O DTRD# TXCLKD GPIO65 DTRD# PIC_0_BUS_1[22] PIC_1_BUS_1[22] GPIO65 34 I/O TXDD TXDD GPIO66 PIC_0_BUS_1[23] PIC_1_BUS_1[23] GPIO66 35 I/O GPIO67 PIC_0_CLK[I] PIC_0_CLK[0] EIRQ3 GPIO67 36 I/O GPIO68 PIC_0_GEN_IO[0] PIC_1_GEN_IO[0] PIC_1_CAN_RXD GPIO68 37 I/O GPIO69 PIC_0_GEN_IO[1] PIC_1_GEN_IO[1] PIC_1_CAN_TXD GPIO69 38 I/O GPIO70 PIC_0_GEN_IO[2] PIC_1_GEN_IO[2] PWM0 GPIO70 39 I/O GPIO71 PIC_0_GEN_IO[3] PIC_1_GEN_IO[3] PWM1 GPIO71 40 I/O GPIO72 PIC_0_GEN_IO[4] PIC_1_GEN_IO[4] PWM2 GPIO72 21 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Comments ..... X2 pin number Type Module Functionality I/O Multiplexing 41 I/O GPIO73 PIC_0_GEN_IO[5] Comments PIC_1_GEN_IO[5] PWM3 GPIO73 42 I/O GPIO74 PIC_0_GEN_IO[6] PIC_1_GEN_IO[6] Timer0_In GPIO74 43 I/O GPIO75 PIC_0_GEN_IO[7] PIC_1_GEN_IO[7] Timer1_In GPIO75 44 I/O GPIO76 PIC_0_CTL_IO[0] PIC_1_CTL_IO[0] Timer2_In GPIO76 45 I/O GPIO77 PIC_0_CTL_IO[1] PIC_1_CTL_IO[1] Timer3_In GPIO77 46 I/O GPIO78 PIC_0_CTL_IO[2] PIC_1_CTL_IO[2] Timer4_In GPIO78 47 I/O GPIO79 PIC_0_CTL_IO[3] PIC_1_CTL_IO[3] Timer5_In GPIO79 48 I/O GPIO80 PIC_0_BUS_0[0] PIC_1_BUS_0[0] Timer6_In GPIO80 49 I/O USER_BUTTON1# PIC_0_BUS_0[1] GPIO81 PIC_1_BUS_0[1] Timer7_In GPIO81 50 I/O USER_LED1# PIC_0_BUS_0[2] GPIO82 PIC_1_BUS_0[2] Timer8_In GPIO82 www.digiembedded.com 22 Chapter 1 X2 pin number Type Module Functionality I/O Multiplexing 51 I/O GPIO83 PIC_0_BUS_0[3] PIC_1_BUS_0[3] Timer9_In GPIO83 52 I/O USER_BUTTON2# PIC_0_BUS_0[4] GPIO84 PIC_1_BUS_0[4] Timer0_Out GPIO84 53 I/O USER_LED2# PIC_0_BUS_0[5] GPIO85 PIC_1_BUS_0[5] Timer1_Out GPIO85 54 I/O GPIO86 PIC_0_BUS_0[6] PIC_1_BUS_0[6] Timer2_Out GPIO86 55 I/O GPIO87 PIC_0_BUS_0[7] PIC_1_BUS_0[7] Timer3_Out GPIO87 56 I/O GPIO93 PIC_0_BUS_0[13] PIC_1_BUS_0[13] Timer9_Out GPIO93 57 I/O GPIO94 PIC_0_BUS_0[14] PIC_1_BUS_0[14] QDCI GPIO94 58 I/O GPIO95 PIC_0_BUS_0[15] PIC_1_BUS_0[15] QDCQ GPIO95 59 I/O CAN0_RXD PIC_0_BUS_1[0] GPIO96 PIC_1_BUS_1[0] PIC_0_CAN_RXD GPIO96 60 I/O CAN0_TXD PIC_0_BUS_1[1] GPIO97 PIC_1_BUS_1[1] PIC_0_CAN_TXD GPIO97 23 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Comments ..... X2 pin number Type Module Functionality I/O Multiplexing 61 I/O CAN1_RXD PIC_0_BUS_1[2] GPIO98 PIC_1_BUS_1[2] Comments PIC_1_CAN_RXD GPIO98 62 I/O CAN1_TXD PIC_0_BUS_1[3] GPIO99 PIC_1_BUS_1[3] PIC_1_CAN_TXD GPIO99 63 I/O GPIO100 PIC_0_BUS_1[4] PIC_1_BUS_1[4] PWM4 GPIO100 64 I/O EIRQ3# PIC_0_BUS_1[5] GPIO101 PIC_1_BUS_1[5] EIRQ3 GPIO101 65 I/O I2C_SCL PIC_0_BUS_1[6] GPIO102 PIC_1_BUS_1[6] 4k7 pull-up on module I2C_SCL GPIO102 66 I/O I2C_SDA PIC_0_BUS_1[7] GPIO103 PIC_1_BUS_1[7] 4k7 pull-up on module I2C_SDA GPIO103 www.digiembedded.com 67 I ADC_IN0 VIN0_ADC 68 I ADC_IN1 VIN1_ADC 69 I ADC_IN2 VIN2_ADC 70 I ADC_IN3 VIN3_ADC 71 I ADC_IN4 VIN4_ADC 72 I ADC_IN5 VIN5_ADC 73 I ADC_IN6 VIN6_ADC 74 I ADC_IN7 VIN7_ADC 75 P VSS_ADC Connected on module to AGND through 0Ù resistor 76 P VREF_ADC 100nF decoupling capacitor between VREF_ADC and VSS_ADC 77 P VDD +3.3V 24 Chapter 1 Configuration pins — CPU X2 pin number Type Module Functionality 78 P VDD +3.3V 79 P GND 80 P GND I/O Multiplexing Comments None of the 64 GPIO pins on connector X2 disturb CPU boot strap functions. The boot strap functions are controlled by address signals. A user can not disturb boot strap functions from the outside if the module configuration signals, described below, are correctly configured. Default module CPU configuration The user has access to six configuration signals: Configuration pins — Module  LITTLE#/BIG_ ENDIAN which allows the user to select the endianess of the module  OCD_EN# which allows the user to activate on-chip debugging  SW_CONF [3:0] which are reserved for the user; the user software can read out these signals through the GEN ID register (@ 0xA090_0210). The ConnectCore 9P 9215 Family of modules support the following JTAG signals: TCK, TMS, TDI, TDO, TRST#, and RTCK. Selection can be made between ARM debug mode and boundary scan mode with the signal OCD_EN#. Identification of the module In order to make it easier for software to recognize a module and especially a hardware variant of the module, a specific bit field made of 4 bits has been reserved on the module. This bit field can be read out through GEN ID register and corresponds to A[12:9]. These configuration signals use the internal CPU pull-up resistor and can be pulled down through external population option 2k2 resistors. In the same way, 3 bits are available on the module to identify the SDRAM configuration scheme. These bits correspond to A[19:17]. It is impossible for the user to disturb either the variant specific or SDRAM configuration specific bits from outside. In addition, the ConnectCore 9P 9215 Family of modules have reserved 4 bits for special platform identification. This bit field can be read out through GEN ID register and corresponds to A[16:13]. Configuration of these signals is done through the SW_CONF pins. SW_CONF0 is connected to A13 through a 2k2 series resistor, and so on for the further SW_CONF pins. Therefore, this bit can be set high by leaving the 25 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... corresponding SW_CONF pin unconnected and set low by connecting the corresponding SW_CONF pin directly low. These pins are available for user defined application or platform specific software configurations. Module pin configuration Signal name Function PU/PD Comment LITTLE#/BIG_ Set module endianess. 0 module boots in ENDIAN little endian mode. 1 module boots in big endian mode. PU Signal LITTLE#/BIG_ENDIAN is connected to GPIO_A3/A27 through a 2k2 series resistor. OCD_EN# PU 10K JTAG / Boundary scan function select 0 1 SW_CONF0 ARM debug mode, BISTEN# set to high Boundary scan mode, BISTEN# set to low This pin is a user/application defined software configuration pin. Connected to A13 through a 2k2 series resistor. Read bit 4 of GEN ID register (@ 0xA0900210). www.digiembedded.com SW_CONF1 This pin is a user/application defined software configuration pin. Connected to A14 through a 2k2 series resistor. Read bit 5 of GEN ID register (@ 0xA0900210). SW_CONF2 This pin is a user/application defined software configuration pin. Connected to A15 through a 2k2 series resistor. Read bit 6 of GEN ID register (@ 0xA0900210). SW_CONF3 This pin is a user/application defined software configuration pin. Connected to A16 through a 2k2 series resistor. Read bit 7 of GEN ID register (@ 0xA0900210). 26 Chapter 1 Clock generation Clock frequencies Hardware strapping determines the initial powerup PLL settings. The table below summarizes the default clock frequencies for the ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 modules: Hardware strapping: "PLL reference clock divider setting: A[4:0] = 0x1D (0b11101) NR = 5 "PLL output divider setting: A[6:5] = 0x3 (0b11) OD = 0 "PLL bypass setting: A[7] = 0x1 (0b1) Normal operation PLL frequency formula: PLL Vco = (RefClk / NR+1) * (NF+1) ClkOut = PLL Vco / (OD+1) RefClk (Crystal) = 29.4912MHz NF = 0x3C (reset value - can only be changed by software). PLL Vco = (29.4912 / 6) * 61 = 299.8272 MHz ClkOut = 299.8272 MHz Resulting clock settings: PIC clock = 299.8272 MHz CPU clock = 299.8272 MHz / 2 = 149.9136 MHz AHB clock = 149.9136 MHz / 2 = 74.9568 MHz 27 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Changing the CPU speed After power-up, software can change the PLL settings by writing to the PLL configuration register (@ 0xA090_0188). Important: When PLL parameters are changed, a reset is provided for the PLL to stabilize. Applications using this feature need to be aware that the SDRAM contents will be lost. See reset behavior in the table below. Reset Behavior Boot process www.digiembedded.com RESET _n pin SRESET _n pin PLL Config Reg. Update Watchdog Time-Out Reset SPI boot YES YES YES YES Strapping PLL YES NO NO NO Other strappings (Endianess) YES NO NO NO GPIO configuration YES NO NO NO Other (ASIC) registers YES YES YES YES SDRAM keeps its contents NO YES NO YES The ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 modules boot directly from NOR flash. The start-up code is located at address 0x00000000 during the boot process. When the system is booted, the SDRAM is remapped to address 0x00000000 and NOR Flash to 0x50000000 by modifying the address map in the AHB decoder. 28 Chapter 1 The module has eight chip selects: four for dynamic memory and four for static memory. Each chip select has a 256MB range. Chip selects Chip select memory map Name CPU Sig. name Pin Address range Size [Mb] Usage Comments SDM_CS0# CS1# D6 0x00000000– 0x0FFFFFFF 256 SDRAM bank 0 First bank on module SDM_CS1# CS3# B5 0x10000000– 0x1FFFFFFF 256 not used SDM_CS2# CS5# A4 0x20000000– 0x2FFFFFFF 256 not used SDM_CS3# CS7# B4 0x30000000– 0x3FFFFFFF 256 not used EXT_CS0# CS0# C6 0x40000000– 0x4FFFFFFF 256 external, CS0# INT_CS1# CS2# B6 0x50000000– 0x5FFFFFFFF 256 NOR-Flash EXT_CS2# CS4# C5 0x60000000– 0x6FFFFFFFF 256 external, CS2# INT_CS3# CS6# A3 0x70000000– 0x7FFFFFFF 256 internal, CS3# SDRAM banks 29 Program memory on module Reserved for internal usage The modules provide connection to 1 SDRAM chip, connected to CS1# (SDM_CS0#). The other SDRAM chip selects are not used. The standard module has one of these SDRAM onboard: 1Mx16x4-banks. A13 is the highest address connected. BA0 and BA1 are connected to A21 and A22, respectively. ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Multiplexed GPIO pins The 108 GPIO pins (including address bits A24 through A27) available on the module connector are multiplexed with other functions, such as:  UART  SPI  Ethernet  DMA  I2C port  Timers and interrupt inputs  Memory bus data  GPIO [15:0] has five multiplex modes.  GPIO [103:16] and GPIO_A [3:0] have four multiplex modes.  Using a pin as GPIO may result in the loss of some functionalities. Certain functions are duplicated to enhance the likelihood of the pin being used without sacrificing other vital functions.  Using original and (dup) functions in parallel is not recommended.  