AP.25B.07.0052A
AP.25B.07.0052A
    TAOGLASLIMITED
    ANTENNA 16DB EMBEDDED GPS
AP.25B.07.0052A 数据手册
SPECIFICATION Part No. : AP.25B.07.0052A Product Name : 25mm One Stage GPS Active Patch Antenna Module Features : 35mm*35mm*4.50mm (Ground Plane) 52mm Ø1.13 I-PEX MHFI (U.FL) 15dB LNA 1.8V/3.0V/5.0V ROHS Compliant Photo : REVISION STATUS Version Date Page Revision Description Prepared Approved 01 May 11th 2007 All New format TW Product Centre Ronan Quinlan 02 Oct 13th 2009 All Ireland Dermot O'Shea New format Voltage range increased © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 1.0 Introduction Designed for embedded (inside device) integration with GPS receiver modules, the AP.25B combines a 25*25*2mm advanced low profile ceramic patch antenna with a one stage LNA and ultra thin coaxial cable. The Ground Plane size of 35*35mm gives this solution a performance increase in gain of 12dB. It also helps shields the patch antenna from noise. Taoglas active antenna modules utilise XtremeGain™ technology for the highest sensitivity in the industry. The AP.25B has been optimized for telematics, asset tracking, navigation, and remote monitoring applications or simply any GPS device that requires high performance and needs quick, relaible and consistent lock. It has been designed to sit directly above the main board adhered to the underside of the plastic housing. The is a constant Voltage Regulator built into the LNA integrated circuit this allows any device using the AP.25B to benefit from Lower Power Consumption. 2.0 Specification Patch Antenna Frequency 1575.42 ± 1.023MHz 90°: 2.0 dBi Min. Antenna Gain 20°: -5.0 dBi Min Mounted on a 60*60mm Ground Plane Polarization Axialration Patch Dimension RHCP 90°: 4.0 dBi Max. Mounted on a 60*60mm Ground Plane 25mm x 25mm x 2mm LNA Frequency 1575.42 ± 1.023MHz Typ. 15dB ± 2.5dB (+25°C5°C) Gain Output Impedance Noise Figure Output VSWR 50Ω Max 1.5dB (+25°C5°C) Max: 2.2dB (+85°C) 2.0 Max © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com Cable* & Connector RF Cable Coaxial Cable ψ1.13 ± 0.1mm, length 52 ± 3.0mm Connector Ipex MHFI (U.FL) Dimensions Dimensions Weight 35*35*4.50mm 12.3g (typ) Total Specification Frequency Gain 1575.42 ± 5MHz 90°: 17± 4.5dBi Output Impedance Polarization Output VSWR 50Ω RHCP Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 100°C Relative Humidity Input Voltage Current 40% to 95% 1.8V/3.0V/5.0V Max: 5.0V Typ. 3.8mA at 3v © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 3.0 Technical Drawing © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com S21 – Gain – Input Voltage 1.8V Noise Figure Meter – 1.8V © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com S21 – Gain – Input Voltage 3V Noise Figure Meter – 3V © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com S21 – Gain – Input Voltage 5V Noise Figure Meter – 5V © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com
AP.25B.07.0052A 价格&库存
很抱歉,暂时无法提供与“AP.25B.07.0052A”相匹配的价格&库存,您可以联系我们找货
