Laird Technologies - Item # S828SLP12NF, Dual Linear Antennas
Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional
Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi
Omnidirectional Ceiling Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band
800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > SL8025WP Tri-Band Omni
Antenna > SL80173WP Tri-Band Omni Antenna > 800 MHz Wall/Mast Mount Omnidirectional Antennas > 800/900
MHz. Omnidirectional Antennas for Data Communications > Laird Technologies Dual Feed, Linear & Circular
Panel Antennas (CELL) > Item # S828SLP12NF
Linear Polarization Panel Antennas
Laird Technologies linearly polarized panel antennas feature high
performance and versatility. All antennas in the series are provided with
UV stabilized radome enclosures and can be mounted to either interior or
exterior wall surfaces or masts in either fixed or articulating
configurations. Models are available from 8 dBi to 17 dBi gain.
Integrated coaxial pigtails can be modified for length and connectors can
be modified to suit the application.
Consult your Laird Technologies Sales Representative to discuss these
alternatives.
larger image
Dual Feed Panel Antennas
Dual feed panel antennas offer two ports for polarization diversity and are well suited to environments where
multipath is a concern but space is limited. Polarization diversity allows the user to achieve the desired diversity
benefit in the footprint of one antenna. All Laird Technologies dual feed antennas feature a minimum of 18 dB of
port isolation.
HVP antennas offer diversity benefits in the foot print of a single antenna.
Circular Polarization Panel Antennas
Circular polarization antennas are a good choice for system applications where remote device orientation is random
and widely variable.
Circular Polarized antennas mitigate performance degradation sometimes caused by variation in remote terminal
orientation.
Specifications
Frequency
824 to 896 MHz
Gain
8 dBi
VSWR
1.5:1
Polarization
Dual Linear + 45°
3dB Beamwidth, E Plane
65 º
3dB Beamwidth, H Plane
70 º
http://lairdtech.thomasnet.com/printitem/all-categories/aft-dual-feed-linear-circular-panel-an... 8/8/2012
Weight
2.2 lbs
1.00 kg
RF Connector
N (Female)
Dimensions
8 x 12 x 2 in.
20.3 x 30.5 x 5.1 cm
Power
50 watts
Mounting Style
Mast
Wall Mount
Page 2 of 2
很抱歉,暂时无法提供与“S828SLP12NF”相匹配的价格&库存,您可以联系我们找货