Default function of GPIOs after CPU power-up is function 03, except GPIO12 (function 02-reset_done) and GPIO [31:16] (function 00 - DATA[15:0]). Pin notes GPIO multiplex table In the GPIO multiplex table below,  the default function is written in bold,  # means low active signal,  (dup) means the function is available multiple times. Port name, Function 03 Alternate function 00 Alternate function 01 Alternate function 02 Alternate function 04 (only GPIO00 ...GPIO15) On module, default used as GPIO0 DCDA# DMA0_DONE PIC_0_GEN_IO[0] SPI_EN# (dup) DCDA# / SPI_EN# GPIO1 CTSA# EIRQ0 PIC_0_GEN_IO[1] EIRQ0 - Reserved on wireless variant CTSA# GPIO2 DSRA# EIRQ1 PIC_0_GEN_IO[2] Reserved DSRA# GPIO3 RXDA# DMA0_PDEN PIC_0_GEN_IO[3] SPI_RXD (dup) RXDA / SPI_RXD GPIO4 RIA# EIRQ2 Timer6_In SPI_CLK (dup) RIA# / SPI_CLK GPIO5 RTSA# / 485CTLA EIRQ3 Timer6_Out SPI_CLK (dup) RTSA# www.digiembedded.com 30 Chapter 1 Port name, Function 03 Alternate function 00 Alternate function 01 Alternate function 02 Alternate function 04 (only GPIO00 ...GPIO15) On module, default used as GPIO6 TXCLKA / DTRA# DMA0_REQ Timer7_In PIC_DBG_DATA_OUT DTRA# GPIO7 TXDA Timer8_In Timer7_Out SPI_TXD (dup) TXDA / SPI_TXD GPIO8 DCDC# / TXCLKC DMA1_DONE Timer8_Out SPI_EN# (dup) DCDC# GPIO9 CTSC# I2C_SCL EIRQ0 (dup) PIC_DBG_DATA_IN CTSC# Reserved on wireless variant GPIO10 DSRC# QDCI EIRQ1 (dup) PIC_DBG_CLK DSRC# GPIO11 RXDC# DMA1_PDEN EIRQ2 (dup) SPI_RXD (boot) RXDC GPIO12 RXCLKC / RIC# I2C_SDA RESET_DONE SPI_CLK (dup) RIC# 1 GPIO13 RXCLKC / RTSC# /485CTLC QDCQ Timer9_out SPI_CLK (boot) RXCLKC / RTSC# GPIO14 TXCLKC / DTRC# DMA1_REQ PIC_0_CAN_RXD SPI_TXD (boot) TXCLKC GPIO15 TXDC Timer9_In PIC_0_CAN_TXD SPI_EN# (boot) TXDC GPIO16 D0 DCDB# EIRQ0 (dup) Reserved on wireless variant Reserved for upper data lines GPIO17 D1 CTSB# EIRQ1 (dup) Reserved for upper data lines GPIO18 D2 DSRB# EIRQ2 (dup) Reserved for upper data lines GPIO19 D3 RXDB EIRQ3 (dup) Reserved for upper data lines GPIO20 D4 RIB# DMA0_DONE (dup) Reserved for upper data lines GPIO21 D5 RTSB# / 485CTLB DMA0_PDEN (dup) Reserved for upper data lines GPIO22 D6 TXCLKB / DTRB# DMA1_DONE (dup) Reserved for upper data lines GPIO23 D7 TXDB PIC_1_CAN_RXD Reserved for upper data lines GPIO24 D8 DCDD# PIC_1_CAN_TXD Reserved for upper data lines GPIO25 D9 CTSD# RESET_DONE (dup) Reserved for upper data lines GPIO26 D10 DSRD# PIC_1_GEN_IO[0] Reserved for upper data lines 31 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Port name, Function 03 Alternate function 00 Alternate function 01 Alternate function 02 GPIO27 D11 RXDD PIC_1_GEN_IO[1] Reserved for upper data lines GPIO28 D12 RID# PIC_1_GEN_IO[2] Reserved for upper data lines GPIO29 D13 RTSD# / 485CTLD PIC_1_GEN_IO[3] Reserved for upper data lines GPIO30 D14 TXCLKD / DTRD# Reserved Reserved for upper data lines GPIO31 D15 TXDD Reserved Reserved for upper data lines GPIO32 MII_MDC PIC_0_GEN_IO[0] Reserved MII Interface GPIO33 MII_TXC PIC_0_GEN_IO[1] Reserved MII Interface GPIO34 MII_RXC PIC_0_GEN_IO[2] Reserved MII Interface GPIO35 MII_MDIO PIC_0_GEN_IO[3] Reserved MII Interface GPIO36 MII_RXDV PIC_0_GEN_IO[4] Reserved MII Interface GPIO37 MII_RXER PIC_0_GEN_IO[5] Reserved MII Interface GPIO38 MII_RXD0 PIC_0_GEN_IO[6] Reserved MII Interface GPIO39 MII_RXD1 PIC_0_GEN_IO[7] Reserved MII Interface GPIO40 MII_RXD2 PIC_1_GEN_IO[0] Reserved MII Interface GPIO41 MII_RXD3 PIC_1_GEN_IO[1] Reserved MII Interface GPIO42 MII_TXEN PIC_1_GEN_IO[2] Reserved MII Interface GPIO43 MII_TXER PIC_1_GEN_IO[3] Reserved MII Interface GPIO44 MII_TXD0 PIC_1_GEN_IO[4] Reserved MII Interface GPIO45 MII_TXD1 PIC_1_GEN_IO[5] Reserved MII Interface GPIO46 MII_TXD2 PIC_1_GEN_IO[6] Reserved MII Interface GPIO47 MII_TXD3 PIC_1_GEN_IO[7] Reserved MII Interface GPIO48 MII_COL Reserved Reserved MII Interface GPIO49 MII_CRS Reserved Reserved MII Interface GPIO50 MII_PHY_Int PIC_1_CLK (I) PIC_1_CLK(0) MII Interface GPIO51 DCDB# (dup) PIC_0_BUS_1[8] PIC_1_BUS_1[8] DCDB# GPIO52 CTSB# (dup) PIC_0_BUS_1[9] PIC_1_BUS_1[9] CTSB# GPIO53 DSRB# (dup) PIC_0_BUS_1[10] PIC_1_BUS_1[10] DSRB# GPIO54 RXDB (dup) PIC_0_BUS_1[11] PIC_1_BUS_1[11] RXDB www.digiembedded.com Alternate function 04 (only GPIO00 ...GPIO15) On module, default used as 32 Chapter 1 Port name, Function 03 Alternate function 00 Alternate function 01 Alternate function 02 Alternate function 04 (only GPIO00 ...GPIO15) On module, default used as GPIO55 RIB# (dup) PIC_0_BUS_1[12] PIC_1_BUS_1[12] RIB# GPIO56 RTSB# / 485CTLB (dup) PIC_0_BUS_1[13] PIC_1_BUS_1[13] RTSB# GPIO57 TXCLKB (dup) / DTRB# (dup) PIC_0_BUS_1[14] PIC_1_BUS_1[14] DTRB# GPIO58 TXDB (dup) PIC_0_BUS_1[15] PIC_1_BUS_1[15] TXDB GPIO59 DCDD# (dup) PIC_0_BUS_1[16] PIC_1_BUS_1[16] DCDD# GPIO60 CTSD# (dup) PIC_0_BUS_1[17] PIC_1_BUS_1[17] CTSD# GPIO61 DSRD# (dup) PIC_0_BUS_1[18] PIC_1_BUS_1[18] DSRD# GPIO62 RXDD (dup) PIC_0_BUS_1[19] PIC_1_BUS_1[19] RXDD GPIO63 RID# (dup) PIC_0_BUS_1[20] PIC_1_BUS_1[20] RID# GPIO64 RTSD# / 485CTLD (dup) PIC_0_BUS_1[21] PIC_1_BUS_1[21] RTSD# GPIO65 TXCLKD (dup) / PIC_0_BUS_1[22] PIC_1_BUS_1[22] DTRD# DTRD# (dup) GPIO66 TXDD (dup) PIC_0_BUS_1[23] PIC_1_BUS_1[23] TXDD GPIO67 PIC_0_CLK (I) PIC_0_CLK (O) EIRQ3 (dup) PIC_0_CLK GPIO68 PIC_0_GEN_IO[0] PIC_1_GEN_IO[0] PIC_1_CAN_RXD PIC_0_GEN_IO[0] GPIO69 PIC_0_GEN_IO[1] PIC_1_GEN_IO[1] PIC_1_CAN_TXD PIC_0_GEN_IO[1] GPIO70 PIC_0_GEN_IO[2] PIC_1_GEN_IO[2] PWM0 PIC_0_GEN_IO[2] GPIO71 PIC_0_GEN_IO[3] PIC_1_GEN_IO[3] PWM1 PIC_0_GEN_IO[3] GPIO72 PIC_0_GEN_IO[4] PIC_1_GEN_IO[4] PWM2 PIC_0_GEN_IO[4] GPIO73 PIC_0_GEN_IO[5] PIC_1_GEN_IO[5] PWM3 PIC_0_GEN_IO[5] GPIO74 PIC_0_GEN_IO[6] PIC_1_GEN_IO[6] Timer0_In PIC_0_GEN_IO[6] GPIO75 PIC_0_GEN_IO[7] PIC_1_GEN_IO[7] Timer1_In PIC_0_GEN_IO[7] GPIO76 PIC_0_CTL_IO[0] PIC_1_CTL_IO[0] Timer2_In PIC_0_CTL_IO[0] GPIO77 PIC_0_CTL_IO[1] PIC_1_CTL_IO[1] Timer3_In PIC_0_CTL_IO[1] GPIO78 PIC_0_CTL_IO[2] PIC_1_CTL_IO[2] Timer4_In PIC_0_CTL_IO[2] GPIO79 PIC_0_CTL_IO[3] PIC_1_CTL_IO[3] Timer5_In PIC_0_CTL_IO[3] GPIO80 PIC_0_BUS_0[0] PIC_1_BUS_0[0] Timer6_In (dup) Timer6_In GPIO81 PIC_0_BUS_0[1] PIC_1_BUS_0[1] Timer7_In (dup) Timer7_In GPIO82 PIC_0_BUS_0[2] PIC_1_BUS_0[2] Timer8_In (dup) Timer8_In GPIO83 PIC_0_BUS_0[3] PIC_1_BUS_0[3] Timer9_In (dup) Timer9_In 33 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Port name, Function 03 Alternate function 00 Alternate function 01 Alternate function 02 Alternate function 04 (only GPIO00 ...GPIO15) On module, default used as GPIO84 PIC_0_BUS_0[4] PIC_1_BUS_0[4] Timer0_Out Timer0_Out GPIO85 PIC_0_BUS_0[5] PIC_1_BUS_0[5] Timer1_Out Timer1_Out GPIO86 PIC_0_BUS_0[6] PIC_1_BUS_0[6] Timer2_Out Timer2_Out GPIO87 PIC_0_BUS_0[7] PIC_1_BUS_0[7] Timer3_Out Timer3_Out GPIO88 PIC_0_BUS_0[8] PIC_1_BUS_0[8] Timer4_Out User LED 0 => LED 1 (on module) GPIO89 PIC_0_BUS_0[9] PIC_1_BUS_0[9] Timer5_Out User LED 1 => LED 2 (on module) GPIO90 PIC_0_BUS_0[10] PIC_1_BUS_0[10] Timer6_Out (dup) GPIO reserved on module GPIO91 PIC_0_BUS_0[11] PIC_1_BUS_0[11] Timer7_Out (dup) Reserved NAND_R/B# GPIO92 PIC_0_BUS_0[12] PIC_1_BUS_0[12] Timer8_Out (dup) GPIO reserved on module GPIO93 PIC_0_BUS_0[13] PIC_1_BUS_0[13] Timer9_Out (dup) Timer9_Out GPIO94 PIC_0_BUS_0[14] PIC_1_BUS_0[14] QDCI (dup) QDCI GPIO95 PIC_0_BUS_0[15] PIC_1_BUS_0[15] QDCQ (dup) QDCQ GPIO96 PIC_0_BUS_1[0] PIC_1_BUS_1[0] PIC_0_CAN_RXD PIC_0_CAN_RXD GPIO97 PIC_0_BUS_1[1] PIC_1_BUS_1[1] PIC_0_CAN_TXD PIC_0_CAN_TXD GPIO98 PIC_0_BUS_1[2] PIC_1_BUS_1[2] PIC_1_CAN_RXD PIC_1_CAN_RXD GPIO99 PIC_0_BUS_1[3] PIC_1_BUS_1[3] PIC_1_CAN_TXD PIC_1_CAN_TXD GPIO100 PIC_0_BUS_1[4] PIC_1_BUS_1[4] PWM4 PWM4 GPIO101 PIC_0_BUS_1[5] PIC_1_BUS_1[5] EIRQ3 (dup) EIRQ3 GPIO102 PIC_0_BUS_1[6] PIC_1_BUS_1[6] I2C_SCL (dup) I2C_SCL GPIO103 PIC_0_BUS_1[7] PIC_1_BUS_1[7] I2C_SDA (dup) I2C_SDA GPIO_A0 A24 I2C_SCL dupe EIRQ0 (dup) EIRQ0 - Reserved on wireless variant GPIO_A1 A25 I2C_SDA dupe EIRQ1 (dup) Reserved EIRQ1 - USB GPIO_A2 A26 CS0_WE# EIRQ2 (dup) GPIO reserved on module GPIO_A3 A27 CS0_OE# UART_REFCLK Little/Big Endian 1 Put a series resistor on the Development Board in this case to avoid input/output conflict between RESET_DONE (output/boot default) and RIC# (input/configuration default). www.digiembedded.com 34 Chapter 1 Module LEDs The ConnectCore 9P 9215 Family of modules have two on module LEDs: LE1 and LE2. For each module variant, the default use varies:  ConnectCore 9P 9215: LE1 will flash a repeating blink pattern in a major system failure; for example, a processor execption or power-on self test failure.  ConnectCore Wi-9P 9215: To indicate WLAN-related information, such as association status and network activity. ConnectCore 9P 9215 LEDs ID Connects to Default Description LE1 GPIO88 Off Setting to output logic “0” turns on the LED. LE2 GPIO89 Off Setting to output logic “0” turns on the LED. ConnectCore Wi-9P 9215 LEDs ID Color LED Blink pattern Status / Activity LE1 Green Link integrity On The unit is associated to an access point (infrastructure mode) Slow The unit is in ad-hoc mode Quick The unit is scanning for a network Blinking Network traffic is received or transmitted Off Network is idle LE2 Note: 35 Yellow Network activity The network activity LED is used for diagnostic purposes during boot-up. ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... External interrupts The ConnectCore 9P 9215 Family of modules provide access to four external interrupts signals, which are multiplexed with other functions on the GPIO pins. External interrupt EIRQ0 GPIO multiplexing Other functions, 1st position Comments GPIO1 X2.4 GPIO9 X2.12 EIRQ0 is used in ConnectCore Wi-9P 9215 as radio chip interrupt and is not available for use. GPIO16 GPIO_A0 EIRQ1 GPIO2 X2.5 GPIO10 X2.13 GPIO17 GPIO_A1 EIRQ2 GPIO4 X2.7 GPIO11 X2.14 GPIO18 GPIO_A2 EIRQ3 GPIO5 X2.8 GPIO67 X2.35 GPIO101 X2.64 EIRQ3# is used on the Development Board to implement I²C I/O expander interrupt functionality. GPIO19 www.digiembedded.com 36 Chapter 1 Interfaces 10/100 Mbps Ethernet port The Digi NS9215 processor’s 10/100 Mbps Ethernet MAC allows a glueless connection of a 3.3V MII PHY chip that generates the physical Ethernet signals. The module has a MII PHY chip in a 56-pin QFN package on board. By default, the module does not have a transformer or Ethernet connector; the Development Board must provide these parts. However, it's possible to populate a specific RJ45 connector with magnetics on the module. The appropriate RJ-45 is Midcom MIC2412A-5108WLF3. A PHY clock of 25 MHz is generated in the PHY chip with a 25 MHz crystal. GPIO90 is controlling the PHY RESET# signal. This GPIO has a 2k2 pull-down resistor to GND populated on the module. GPIO90 must be asserted high before PHY can be used. When not used, the PHY can be put in low-power mode by asserting GPIO90 low. The PHY address on the MII bus is 0x7 (0b00111). In addition to providing access to the Ethernet signals coming out of the PHY, the module also supports two status LEDs: ETH_ACTIVITY# and ETH_LINK#. UART The ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 modules provide up to four UART ports, used in asynchronous mode:  Port A = GPIOO through GPIO7  Port B = GPIO51 through GPIO58  Port C = GPIO8 through GPIO15  Port D = GPIO59 through GPIO66 The module supports baud rates up to 1.8432 Mbps in asynchronous mode. Each UART has a 64-byte TX and RX FIFO available. SPI The following interfaces are only available on the ConnectCore 9P 9215 and ConnectCore Wi-9P 9215. The module provides one SPI port which can be used in either master or slave mode.  Master: 33.33 Mbps  Slave: 7.50 Mbps The SPI module is made of four signals: RXD, TXD, CLK and CS#. 37 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... I 2C bus The I2C bus is completely free on the module - no EEPROM and no RTC - since the RTC is in the processor. The I2C clock is max 400kHz. I2C signals are provided on the module with 4k7 pull-up resistors. RTC The RTC is integrated in the processor and has its own 32.768 KHz clock crystal.  When powered by VBAT, an RTC unit will function until VBAT (X1.78) reaches a threshold of 2.3 - 2.4V - then the internal unit switches off.  