Laird Technologies - Item # PC18513N, PCS/DCS and 2.4 GHz ISM band Yagi antennas
Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Antennas & Reception Solutions > Vehicular Antennas & Telematics > Cellular Antennas > Dual
Band & Special Applications Antennas > PCS/DCS and 2.4 GHz ISM band Yagi antennas > Item # PC18513N
Cushcraft's PC18513N is a linearly polarized Yagi antenna which provides for reception and transmission of signals
in the 1850-1990 MHz frequency band. The antenna provides a minimum of 13 dBi gain with a nominal 32 by 32
degree half power beamwidth. The PC18513N has a VSWR of 2.0:1 maximum on 50 ohms impedance.
The PC18513N is housed in a rugged, UV stable polycarbonate radome which is weather resistant for outdoor
applications. The PC18513N radome is white in color. The antenna is typically provided with a 12 inch (30 cm)
coaxial cable and type N female connector. The standard antenna mounting adapter is designed for mast or pole
mounting. A variety of custom cable and connector configurations are available.
larger image
larger image
Specifications
Band
DCS
ISM
PCS
Frequency
1850 to 1990 MHz
Gain
13 dBi
Front to Back Ratio
14 dB
3dB Beamwidth, E Plane
35 º
3dB Beamwidth, H Plane
35 º
Radiating Element
Brass
Impedance
50 ohms
http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/pcs-dcs-and-2-4-ghz-ism-ba...
8/8/2012
RF Connector
N (Female)
Weight
很抱歉,暂时无法提供与“PC18513N”相匹配的价格&库存,您可以联系我们找货
