SA.PANEL.22
SA.PANEL.22
    TAOGLASLIMITED
    ANT 18DBI BASE STATION W/N
SA.PANEL.22 数据手册
SPECIFICATION Part No. : SA.PANEL.22 Spec No. : 3022 Product Name : 18dBi Vertical Polarized 90° Sector Antenna 4900-5900MHz Dimensions : 630*70*70mm Features : Excellent Radiation Patterns Wide Bandwidth with high gain across the band UV Stabilised Radome with Stainless steel Brackets RoHS Compliant REVISION STATUS Version Date Page Revision Description Prepared Approved 01 Aug 12th 2009 All New Product TW Product Centre Ronan Quinlan © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 1.0 Introduction This broadband vertically polarized base-station antenna is designed for sectored applications offering superior Azimuth and Elevation pattern control across the entire frequency band. These antennas are aesthetically pleasing while maintaining a rugged design. Applications:- Base-station Antennas, Point to Multi-Point Solutions, 802.11 Wi-Fi. 2.0 Antenna Performance 2.1 Electrical Specifications No. Parameter Specification 1 Communication System Wireless LAN 2 Frequency Band 4900-5900 MHz 3 Return Loss >14dB 4 Gain 18 dBi 5 Impedance 50 Ohm 6 Polarization Vertical 7 Max Power Handling 50W 8 Horizontal Beamwidth 90° 9 Vertical Beamwidth 5° 10 Front to Back Ratio >25dB 11 Upper Sidelobe Suppression >18dB 12 Electrical Downtilt 0° 2.2 Mechanical Specifications No. Parameter Specification 1 Connector N Type Female 2 Connector Location Bottom 3 Dimensions (L*W*D) 630*70*70mm 4 Weight 2kg 5 Radome UV Stabilised ASA 6 Mounting Adjustable pipe mount (included) © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 2.3 Environmental Ratings No. Parameter Specification 1 Rated Wind Velocity 200km/h (125mph) 2 Lightening Protection DC Grounded 3 Temperature -40°C to +70°C 3.0 Performance © All Rights Reserved Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland www.taoglas.com
SA.PANEL.22 价格&库存
很抱歉,暂时无法提供与“SA.PANEL.22”相匹配的价格&库存,您可以联系我们找货