The battery current without +3.3V power applied is up to 40µA. The current is used to power the RTC, 32.768kHz oscillator and 64-byte internal RAM.  When the Development Board ships from the factory the battery is disabled. To enable the battery, place a jumper on the Development Board at J2. WLAN In addition to the wired Ethernet interface, the ConnectCore Wi-9P 9215 module also offers an integrated dual-diversity 802.11a/b/g interface with data rates up to 54 Mbps. Two U.FL antenna connectors are provided on the module. ADC The ADC on the module provides 12-bit resolution / 1 MHz conversion capabilities, single-ended 8:1 multiplexed inputs, rail-to-rail input range, 12-bit output (DMA/direct), and external reference. FIM The Flexible Interface Modules (FIM) are based on two independent 8-bit DRPIC1655X cores running at 300 MHz maximum core clock (4x NS9215 bus speed) with 192-byte data and 2 KB program SRAM. The FIMs allow the flexible software-based selection of Digi-provided application specific hardware interfaces such as UART, SD/SDIO, 1-Wire, CAN bus, and others. External Address/Data Bus The modules provide a 17-bit address and 16-bit data bus with 2 external chip selects for peripheral connections. www.digiembedded.com 38 Chapter 1 Antenna Note: When disconnecting U.FL connectors, the use of a U.FL plug extraction tool (Hirose P/N U.FL-LP-N-2 or U.FL-LP(V)-N-2) is strongly recommended to avoid damage to the U.FL connectors on the ConnectCore Wi-9P 9215 module. To mate U.FL connectors, the mating axes of both connectors must be aligned. The "click" will confirm afully mated connection. Do not attempt insertion at an extreme angle. ConnectCore Wi-9P 9215 WLAN For the ConnectCore Wi-9P 9215, connect antennas to the primary and secondary connectors. The module uses the same antennas to transmit and receive the 802.11b/g RF signal. An antenna switch is required to isolate the transmit signal from the receive signal. The antenna switch works by alternately connecting the antennas to either the transceiver PA transmit output or the transceiver receive input. To support this antenna sharing scheme, the module operates in half-duplex mode; receive and transmit operations do not occur at the same time. 39 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... WLAN Antenna Switch The antenna switch is a digitally controlled 2.4 GHz, 50 ohm, multi-function solid state switch, controlled by software. The receive port can be switched between antenna 1 or antenna 2. The transmit port can be switched between antenna 1 or antenna 2. The switch can handle >28dBm of signal on the transmit port. The insertion loss of the antenna switch is 23dB. Power Power supply The module has +3.3V and VLIO supply pins. VLIO can be connected either to a Li-Ion battery (2.5V - 5.5V) in a mobile application, or it can be connected directly to +3.3V. Connecting VLIO to a battery causes efficiency to be gained without an additional voltage regulator. Internal voltage The internal 1.8V core voltage is generated through a high-efficiency synchronous step-down converter, which uses VLIO as input voltage. The core voltage regulator can provide up to 600mA. www.digiembedded.com 40 Chapter 1 Digi Plug-and-Play Firmware .................................................................................. This section describes the features and functionality of modules utilizing Digi Plugand-Play Firmware only. If you are using a module that utilizes the embedded NET+OS or Linux software see page 14. Once you have read through all the Digi Plug-and-Play Firmware related sections, proceed to Chapter 2. Note: Digi Plug-and-Play Firmware is only available for the ConnectCore Wi-9P 9215. Module pinout The module has two 80 pins connectors, X1 and X2. The next tables describe each pin, its properties, and its use on the Development Board. Pinout legend: Type I Input O Output I/O Input or output P Power X1 pinout X1 pin number Type Module functionality 1 P GND 2 P GND 3 I RSTIN# 4 O SRESET# Comments 10k pull-up on module Output of the reset controller push pull with 470R current limiting resistor 41 5 O RSTOUT# Output of logical AND function between NS9215 RESET_DONE and NS9215 RESET_OUT# 6 I TCK Not Connected, Reserved 7 I TMS Not Connected, Reserved 8 I TDI Not Connected, Reserved 9 O TDO Not Connected, Reserved 10 I TRST# Not Connected, Reserved 11 O RTCK Not Connected, Reserved 12 I OCD_EN# Not Connected, Reserved ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... www.digiembedded.com X1 pin number Type Module functionality Comments 13 I LITTLE# / BIG ENDIAN Not Connected, Reserved 14 I WLAN_DISABLE# For ConnectCore Wi-9P 921 low active WLAN Disable signal. For ConnectCore 3G 9P 9215 normally connected to X2-15. 15 I SW_CONF0 2k2 series resistor on module 16 I SW_CONF1 2k2 series resistor on module 17 I SW_CONF2 2k2 series resistor on module 18 I SW_CONF3 2k2 series resistor on module 19 O (WLAN_LED#) Active low signal coming from low-active WLAN signal. This signal comes directly from the Piper chip without series resistor. Not connected, for the ConnectCore 3G 9P 9215. 20 P GND 21 I/O BD0 Not Connected, Reserved 22 I/O BD1 Not Connected, Reserved 23 I/O BD2 Not Connected, Reserved 24 I/O BD3 Not Connected, Reserved 25 I/O BD4 Not Connected, Reserved 26 I/O BD5 Not Connected, Reserved 27 I/O BD6 Not Connected, Reserved 28 I/O BD7 Not Connected, Reserved 29 I/O BD8 Not Connected, Reserved 30 I/O BD9 Not Connected, Reserved 31 I/O BD10 Not Connected, Reserved 32 I/O BD11 Not Connected, Reserved 33 I/O BD12 Not Connected, Reserved 34 I/O BD13 Not Connected, Reserved 35 I/O BD14 Not Connected, Reserved 36 I/O BD15 Not Connected, Reserved 37 P GND 38 O BAO Not Connected, Reserved 39 O BA1 Not Connected, Reserved 40 O BA2 Not Connected, Reserved 41 O BA3 Not Connected, Reserved 42 O BA4 Not Connected, Reserved 42 Chapter 1 43 X1 pin number Type Module functionality Comments 43 O BA5 Not Connected, Reserved 44 O BA6 Not Connected, Reserved 45 O BA7 Not Connected, Reserved 46 O BA8 Not Connected, Reserved 47 O BA9 Not Connected, Reserved 48 O BA10 Not Connected, Reserved 49 O BA11 Not Connected, Reserved 50 O BA12 Not Connected, Reserved 51 O BA13 Not Connected, Reserved 52 O BA14 Not Connected, Reserved 53 O BA15 Not Connected, Reserved 54 O BA16 Not Connected, Reserved 55 O GND 56 O EXT_OE# Not Connected, Reserved 57 O EXT_WE# Not Connected, Reserved 58 O EXT_CSO# Not Connected, Reserved 59 O EXT_CS2# Not Connected, Reserved 60 O BE2# Not Connected, Reserved 61 O BE3# Not Connected, Reserved 62 I EXT_WAIT# Not Connected, Reserved 63 O EXT_CLK# Not Connected, Reserved 64 P GND 65 I ETH_TPIN 66 O ETH_ACTIVITY# 67 I ETH_TPIP 68 O ETH_LINK# 69 O ETH_TPON 70 O ETH_TPOP 71 P GND 72 P 73 I Low active signal with 330R resistor on module Low active signal with 330R resistor on module Reserved for the ConnectCore 3G 9P 9215: +3.3V additional power supply pin USB_OC# ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Reserved for the ConnectCore 3G 9P 9215: USB_OC# over current input ..... X1 pin number Type Module functionality Comments 74 I/O USB_P Reserved for the ConnectCore 3G 9P 9215: USB_P OTG channel 75 I/O USB_N Reserved for the ConnectCore 3G 9P 9215: USB_N OTG channel 76 O USB_PWR# Reserved for the ConnectCore 3G 9P 9215: USB_PWR# 77 I Reserved 78 P VRTC Backup Battery for RTC, for 3V cell. Can be left floating, if RTC backup not needed. 79 P VLIO Mobile: Power from Li-Ion Battery (2.5V-5.5V) Non-Mobile: connected to 3.3V 80 P GND X2 pinout The following table shows the GPIO multiplexing capabilities for the Digi Plug-andPlay Firmware module: X2 pin number Type Module Functionality I/O Multiplexing 1 P GND 2 P GND 3 I/O DCDA# GPIO0 SPI_EN# GPIO0 DCDA Comments See Note 1 XBEE_ON_SLEEP# 4 5 6 I/O I/O I/O CTSA# GPIO1 GPIO1 CTSA DSRA# GPIO2 GPIO2 XBEE_RESET# DSRA RXDA GPIO3 SPI_RXD RXDA See Note 1 See Note 1 See Note 1 GPIO3 7 www.digiembedded.com I/O RIA# GPIO4 ERIQ2 RIA GPIO4 EIRQ2 See Note 1 and Note 4 44 Chapter 1 X2 pin number Type Module Functionality I/O Multiplexing Comments 8 I/O RTSA# GPIO5 See Note 1 SPI_CLK RTSA GPIO5 9 I/O DTRA# GPIO6 GPIO6 DTRA See Note 1 SLEEP_RQ 10 I/O TXDA GPIO7 SPI_TXD TXDA See Note 1 GPIO7 11 I/O DCDC# GPIO8 TXCLKC DCDC See Note 2 GPIO8 12 13 14 15 I/O I/O I/O I/O CTSC# GPIO9 GPIO9 CTSC DSRC# GPIO10 GPIO10 DSRC RXDC GPIO11 GPIO11 RXDC RIC# GPIO12 RXCLKC RIC See Note 2 See Note 2 See Note 1 See Note 3 GPIO12 16 I/O RTSC# GPIO13 RXCLKC RTSC See Note 2 GPIO13 17 I/O DTRC# GPIO14 TXCLKC DTRC See Note 1 GPIO14 18 19 20 21 22 45 I/O I/O I/O I/O I/O TXDC GPIO15 GPIO15 TXDC DCDB# GPIO51 GPIO51 DCDB CTSB# GPIO52 GPIO52 CTSB DSRB# GPIO53 GPIO53 DSRB RXDB GPIO54 GPIO54 RXDB ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference See Note 2 See Note 1 See Note 1 See Note 1 See Note 1 ..... X2 pin number Type Module Functionality I/O Multiplexing Comments 23 I/O RIB# GPIO55 See Note 1 GPIO55 RIAB RTSB# GPIO56 GPIO56 RTSB DTRB# GPIO57 GPIO57 DTRB TXDB GPIO58 GPIO58 TXDB DCDD# GPIO59 GPIO59 DCDD CTSD# GPIO60 GPIO60 CTSD DSRD# GPIO61 GPIO61 DSRD RXDDD GPIO62 GPIO62 RXDD RID# GPIO63 GPIO63 RIAD RTSD# GPIO64 GPIO64 RTSD DTRD# GPIO65 GPIO65 DTRD TXDD GPIO66 GPIO66 TXDD 24 25 26 27 28 29 30 31 32 33 34 I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 See Note 1 35 I/O GPIO67 GPIO67 See Note 1 36 I/O GPIO68 GPIO68 See Note 1 and Note 5 FIM_UART_0_TXD 37 I/O GPIO69 GPIO6 See Note 1 and Note 5 FIM_UART_0_RXD 38 I/O GPIO70 GPIO7 See Note 1 and Note 5 FIM_UART_0_RTS 39 I/O GPIO71 GPIO71 See Note 1 and Note 5 FIM_UART_0_CTS 40 I/O GPIO72 GPIO72 See Note 1 and Note 5 FIM_UART_1_TXD 41 I/O GPIO73 GPIO73 See Note 1 and Note 5 FIM_UART_1_RXD www.digiembedded.com 46 Chapter 1 X2 pin number Type Module Functionality I/O Multiplexing Comments 42 I/O GPIO74 GPIO74 See Note 1 and Note 5 FIM_UART_1_RTS 43 I/O GPIO75 GPIO75 See Note 1 and Note 5 FIM_UART_1_CTS 44 I/O GPIO76 GPIO76 See Note 1 45 I/O GPIO77 GPIO77 See Note 1 46 I/O GPIO78 GPIO78 See Note 1 47 I/O GPIO79 GPIO79 See Note 1 48 I/O GPIO80 GPIO80 See Note 1 49 I/O USER_BUTTON1# GPIO81 This pin is reserved as a soft reset input, active low. GPIO82 See Note 1 GPIO81 50 I/O USER_LED1# GPIO82 51 I/O GPIO83 GPIO83 52 I/O USER_BUTTON2# GPIO84 See Note 1 GPIO84 53 I/O USER_LED2# GPIO85 GPIO85 54 I/O GPIO86 GPIO86 55 I/O GPIO87 GPIO87 56 I/O GPIO93 GPIO93 57 I/O GPIO94 GPIO94 58 I/O GPIO95 GPIO95 59 I/O CAN0_RXD CAN_RX0 See Note 5 CAN_TX0 See Note 5 CAN_RX1 See Note 5 CAN_TX1 See Note 5 GPIO96 60 I/O CAN0_TXD GPIO97 61 I/O CAN1_RXD GPIO98 62 I/O CAN1_TXD GPIO99 63 I/O GPIO100 GPIO100 See Note 1 64 I/O EIRQ3# GPIO101 See Note 1 GPIO102 4k7 pull-up on module GPIO101 65 I/O I2C_SCL GPIO102 47 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... X2 pin number Type Module Functionality I/O Multiplexing Comments 66 I/O I2C_SDA GPIO103 4k7 pull-up on module GPIO103 67 I ADC_IN0 VIN0_ADC Not Connected, Reserved 68 I ADC_IN1 VIN1_ADC Not Connected, Reserved 69 I ADC_IN2 VIN2_ADC Not Connected, Reserved 70 I ADC_IN3 VIN3_ADC Not Connected, Reserved 71 