DCE8658PLFSMF
DCE8658PLFSMF
    LAIRD(莱尔德)
    868MHz Panel RF Antenna 865MHz ~ 870MHz 8.5dBic Connector, SMA Female Chassis Mount
DCE8658PLFSMF 数据手册
RFID HD RooTenna® 10 X 10 Die-Cast Enclosure RFID Antennas DCE ENCLOSURE OFFERS SIX OPTIONS OF INTEGRATED RFID ANTENNAS COVERING 860-960 MHz The RFID HD RooTenna® from Laird Technologies is an innovative antenna system that gives the operator ultimate system flexibility. The Radome is UV resistant ASA plastic, the hardware is stainless steel, and the mounting plate inside for adding electronics is removable and customizable by the user. The die-cast enclosure can be pole or wall mounted. A heavy duty tilt bracket is available for those installations requiring up or down tilt. Eleven (11) engineered knockouts are provided; nine sized for N connectors, and two sized for a cable feed through. This series of antennas is available with a choice of six different circularly polarized UHF antennas integrated into the Radome cover. These antennas cover the standard 902-928 MHz, 865-868 MHz RFID frequencies, as well as a wide band version that covers 865-960 MHz. All are available in a choice of RH and LH circular polarization. These antennas feature very low VSWR, axial ratio, and a fixed SMA connector. ANTENNA PATTERN 345 330 0 15 30 345 345 45 315 FEATURES MARKETS • • • • • • • • • • 11 engineered knockouts IP 67 Rated Rugged and weatherproof Hinged cover for easy maintenance Choice of six high-performance, circularly-polarized antennas Outdoors Loading docks Warehouses Mast mounted Side of building Industrial / wet locations 60 300 75 285 -30 270 -30 -20 -20 -10 -10 dB dB 90 dBi 105 255 120 240 225 135 210 150 195 180 SPECIFICATIONS DCE8658PR / L DCE8658WPR / L Frequency: 902-928 MHz 865-870 MHz 865-960 MHz Gain: 9 dBic 8.5 dBic 8.5 dBic 3 dB Beamwidth 70º x 70º 70º x 70º 65º x 65º Polarization: Right or Left Hand Circular Right or Left Hand Circular Right or Left Hand Circular VSWR:
DCE8658PLFSMF 价格&库存
很抱歉,暂时无法提供与“DCE8658PLFSMF”相匹配的价格&库存,您可以联系我们找货
