Laird Technologies - Item # S8802MP10NF, 800 MHz Wall/Mast Mount Omnidirectiona... Page 1 of 1
Laird Technologies
Web site: www.LairdTech.com
All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional Antennas for
Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi Omnidirectional Ceiling
Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band 800 MHz/1900 MHz, 900
MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > SL8025WP Tri-Band Omni Antenna > SL80173WP Tri-Band
Omni Antenna > 800 MHz Wall/Mast Mount Omnidirectional Antennas > Item # S8802MP10NF
Item # S8802MP10NF, 800 MHz Wall/Mast Mount Omnidirectional
Antennas
Designed to provide a very attractive alternative, the antenna exhibits 2 dBi of
omnidirectional gain in the AMP, GSM or SMR frequency band in a very
diminutive package (antenna measures only 4" x 3" x 1.5"). For wall mounting,
best omnidirectional coverage is achieved by mounting to an interior wall
surface backed by traditional wood frame studs. Antenna comes standard with
coax pigtail and N female, SMA or TNC connector.
larger image
Specifications
Band
GSM
AMP
SMR
Frequency
880 to 960 MHz
Gain
2 dBi
3dB Beamwidth, E Plane
120 º
3dB Beamwidth, H Plane
110 º
VSWR
2:1
Polarization
Linear vertical
Weight
0.4 lbs
0.18 kg
RF Connector
N (Female)
Enclosure Material
PVC
Power
10 watts
Mounting Style
Yes
Dimensions
4 x 3 x 1.5 in
http://lairdtech.thomasnet.com/printitem/all-categories/800-mhz-wall-mast-mount-omnidire... 8/8/2012
很抱歉,暂时无法提供与“S8802MP10NF”相匹配的价格&库存,您可以联系我们找货
