PAL86518H-FNF
PAL86518H-FNF
    LAIRD(莱尔德)
    910MHz Panel RF Antenna 865MHz ~ 956MHz 8.5dBic Connector, N Female Chassis Mount
PAL86518H-FNF 数据手册
PAL86518H-FNF/PAR86518H-FNF Circular Polarity Wide Band RFID Antenna 865-956 MHZ 8.5 dBic CIRCULAR POLARITY PANEL The Laird PAL86518H-FNF/PAR86518H-FNF antennas are circularly polarized panel antennas that provide reception and transmission of signals in the 865-956 MHz frequency band. Laird’s industry renowned design methodology achieves maximum efficiency and performance across the entire frequency band. Both VSWR and axial ratios are excellent and allow the user to achieve the maximum performance for an antenna of this type. The antenna is housed in a heavy duty radome enclosure that can be directly wall mounted. An optional articulating mount allows either wall or mast mounting. The antenna is offered with a Fix N connector. FEATURES APPLICATIONS • Low profile • Extremely low VSWR and axial ratio • Warehouse • Distribution center • Wide band • Weather and UV resistant radome • Airports and hospitals • Transit terminals • Wide range of connector and cable options • Left hand and right hand CP versions • Conveyer belt • IP 67 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-PAL86518H PAR86518H 0515 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All kind. products All Laird products sold pursuant to theTerms Laird Technologies’ Terms of sale in effect from time to copybe of furnished which will upon be furnished upon request. ©2015 Copyright Laird are soldare pursuant to the Laird and Conditions of and saleConditions in effect from time to time, a copy of time, whicha will request. © Copyright Laird 2013AllLaird Technologies, All Laird RightsTechnologies, Reserved. Laird, the Laird Technologies other markstrade are trademarks or registered trademarks of Laird Technologies, Inc. Rights Reserved.Inc. Laird, theLaird LairdTechnologies, Logo, and other marks are trade Logo, marksand or registered marks of Laird Inc. or an affiliate company thereof. Inc. or product an affiliate thereof.may Other product or service names may be the property third parties. Nothing herein license Laird or any third party intellectual Other or company service names be the property of third parties. Nothing hereinofprovides a license under any provides Laird or aany thirdunder partyany intellectual property rights. property rights.
PAL86518H-FNF
- 物料型号:PAL86518H-FNF/PAR86518H - 器件简介:该天线是圆极化的面板天线,工作在865-956 MHz频段,具有优秀的VSWR和轴比,提供最大效率和性能。 - 引脚分配:文档中未明确提及引脚分配。 - 参数特性: - 频率范围:865-956 MHz - 增益:8.5 dBic - 最大VSWR:1.5:1 - 3 dB波束宽度-方位:65° - 前后比:20 dB - 极化:圆极化右旋或左旋 - 最大输入功率:3瓦特 - 输入阻抗:50欧姆 - 轴比:1 dB - 重量:1.89磅(0.86公斤) - 机械尺寸:10.2" x 10.2" x 1.32" - 天线连接:固定N型 - 雷达罩:高强度聚碳酸酯 - 安装方式:螺纹柱 - 工作温度:-25°C至+70°C - 防雷保护:直流接地 - 环境等级:IP67 - 功能详解:文档中未提供详细的功能解释,但提到了天线的低剖面、极宽的带宽、天气和紫外线抗性雷达罩、多种连接器和电缆选项、左旋和右旋圆极化版本。 - 应用信息:适用于仓库、配送中心、机场、医院、交通枢纽、传送带等。 - 封装信息:雷达罩材料为高强度聚碳酸酯,安装方式为螺纹柱。
PAL86518H-FNF 价格&库存
很抱歉,暂时无法提供与“PAL86518H-FNF”相匹配的价格&库存,您可以联系我们找货
