PDQ244915-91NF
PDQ244915-91NF
    LAIRD(莱尔德)
    2.4GHz, 5.4GHz WLAN Panel RF Antenna 2.4GHz ~ 2.5GHz, 4.9GHz ~ 5.9GHz 15dBi Connector, N Female Brac...
PDQ244915-91NF 数据手册
PDQ244915 2400 to 2500 MHz/4900 to 5950 MHz 4-port MIMO Directional Antenna 4‐PORT MIMO DUAL‐BAND, DUAL POLARIZED DIRECTIONAL ANTENNA The Laird patent pending PDQ244915 antenna is a 4-port dual-band, dual polarized directional antenna for use in 802.11n MIMO indoor and outdoor applications. The antenna is an excellent choice for high density WiFi applications where adjacent interference is of concern. The dual-band frequency coverage means that a single type of antenna can be deployed with any MIMO radio in the 2400-2500 MHz and 4900-5950 MHz bands. In addition, the uniform and symmetrical radiation patterns will provide a high-level signal density into engineered coverage areas. FEATURES     Ultra thin, compact ASA UV stable white housing    Articulating arm mount can anchored directly to a vertical surface or mast mounted and oriented for optimal siganal radiation.    Four radiating elements optimized for indoor & outdoor 802.11 MIMO applications    Both horizontal & vertical polarization for multipath mitigation    IP67 Rated and RoHS compliant Patent Pending  PDQ244915 MARKETS     High density WiFi    Sports Entertainment - outdoor stadiums, arenas     & convention centers Hospitality – hotels & casinos Transportation – airport, bus, & train  terminals Retail – stores & indoor pedestrian malls Education – libraries & museums PARAMETER SPECIFICATIONS Number of Ports   Polarization   Frequency Bands, MHz   2-ports Vertical 2400-2500 10.7  Peak Gain, dBi (Typical)  11.1  Max Gain ± 30o above Horizon, dBi  N/A  4.7  Azimuth Plane 3-dB Beamwidth V-pol, Typical  48o  21o  Azimuth Plane 3-dB Beamwidth H-pol, Typical  50o 21o  Elevation Plane 3-dB Beamwidth V-pol, Typical  48o  Elevation Plane 3-dB Beamwidth H-pol, Typical  47o  18o  20o  VSWR, Typical  < 1.5:1  < 2.0:1  < 2.0:1  < 2.0:1  50 Ω  > 40   > 30   Port-to-Port Isolation, dB (Maximum)  F/B Ratio  Input Power, Max (Ambient Temp)   > 25 dB 10 W (25oC/77oF) ‐30° C to +70° C  (-22°F to 158°F) Storage Temperature  IP Dust & Water Ingress Rating -40oC to +85oC (-40oF to +185oF)  IP67  Mounting 373.3 x 411.4 x 35.8 mm Plenum Rated,CMP Rated for Plenum per NFPA 262 1.58 Kg (3.48 lb), 2.28 kg (5.03 lb- w/HDMNT) Mast (44-57 mm) or Concrete Wall (HDMNT kit) Radome/Baseplate Material  ASA, White, UV Stable  Material Compliance  Asia:  +86.21.5855.0827.127  IAS‐AsiaSales@lairdtech.com  www.lairdtech.com  > 39   > 30  Operating Temperature Dimensions (length x width x height)  Cable  Weight   Europe: +44.1628.858941  IAS‐EUSales@lairdtech.com  15.0  VSWR, Max  Port-to-Port Isolation, dB (Typical)  Americas: +1.847 839.6925  IAS‐AmericasEastSales@lairdtech.com  13.4 Peak Gain, dBi (Max)  Nominal Impedence  Patent Pending  PDQ244915 w/standard articulating mount Four (4)   and 2-ports Horizontal 4900-5950 PART NUMBER RoHS Compliant  CABLE LENGTH PDQ244915-91NF 4x- 91 cm (3.0 ft) PDQ244915-91NM 4x- 91 cm (3.0 ft) PDQ244915-FNF N/A CONNECTOR 4x - Type N-Female 4x - Type N-Male 4x - Type N-Female Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. PDQ244915 2400 to 2500 MHz/4900 to 5950 MHz 4-port MIMO Directional Antenna       RADIATION PATTERNS Azmith Radiation Pattern at 2400 MHz Azmith Radiation Pattern at 2450 MHz Azmith Radiation Pattern at 2500 MHz Elevation Radiation Pattern at 2400 MHz Elevation Radiation Pattern at 2450 MHz Elevation Radiation Pattern at 2500 MHz CLS69273P PDQ244915 698-960 MHz/1710-2700 MHz Low Profile /2400 to 2500 MHz/4900 to 5950 MHz Low PIM Ceiling Mount Antenna 4-port MIMO Directional Antenna Azmith Radiation Pattern at 4900 MHz Elevation Radiation Pattern at 4900 MHz 2305 MHz 2507 MHz Azmith Radiation Pattern at 5500 MHz Elevation Radiation Pattern at 5500 MHz 2700 MHz Azmith Radiation Pattern at 5950 MHz ANT-DS-PDQ244915 1115 ANT-DS-CLS69273 1115 Elevation Radiation Pattern at 5950 MHz Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
PDQ244915-91NF 价格&库存
很抱歉,暂时无法提供与“PDQ244915-91NF”相匹配的价格&库存,您可以联系我们找货
