AP.25C.07.0080A
AP.25C.07.0080A
    TAOGLASLIMITED
    ANTENNA 30DB EMBEDDED GPS
AP.25C.07.0080A 数据手册
AP.25F.07.0078A Specification Part No. AP.25F.07.0078A Product Name 25mm Two Stage GPS Active Patch Antenna Module with front-end Saw Filter Feature Industry leading GPS antenna performance 25mm*25mm*8mm (Ground Plane) 78mm Ø1.13 I-PEX MHFI (U.FL) 28dB LNA Wide Input Voltage 1.8V to 5.5V Low Power Consumption ROHS Compliant SPE-11-8-030/A | page 1 of 11 1. Introduction The AP.25F has been designed specifically for embedded (inside device) integration with GPS receiver modules where there is a GSM transmitter nearby and risk of interference and saturation. The AP.25F combines a 25*25*4mm advanced low profile ceramic patch antenna with a two stage LNA and a front-end SAW filter, with ultra thin coaxial cable. Taoglas active antenna modules utilise XtremeGainTM technology for the highest sensitivity in the industry. The AP.25F consists of 2 functional blocks – the LNA and also the patch antenna. ANTENNA SAW Filter LNA LNA I-PEX + cable The AP.25F has a SAW filter on the front of it. The main use of the AP.25F would be for small devices where the GSM transmitter is close to the GPS antenna, it helps avoid burn-out of the LNA or the module due to interference from the GSM transmitter at out band frequencies. SPE-11-8-030/A | page 2 of 11 2. Specification 2.1 Patch Antenna Parameter Specification Frequency 1575.42 ± 1.023MHz Gain @ Zenith +2.0 dBic Typ. @ Zenith Polarization RHCP Axial Ratio 3.0dB max. @ Zenith Patch Dimension 25*25*4mm 2.2 LNA Parameter Specification Frequency Outer Band Attenuation 1575.42 ± 1.023MHz F0=1575.42MHz F0±30MHz 5dB min. F0±50MHz 20dB min. F0±100MHz Output Impedance 50Ω Output VSWR 2.0 Max Typ. -2dBm Min. -6dBm Pout at 1dB Gain Compression point 25dB min. LNA Gain, Power Consumption and Noise Figure Voltage LNA Gain (Typ) Power Consumption(mA) Typ Noise Figure Typ Min. 1.8V 23dB Min. 3mA - Max. 10mA 2.7dB Typ. 3.0V 28dB Min. 8mA – Max. 20mA 3.0dB Max. 5.5V 30dB Min. 30mA – Max. 40mA 3.7dB 2.3 Cable* & Connector Parameter Specification RF Cable Coaxial Cable Ø1.13 ± 0.1mm, length 80 ± 2.0mm Connector IPEX MHFI (U.FL) SPE-11-8-030/A | page 3 of 11 3. LNA Gain and Out Band Rejection @3.0V Tr1 S21 Log Mag 10.00dB/ Ref -40.00dB (F2) 60.00 >1 1.5754200 GHz 30.649 dB 50.00 40.00 1 30.00 3 20.00 10.00 5 0.000 7 -10.00 2 -20.00 1 4 6 -30.00 -40.00 1 Center 1.57542 GHz IFBW 70 Hz Cg1 Tr1 S21 >1 1.5754200 GHz 30.649 dB Cg1 Tr1 S21 2 1.6054200 GHz -6.7098 dB Cg1 Tr1 S21 3 1.5454200 GHz 24.584 dB Cg1 Tr1 S21 4 1.6254200 GHz -5.6354 dB Cg1 Tr1 S21 5 1.5254200 GHz 8.0734 dB Cg1 Tr1 S21 6 1.6754200 GHz -15.436 dB Cg1 Tr1 S21 7 1.4754200 GHz 1.5714 dB Span 400 MHz 18/20 Cor SPE-11-8-030/A | page 4 of 11 4. LNA Noise Figure @3.0V Mkr1 1.5754 GHz 2.909 dB 30.298 dB 9.000 NFIG Scale/ 1.000 dB 1 -1.000 40.00 1 GAIN Scale/ 5.000 dB -10.00 Center 1.57542 GHz BW 4 MHz Tcold 296.50 K Avgs 16 Points 11 Att 0/ - - dB Span 3.00 MHz Loss Off Corr 5. Total Specification (through Antenna, LNA, Cable and Connector) Parameter Specification Frequency 1575.42 ± 1.023MHz Gain At 3V: 30 ± 3dBic @ 90° Output Impedance 50Ω Polarization RHCP Output VSWR Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% Input Voltage Min. 1.8V, Typ. 3.0V, Max. 5V Antenna 25*25*8mm SPE-11-8-030/A | page 5 of 11 