S1856MPC10NF
S1856MPC10NF
    LAIRD(莱尔德)
    ANT 1850-1990MHZ 6DBI N FEMALE
S1856MPC10NF 数据手册
Laird Technologies - Item # S1856MPC10NF, DirectLink™ Series Antennas Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > In-Building, CPE, Access Point, and Mobile Client Antennas > CPE Antennas (WiMAX, 3G/4G, LTE, Cellular, BWA) > Cellular (CELL) Antennas > Laird Technologies Dual Feed, Linear & Circular Panel Antennas (CELL) > 800/900 MHz. Omnidirectional Antennas for Data Communications > DirectLink™ Series Antennas > Item # S1856MPC10NF Item # S1856MPC10NF, DirectLink™ Series Antennas Campus & in-building directional antennas DirectLink is a series of wall and mast mount directional antennas that has been designed to meet the most demanding needs of the contemporary wireless environment. DirectLink's attractive, UV resistant housings and mounts allow the antennas to be mounted anywhere in the larger image campus or in-building environment. The antennas offer very precise and controllable pattern characteristics in frequencies starting with the 1710 MHz DCS band and continuing through the 5.725 GHz ISM band. All popular contemporary wireless system applications are covered with gain characteristics varying with frequency. All antennas in the series may be wall or mast mounted and all are available with a variety of flush and articulating mounts. Flush mounts allow the antenna to hug the wall for minimal visual impact. There are two available articulating mounts that allow the pattern to be directed while still maintaining minimal visual impact. Standard antennas come with either TNC, SMA or N female connectors and an integrated coaxial pigtail. Other connector and pigtail combinations are available upon request. Specifications Band DCS ISM Frequency 1850 to 1990 MHz Gain 6 dBic 3dB Beamwidth, E Plane 70 º 3dB Beamwidth, H Plane 70 º VSWR 1.5:1 Front to Back Ratio 20 dB Connector N (Female) Articulating Version Yes Power 75 watts Power at 5 GHz 25 watts http://lairdtech.thomasnet.com/printitem/all-categories/directlink-trade-series-antennas/s185... 8/8/2012 Laird Technologies - Item # S1856MPC10NF, DirectLink™ Series Antennas Page 2 of 2 Polarization Linear Standard Wall Mount Dimension 5.70 x 3.81 x 1.50 in 14.48 x 9.68 x 3.80 cm Articulating Wall Mount Dimension 5.80 x 3.81 x 2.26 in 14.73 x 9.68 x 5.74 cm Weight (Standard Wall Mount) 5 oz 0.14 kg Weight (Articulating Wall Mount) 8 oz 0.23 kg Mounting Style Standard units for wall mounting. Mast mount bracket kits available. Custom mount configurations for volume users. Cable Low loss pigtail provided http://lairdtech.thomasnet.com/printitem/all-categories/directlink-trade-series-antennas/s185... 8/8/2012
S1856MPC10NF
物料型号:S1856MPC10NF
器件简介:DirectLink™系列天线是为满足当代无线环境的苛刻需求而设计的墙面和杆塔定向天线,具有耐腐蚀的外壳和支架,适用于校园或建筑内部环境。这些天线提供了精确且可控的模式特性,覆盖从1710 MHz DCS频带到5.725 GHz ISM频带的所有流行现代无线系统应用。
引脚分配:文档中没有明确提供引脚分配信息。
参数特性: - 频段:DCS ISM - 频率:1850至1990 MHz - 增益:6 dBic - E平面3dB波束宽度:70º - H平面3dB波束宽度:70º - VSWR:1.5:1 - 前后比:20 dB - 连接器:N型(女头) - 馈电类型:支持人工调整版本 - 功率:75瓦特(5 GHz时25瓦特)
功能详解:DirectLink™天线提供精确的定向覆盖,适用于需要最小化视觉影响的场合,可通过墙面或杆塔安装,并提供多种安装支架选择。
应用信息:适用于校园或建筑内部环境中的定向覆盖,覆盖所有流行的现代无线系统应用。
封装信息:标准墙面安装尺寸为5.70 x 3.81 x 1.50英寸(14.48 x 9.68 x 3.80厘米),重量为5盎司(0.14公斤)。人工调整墙面安装尺寸为5.80 x 3.81 x 2.26英寸(14.73 x 9.68 x 5.74厘米),重量为8盎司(0.23公斤)。提供低损耗尾纤。
S1856MPC10NF 价格&库存
很抱歉,暂时无法提供与“S1856MPC10NF”相匹配的价格&库存,您可以联系我们找货