I ADC_IN4 VIN4_ADC Not Connected, Reserved 72 I ADC_IN5 VIN5_ADC Not Connected, Reserved 73 I ADC_IN6 VIN6_ADC Not Connected, Reserved 74 I ADC_IN7 VIN7_ADC Not Connected, Reserved 75 P AGND_ADC VSS_ADC Not Connected, Reserved 76 P VRED_ADC VREF_ADC Not Connected, Reserved 77 P AGND_ADC 3.3V 78 P VREF_ADC 3.3V 79 P GND 80 P GND Note 1: This pin is defined in the table of the “Multiplexed GPIO Pins” section on page 51. Note 2: For the ConnectCore 3G 9P 9215, the following pins are outputs with fixed functionality, and can be used to drive LEDs: X2-11: Cellular link activity output. X2-12: Cellular 3G connectivity indicator. X2-13: Cellular signal strength (1st bar). X2-16: Cellular signal strength (2nd bar). X2-18: Cellular signal strength (3rd bar). These signals are “ACTIVE LOW” and are intended to be used with LEDs to indicate cellular states. It is recommended to connect these IO pins in a “sinking circuit” as indicated in the figure on the next page: www.digiembedded.com 48 Chapter 1 VCC_3.3V LED CC3G I/O Pin (ACTIVE LOW) R = 510 Ohms Note 3: For the ConnectCore 3G 9P 9215, this pin is the cellular disable output and should be tied directly to CELL_DISABLE_N, pin X1-14. Note 4: EIRQ2 is default configured to support the Wake-up button on the Development Board. Note 5: See the “FIM” section on page 56 for more information. Configuration pins — Module Module pin configuration Dipswitch S4 Signal name Function PU/PD Comment LITTLE#/BIG_ Must be set to BIG_ENDIAN ENDIAN PU Signal LITTLE#/BIG_ENDIAN is connected to GPIO_A3/A27 through a 2k2 series resistor. OCD_EN# Not used PU 10K Not Connected, Reserved SW_CONF0 See Note 1 Connected to A13 through a 2k2 series resistor. SW_CONF1 See Note 1 Connected to A14 through a 2k2 series resistor. SW_CONF2 See Note 1 Connected to A15 through a 2k2 series resistor. SW_CONF3 See Note 1 Connected to A16 through a 2k2 series resistor. Note 1: This pin is defined in the "Connector X2 Pins Available for a Python Application" section, which describes how the setting of this strapping will affect the capabilities of various I/O pins. 49 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Connector X2 Pins Available for a Python Application The connector X2 GPIO pins are referenced in Python as the pin number on the X2 connector, not the GPIO number. For example, GPIO67 is connected to connector X2 pin 35. To control GPIO67, you will reference it using "X2_35". The ConnectCore 3G 9P 9215 module can be strapped to enable zero to three serial ports. The ConnectCore Wi-9P 9215 and the ConnectCore 9P 9215 modules can be strapped to enable zero to four serial ports. Serial port strapping is defined by the SW_CONF0, SW_CONF1, SW_CONF2 and SW_CONF3 switch settings on Dipswitch S4 which is next to the JTAG connector. The default is to have two serial ports enabled (Port B and Port D). If Port A is defined as a serial port, it cannot be used by ZigBee. ZigBee is only available under the following conditions: 1. Port A is not strapped to be a serial port. 2. ZigBee is enabled. Use Dipswitch S4 to configure the number of serial ports that are enabled. Changes to Dipswitch S4 are only sensed after a hard reset. SW_CONF0 SW_CONF1 SW_CONF2 SW_CONF3 Number of Serial Ports Enabled OFF ON ON ON 0 ON OFF ON ON 1 - Port B ON ON ON ON 2 - Port B, Port D (factory) OFF OFF ON ON 3 - Port B, Port D, Port A ON ON OFF ON 4 - Port B, Port D, Port A, Port C Four serial ports are only available on the ConnectCore 9P 9215 and ConnectCore Wi-9P 9215. Serial Port A must not be strapped as a serial port if Wake-up functionality is used. See the “External Interrupts” section on page 54 for more information. The fewer serial ports enabled, the more GPIO pins available for a Python application. www.digiembedded.com 50 Chapter 1 Available GPIO pins per number of serial ports enabled Product 0 Serial Ports 1 Serial Port 2 Serial Ports 3 Serial Ports 4 Serial Ports ConnectCore 3G 9P 9215 42 34 26 18 N/A ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 50 42 34 26 18 If you are migrating to the ConnectCore 3G 9P 9215 from the ConnectCore Wi-9P 9215 or the ConnectCore 9P 9215, connector pins "X2_11" - "X2_18" will no longer be accessible. If you are migrating from the ConnectCore 3G 9P 9215 to the ConnectCore Wi-9P 9215 or the ConnectCore 9P 9215, connector pins "X2_11" "X2_18" will now be accessible. Multiplexed GPIO Pins The table below shows the available GPIOs available through the GPIO Python API. The first column in the table lists the pin on the module connector. The second column lists the GPIO available when configured for zero serial ports. The third column for one port, and so on. Some pins have dual purpose, such as GPIO68, which could also be used for EXT_SIM_VCC. So if the external SIM function is being used, GPIO68 is not available. Module Pin (Python Name) 51 0 Serial Ports 1 Serial Port 2 Serial Ports 3 Serial Ports 4 Serial Ports X2-3 GPIO0 GPIO0 GPIO0 DCDA DCDA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_ON_SLEEP. X2-4 GPIO1 GPIO1 GPIO1 CTSA CTSA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_CTS. X2-5 GPIO2 GPIO2 GPIO2 DSRA DSRA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_DSR. X2-6 GPIO3 GPIO3 GPIO3 RXDA RXDA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_RXD. X2-7 GPIO4 GPIO4 GPIO4 RIA RIA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_RI. X2-8 GPIO5 GPIO5 GPIO5 RTSA RTSA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_RTS. ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Comments ..... Module Pin (Python Name) www.digiembedded.com 0 Serial Ports 1 Serial Port 2 Serial Ports 3 Serial Ports 4 Serial Ports Comments X2-9 GPIO6 GPIO6 GPIO6 DTRA DTRA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_DTR. X2-10 GPIO7 GPIO7 GPIO7 TXDA TXDA If XBEE is enabled this signal is not available. Instead, it is used as XBEE_TXD. X2-11 GPIO8 GPIO8 GPIO8 GPIO8 DCDC Cellular link activity output for ConnectCore 3G 9P 9215. X2-12 GPIO9 GPIO9 GPIO9 GPIO9 CTSC Cellular 3G connectivity indicator for ConnectCore 3G 9P 9215. X2-13 GPIO10 GPIO10 GPIO10 GPIO10 DSRC Cellular signal strength (1st bar) for ConnectCore 3G 9P 9215. X2-14 GPIO11 GPIO11 GPIO11 GPIO11 RXDC Not available for ConnectCore 3G 9P 9215. X2-15 GPIO12 GPIO12 GPIO12 GPIO12 RIC Not available for ConnectCore 3G 9P 9215. X2-16 GPIO13 GPIO13 GPIO13 GPIO13 RTSC Cellular signal strength (2nd bar) for ConnectCore 3G 9P 9215. X2-17 GPIO14 GPIO14 GPIO14 GPIO14 DTRC Not available for ConnectCore 3G 9P 9215. X2-18 GPIO15 GPIO15 GPIO15 GPIO15 TXDC Cellular signal strength (3rd bar) for ConnectCore 3G 9P 9215. X2-19 GPIO51 DCDB DCDB DCDB DCDB X2-20 GPIO52 CTSB CTSB CTSB CTSB X2-21 GPIO53 DSRB DSRB DSRB DSRB X2-22 GPIO54 RXDB RXDB RXDB RXDB X2-23 GPIO55 RIB RIB RIB RIB X2-24 GPIO56 RTSB RTSB RTSB RTSB X2-25 GPIO57 DTRB DTRB DTRB DTRB X2-26 GPIO58 TXDB TXDB TXDB TXDB X2-27 GPIO59 GPIO59 DCDD DCDD DCDD X2-28 GPIO60 GPIO60 CTSD CTSD CTSD X2-29 GPIO61 GPIO61 DSRD DSRD DSRD X2-30 GPIO62 GPIO62 RXDD RXDD RXDD X2-31 GPIO63 GPIO63 RID RID RID 52 Chapter 1 Module Pin (Python Name) 53 0 Serial Ports 1 Serial Port 2 Serial Ports 3 Serial Ports 4 Serial Ports X2-32 GPIO64 GPIO64 RTSD RTSD RTSD X2-33 GPIO65 GPIO65 DTRD DTRD DTRD X2-34 GPIO66 GPIO66 TXDD TXDD TXDD X2-35 GPIO67 GPIO67 GPIO67 GPIO67 GPIO67 X2-36 GPIO68 GPIO68 GPIO68 GPIO68 GPIO68 X2-37 GPIO69 GPIO69 GPIO69 GPIO69 GPIO69 X2-38 GPIO70 GPIO70 GPUO70 GPIO70 GPIO70 X2-39 GPIO71 GPIO71 GPIO71 GPIO71 GPIO71 X2-40 GPIO72 GPIO72 GPIO72 GPIO72 GPIO72 X2-41 GPIO73 GPIO73 GPIO73 GPIO73 GPIO73 X2-42 GPIO74 GPIO74 GPIO74 GPIO74 GPIO74 X2-43 GPIO75 GPIO75 GPIO75 GPIO75 GPIO75 X2-44 GPIO76 GPIO76 GPIO76 GPIO76 GPIO76 X2-45 GPIO77 GPIO77 GPIO77 GPIO77 GPIO77 X2-46 GPIO78 GPIO78 GPIO78 GPIO78 GPIO78 X2-47 GPIO79 GPIO79 GPIO79 GPIO79 GPIO79 X2-48 GPIO80 GPIO80 GPIO80 GPIO80 GPIO80 X2-50 GPIO82 GIO82 GPIO82 GPIO82 GPIO82 User LED1 X2-52 GPIO84 GPIO84 GPIO84 GPIO84 GPIO84 User button2 X2-63 GPIO100 GPIO100 GPIO100 GPIO100 GPIO100 X2-64 GPIO101 GPIO101 GPIO101 GPIO101 GPIO101 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Comments ..... Module LEDs The ConnectCore 9P 9215, the ConnectCore Wi-9P 9215 and ConnectCore 3G 9P 9215 modules have two on module LEDs: LE1 and LE2. During startup, LE1 will flash a repeating blink pattern for a major system failure; for example, a processor exception or power on self test failure. If startup is successful, you will see three blinks. After startup, LE1 is available at the Python programming layer, via the user_led_set() function if you are using the ConnectCore 9P 9215 or the ConnectCore 3G 9P 9215 module. After startup, LE1 and LE2 are used as follows for the ConnectCore Wi-9P 9215. ID Color LED Blink Pattern Status/Activity LE1 Green Link Integrity On The unit is associated to an access point (infrastructure mode) Slow The unit is in ad-hoc mode Quick The unit is scanning for a network Blinking Network traffic is received or transmitted Off Network is idle LE2 Yellow Network Activity External Interrupts The Wake-up button can be used to exit from power-save mode. Serial Port A must NOT be strapped as a serial port if Wake-up functionality is used. EIRQ2 is default configured to support the Wake-up button on the Development Board. www.digiembedded.com 54 Chapter 1 Interfaces 10/100 Mbps Ethernet port The Digi NS9215 processor’s 10/100 Mbps Ethernet MAC allows a glueless connection of a 3.3V MII PHY chip that generates the physical Ethernet signals. The module has a MII PHY chip in a 56-pin QFN package on board. By default, the module does not have a transformer or Ethernet connector; the base board must provide these parts. However, it's possible to populate a specific RJ45 connector with magnetics on the module. The appropriate RJ-45 is Midcom MIC2412A-5108W-LF3. A PHY clock of 25 MHz is generated in the PHY chip with a 25 MHz crystal. GPIO90 is controlling the PHY RESET# signal. This GPIO has a 2k2 pull-down resistor to GND populated on the module. GPIO90 must be asserted high before PHY can be used. When not used, the PHY can be put in low-power mode by asserting GPIO90 low. The PHY address on the MII bus is 0x7 (0b00111). The module does not only provide access to the Ethernet signals coming out of the PHY, but supports also two status LEDs: ETH_ACTIVITY# and ETH_LINK#. UART The ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 modules provide up to four UART ports, the ConnectCore 3G 9P 9215 module provides up to three UART ports, used in asynchronous mode:  Port A = X2_3 to X2_10  Port B = X2_19 to X2_26  Port C = X2_11 to X2_18 (Not available on the ConnectCore 3G 9P 9215)  Port D = X2_27 to X2_34 The module supports baud rates up to 1.8432 Mbps in asynchronous mode. Each UART has a 64-byte TX and RX FIFO available. For Python applications, the following table shows a cross reference with Python logical programmatic com port (i.e. “com0”) to the physical com port (i.e. “Serial Port B”). Port to Open in Python Applications Product 55 Serial Port A Serial Port B Serial Port C Serial Port D FIM 0 FIM 1 ConnectCore 3G 9P 9215 “com2” “com0” N/A “com1” “com3” “com4” ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 “com2” “com0” “com3” “com1” “com4” “com5” ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... RTC The RTC is integrated in the processor and has its own 32.768 KHz clock crystal.  