6. Radiation Patterns 6.1 XZ Plane Radiation 0 8 5 0 -5 -10 -15 -20 -25 -30 -35 -40 90 270 180 Pattern 1 Model No. AP.25F.07.0078A Test Mode Freq (MHz) Max Gain(dBi) Min Gain(dBi) XZ 1610.00 0.59 / 6.00 -14.77 / 134.00 Avg. Gain(dBi) Source Polar. -4.16 RHCP SPE-11-8-030/A | Date 2010/4/19 page 6 of 11 6.2 YZ Plane Radiation 0 8 5 0 -5 -10 -15 -20 -25 -30 -35 -40 90 270 180 Pattern 1 Model No. AP.25F.07.0078A Test Mode Freq (MHz) Max Gain(dBi) Min Gain(dBi) YZ 1610.00 0.17 / 356.97 -14.85 / 121.35 Avg. Gain(dBi) Source Polar. -4.75 RHCP SPE-11-8-030/A | Date 2010/4/19 page 7 of 11 6.3 XY Plane Radiation 0 8 5 0 -5 -10 -15 -20 -25 -30 -35 -40 90 270 180 Pattern Model No. Test Mode Freq (MHz) Max Gain(dBi) Min Gain(dBi) Avg. Gain(dBi) Source Polar. Date 1 AP.25F.07.0078A XZ 1610.00 0.59 / 6.00 -14.77 / 134.00 -4.16 RHCP 2010/4/19 2 AP.25F.07.0078A YZ 1610.00 0.17 / 356.97 -14.85 / 121.35 -4.75 RHCP 2010/4/19 SPE-11-8-030/A | page 8 of 11 7. Technical Drawing A ALL Initial Design A Kiwi ALL Initial Design 2011/7/11 Kiwi 2011/7/11 Connector IPEX MHF1 Connector IPEX MHF1 Top Top Side Side Bottom Name Name 1 Patch(25*25*4mm) 2 1.13 Coaxial Cable 1 Patch(25*25*4mm) 2 1.13 Coaxial Cable 3 IPEX MHF1 3 IPEX MHF1 4 PCB 4 PCB Shielding Case 5 Shielding Case 5 "A" Bottom "A" Material Material Name Finish QTY Finish QTY Finish Material QTY Ceramic Clear 1 NOTE: 1 Ceramic Patch(25*25*4mm)Clear Ceramic 1 Clear 1 NOTE: 1.Soldered area NOTE: FEP 1 Gray 1.Soldered area 2.All material must RoHS compliant. Soldered area 2 FEP 1.13 Coaxial Cable Gray FEP 1 1.be Gray 1 Brass Gold 1 2.Allhas material 3.The connector orientation a fixedmust be RoHS compliant. 2. All material must be RoHS compliant. 3 IPEX MHF1 Brass Gold connector position to the1antenna3.The as per drawing. orientation has a fixed Brass Gold Green 1 1 FR4 0.8t 3. The connector a fixed position to the orientation antenna as perhas drawing. Green 1 4 PCB FR4 0.8t Tin Plated 1 1 position to the antenna as per drawing. FR4(Tin)SPTE 0.8t Green 5 Shielding Case Tin Plated 1 (Tin)SPTE (Tin)SPTE Tin Plated 1 TW Design Centre This drawing and its inherent design concepts are property of Taoglas. Not to TW Design Centre be copied or given to third parties without the written consent of Taoglas. This drawing and its inherent design concepts are property of Taoglas. Not to be copied or given to third parties without the written consent of Taoglas. SPE-11-8-030/A | page 9 of 11 8. Plugs Usage Precautions 8.1 Mating / unmating (1) To disconnect connectors, insert the end portion of I-PEX under the connector flanges and pull off vertically, in the direction of the connector mating axis. Coaxial Cable (2) To mate the connectors, the mating axes of both connectors must be aligned and the connectors can be mated. The “click” will confirm fully mated connection. Do not attempt to insert on an extreme angle. 2 PLUG 1 Pulling Tool P/N : 90192-001 RECEPTACLE 8.2 Pull forces on the cable after connectors are mated After the connectors are mated, do not apply a load to the cable in excess of the values indicated in the diagram below. 2N MAX. PLUG 4N MAX. 2N MAX. RECE Coaxial Cable SPE-11-8-030/A | page 10 of 11 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd. SPE-11-8-030/A | page 11 of 11
AP.25C.07.0080A 价格&库存
很抱歉,暂时无法提供与“AP.25C.07.0080A”相匹配的价格&库存,您可以联系我们找货
