PDQ24499
2400 to 2500 MHz/4900 to 5950 MHz
4-port MIMO Directional Antenna
4-PORT MIMO DUAL-BAND, DUAL POLARIZED DIRECTIONAL ANTENNA
The Laird patent pending PDQ24499 antenna is a 4-port dual-band, dual polarized directional panel
antenna for use in 802.11n MIMO indoor and outdoor applications. The antenna is an excellent
choice for high density Wi-Fi applications where adjacent interference is of concern. The dual-band
frequency coverage means that a single type of antenna can be deployed with any MIMO radio in
the 2400-2500 MHz and 4900-5950 MHz bands. In addition, the uniform and symmetrical radiation
patterns will provide a high-level signal density into engineered coverage areas.
Patent Pending PDQ24499
FEATURES
MARKETS / APPLICATIONS
Ultra thin, compact ASA UV stable white housing.
Four radiating elements optimized for indoor &
outdoor 802.11n or 802.11ac MIMO applications.
Articulating arm mount can anchored directly
to a vertical surface or mast mounted and
oriented for optimal signal radiation.
Both horizontal & vertical polarization for
multipath mitigation.
IP67 Rated and RoHS compliant.
High density WiFi
Sports Entertainment - outdoor stadiums,
arenas & convention centers
Hospitality – hotels & casinos
Transportation – airport, bus, & train terminals
Retail – stores & indoor pedestrian malls
Education – libraries & museums
PARAMETERS
SPECIFICATIONS
Number of Ports
Four (4)
Frequency Bands, MHz
2400-2500
4900-5950
Peak Gain, Typical dBi
8.2
8.3
Peak Gain, Max dBi
8.6
9.4
Max Gain ± 30o above Horizon, dBi
N/A
7.4
Azimuth 3 dB Beamwidth, Typ (V-pol/H-pol)
75°/62°
62°/57°
Elevation 3 dB Beamwidth, Typ (V-pol/H-pol)
62°/73°
50°/65°
VSWR, Typical
< 1.6:1
< 1.8:1
VSWR, Max
< 2.0:1
< 2.0:1
Port-to-Port Isolation, Typical
> 34 dB
> 34 dB
Port-to-Port Isolation, Maximum
> 30 dB
Nominal Impedance
Polarization
Standard Articulating Mount
2-Ports Vertical, 2-Ports Horizontal
Front-to-Back Ratio
> 15 dB
Maximum Input Power (per port)
10 W (ambient temp of 25°C/77°F)
Dimensions
254 x 254 x 41 mm (10” x 10” x 1.6”)
Weight (without mount)
1.14 kg (2.50 lbs)
Mounting
Articulating Mount, Mast or Flush Mount
Cable Type
Low Temperature Plenum Rated Cable
Wind Survival
200 km/h (125 mph)
Wind Gust Survival
266 km/h (165 mph)
Ingress Protection
Americas: +1.847 839.6925
IAS-AmericasEastSales@lairdtech.com
IP67
Operating Temperature
-30°C to +70°C (-22°F to +158°F)
Storage Temperature
-40°C to +85°C (-40°F to +185°F)
Radome/Baseplate Material
Polycarbonate, UL94-V0, UV Stable White
Material Compliance
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
PART NUMBER
Asia: +86.215855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
> 30 dB
50Ω
RoHS Compliant
CABLE LENGTH
CONNECTOR
PDQ24499-FNF
N/A
4x- Fixed Type N-female
PDQ24499-91NF
Dual- 91 cm (3.00 ft)
4x- Type N- female
PDQ24499-91NM
4x- Type N- male
PDQ24499
RADIATION PATTERNS
2400 MHz
Azimuth Radiation Pattern
330
300
270
Elevation Plane
Azimuth Plane
10
5
-10
-15
-20
-25
-30
2450 MHz
Elevation Radiation Pattern
30
300
60
90
240
270
30
300
90
270
120
210
150
330
60
240
120
210
10
5
-10
-15
-20
-25
-30
10
5
-10
-15
-20
-25
-30
150
330
300
270
10
5
-10
-15
-20
-25
-30
330
300
90
240
270
120
210
10
5
-10
-15
-20
-25
-30
330
30
300
60
90
270
10
5
-10
-15
-20
-25
-30
300
270
30
60
240
210
150
180
270
120
10
5
-10
-15
-20
-25
-30
60
90
240
150
120
210
150
180
5950 MHz
330
300
120
300
90
210
150
330
180
150
Elevation Plane
240
Elevation Plane
60
120
30
90
Azimuth Plane
Azimuth Plane
10
5
-10
-15
-20
-25
-30
60
180
5400 MHz
330
30
210
150
120
180
180
240
150
10
5
-10
-15
-20
-25
-30
4900 MHz
270
120
Elevation Plane
30
300
90
210
Azimuth Plane
330
60
2500 MHz
Elevation Plane
30
240
180
180
Azimuth Plane
270
10
5
-10
-15
-20
-25
-30
330
60
300
90
240
120
210
150
180
Elevation Plane
Azimuth Plane
270
10
5
-10
-15
-20
-25
-30
30
300
60
90
240
120
210
150
180
270
10
5
-10
-15
-20
-25
-30
60
90
240
120
210
150
180
Laird warrants to the original end user customer of its products that its products are free from defects in material andworkmanship. Subject to conditions
and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials.
This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end
product may vary but is not to exceed five (5) years from the original date of the end product purchase.
ANT-DS-PDQ24499 0216
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All
Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other
product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“PDQ24499-91FNF”相匹配的价格&库存,您可以联系我们找货
