Laird Technologies - Item # SM1852PSMF, 2 dBi Omnidirectional Ceiling Mount Anten... Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional
Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi
Omnidirectional Ceiling Mount Antenna for PCS > Item # SM1852PSMF
Item # SM1852PSMF, 2 dBi Omnidirectional Ceiling Mount Antenna for PCS
The SM1852PSMF antenna offers the kind of uniform and symmetrical energy distribution that one normally expects
from much larger antennas. It is the first antenna of its kind to offer "no compromise" performance in a small
package. The SM1852PSMF, 2 dBi omnidirectional ceiling mount antenna is designed for use in the PCS band from
1850-1990 MHz. The antenna dimensions are only 2.0" x 1 5/8" x 1/4".
Since the antenna's omnidirectional pattern is very uniform and symmetrical, it is perfectly suited to contemporary
in-building wireless systems applications. Avery well defined coverage area with high levels of radiated energy
within each cell is critical to maintaining system-wide in-building performance especially if capacity related issues
are driving the system design.
The antenna employs versatile easy to install clips for mounting to the ceiling support T-bar. The antenna mounting
system is even adjustable for ceiling tile depth variances of as much as 0.5" from the ceiling grid support system.
The antenna comes standard with SMA female connector and Cushcraft makes jumper cables available in varying
lengths and connector options.
larger image
larger image
Specifications
Band
PCS
Frequency
1850 to 1990 MHz
Gain
2 dBi
http://lairdtech.thomasnet.com/printitem/all-categories/-dbi-omnidirectional-ceiling-mount-...
8/8/2012
Laird Technologies - Item # SM1852PSMF, 2 dBi Omnidirectional Ceiling Mount Anten... Page 2 of 2
VSWR
2:1
Omnidirectionality
4 dB
Polarization
Linear
Weight
0.1 lbs
0.05 kg
Power
10 watts
Enclosure Material
PVC
White Acrylic
Mounting Style
Ceiling Grid
8/8/2012
很抱歉,暂时无法提供与“SM1852PSMF”相匹配的价格&库存,您可以联系我们找货
