VHP69273W22G-518A
VHP69273W22G-518A
    LAIRD(莱尔德)
    829MHz, 1.575GHz, 2.2GHz, 2.5GHz, 5.4GHz GPS, LTE, Wi-Fi Dome RF Antenna 698MHz ~ 960MHz, 1.572GHz ~...
VHP69273W22G-518A 数据手册
Vehicular 5-Port MIMO Antenna VHP69273x22G 698-960 / 1710-2700 / 2300-2700 / 4900-5900 MHz + GPS MIMO ANTENNA The Laird vehicular 5-port MIMO antenna covers the 698-960 / 1710-2700 MHz, 2300-2700 / 4900-5900 MHz as well as GPS (1575.42 MHz) frequency ranges. Configured with 4-port, dual-band elements in addition to 1-port with integrated GPS. Connector options include SMA male connectors for 3G/4G LTE and GPS ports with an RPSMA male connector for the WiFi port. The housing incorporates a low-profile, rugged design that meets IP67 standards. The antenna also features high impact, UV-resistant polycarbonate plastic available in black or white. SPECIFICATIONS PARAMETER Model Number PERFORMANCE VHP69273B22G-518A (Black) VHP69273W22G-518A (White) 5 (2-ports 3G/4G LTE, 2-ports WiFi, 1-port GPS) 3G/4G Port WiFi Port No. of Ports Patent Pending VHP96273x22G Frequency Bands (MHz) Peak Gain * dBi 698-960 MHz 1710-2700 MHz 2300-2700 MHz 4900-5900 MHz 4.1 6.5 5.9 6.2 Max Gain +/- 30 above horizon N/A VSWR* Typical < 1.7:1 VSWR * Max < 2.0:1 Typical Port-to-Port Isolation * 698-960 N/A N/A < 1.6:1 < 1.7:1 6.2 < 1.4:1 < 2.0:1 < 2.0:1 < 2.0:1 1710-2700 2300-2700 4900-5900 > 26 dB > 31 dB > 29 dB LTE 1-to-LTE 2 LTE 1-to-WiFi 1 > 27 dB > 18 dB > 28 dB > 20 dB LTE 1-to-WiFi 2 > 26 dB > 23 dB > 23 dB > 28 dB LTE 2-to-WiFi 1 LTE 2-to-WiFi 2 WiFi 1-to-WiFi 2 Nominal Impedance Polarization Azimuth Beam Width Input Power, Max Operating Temperature Dimensions (dia. x hgt) Weight RF Connector Cable (exposed length) Radome / Baseplate Material Material Compliance IP Dust & Water Ingress Rating > 14 dB N/A > 27 dB > 23 dB > 23 dB > 26 dB > 18 dB > 20 dB > 33 dB N/A N/A > 21 dB > 29 dB 50 Ω Vertical Linear Omnidirectional 50 watts (ambient temp of 25°C/ 77°F) -30° C - +70° C (-22°F to +158°F) 132 mm x 87 mm (5.2" x 3.4") Approximately 1.16kg (2.56lbs) SMA-Male (3G/4G LTE port) RPSMA-Male (WiFi port) LMR195M- 518.2 cm (17 ft) PC, UL94 - V0 Rating, UV Stable (Black & White) ROHS compliant IP67 *Measured on 1 ft. (30.48 cm) diameter ground plane Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Vehicular 5-Port MIMO Antenna VHP69273x22G GPS ANTENNA SPECIFICATIONS PERFORMANCE PARAMETER Frequency Band 1575.42 MHz (GPS L1) Band Width 6 MHz (Typical) 27 dB ± 3 dBc Amplier Gain 50 Ω Nominal Impedance < 1.5:1 Output VSWR DC Voltage 2.7 - 12 Vdc 20 mA (Nominal); < 30 mA ( -40°C - +85°C) DC Current > 40 dB rejection @ ± 50 MHz from center frequency Out-of-Band Signal Rejection Intermodulation@ CW Mode (-40°C - +85°C) Int1 Int2 IM3 Power, dBm -10(1842.8 MHz) -10(2110 MHz) Power, dBm -10(829.58 MHz) -10(2405 MHz) -100(1575.6 MHz) -100(1575.42 MHz) Power, dBm -10(755.42 MHz) -10(820 MHz) -100(1575.42 MHz) Input 1 dB Compression @ 750 MHz, 2000 MHz & 3500 MHz RF Connector Cable (exposed length) > 10 dBm (-40°C - +85°C) SMA-Male RG174-518.2 cm (17ft) PART NUMBERS PART NUMBER VHP69273B22G-518A 2-Ports 4G/LTE, 1-Port GPS: SMA Male; 2 Ports WiFi:RPSMA Male(Black) VHP69273W22G-518A 2-Ports 4G/LTE, 1-Port GPS: SMA Male; 2 Ports WiFi:RPSMA Male(White) ANT-DS-VHP69273x22G 0815 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
VHP69273W22G-518A
物料型号: - VHP69273B22G-518A(黑色) - VHP69273W22G-518A(白色)
器件简介: Laird的车载5端口MIMO天线覆盖698-960 / 1710-2700 / 2300-2700 / 4900-5900 MHz和GPS(1575.42 MHz)频段。配置了4端口双频段元件和1端口集成GPS。
引脚分配: - 3G/4G LTE端口:SMA公头连接器 - WiFi端口:RP-SMA公头连接器
参数特性: - 频率范围:698-960 MHz,1710-2700 MHz,2300-2700 MHz,4900-5900 MHz - 增益:LTE端口3G/4G的增益为4.1 dBi,WiFi端口的增益为5.9 dBi - 典型VSWR:LTE端口小于1.7:1,WiFi端口小于1.6:1 - 端口间隔离:LTE 1至LTE 2端口间隔离大于14 dB,LTE 1至WiFi 1端口间隔离大于27 dB
功能详解: - 天线具有全向辐射模式,垂直线性极化,可承受最大输入功率50瓦(在25°C环境温度下) - 工作温度范围:-30°C至+70°C - 尺寸:直径132毫米,高度87毫米 - 重量:约1.16公斤 - 射频连接器:SMA-Male(3G/4G LTE端口),RP-SMA-Male(WiFi端口) - 电缆(暴露长度):LMR195M,长度518.2厘米
应用信息: - 适用于3G/4G LTE和WiFi信号的接收和发送,集成GPS功能,适用于车辆安装
封装信息: - 材料:PC,符合ROHS标准,具有UV稳定性(黑色和白色) - IP等级:IP67 - 尺寸和重量:132毫米×87毫米,约1.16公斤
VHP69273W22G-518A 价格&库存
很抱歉,暂时无法提供与“VHP69273W22G-518A”相匹配的价格&库存,您可以联系我们找货
