S8243B
S8243B
    LAIRD(莱尔德)
    ANT 824-896MHZ 3DBD N FEMALE
S8243B 数据手册
Laird Technologies - Item # S8243B, 800/900 MHz. Omnidirectional Antennas for Data ... Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi Omnidirectional Ceiling Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band 800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > SL8025WP Tri-Band Omni Antenna > SL80173WP Tri-Band Omni Antenna > 800 MHz Wall/Mast Mount Omnidirectional Antennas > 800/900 MHz. Omnidirectional Antennas for Data Communications > Item # S8243B Item # S8243B, 800/900 MHz. Omnidirectional Antennas for Data Communications AMPS Band Omnidirectional Collinear Antenna Cushcraft’s S8243B12NF antenna provides for omnidirectional coverage in the 824-896 MHz frequency band. The antenna features an efficient low loss brass radiator and is enclosed in a fiberglass radome. The antenna comes complete with heavy duty mast mounting hardware eliminating the need to purchase and inventory mounting hardware as a separate item. larger image larger image Specifications Band AMPS Frequency 824 to 896 MHz Gain 3 dBD Nominal VSWR 1.5:1 Bandwidth 62 MHz 3dB Beamwidth, E Plane 45 º RF Connector N (Female) Height 30 3/4 in 78 cm Weight 1.19 lbs http://lairdtech.thomasnet.com/printitem/all-categories/z-omnidirectional-antennas-for-data-... 8/8/2012 Laird Technologies - Item # S8243B, 800/900 MHz. Omnidirectional Antennas for Data ... Page 2 of 2 0.53 kg Wind Surface Area 0.176 m2 0.016 ft2 Wind Survival 125 mph 200 kph Pigtail 23 cm Element Material Plated Copper Laminate Enclosure Material Fiberglass Mounting Style Tube end Max. Mast Diameter 2 in 5.1 cm http://lairdtech.thomasnet.com/printitem/all-categories/z-omnidirectional-antennas-for-data-... 8/8/2012
S8243B 价格&库存
很抱歉,暂时无法提供与“S8243B”相匹配的价格&库存,您可以联系我们找货
