ANT-2.4-YG6-N
ANT-2.4-YG6-N
    LINXTECHNOLOGIES(灵思)
    ANTENNA YAGI 2.4GHZ 6-ELEMENT
ANT-2.4-YG6-N 数据手册
ANT-2.4-YG6-N DATA SHEET Product Dimensions Description The YG Series of Yagi antennas are designed for long-distance directional communication and can greatly enhance the performance of RF links. Made of stainless steel and featuring sturdy mast mounts, these rugged antennas are constructed to withstand the stress of long-term use. All antennas are designed for 50-ohm system matches with maximum inputs of 100W. 1.77” (45.0) 0.51” (13.0) *NOTE* Use of these antennas may result in TX and RX emission levels in excess of legal limits. Antenna Depth 1.34” (34.0) RG-8/U Cable Length 17.72” (450.0) Features • • • • • 14.37” (365.0) High gain Stainless steel construction Fully weatherized Rugged & damage-resistant RG-8/U cable with female N connector Electrical Specifications 4.53” (115.0) 2.35” (59.6) • • • • • • • • • • • • Center Freq. Bandwidth Polarization VSWR Impedance F/B Ratio Gain Beamwidth Max. Power Connector Weight Wind Velocity 2.45GHz 83MHz Vertical or horizontal ≤1.5 typ. at center 50 ohms ≥16dB 9.5dBi 50º horizontal, 45º vertical 100W N-style female 1.4lbs (0.65kg) 134.2mph (60m/s) Ordering Information 3.15” (80.0) • ANT-2.4-YG6-N VSWR Graph S11 SWR 1.077 CENTER 2450.000MHz SPAN 200.000MHz Typical VSWR Antenna Factor 159 Ort Lane Merlin, OR 97532 www.antennafactor.com 541-956-0931 (phone) 541-471-6251 (fax) Rev 12-21-09
ANT-2.4-YG6-N 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-YG6-N”相匹配的价格&库存,您可以联系我们找货
