PDQ244915
2400 to 2500 MHz/4900 to 5950 MHz
4-port MIMO Directional Antenna
4‐PORT MIMO DUAL‐BAND, DUAL POLARIZED DIRECTIONAL ANTENNA
The Laird patent pending PDQ244915 antenna is a 4-port dual-band, dual polarized directional antenna for use in
802.11n MIMO indoor and outdoor applications. The antenna is an excellent choice for high density WiFi
applications where adjacent interference is of concern. The dual-band frequency coverage means that a single type
of antenna can be deployed with any MIMO radio in the 2400-2500 MHz and 4900-5950 MHz bands. In addition, the
uniform and symmetrical radiation patterns will provide a high-level signal density into engineered coverage areas.
FEATURES
Ultra thin, compact ASA UV stable white housing
Articulating arm mount can anchored directly
to a vertical surface or mast mounted and
oriented for optimal siganal radiation.
Four radiating elements optimized for
indoor & outdoor 802.11 MIMO applications
Both horizontal & vertical polarization for
multipath mitigation
IP67 Rated and RoHS compliant
Patent Pending
PDQ244915
MARKETS
High density WiFi
Sports Entertainment - outdoor stadiums, arenas
& convention centers
Hospitality – hotels & casinos
Transportation – airport, bus, & train terminals
Retail – stores & indoor pedestrian malls
Education – libraries & museums
PARAMETER
SPECIFICATIONS
Number of Ports
Polarization
Frequency Bands, MHz
2-ports Vertical
2400-2500
10.7
Peak Gain, dBi (Typical)
11.1
Max Gain ± 30o above Horizon, dBi
N/A
4.7
Azimuth Plane 3-dB Beamwidth V-pol, Typical
48o
21o
Azimuth Plane 3-dB Beamwidth H-pol, Typical
50o
21o
Elevation Plane 3-dB Beamwidth V-pol, Typical
48o
Elevation Plane 3-dB Beamwidth H-pol, Typical
47o
18o
20o
VSWR, Typical
< 1.5:1
< 2.0:1
< 2.0:1
< 2.0:1
50 Ω
> 40
> 30
Port-to-Port Isolation, dB (Maximum)
F/B Ratio
Input Power, Max (Ambient Temp)
> 25 dB
10 W (25oC/77oF)
‐30° C to +70° C (-22°F to 158°F)
Storage Temperature
IP Dust & Water Ingress Rating
-40oC to +85oC (-40oF to +185oF)
IP67
Mounting
373.3 x 411.4 x 35.8 mm
Plenum Rated,CMP Rated for Plenum per NFPA 262
1.58 Kg (3.48 lb), 2.28 kg (5.03 lb- w/HDMNT)
Mast (44-57 mm) or Concrete Wall (HDMNT kit)
Radome/Baseplate Material
ASA, White, UV Stable
Material Compliance
Asia: +86.21.5855.0827.127
IAS‐AsiaSales@lairdtech.com
www.lairdtech.com
> 39
> 30
Operating Temperature
Dimensions (length x width x height)
Cable
Weight
Europe: +44.1628.858941
IAS‐EUSales@lairdtech.com
15.0
VSWR, Max
Port-to-Port Isolation, dB (Typical)
Americas: +1.847 839.6925
IAS‐AmericasEastSales@lairdtech.com
13.4
Peak Gain, dBi (Max)
Nominal Impedence
Patent Pending
PDQ244915 w/standard
articulating mount
Four (4)
and
2-ports Horizontal
4900-5950
PART NUMBER
RoHS Compliant
CABLE LENGTH
PDQ244915-91NF
4x- 91 cm (3.0 ft)
PDQ244915-91NM
4x- 91 cm (3.0 ft)
PDQ244915-FNF
N/A
CONNECTOR
4x - Type N-Female
4x - Type N-Male
4x - Type N-Female
Laird warrants to the original end user customer of its products that its products are free from defects in material and
workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products
that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful
lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may
vary but is not to exceed five (5) years from the original date of the end product purchase.
PDQ244915
RADIATION PATTERNS
Azmith Radiation Pattern at 2400 MHz
Azmith Radiation Pattern at 2450 MHz
Azmith Radiation Pattern at 2500 MHz
Elevation Radiation Pattern at 2400 MHz
Elevation Radiation Pattern at 2450 MHz
Elevation Radiation Pattern at 2500 MHz
CLS69273P
PDQ244915
698-960 MHz/1710-2700
MHz
Low Profile /2400 to 2500 MHz/4900 to 5950 MHz
Low PIM Ceiling Mount Antenna
Azmith Radiation Pattern at 4900 MHz
Elevation Radiation Pattern at 4900 MHz
2305 MHz
2507 MHz
Azmith Radiation Pattern at 5500 MHz
Elevation Radiation Pattern at 5500 MHz
2700 MHz
Azmith Radiation Pattern at 5950 MHz
ANT-DS-PDQ244915
1115
ANT-DS-CLS69273 1115
Elevation Radiation Pattern at 5950 MHz
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All
Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other
product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“PDQ244915-91NM”相匹配的价格&库存,您可以联系我们找货
