FXP240.07.0100A
FXP240.07.0100A
    TAOGLASLIMITED
    ANT ISM BAND FLEX PCB W/CABLE
FXP240.07.0100A 数据手册
Specification Spec No. : FXP240 Part No. : FXP240.07.0100A Model : 433MHz ISM Band Flex Circuit Antenna Features : 75*45*0.1mm 100mm Ø1.13 Cable RoHS  VERSION DATE PAGE DESCRIPTION CENTRE APPROVED A 09/21/2009 All Antenna Specifications Taiwan Ruben F. Cuadras © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com I. OVERVIEW The Taoglas FXP240 433 MHz ISM Antenna covers from 433-435 MHz used in the 433 MHz ISM (Industrial Scientific Medical) Band. The antenna has been designed in a flexible material with a square form-factor and cable connection for an easy installation. The antenna works on different plastic materials and thickness. We have selected a piece of ABS with 2 mm of thickness as a baseline for testing. II. ANTENNA CHARACTERISTICS Parameter Frequency Range Return Loss (dB) Gain (dBi) Impedance VSWR Polarization Power Handled Operation Temperature Storage Temperature Dimensions Weight Connector Cable Standard Cable Length and color RoHS Compliant Adhesive Specification 433MHz to 435MHz -20 0 50 Ω ≤2:1 Linear 5W -40°C ~ +85°C -40°C ~ +85°C 75*45*0.1mm 1.5g MHFII (U.FL Compatible) Mini-Coax 1.13 mm 100mm, Black Yes 3M 467 © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com III. TEST SET UP Rhode & Schwartz ZVL6 Vector Network Analyzer Figure 1. Network Analyzer. © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com IV. ANTENNA PARAMETERS The next antenna parameter graphs like Return Loss, VSWR and smith chart were measured in the Agilent Rhode & Schwartz ZVL6 Vector Network Analyzer. A. Return Loss Data Figure 2. Return Loss for the FXP240 Antenna. B. VSWR Data Figure 3. VSWR for the FXP240 Antenna. © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com C. Smith Chart Data Figure 4. Smith Chart for the FXP240 Antenna. V. MECHANICAL DRAWING Figure 5. Mechanical Drawing for the FXP240 Antenna. © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com
FXP240.07.0100A 价格&库存
很抱歉,暂时无法提供与“FXP240.07.0100A”相匹配的价格&库存,您可以联系我们找货