When powered by VBAT, RTC unit will function until VBAT (X1.78) reaches a threshold of 2.3 - 2.4V - then the internal unit switches off.  The battery current without +3.3V power applied is up to 40µA. The current is used to power the RTC, 32.768kHz oscillator and 64-byte internal RAM.  When the Development Board ships from the factory the battery is disabled. To enable the battery, place a jumper on the Development Board at J2. WLAN In addition to the wired Ethernet interface, the ConnectCore Wi-9P 9215 module also offers an integrated dual-diversity 802.11a/b/g interface with data rates up to 54 Mbps. Two U.FL antenna connectors are provided on the module. WWAN The ConnectCore 3G 9P 9215 offers 3G connection technologies by using the Qualcomm Gobi PCIe module. FIM The Flexible Interface Modules (FIM) are based on two independent 8-bit DRPIC1655X cores running at 300 MHz maximum core clock (4x NS9215 bus speed) with 192-byte data and 2 KB program SRAM. The FIMs allow the flexible software-based selection of Digi-provided application specific hardware interfaces such as UART, SD/SDIO, 1-Wire, CAN bus, and others. To use the FIMS (Flexible Interface Modules) for CAN bus or additional serial ports, you will be using the FIM Application Kit. The FIM application kit is not supplied with the development kit. You need to purchase "Product: Application Kit - FIM". There are two available FIMs that can be used in combinations of CAN bus and serial port(s). The FIM Application Kit provides interfaces to test the different firmware implemented on the FIMs of the ConnectCore 3G 9P 9215, ConnectCore Wi-9P 9215 and ConnectCore 9P 9215 modules. The FIMs are 8-bit microcontrollers embedded in the main microcontroller of the modules. The current implementation does not support dual CAN bus. CAN bus is only supported on FIM0, and can only be accessed using Python. Both Serial FIM0 and Serial FIM1 can be used for additional serial ports. The ports can only be accessed using Python. For more detailed information, see the links below:  www.digiembedded.com FIM Application Kit Quick Start Guide: http://ftp1.digi.com/support/documentation/90001076_A.pdf 56 Chapter 1  FIM Application Kit Hardware Reference Manual: http://ftp1.digi.com/support/documentation/90001074_A.pdf  FIM Application Kit Schematics: http://ftp1.digi.com/support/documentation/90001104_A.pdf USB Host The ConnectCore 3G 9P 9215 has a high speed USB Host controller, capable of handling external mass storage devices (i.e., USB Flash Drivers) or a Digi Watchport Camera. Antenna Note: When disconnecting U.FL connectors, the use of U.FL plug extraction tool (Hirose P/N U.FL-LP-N-2 or U.FL-LP(V)-N-2) is strongly recommended to avoid damage to the U.FL connectors on the ConnectCore Wi-9P 9215 and ConnectCore 3G 9P 9215 modules. To mate U.FL connectors, the mating axes of both connectors must be aligned. The "click" will confirm fully mated connection. Do not attempt insertion at an extreme angle. 57 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... ConnectCore Wi-9P 9215 WLAN For the ConnectCore Wi-9P 9215, connect antennas to the primary and secondary connectors. The module uses the same antennas to transmit and receive the 802.11b/g RF signal. An antenna switch is required to isolate the transmit signal from the receive signal. The antenna switch works by alternately connecting the antennas to either the transceiver PA transmit output or the transceiver receive input. To support this antenna sharing scheme, the module operates in half-duplex mode; receive and transmit operations do not occur at the same time. WLAN Antenna Switch The antenna switch is a digitally controlled 2.4 GHz, 50 ohm, multi-function solid state switch, controlled by software. The receive port can be switched between antenna 1 or antenna 2. The transmit port can be switched between antenna 1 or antenna 2. The switch can handle >28dBm of signal on the transmit port. The insertion loss of the antenna switch is 23dB. www.digiembedded.com 58 Chapter 1 ConnectCore 3G 9P 9215 WWAN The ConnectCore 3G 9P 9215 Development Board and module contains several RF connectors, as well as the two connectors located on the Gobi 3000 module (refer to the diagrams on the following page). Cellular RF Path: The cellular RF path is established when the Gobi 3000 module MAIN connector is cabled directly to the back of the ConnectCore 3G 9P 9215 J2 connector. The cellular antenna is connected to J2. Note: This is how the module is certified and any deviation from this configuration will require re-certification.) GPS RF Path: The GPS RF path has two possible configurations, based on the GPS antenna: Active and Passive. Digi supplies an Active antenna. When using an active GPS antenna, the Gobi 3000 module AUX connector is cabled to the ConnectCore 3G 9P 9215 X30 connector, and the ConnectCore 3G 9P 9215 X29 connector is cabled to the Development Board Cellular Secondary connector X31. When an Active GPS antenna is connected to the Development Board at J7, GPS traffic is then available to the module. When using a Passive GPS antenna, the Gobi 3000 AUX connector could be cabled directly to the Development Board Cellular Secondary connector X31. A Passive GPS antenna is connected at J7. 59 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... ConnectCore 3G 9P 9215 Module To J7 on Development PCB X29 (GPS) X30 (GPS) from Gobi AUX J2 (WWAN) Gobi 3000 Module Aux RF Connector Main RF Connector www.digiembedded.com 60 Chapter 1 Power Power supply The module has +3.3V and VLIO supply pins. VLIO can be connected either to a Li-Ion battery (2.5V - 5.5V) in a mobile application, or it can be connected directly to +3.3V. Connecting VLIO to a battery causes efficiency to be gained without an additional voltage regulator. Internal voltage The internal 1.8V core voltage is generated through a high-efficiency synchronous step-down converter, which uses VLIO as input voltage. The core voltage regulator can provide up to 600mA. 61 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference About the Development Board C H A P T E R 2 T he ConnectCore 9P 9215 Development Board supports the onnectCore 9P 9215 Family of modules. This chapter describes the components of the Development Board and explains how to configure the board for your requirements. The Development Board has two 4x20 pin connectors that are 1:1 copies of the module pins. What’s on the Development Board?  RJ-45 Ethernet connector  Four RP-SMA antenna connectors. –  Four serial interface connectors: – 1 x UART B MEI (RS232/RS4xx) with status LEDs on SUB-D 9-pin connector (X6) – 1 x UART D RS232 with status LEDs, on SUB-D 9-pin connector (X3) – 1 x UART C with TTL levels shared with HDLC signals on 10-pin header (X5) – 1 x UART A with TTL levels shared with SPI signals on 10-pin header (X4)  Socket for XBee® module  Peripheral application header – www.digiembedded.com Connection to module via U.FL connectors Including access to 16-bit data/10-bit address bus signals  Headers with 1:1 copies of the module pins (X1/X2)  Two user pushbuttons, two user LEDs, one wake-up button  Eight-position configuration dip switches 62 Chapter 2   Four each for hardware/software configuration – GPIO screw-flange connector – +9/30VDC power supply Current measurement option – Development Board + module, and module alone – 3.3V coincell battery with socket – PoE connectors for optional 802.3af PoE Application Kit (P/N DG-ACC-POE) – Prototyping area (15 x 28 holes) with +3.3V and GND connections ConnectCore 3G 9P 9215 Specifics  USB host connector  2 x SMA antenna connectors for cellular/GPS antennas Connection to module via U.FL connectors ConnectCore 9P 9215 Development Board 63 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... User interface .................................................................................. The ConnectCore 9P 9215 Development Board implements two user buttons and two user LEDs, in addition to those provided on the module. The user LEDs on the Development Board can be enabled or disabled by population option jumper J4 & J5. The table below shows which NS9215 GPIO is available for implementing the user interface. www.digiembedded.com Signal name GPIO used Comments USER_BUTTON1 GPIO81 10k pull-up to +3.3V on the Development Board USER_LED1# GPIO82 Remove jumper J5 to isolate (and disable) LED (LE5) USER_BUTTON2 GPIO84 10k pull-up to +3.3V on the Development Board USER_LED2# GPIO85 Remove jumper J4 to isolate (and disable) LED (LE6) 64 Chapter 2 Switches and Pushbuttons .................................................................................. ConnectCore 9P 9215 Development Board Configuration Switch, S4 Reset Button, S3 Power Switch, S2 Serial Port B (MEI) Configuration Switch, S1 Wake Up Button, S8 User Button 1, S6 User Button 2, S7 Reset control, S3 The reset pushbutton, S3, resets the module. On the module, RSTOUT# and PWRGOOD are produced for peripherals. A pushbutton allows manual reset by connecting RSTIN# to ground. Power switch, S2 The Development Board has an ON/OFF switch, S2. The power switch, S2, can switch both 9V-30V input power supply and 12V coming out of the PoE module. However, if a power plug is connected in the DC power jack, the PoE module is disabled. 65 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... User pushbuttons, S6 and S7 Use the user pushbuttons to interact with the applications running on the ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 modules. Use these module signals to implement the pushbuttons: Signal name Switch (pushbutton) GPIO used USER_PUSH_BUTTON_1 S6 GPIO81 USER_PUSH_BUTTON_2 S7 GPIO84 Note: User Button 1 has reserved functionality. A quick button press causes a soft reset. Holding the button at power-up for 20 seconds, then releasing, will factory default the module. Legend for multi-pin switches Switches 1 and 4 are multi-pin switches. In the description tables for these switches, the pin is designated as S[switch number].[pin number]. For example, pin 1 in switch 4 is specified as S4.1. Module configuration switches, S4 Use S4 to configure the module: Switch pin S4.1 Function On = Little endian Off = Big endian S4.2 Not used S4.3 On = ARM Debug Off = Boundary Scan S4.4 Not used S4.5 – S4.8 Used for application configuration settings. Note: Wake-up button, S8 www.digiembedded.com When running Linux based applications, always select Little Endian. All other applications must use Big Endian. Failure to do so will prevent your board from running or booting. The wake-up pushbutton, S8, generates an external interrupt to the module's NS9215 processor using the EIRQ2 signal. 