AP.10A.07.0050B
AP.10A.07.0050B
    TAOGLASLIMITED
    ANTENNA 15DB EMBEDDED GPS
AP.10A.07.0050B 数据手册
SPECIFICATION Part No. : AP.10A.07.0050B Product Name : 10mm One Stage Active GPS Patch Antenna Features : World smallest GPS active patch High performance Ultra low power consumption RoHS compliant Photo : REVISION STATUS Version Date Page Revision Description Prepared Approved 01 Apr 9th 2008 All New product TW Product Centre Zita Lin 3 Environmental Conditions TW Product Centre Dermot O’Shea 02 th Oct 15 2008 © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 1.0 Introduction The AP.10A.07.0050B active GPS patch antenna is the smallest GPS high performance antenna currently available in the world. Using extremely sensitive high dielectric constant powder formulation and tight process control the 10mm x 10mm x 4mm patch antenna is accurately tuned to have its frequency band right at 1575.42MHz for GPS systems. With an ultra low power consumption one stage LNA , this small active patch has the performance of an ordinary active patch, but at only a quarter of the size. This product is suited to small form factor mobile devices such as GPS Smartphones, Personal Location, Medical devices, Telematic devices and Automotive navigation and tracking. Custom gain, connector and cable versions are available. 2.0 Specification Antenna Parameter Specification Frequency 1575.42 ± 1.023MHz Gain Typ -3dBic @ Zenith Impedance 50Ω Polarization RHCP Axial Ratio Max 4.0dB @ Zenith Dimension 10mm x 10mm x 4mm Frequency 1575.42 ± 1.023MHz Gain Min. 13dB, Typ. 15dB @ 25oC ± 5oC LNA Noise Figure Typ. 1.4dB @ 25oC ± 5oC Max 1.8dB @ 85oC Output Impedance 50Ω Output VSWR Max. 2.0 Cable* & Connector RF Cable Connector Coaxial Cable ψ0.8 ± 0.1mm, length 50 ± 2.0mm Ipex MHFI (U.FL) © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com Total Specification Parameter Specification Frequency 1575.42 ± 1.023MHz Gain 12 ± 4dBic @ 90o Output Impedance 50Ω Polarization RHCP Output VSWR Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% Input Voltage Current Min. 2.7V, Typ. 3.0V, Typ. 3mA, Max. 3.3V Max. 5mA © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com 3.0 Technical Drawing © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland www.taoglas.com
AP.10A.07.0050B
物料型号: AP.10A.07.0050B
器件简介: - 世界上最小的高性能GPS主动贴片天线。 - 使用高介电常数粉末配方和严格的工艺控制。 - 尺寸为10mm x 10mm x 4mm,精确调谐至1575.42MHz的GPS系统频率。 - 配备超低功耗的一阶段低噪声放大器(LNA)。
引脚分配: 文档中未提供引脚分配信息。
参数特性: - 频率:1575.42±1.023MHz - 增益:典型值-3dBi(在天顶方向) - 阻抗:50欧姆 - 极化:右旋圆极化(RHCP) - 轴比:最大4.0dB(在天顶方向) - 尺寸:10mm x 10mm x 4mm
功能详解: - 适用于小型移动设备,如GPS智能手机、个人定位设备、医疗设备、远程信息处理设备和汽车导航及追踪系统。 - 可定制增益、连接器和电缆版本。
应用信息: 适用于需要小型化GPS天线的移动设备。
封装信息: - 天线:10mm x 10mm x 4mm - LNA(低噪声放大器):最小增益13dB,典型值15dB;噪声系数典型值1.4dB。 - 电缆和连接器:同轴电缆,外径0.8±0.1mm,长度50±2.0mm;连接器为Ipex MHFI (U.FL)。
AP.10A.07.0050B 价格&库存
很抱歉,暂时无法提供与“AP.10A.07.0050B”相匹配的价格&库存,您可以联系我们找货
