Laird Technologies - Item # S1713BNF, Special Purpose Omnidirectional Antennas
Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Antennas & Reception Solutions > Vehicular Antennas & Telematics > Cellular Antennas > Dual
Band & Special Applications Antennas > PCS/DCS and 2.4 GHz ISM band Yagi antennas > 800 MHz Models ESMR, SMR, Cellular, GSM and Conventional > Special Purpose Omnidirectional Antennas > Item # S1713BNF
Omnidirectional Antennas for PCS/DCS and Wireless LAN
Laird Technologies is world renowned for its special purpose
omnidirectional antenna designs. Antennas are available for frequencies
from the 1.7 GHz DCS band through the 5.8 GHz ISM band and can
either be suspension ceiling mounted, I-beam mounted or mast mounted.
2.4 GHz Monopole Omni
The Laird Technologies 2.4 GHz monopole antenna has a large
backplane and is designed for applications with a very focused
omnidirectional pattern where an in-building system is required. For
example, the monopole could be used to focus signal directly into an area where it is very difficult to get any
coverage.
larger image
Specifications
Band
DCS
PCS
Frequency
1710 to 1880 MHz
Gain
3 dBD
VSWR
1.5:1
Bandwidth
170 MHz
3dB Beamwidth, E Plane
38 º
Height
14 in
35.5 cm
Weight
1.4 lbs
0.64 kg
Wind Surface Area
0.07 m2
0.006 ft2
Wind Survival
125 mph
200 kph
Power
50 watts
http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/special-purpose-omnidirectio... 8/8/2012
Enclosure Material
Polycarbonate
Mounting Style
Direct Mount
RF Connector
N (Female)
Pigtail
12 in
30.5 cm
Element Material
Printed Circuit - Radome Dia. 1”
Page 2 of 2
很抱歉,暂时无法提供与“S1713BNF”相匹配的价格&库存,您可以联系我们找货
