S18512P12NF
S18512P12NF
    LAIRD(莱尔德)
    ANT 1850-1990MHZ 12DBI N FEMALE
S18512P12NF 数据手册
Laird Technologies - Item # S18512P12NF, Linear Panel Antennas Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > In-Building, CPE, Access Point, and Mobile Client Antennas > CPE Antennas (WiMAX, 3G/4G, LTE, Cellular, BWA) > Cellular (CELL) Antennas > Laird Technologies Dual Feed, Linear & Circular Panel Antennas (CELL) > Item # S18512P12NF Item # S18512P12NF, Linear Panel Antennas 12 dBi, Low Profile Directional Panel Antenna This antenna design offers 12 dBi directional gain in a low profile housing. The antenna is well suited to both indoor and outdoor wall or mast mount applications. Cushcraft's versatile ALLPMTW and ALLPMTM articulating mounts can be used to orient the signal into the desired coverage area. Coax length and connector type can be modified to specific application. Offices, HealthCare facilities, educational and industrial campuses and shopping malls are just a few of the more common applications for this antenna design. larger image larger image Specifications Band DCS PCS Frequency 1850 to 1990 MHz Gain 12 dBi VSWR 1.5:1 Polarization Linear 3dB Beamwidth, E Plane 25 º 3dB Beamwidth, H Plane 65 º Weight 1.60 lbs 0.73 kg RF Connector N (Female) http://lairdtech.thomasnet.com/printitem/all-categories/aft-dual-feed-linear-circular-panel-an... 8/8/2012 Laird Technologies - Item # S18512P12NF, Linear Panel Antennas Dimensions 6 x 13 x 1 in. 15.2 x 33.0 x 2.5 cm Power 50 watts Mounting Style Mast Wall Mount Page 2 of 2 http://lairdtech.thomasnet.com/printitem/all-categories/aft-dual-feed-linear-circular-panel-an... 8/8/2012
S18512P12NF 价格&库存
很抱歉,暂时无法提供与“S18512P12NF”相匹配的价格&库存,您可以联系我们找货
