ANT-916-CN-N
ANT-916-CN-N
    LINXTECHNOLOGIES(灵思)
    ANTENNA CORNER 916MHZ N-CONN
ANT-916-CN-N 数据手册
ANT-916-CN-N DATA SHEET Product Dimensions Description CN Series corner antennas feature a wide >70MHz bandwidth, 25dB frontto-back ratio, high gain and a wide beamwidth. These rugged antennas are constructed to withstand the stress of long-term use. They are designed for 50-ohm system matches with a maximum input of 100W. 6.30” (160.0) 11.81” (300.0) 14.17” (360.0) 8.66” (220.0) *NOTE* Use of these antennas may result in TX and RX emission levels in excess of legal limits. Features • • • • • High gain Stainless steel construction Fully weatherized Rugged & damage-resistant RG-8/U cable with female N connector Electrical Specifications 18.11” (460.0) R 1.97” (50.0) • • • • • • • • • • • • Center Freq. Bandwidth Polarization VSWR Impedance F/B Ratio Gain Beamwidth Max. Power Connector Weight Wind Velocity 916MHz 72MHz Vertical ≤1.5 typ. at center 50 ohms ≥25dB 10.2dBi 58º horizontal, 52º vertical 100W N-style female 2.6lbs (1.2kg) 134.2mph (60m/s) Ordering Information 7.48” (190.0) • ANT-916-CN-N VSWR Graph S11 SWR 1.106 CENTER 916.000MHz SPAN 200.000MHz Typical VSWR Antenna Factor 159 Ort Lane Merlin, OR 97532 www.antennafactor.com 541-956-0931 (phone) 541-471-6251 (fax) Rev 7-25-11
ANT-916-CN-N 价格&库存
很抱歉,暂时无法提供与“ANT-916-CN-N”相匹配的价格&库存,您可以联系我们找货