66 Chapter 2 Serial Port B MEI configuration switches, S1 Use S1 to configure the line interface for serial port B MEI: Switch pin Function S1.1 On = RS232 transceiver enabled RS422/RS485 transceivers disabled Off = RS232 transceiver disabled RS422/RS485 transceivers enabled S1.2 On = Auto Power Down enabled Off = Auto Power Down disabled S1.3 On = 2-wire interface (RS422/RS485) Off = 4-wire interface (RS422) S1.4 On = Termination on Off = No termination 67 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Comments Auto Power Down is not supported on this board. This signal is only accessible to permit the user to completely disabled the MEI interface for using the signals for other purposes. To disable the MEI interface, go into RS232 mode (S1.1 = ON) and activate the Auto Power Down feature (S1.2 = ON) - be sure that no cable is connected to connector X3. ..... Jumpers .................................................................................. ConnectCore 9P 9215 Development Board Battery Jumper, J2 WLAN Jumper, J3 Serial Port D Transceiver Jumper, J1 User LED1 Jumper, J5 www.digiembedded.com User LED2 Jumper, J4 68 Chapter 2 Jumper functions Jumper Name If connection made Default J1 Enable transceiver This jumper allows a user to disable the console RS232 transceiver. Connection made = console active J2 Battery enable Supplies the real time clock with 3V from the battery (lithium coin cell battery, G1) even if the board is switched off. This is for keeping time in the RTC. Connection not made = Backup battery disabled J3 WLAN_DISABLE# Disables the WiFi unit on the module. Connection made = WLAN disabled J4 USER_LED2# Enables User LED2 (LE6) to show the status of this signal (lit if low). Connection made = User LED2 enabled J5 USER_LED1# Enables User LED1 (LE5) to show the status of this signal (lit if low). Connection made = User LED1 enabled Note: The User LEDs are specific to the ConnectCore 3G 9P 9215 module: USER_LED2 - indicated GPS lock USER_LED1 - available through the Python GPIO API Battery and Battery Holder .................................................................................. 69 Battery Holder Battery Coin-Cell Holder for CR2477 Battery, THT Lithium coin cell, CR2477, 24mm, 950mAh Keystone 1025-7 Panasonic CR2477 Ettinger 15.61.252 Renata CR2477N ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... LEDs .................................................................................. ConnectCore 9P 9215 Development Board Power LED 9-30V, LE3 Power LED +5V, LE4 Power LED +3.3V, LE8 WLAN/WWAN LED, LE7 Serial Port D Status LEDs Serial Port B Status (MEI) LEDs User LED1, LE5 User LED2, LE6 WLAN LED LE7 LED indicating WLAN activity. Power LEDs, LE3 and LE4 The power LEDs are all red LEDs. These power supplies must be present and cannot be switched: www.digiembedded.com ConnectCore 3G 9P 9215 - LED indicating WWAN activity (directly connected to the PCIe connector pin 42).  LE3 ON indicates the +9VDC / +30VDC power is present.  LE4 ON indicates the +5VDC power is present. 70 Chapter 2  User LEDs, LE5 and LE6 LE8 ON indicates the +3.3VDC power is present. The user LEDs are controlled through applications running on the ConnectCore 9P 9215 Family of modules, if jumpers J5 and J4 are inserted. Use these module signals to implement the LEDs: Signal name LED GPIO used USER_LED1# LE5 GPIO82 USER_LED2# LE6 GPIO85 Note: Serial status LEDs Status LEDs Serial Port D LEDs Status LEDs Serial Port B LEDs 71 On the ConnectCore 3G 9P 9215, USER_LED2 is reserved for the GPS lock indication. The Development Board has two sets of serial port LEDs — four for serial port D and eight for serial port B. The LEDs are connected to the TTL side of the RS232 or RS422/485 transceivers.  Green means corresponding signal high.  Red means corresponding signal low.  The intensity and color of the LED will change when the voltage is switching. LED reference Function RED GREEN LE60 LE45 CTSD#/GPIO60 LE61 LE46 RTSD#/GPIO64 LE62 LE47 RXDD/GPIO62 LE63 LE48 TXDD/GPIO66 LED reference Function RED GREEN LE64 LE49 DCDB#/GPIO51 LE65 LE50 RIB#/GPIO55 LE66 LE51 DSRB#/GPIO53 LE67 LE52 DTRB#/GPIO57 LE68 LE53 CTSB#/GPIO52 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... LED reference Function LE69 LE54 RTSB#/GPIO56 LE70 LE55 RXDB/GPIO54 LE71 LE56 TXDB/GPIO58 Note: For more information please see the ConnectCore 9P 9215 schematics document online. Serial UART Ports .................................................................................. The Development Board supports the four serial ports available on the ConnectCore 9P 9215 and ConnectCore Wi-9P 9215 modules, including the three serial ports available on the Connect Core 3G 9P 9215. (ConnectCore 9P 9215 Port C is not available on the Connect Core 3G 9P 9215.) ConnectCore 9P 9215 Development Board Serial Port D (RS232), X3 Serial Port B (MEI), X6 Serial Port A TTL, X4 Serial Port C TTL, X5 www.digiembedded.com 72 Chapter 2 Serial port D, RS232 The serial (UART) port D connector, X3, is a DB9 male connector and is also used as the standard console. This asynchronous serial port is DTE and requires a null-modem cable to connect to a computer serial port. The serial port D interface corresponds to NS9215 UART port D. The line driver is enabled or disabled using jumper J1. Serial port D pins are allocated as shown: Pin Function Connector X2 Pin Defaults to 1 DCD# X2_27 GPIO59 2 RXD X2_30 GPIO62 3 TXD X2_34 GPIO66 4 DTR# X2_33 GPIO65 5 GND 6 DSR# X2_29 GPIO61 7 RTS# X2_32 GPIO64 8 CTS# X2_28 GPIO60 9 RIB# X2_31 GPIO63 By default, Serial D signals are configured to their respective GPIO signals. It is the responsibility of the driver to configure them properly. Serial port A, TTL interface The serial (UART) port A interface is a TTL interface connected to a 2x5 pin, 0.1” connector, X4. The connector supports only TTL level. The serial port A interface corresponds to NS9215 UART port A. Serial port A pins are allocated as shown: 73 Pin Function Connector X2 Pin 1 DCDA#/SPI_EN# X2_3 GPIO0 2 DSRA# X2_5 GPIO2 3 RXDA/SPI_RXD X2_6 GPIO3 Can be programmed as SPI receive data to X4 4 RTSA#/SPI_CLK X2_8 GPIO5 Can be programmed as SPI clock to X4 5 TXDA/SPI_TXD X2_10 GPIO7 Can be programmed as SPI transmit data to X4 6 CTSA# X2_4 GPIO1 7 DTRA# X2_9 GPIO6 8 RIA#/EIRQ2 X2_7 GPIO4 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Defaults to Comment Can be programmed as SPI enable to X4 This signal is default configured to support the wake-up button on the Development Board.. ..... Pin Function 9 GND 10 3.3V Connector X2 Pin Defaults to Comment By default, Serial A signals are configured to their respective GPIO signals. It is the responsibility of the driver to configure them properly. Serial port A must not be connected if SPI, WakeUp, or XBee module functionality is used. Serial port A, XBee socket www.digiembedded.com The XBee socket consists of two separate connectors J8 and J9. The XBee pinning counts counter-clockwise, so pin 1 of J9 is pin 20 of the module. All pins are connected 1:1 to a pin row to enable the usage of unconnected pins. Pin Function Connector X2 Pin Defaults to Comments 1 VCC 2 RXDA/SPI_RXD/GPIO3 X2_6 GPIO3 Can be programmed as SPI receive data to X4 3 TXDA/SPI_TXD/GPIO7 X2_10 GPIO7 Can be programmed as SPI transmit data to X4 4 NC 5 DSRA#/GPIO2/ XBEE_RESET# X2_5 GPIO2 6 NC 7 NC 8 NC 9 DTRA#/GPIO6/SLEEP_RQ X2_9 GPIO6 10 GND 11 NC 12 CTSA#/GPIO01 X2_4 GPIO1 13 DCDA#/SPI_EN#/GPIO0/ XBEE_ON_SLEEP# X2_3 GPIO0 14 NC 15 ASSOC 16 RTSA#/SPI_CLK/GPIO5 Onboard 3.3V X2_8 ASSOC LED output of XBEE module (LE57 on dev-board) GPIO5 Can be programmed as SPI clock on X4 74 Chapter 2 Serial port C, TTL interface Pin Function 17 NC 18 NC 19 NC 20 IDNET Connector X2 Pin 2 Pin Defaults to IDENT Comments Connected to S9 on dev-board The serial (UART) port C interface is a TTL interface connected to a 2x5 pin, 0.1” connector, X5. The connector supports only TTL level. The serial port C interface corresponds to the NS9215 UART port C. The signals are shared with the HDLC interface. Serial port C pins are allocated as shown: Pin Function Connector X2 Pin Defaults to 1 DCDC#/TXCLKC X2-11 GPIO8. 2 DSRC# X2-13 GPIO10. 3 RXDC# X2-14 GPIO11 4 RTSC#/RXCLKC X2-16 GPIO13 5 TXDC X2-18 GPIO15 6 CTSC# X2-12 GPIO9 7 DTRC#/TXCLKC X2-17 GPIO14 8 RIC#/RXCLKC/GPIO 12 X2-15 RESET_DONE (see note) 9 GND 10 3.3V Note: Comments If using GPIO12 as RIC#, be sure to populate a series resistor on the Development Board. This is necessary to avoid conflict between the default configuration of the GPIO when booting (RESET_DONE / output) and the chosen configuration once booted (RIC# / input). By default, Serial C signals are configured to their respective GPIO signals, except for GPIO12. It is the responsibility of the driver to configure them properly. 75 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Serial port B, MEI interface The serial (UART) port B connector, X6, is a DB9 male connector. This asynchronous serial port is DTE and requires a null-modem cable to connect to a computer serial port. The serial port B MEI (Multiple Electrical Interface) interface corresponds to NS9215 UART port B. The line drivers are configured using switch S1. Note that all pins on S1 contribute to the line driver settings for this port. Serial port B pins are allocated as shown: Pin RS232 fucntion RS232 default Connector X2 Pin RS485 function RS485 default 1 DCD# GPIO51 X2-19 CTS- n/a 2 RXD GPIO54 X2-22 RX+ GPIO54 3 TXD GPIO58 X2-26 TX+ GPIO58 4 DTR# GPIO57 X2-25 RTS- n/a 5 GND 6 DSR# GPIO53 X2-21 RX- n/a 7 RTS# GPIO56 X2-24 RTS+ GPIO56 8 CTS# GPIO52 X2-20 CTS+ GPIO52 9 RI# GPIO55 X2-23 TX- n/a GND By default, Serial B signals are configured to their respective GPIO signals. It is the responsibility of the driver to configure them properly. www.digiembedded.com 76 Chapter 2 I2C Interface .................................................................................. ConnectCore 9P 9215 Development Board 2 I C Header, X15 I 2 C header 77 2 I C Digital I/Os, X44 The I2C interface has only one device connected to the bus on the Development Board - an I/O expander (see next paragraph). Otherwise, additional I2C devices (like EEPROMs) can be connected to the module by using I2C header X15. The pinning of this header is provided as follows: Pin Signal 1 I2C_SDA/GPIO103 2 +3.3V 3 I2C_SCL/GPIO102 4 GND ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... I 2C digital I/O expansion The Development Board provides a 3.81mm (1.50") green terminal block, X44, for additional digital I/Os. The I2C I/O port chip is on-chip ESD-protected, and provides an open drain interrupt output. The I/O expander is a Philips PCA9554D at I2C address 0x20 / 0x21. The pins are allocated as shown: www.digiembedded.com Pin Signal 1 IO_0 2 IO_1 3 IO_2 4 IO_3 5 IO_4 6 IO_5 7 IO_6 8 IO_7 9 GND 78 Chapter 2 SPI Interface .................................................................................. ConnectCore 9P 9215 Development Board SPI Header, X8 The Development Board provides access to the SPI interface on the module using the SPI connector, X8. The SPI interface on the Development Board is shared with UART_A (NS9215 port A). Since the module’s SPI interface is shared with a UART interface, you cannot use both simultaneously. Note: 79 The default configuration of UART Port A is to support GPIOs. To move from GPIO to UART or SPI, you need to configure the software properly. ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Pin allocation www.digiembedded.com SPI connector pins are allocated as shown: Pin Signal 1 +3.3V 2 TXDA/SPI_TXD/GPIO7 3 RXDA/SPI_RXD/GPIO3 4 RTSA#/SPI_CLK/GPIO5 5 DCDA#/SPI_EN#/GPIO0 6 GND 80 Chapter 2 Current Measurement Option .................................................................................. The Current Measurement Option uses 0.025R ohm series resistors to measure the current. The ConnectCore 9P 9215 Development Board allows a user to measure:  the current used by the Development Board and module (through R80), and  the current used by the internal NS9215 1.8V core generated from VLIO using a high-efficiency synchronous step-down converter (through R81) ConnectCore 9P 9215 Development Board Current Measurement Option (CMO) +3.3V development board and module, R80 Current Measurement Option (CMO) +3.3V VLIO for 1.8V core, module only, R81 Current Measurement Option (CMO) +3.3V for module only, R94 How the CMO works To measure the load current used on different power supplies, measure DC voltage across the sense (CMO) resistor. The value of the resistor is 0.025R ± 1%. Calculate the current using this equation: I = U/R where 81  I = current in Amps  U = measured voltage in Volts  R = 0.025 Ohms ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... JTAG Interface .................................................................................. ConnectCore 9P 9215 Development Board JTAG Multi-Ice Connector, X13 www.digiembedded.com 82 Chapter 2 Standard JTAG ARM connector, X13 83 The standard JTAG ARM connector is a 20-pin header and can be used to connect development tools such as Digi’s JTAG Link, ARM’s Multi-ICE, Abatron BDI2000, and others. Pin Signal Pin Signal 1 +3.3V 2 +3.3V 3 TRST# 4 GND 5 TDI 6 GND 7 TMS 8 GND 9 TCK 10 GND 11 RTCK (optional) 12 GND 13 TDO 14 GND 15 SRESET# 16 GND 17 No connect 18 GND 19 No connect 20 GND ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... PoE module connectors - IEEE802.3af .................................................................................. The Development Board has two PoE module connectors, X9 and X26. The PoE module is an optional accessory item that can be plugged on the Development Board through two connectors:  X9, input connector: Provides access to the PoE signals coming from the Ethernet interface.  X26, output connector: Provides the output power supply from the PoE module. Note: The PoE interface is only available for the ConnectCore 9P 9215 module. ConnectCore 9P 9215 Development Board PoE Header, X26 Power Jack, X24 PoE Header, X9 www.digiembedded.com 84 Chapter 2 The 802.3af PoE Application Kit Plug in the 802.3af PoE Application Kit (P/N DG-ACC-POE) at a right angle to the Development Board, as shown in the following drawing: 80 2 .3 a f Po E A pp lic at io n K it C o nnectC o re 9 P 9 2 1 5 De velo pm en t Bo a rd X9 X26 85 PoE input connector pins are allocated as shown: Pin Signal 1 POE_TX_CT 2 POE_RX_CT 3 POE_RJ45_4/5 4 POE_RJ45_7/8 PoE output connector pins are allocated as shown: Pin Signal 1 +12V_PoE 2 +12V_PoE 3 GND 4 GND 5 PoE_GND 6 PoE_GND ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... POE_GND The Development Board provides access to POE_GND allowing it to be turned off when power is provided through the power jack, X26.4 and X26.5. Power Jack, X24 The power jack is a barrel connector with 9-30VDC operating range. The power jack is labeled X24 on the Development Board. The following figure schematically represents the power jack’s polarity. www.digiembedded.com 86 Chapter 2 Ethernet Interface .................................................................................. The module provides the 10/100 Ethernet PHY chip. The Development Board provides the 1:1 transformer and Ethernet connector. The Ethernet connector is an 8-wire RJ-45 jack, labeled X19 on the Development Board. The connector has eight interface pins, as well as two integrated LEDs that provide link status and network activity information. ConnectCore 9P 9215 Development Board Ethernet RJ-45, X19 87 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... RJ-45 pin allocation, X19 LEDs www.digiembedded.com RJ-45 connector pins are allocated as shown: Pin Signal 802.3af End-Span (Mode A) 802.3af Mid-Span (Mode B) 1 TXD+ Negative VPort Transmit data + 2 TXD- Negative VPort Transmit data - 3 RXD+ Positive VPort Receive data + 4 EPWR+ Positive VPort Power from switch + 5 EPWR+ Positive VPort Power from switch + 6 RXD- 7 EPWR- Negative VPort Power from switch - 8 EPWR- Negative VPort Power from switch - Positive VPort Description Receive data - The RJ-45 connector has two LEDs located near the outer lower corners of the connector. These LEDs are not programmable. LED Description Yellow Network activity (speed): Flashing when network traffic detected; Off when no network traffic detected. Green Network link: On indicates an active network link; Off indicates that no network link is present. 88 Chapter 2 WLAN Interface .................................................................................. For the ConnectCore Wi-9P 9215, attach the antenna to the primary connector [X18] and the secondary connector [X17] on the Development Board (see the figure below for details). ConnectCore 9P 9215 Development Board Primary Antenna Connector, X18 Secondary Antenna Connector, X17 89 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... WWAN Interface .................................................................................. For the ConnectCore 3G 9P 9215, attach the cellular antenna to the primary connector [J6] and the GPS antenna to the secondary connector [J7]. ConnectCore 9P 9215 Development Board Cellular Primary, J6 Cellular Secondary, J7 www.digiembedded.com 90 Chapter 2 ConnectCore 3G 9P 9215 Module X30, U.FL connector with decoupled connection to X29 for secondary (AUX)/GPS antenna X29, U.FL connector with 3.3V for active GPS antenna J2, SMA to U.FL adapter (U.FL connector is on the back side of the SMA connector) for primary antenna connection P1, PCIe connector for the cellular module Dual SIM socket SIM Installation If you have not done so already, insert your SIM card(s) as shown (GSM/GPRS networks only): a Insert primary SIM into the lower SIM slot b Insert secondary SIM card (if applicable) SIM slots Note: 91 The correct orientation for the SIMs is notched-side out, SIM cards are not included in your Digi JumpStart Kit®. ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Peripheral (Expansion) Headers .................................................................................. ConnectCore 9P 9215 Development Board Peripheral Application Header, X33 The Development Board provides one, 2x25-pin, 0.10” (2.54mm) pitch header for supporting application-specific daughter cards/expansion boards:  www.digiembedded.com X33, Peripheral application header: Provides access to an 16-bit data bus, 10bit address bus, and control signals (such as CE#, IRQ#, WE#), as well as I2C and power (+3.3V). Using these signals, you can connect Digi-specific extension modules or your own daughter card to the module’s address/data bus. 92 Chapter 2 Peripheral application header, X33 Peripheral application pins are allocated as shown: Pin Signal Pin Signal 1 GND 2 BDO 3 BD1 4 BD2 5 BD3 6 GND 7 BD4 8 BD5 9 BD6 10 BD7 11 GND 12 BD8 13 BD9 14 BD10 15 BD11 16 GND 17 BD12 18 BD13 19 BD14 20 BD15 21 GND 22 * 8-bit / 16-bit# GND selects 16-bit data bus 93 23 GND 24 +3.3V 25 +3.3V 26 BA0 27 BA1 28 BA2 29 BA3 30 GND 31 BA4 32 BA5 33 BA6 34 BA7 35 GND 36 BA8 37 BA9 38 GND 39 EXT_CSO# 40 I2C_SDA/GPIO103 41 EXT_WE# 42 EXT_OE# 43 I2C_SCL/GPIO102 44 EIRQ3/GPIO101 45 +3.3V 46 +3.3V 47 GPIO86 48 GPIO87 49 EXT_CLK 50 GND ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... Module and Test Connectors .................................................................................. The ConnectCore 9P 9215 Family of modules plug into the module connectors X1 and X2 on the Development Board. ConnectCore 9P 9215 Development Board Test Connector, X10, X11 Module Connector X1 Module Connector X2 Test Connector, X20, X21 Module connectors See “Module pinout” on page 41 for related information. Test connectors The Development Board provides two 4x20 pin test connectors, labeled X10/X11 and X20/X21. These connectors are 1:1 copies of the module pins and are used for measurement or test purposes. www.digiembedded.com  X10 and X11 correspond to module connector X1.  X20 and X21 correspond to module connector X2. 94 Chapter 2 X10 pinout X10 pin Signal X10 pin Signal A1 GND B1 GND A2 RSTOUT# B2 TCK A3 TDO B3 TRST# A4 LITTLE#/BIG_ENDIAN B4 WLAN_DISABLE# A5 SW_CONF2 B5 SW_CONF3 A6 BD0 B6 BD1 A7 BD4 B7 BD5 A8 BD8 B8 BD9 A9 BD12 B9 BD13 A10 GND B10 BA0 A11 BA3 B11 BA4 A12 BA7 B12 BA8 A13 BA11 B13 BA12 A14 BA15 B14 BA16 A15 EXT_WE# B15 EXT_CS0# A16 BE3# B16 EXT_WAIT# A17 NC B17 NC A18 NC B18 NC A19 B19 A20 B20 VBAT *USB and Etherent signals are not connected to this connector due to signal quality. 