S888P12NF
S888P12NF
    LAIRD(莱尔德)
    ANTENNA 880-960MHZ 8DBI N FML
S888P12NF 数据手册
Laird Technologies - Item # S888P12NF, Linear Panel Antennas Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi Omnidirectional Ceiling Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band 800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > SL8025WP Tri-Band Omni Antenna > SL80173WP Tri-Band Omni Antenna > 800 MHz Wall/Mast Mount Omnidirectional Antennas > 800/900 MHz. Omnidirectional Antennas for Data Communications > Laird Technologies Dual Feed, Linear & Circular Panel Antennas (CELL) > Item # S888P12NF Item # S888P12NF, Linear Panel Antennas GSM Linearly Polarized and Dual Polarized, Single Patch Antennas Cushcraft’s S888P Series of GSM Microcell Antennas both employ a single broadband microstrip patch to provide a minimum of 8 dBi gain and a nominal 55 by 60 degree pattern. The 888HVP12NF is designed for polarization diversity applications with separate coaxial feeds provided for both horizontal and vertical polarization. Isolation between polarization is nominal 15 dB. These antennas are housed in a rugged low profile, UV stable polycarbonate radome which is weather resistant for outdoor applications. This antenna is available in grey, beige, or white radomes; although they can be painted as required. Mounting configurations include a standard wall mount or articulating version. larger image Specifications Band GSM Frequency 880 to 960 MHz Gain 8 dBi VSWR 1.5:1 Polarization Linear 3dB Beamwidth, E Plane 65 º 3dB Beamwidth, H Plane 70 º Weight 1.9 lbs 0.86 kg RF Connector N (Female) Dimensions 8 x 12 x 2 in. 20.3 x 30.5 x 5.1 cm Power 50 watts Mounting Style Mast http://lairdtech.thomasnet.com/printitem/all-categories/aft-dual-feed-linear-circular-panel-an... 8/8/2012 Laird Technologies - Item # S888P12NF, Linear Panel Antennas Page 2 of 2 Wall Mount http://lairdtech.thomasnet.com/printitem/all-categories/aft-dual-feed-linear-circular-panel-an... 8/8/2012
S888P12NF 价格&库存
很抱歉,暂时无法提供与“S888P12NF”相匹配的价格&库存,您可以联系我们找货
