FLA.01.07.0045A
FLA.01.07.0045A
    TAOGLASLIMITED
    ANT 5-BAND FLEX PCB W/CABLE
FLA.01.07.0045A 数据手册
FLA.01.07.0045A Specification Part No. FLA.01.07.0045A Product Name Flexible PCB Penta-Band GSM Loop Antenna 850/900/1800/1900/2100MHz 45mm 1.13cable, IPEX MHFII Feature Very low profile Penta-Band GSM Adhesive tape for easy mounting RoHS compliant SPE-12-8-052/A/ZL | page 1 of 8 1. Introduction The FLA.01 antenna is a penta-band cellular antenna that is embedded inside medical devices and can achieve high performance, particularly with customization. The technology can be applied to any frequency including licence free bands such as 433MHz, 868MHz, 915MHz, 2.4GHz and higher. With the FLA antenna, medical device designers can ensure their devices now achieve reliable, consistent wireless connections for transmitting patient data and also meet healthcare industry tests. The FLA flexible circuit antenna is particularly suited to the healthcare market because it can conform to anyshape or size, a mechanical advantage for medical devices, which come in different shapes, and sizes. To achieve the best possible performance for an individual healthcare product, antenna customization can improve device efficiency even further. 2. Specifications AMPS GSM DCS PCS 3G Avg. Efficiency % 824-894MHz 23.91% 880-960MHz 22.62% 1710-1880MHz 21.12% 1850-1990MHz 27.02% 1920-2170MHz 27.14% Impedance 50 Ohm VSWR ≤2.5 Radiation Pattern Omni-Directional Polarization Linear FPCB H: 65.7mm * 37mm (at widest) * 0.8mm Band (MHz) Connector IPEX MHFII Cable Ø1.13 Cable Length 45 mm Adhesive Tape 3M 467 Operation Temperature -40°C ~ +85°C Storage Temperature -30°C ~ +95°C * Tested in reference device * Results will vary dependant on the environment / ground plane size SPE-12-8-052/A/ZL | page 2 of 8 3. Electrical Property Antenna Efficiency FLA.01 with 45mm cable in Reference Device 50% 40% 30% 20% 10% MHz 0% 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 (MHZ)   SPE-12-8-052/A/ZL | page 3 of 8 Frequency E Total. dB Efficiency Efficiency. dB 824000000 1.78 20.22% -6.94 836000000 2.26 21.92% -6.59 849000000 2.9 24.64% -6.08 869000000 3.19 26.84% -5.71 880000000 2.69 25.76% -5.89 894000000 1.96 24.10% -6.18 900000000 2.17 26.88% -5.7 915000000 0.08 20.76% -6.83 925000000 -2.07 16.29% -7.88 940000000 -6.13 10.98% -9.59 960000000 -6.46 9.63% -10.16 1710000000 -7.41 4.45% -13.51 1750000000 -2.91 12.59% -9 1785000000 0.54 24.95% -6.03 1805000000 0.82 27.97% -5.53 1840000000 1.12 26.20% -5.82 1850000000 1.28 26.77% -5.72 1880000000 1 24.92% -6.03 1910000000 0.95 23.34% -6.32 1920000000 0.88 23.08% -6.37 1930000000 0.85 23.15% -6.35 1950000000 0.78 23.79% -6.24 1960000000 0.77 24.18% -6.16 1980000000 0.96 25.56% -5.92 1990000000 1.03 25.75% -5.89 2110000000 0.68 27.53% -5.6 2140000000 0.89 26.39% -5.79 2170000000 1 23.67% -6.26 * Tested in reference device SPE-12-8-052/A/ZL | page 4 of 8 4. Radiation Patterns H - Plane Radiation 5 0 5 -10 -15 -20 -25 -30 -35 _____ 850MHz _____ 900MHz _____ 1800MHz _____ 1900MHz _____ 2100MHz SPE-12-8-052/A/ZL | page 5 of 8 4. Radiation Patterns E - Plane Radiation 0 5 -10 -15 -20 -25 -30 -35 _____ 850MHz _____ 900MHz _____ 1800MHz _____ 1900MHz _____ 2100MHz SPE-12-8-052/A/ZL | page 6 of 8 A ALL Initial D 5. Drawing and Dimensions BOTTOM VIEW 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M TOP VIEW 3M 3M 3M 3M 3M 3M 3M 3M 3M BOTTOM VIEW "A" FLA.01 3 M Loop Cellular 3M 3M 3M 3M 3M Eddie 3M 3M 3M 850/900/1800 /1900/2100 0920 A ALL Initial Design Name NOTES: 1.Soldered area. P/N 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3Material M 3M 2012/3/19 Finish QTY FLA.01 PCB 100112C010011A FPCB 0.1t White 1 1.13 Coaxial Cable OD.113.J FEP White 1 IPEX MHF1 IPEX.MHF1.113 Brass Gold 1 Double-Sided Adhesive See FPCB Spec 3M 467 Brown Liner 1 FL TW Design Centre This drawing and its inherent design concepts are property of Taoglas. Not to be copied or given to third parties without the written consent of Taoglas. 1.1 NOTES: 1.Soldered area. IP Do BOTTOM VIEW 1 TOP VIEW Name Material Finish QTY FLA.01 PCB FPCB 0.1t White 1 FEP White 1 Brass Gold 1 3M 467 Brown Liner 1 3M 3M 3M 2 1.13 Coaxial Cable 3M 3M 3M 3 IPEX MHF1 3M 3M 3M 4 Double-Sided Adhesive 3M 3 3 M M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M 3M "A" FLA.01 SPE-12-8-052/A/ZL Loop Cellular 850/900/1800 /1900/2100 | page 7 of 8 6. Packaging 100pcs antenna per small PE bag 10 small PE bag per big PE bag 1000pcs antennas per big PE bag FLA.01 PE PE Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-052/A/ZL | page 8 of 8
FLA.01.07.0045A 价格&库存
很抱歉,暂时无法提供与“FLA.01.07.0045A”相匹配的价格&库存,您可以联系我们找货