95 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... X11 pinout X11 pin Signal X11 pin Signal C1 RSTIN# D1 SRESET# C2 TMS D2 TDI C3 RTCK D3 OCD_EN# C4 SW_CONF0 D4 SW_CONF1 C5 WLAN_LED# (CC Wi-9P 9215) D5 GND C6 BD2 D6 BD3 C7 BD6 D7 BD7 C8 BD10 D8 BD11 C9 BD14 D9 BD15 C10 BA1 D10 BA2 C11 BA5 D11 BA6 C12 BA9 D12 BA10 C13 BA13 D13 BA14 C14 GND D14 EXT_OE# C15 EXT_CS2# D15 BE2# C16 EXT_CLK D16 GND C17 NC D17 NC C18 GND D18 C19 C20 D19 3.3V D20 GND *USB and Etherent signals are not connected to this connector due to signal quality. www.digiembedded.com 96 Chapter 2 X20 pinout 97 X20 pin Signal X20 pin Signal A1 GND B1 GND A2 DSRA#/GPIO2 B2 RXDA/SPI_RXD/GPIO3 A3 DTRA#/GPIO6 B3 TXDA/SPI_TXD/GPIO7 A4 DSRC#/GPIO10 B4 RXDC/GPIO11 A5 DTRC#/TXCLKC/GPIO14 B5 TXDC/GPIO15 A6 DSRB#/GPIO53 B6 RXDB/GPIO54 A7 DTRB#/GPIO57 B7 TXDB/GPIO58 A8 DSRD#/GPIO61 B8 RXDD/GPIO62 A9 DTRD#/GPIO65 B9 TXDD/GPIO66 A10 GPIO69 B10 GPIO70 A11 GPIO73 B11 GPIO74 A12 GPIO77 B12 GPIO78 A13 USER_BUTTON1#/GPIO81 B13 USER_LED1#/GPIO82 A14 USER_LED2#/GPIO85 B14 GPIO86 A15 GPIO94 B15 GPIO95 A16 CAN1_RXD/GPIO98 B16 CAN1_TXD/GPIO99 A17 I2C_SCL/GPIO102 B17 12C_SDA/GPIO103 A18 ADC_IN2 B18 ADC_IN3 A19 ADC_IN6 B19 ADC_IN7 A20 +3.3V B20 +3.3V ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference ..... X21 pinout www.digiembedded.com X21 pin Signal X21 pin Signal C1 DCDA#/SPI_EN/GPIO0 D1 CTSA#/GPIO1 C2 RIA#/EIRO2/GPIO4 D2 RTSA#/SPI_CLK/GPIO5 C3 DCDC#/TXCLKC/GPIO8 D3 CTSC#/GPIO9 C4 RIC#/RXCLKC/GPIO12 D4 RTSC#/RCLKC/GPIO13 C5 DCDB#/GPIO51 D5 CTSB#/GPIO52 C6 RIB#/GPIO55 D6 RTSB#/GPIO56 C7 DCDD#/GPIO59 D7 CTSD#/GPIO60 C8 RID#/GPIO63 D8 RTSD#/GPIO64 C9 GPIO67 D9 GPIO68 C10 GPIO71 D10 GPIO72 C11 GPIO75 D11 GPIO76 C12 GPIO79 D12 GPIO80 C13 GPIO83 D13 USER_BUTTON2#/GPIO84 C14 GPIO87 D14 GPIO93 C15 CAN0_RXD/GPIO96 D15 CAN0_TXD/GPIO97 C16 GPIO100 D16 EIR03#/GPIO101 C17 ADC_IN0 D17 ADC_IN1 C18 ADC_IN4 D18 ADC_IN5 C19 AGND_ADC D19 VREF_ADC C20 GND D20 GND 98 Chapter 2 99 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference Appendix A:Specifications T his appendix provides environmental, mechanical, safety and power information for the ConnectCore 9P 9215 Family of modules. Mechanical Information .................................................................................. ConnectCore 9P 9215 The module size is 50 x 50mm. Two board-to-board connectors are used on the module. The distance between the module and the Development Board depends on the counterpart on the Development Board; the minimum distance is 5mm. The height of the parts mounted on the bottom side of the module does not exceed 2.5mm. The height of the parts mounted on the top side of the module does not exceed 2.5mm if X3 is not populated, or 14 mm if X3 is populated. ConnectCore Wi-9P 9215 The module size is 50 x 70mm. Two board-to-board connectors are used on the module. The distance between the module and the Development Board depends on the counterpart on the Development Board; the minimum distance is 5mm. The height of the parts mounted on the bottom side of the module does not exceed 2.5mm. The height of the parts mounted on the top side of the modules does not exceed 5mm if X3 is not populated, or 14 mm if X3 is populated. 99 ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference A ConnectCore 3G 9P 9215 The module size is 50 x 70mm. Two board-to-board connectors are used on the module. The distance between the module and the Development Board depends on the counterpart on the Development Board; the minimum distance is 5mm. The height of the parts mounted on the bottom side of the module does not exceed 2.5mm. The height of the parts mounted on the top side of the modules does not exceed 10mm including the cellular module. Network Interface .................................................................................. Ethernet WLAN Interface  Standard: IEEE 802.3  Physical layer: 10/100Base-T  Data rate: 10/100 Mbps  Mode: Full or half duplex Note:  Standard: IEEE802.11a/b/g  Frequency: 2.412GHz - 5.875GHz  Data Rates Supported –    Carrier-Sense Multiple Access with Collision Avoidance (CSMA/CA) Wireless Medium – 802.11b/g: Direct Sequence-Spread Spectrum (DSSS) and Orthogonal Frequency Divisional Multiplexing (OFDM) – 802.11a: OFDM DFS Client –  1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, 54 Mbps Media Access Protocol – www.digiembedded.com This WLAN Interface information applies to the ConnectCore Wi-9P 9215 module only. This module supports the DFS Client only between the 5.25 and 5.35GHz bands. It does not support being a DFS Master, nor can it be connected to an ad hoc network in these bands. Modulation DSSS – Differential Binary Phase Shift Keying (DBPSK) @ 1 Mbps – Differential Quadrature Phase Shift Keying (DQPSK) @ 2 Mbps 100 .....     101 – Complementary Code Keying (CCK) @ 5.5 and 11 Mbps OFDM – BPSK @ 6 and 9 Mbps – QPSK @ 12 and 18 Mbps – 16-Quadrature Amplitude Modulation (QAM) @ 24 and 36 Mbps – 64-QAM @ 48 and 54 Mbps Frequency Bands – 2.412 to 2.472 GHz (ETSI) – 2.412 to 2.462 GHz (FCC) – 5.150 to 5.250 GHz (ETSI) – 5.250 to 5.350 GHz (ETSI) excluding TPC and DFS Client – 5.470 to 5.725 GHz (ETSI) excluding TPC and DFS Client – 5.725 to 5.875 GHz (ETSI) excluding TPC and DFS Client – 5.15 to 5.350 GHz (FCC UNII1 and UNII2) – 5.470 to 5.725 GHz – 5.725 to 5.850 GHz (FCC) Receive Sensitivity 802.11a (typical @ 25°C CH 5200 5500 5785 6 Mbps -85 -85 -85 54 Mbps -65 -65 -65 Receive Sensitivity 802.11g (typical 25°C) – -84 dBm @ 6 Mbps – -81 dBm @ 9 Mbps – -80 dBm @ 12 Mbps – -80 dBm @ 18 Mbps – -78 dBm @ 24 Mbps – -76 dBm @ 36 Mbps – -70 dBm @ 48 Mbps – -68 dBm @ 54 Mbps Receive Sensitivity 802.11b (typical 25°C) – -86 dBm @ 1 Mbps – -86 dBm @ 2 Mbps – -84 dBm @ 5.5 Mbps – -80 dBm @ 11 Mbps ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference A  Available Transmit Power Settings (Maximum power setting will vary according to individual country regulations). Typical ( ± 2 dBm) 25°C 802.11b/g: – 14 dBm (~25 mW) @ 1, 2, 5.5, and 11 Mbps – 12 dBm (~16 mW) @ 6,12, 18, 24, 36, 48, and 54 Mbps – 6 dBm (~4 mW) @ 6,12, 18, 24, 36, 48, and 54 Mbps 802.11a: – Note:  WWAN Interface During manufacturing, EVM values are verified up to -23 dBm rms for band A. Available Transmit Power Settings (Typical ( ± 2 dBm) @ 25°C) Note:  6 dBm for all channels Maximum power setting will vary according to individual country regulations. Connector: 2 x U.FL Note: Please use the HIROSE U.FL-LP-N-2 extraction tool for removing a U.FL cable from the ConnectCore Wi-9P 9215 or ConnectCore 3G 9P 9215 modules. Note: This WWAN Interface information applies to the ConnectCore 3G 9P 9215 module only. 2G/3G cellular connectivity based on Qualcomm Gobi 3000: Technology Bands 1xEV-DO Rev A BC0 - 800 MHz - US cell 1xRTT Rev 0 BC1 - 1900MHz - US PCS BC4 - 1800 MHz - KPCS BC6 - 2100 MHz - IMT UMTS/HSDPA/HSUPA B9 - 1700 MHz - Japan 1700 MHz B8 - 900 MHz B6 - 900 MHz - Japan 800 MHz B4 - 1700/2100 - AWS B5 - 850 MHz - US Cell B3 - 1800 MHz - KPCS B2 - 1900 MHz - US PCS www.digiembedded.com 102 ..... Technology Bands GSM/GPRS/EDGE 850 MHz 900 MHz 1800 MHz 1900 MHz Simultaneous GPS Note: D = Rx diversity supported X = band class supported without Rx diversity blank = band class not supported Supported Data Rates: Gobi Operating Mode 103 Peak FL Data Rate Peak RL Data Rate CDMA 1xRTT 153 kbps 153 kbps CDMA 1xEV-DO 3.1 Mbps 1.8 Mbps WCDMA 384 kbps 384 kbps HSDPA/HSUPA 7.2 Mbps 2.0 Mbps GSM 14.1 kbps 14.1 kbps GPRS 115 kbps 115 kbps EDGE 384 kbps 384 kbps ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference A Environmental Information .................................................................................. The module board assemblies meet all functional requirements when operating in the environments provided below. Note: Please refer to the thermal specifications in this manual for additional information about operating temperature conditions ConnectCore 9P 9215  Operating temperature: -40°C to +85°C max  Storage temperature: -40°C to +125°C  Relative humidity: 5% to 95%, non-condensing  Altitude: 0 to 12,000 feet ConnectCore Wi-9P 9215 & ConnectCore 3G 9P 9215 www.digiembedded.com  Operating temperature: -40°C to +85°C max  Storage temperature: -40°C to +125°C  Relative humidity: 5% to 95%, non-condensing  Altitude: 0 to 12,000 feet  Qualcomm Gobi3000 operating temperature: -30°C to +70°C  Qualcomm Gobi3000 storage temperature: -55°C to +100°C  Qualcomm Gobi3000 relative humidity: 10% to 90%, non-condensing 104 ..... Thermal Specifications .................................................................................. The table below shows the specific standard operating temperature ranges for the entire ConnectCore 9P 9215 Family of embedded core modules. Standard Operating Temperature Ranges Product Operating Temperature Range ConnectCore 9P 9215 -40 to +85°C ConnectCore Wi-9P 9215 -40 to +65°C @ 100% Duty Cycle (WLAN) -40 to +85°C @ 33% Duty Cycle (WLAN) ConnectCore 3G 9P 9215 -30 to +70°C The lower standard operating temperature range is specified without restrictions, except condensation must not occur. The upper operating temperature limit depends on the host PCB layout and surrounding environmental conditions. To simplify the customer's design process, a maximum component case temperature has been specified. Maximum Component Case Temperature 105 Product Component Maximum Case Temperature ConnectCore 9P 9215 U1 120°C ConnectCore Wi-9P 9215 U16 95°C ConnectCore 3G 9P 9215 U1 120°C ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference A The maximum component case temperature must remain below the maximum, measured at the locations shown in the figure below. ConnectCore Wi-9P 9215 Module ConnectCore 3G 9P 9215 Module Measure Tcase of U1 www.digiembedded.com 106 ..... When attaching thermocouples, please abide by the following guidelines:  Carefully remove any labels or other foreign material from the component.  Ensure an adhesive with high thermal conductivity is used. Use as little adhesive as possible.  Make sure the thermocouple is touching the case of the component and not "floating" in the adhesive.  The use of precision, fine-wire K-type thermocouples is strongly recommended – Additional design suggestions 107 Omega Engineering P/N 5TC-TT-K-36-72, or similar The following list provides additional design guidance with respect to thermal management in applications with operating temperatures at the high end or beyond the specified standard ambient temperature range.  Providing air movement will improve heat dissipation.  The host PCB plays a large part in dissipating the heat generated by the module. A large copper plane located will improve the heat dissipation capabilities of the PCB.  If the design allows, added buried PCB planes will also improve heat dissipation. The copper planes create a larger surface to spread the heat into the surrounding environment. ConnectCore 9P 9215, Wi-9P 9215 and 3G 9P 9215 Hardware Reference A Safety Statements .................................................................................. To avoid contact with electrical current: www.digiembedded.com  Never install electrical wiring during an electrical storm.  Use a screwdriver and other tools with insulated handles.  Wear safety glasses or goggles.  Installation of inside wiring may bring you close to electrical wire, conduit, terminals, and other electrical facilities. Extreme caution must be used to avoid electrical shock from such facilities. Avoid contact with all such facilities.  Protectors and grounding wire placed by the service provider must not be connected to, removed, or modified by the customer.  Do not touch or move the antenna(s) while the unit is transmitting or receiving.  Do not hold any component containing a radio such that the antenna is very close to or touching any exposed parts of the body, especially the face or eyes, while transmitting.  Do not operate a portable transmitter near unshielded blasting caps or in an explosive environment unless it is a type especially qualified for such use.  Any external communications wiring you may install needs to be constructed to all relevant electrical codes. In the United States, this is the National Electrical Code Article 800. Contact a licensed electrician for details. 108 ..... Power Requirements .................................................................................. ConnectCore 9P 9215 Parameter Limits Input voltage (Vcc) 3.3V±10% (3.00V to 3.60V) Input current 660mA max Input low voltage 0.0V
DG-ANT-20DP-BG-B 价格&库存
很抱歉,暂时无法提供与“DG-ANT-20DP-BG-B”相匹配的价格&库存,您可以联系我们找货
