AP.10B.07.0050B
AP.10B.07.0050B
    TAOGLASLIMITED
    ANTENNA 25DB EMBEDDED GPS
AP.10B.07.0050B 数据手册
SPECIFICATION Part No. : AP.10B.07.0050B Product Name : 10mm 25dB Active GPS Patch Antenna Features : World smallest GPS active patch High performance 25dB Low power consumption RoHS compliant Photo : REVISION STATUS Version Date Page Revision Description Prepared Approved 01 Apr 9th 2008 All New product TW Product Centre Zita Lin 02 Oct 15th 2008 3 Environmental Conditions TW Product Centre Dermot O’Shea © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 1.0 Introduction The AP.10b.01 25dB active GPS patch antenna is the smallest GPS high performance antenna currently available in the world. Using extremely sensitive high dielectric constant powder formulation and tight process control the 10mm x 10mm x 4mm patch antenna is accurately tuned to have its frequency band right at 1575.42MHz for GPS systems. With an ultra low power consumption two stage LNA , this small active patch has the same relative performance of an ordinary active patch, but at only a quarter of the size. This product is suited to small form factor mobile devices such as GPS Smartphones, Personal Location, Medical devices, Telematic devices and Automotive navigation and tracking. Custom gain, connector and cable versions are available. 2.0 Specification Antenna Parameter Specification Frequency 1575.42 ± 1.023MHz Gain Typ -3dBic @ Zenith Impedance 50 Polarization RHCP Axial Ratio Max 4.0dB @ Zenith Dimension 10mm x 10mm x 4mm Frequency 1575.42 ± 1.023MHz Gain Min. 23dB, Typ. 25dB @ 25oC ± 5oC LNA Noise Figure Typ. 1.4dB @ 25oC ± 5oC Max 1.8dB @ 85oC Output Impedance 50 Output VSWR Max. 2.0 Cable *& Connector RF Cable Connector Coaxial Cable ψ0.8 ± 0.1mm, length 50 ± 2.0mm IPEX MHFI (U.FL) © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com Total Specification Parameter Specification Frequency 1575.42 ± 1.023MHz Gain 22 ± 4dBic @ 90o Output Impedance 50 Polarization RHCP Output VSWR Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% Input Voltage Current Min. 2.7V, Typ. 3.0V, Typ. 10mA, Max. 3.3V Max. 13mA © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 3.0 Technical Drawing © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com
AP.10B.07.0050B 价格&库存
很抱歉,暂时无法提供与“AP.10B.07.0050B”相匹配的价格&库存,您可以联系我们找货
