MAF94422
MAF94422
    LAIRD(莱尔德)
    DO-214AC(SMA)
    ANT EMB NANO 802.11BA RA RP SMA
MAF94422 数据手册
11 5 Lc 16.4 ASSY COAX CABLE 2X 4.78 MAP24057 THIS VIEW SHOWS TYPE"A" CONNECTOR ORIENTATION 49.5 CONNECTOR 1.52 A B STRAIN RELIEF (WITH INTERNAL ADHESIVE) (OPTIONAL) TYPE OF CONNECTOR ORIENTATION (REFER TABLE.1) HEAT SHRINK TUBE Ø4X12 MAR70008 C 6.0 +0/-3.0 HEAT SHRINK TUBE Ø2X12 MAR70006 R ANTENNA SBU PENANG, MALAYSIA D Lf CONNECTOR TYPE: 6.00±0.30 3.00±0.30 2.00±0.30 I-PEX TOLERANCE (UNLESS STATED) MMCX/RPMMCX X = XX = ANGULAR = STRAIGHT SMA #0.3 #0.13 # 30' - PRODUCT & PROCESS MUST COMPLY TO LT-GES - MISSING INFORMATION REFER TO 3D DATA - DIMENSIONS ARE IN MILLIMETERS UNLESS STATED OTHERWISE - THIS DRAWING WAS GENERATED VIA PRO/ENGINEER - PRINT NOT TO SCALE FPEN001.015B SYM FERRITE BEAD (OPTIONAL) 3.0 +0/-3.0 NOTES: 1. MATERIAL: SINGLE SIDED 0.06" NELCO NX 9260 Ioz/ft^2 CU 2. FINISH: PURE TIN PLATING WITH SOLDER MASK 3. SOLDER MASK: BLACK ALL OVER EXCEPT FOR EXPOSED SOLDER PADS (DOUBLE SIDED) 4. POLARIZATION: VERTICAL, OMNIDIRECTIONAL 5. NOMINAL IMPEDENCE: 50 ohm 6. V.S.W.R. 2:1 MAX ACROSS ALL BANDS FREQUENCY RANGE 2.4-2.5 GHz 4.9-5.825 GHz CABLE STRIPPING DIMENSION FOR FLYING LEAD ECO/DESCRIPTION DATE CK DRAWN BY: AL CHAN APP R (F16) ECN-IAS-04028 5MAY15 LCTAN CHFONG ANTENNA SBU PENANG, MALAYSIA (F17) ECN-IAS-04477 12AUG15 LCT CHF (F18) ECN-IAS-04595 9SEP15 LCT CHF (F14) ECN-IAS-03758 04MAR15 KHOO FONG (F15) ECN-IAS-03848 24MAR15 KHOO FONG CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DOCUMENT IS OF PROPRIETARY NATURE. IT MAY NOT BE REPRODUCED OR USED WITHOUT EXPRESS WRITTEN PERMISSION OF LAIRD TECHNOLOGIES, ANTENNA SBU CHECKED BY: GJ CHIN DWG. NO.: MAF94355 2007 LAIRD TECHNOLOGIES PROJECT NO. REFER TABLE REV F18 MATERIAL: SEE NOTE DESCRIPTION: NANOBLADE ANTENNA MASTER PRINT C PG. 1/8 DATE: 10/09/07 SCALE: 2.000 UNITS: MM TABLE TOLERANCE (UNLESS STATED) X = XX = ANGULAR = #0.3 #0.13 # 30' - PRODUCT & PROCESS MUST COMPLY TO LT-GES - MISSING INFORMATION REFER TO 3D DATA - DIMENSIONS ARE IN MILLIMETERS UNLESS STATED OTHERWISE - THIS DRAWING WAS GENERATED VIA PRO/ENGINEER - PRINT NOT TO SCALE SYM ECO/DESCRIPTION DATE CK DRAWN BY: AL CHAN APP R ANTENNA SBU PENANG, MALAYSIA CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DOCUMENT IS OF PROPRIETARY NATURE. IT MAY NOT BE REPRODUCED OR USED WITHOUT EXPRESS WRITTEN PERMISSION OF LAIRD TECHNOLOGIES, ANTENNA SBU DWG. NO.: MAF94355 2007 LAIRD TECHNOLOGIES PROJECT NO.:REFER TABLE PG. 2/8 REV F18 MATERIAL: SEE NOTE DESCRIPTION: NANOBLADE ANTENNA MASTER PRINT C FPEN001.015B CHECKED BY: GJ CHIN DATE: 10/09/07 SCALE: 2.000 UNITS: MM
MAF94422 价格&库存
很抱歉,暂时无法提供与“MAF94422”相匹配的价格&库存,您可以联系我们找货
