GSA.8825.A.051N11
GSA.8825.A.051N11
    TAOGLASLIMITED
    GSA.8825 WITH 0.5M RG-174 SMK
GSA.8825.A.051N11 数据手册
SPECIFICATION Part No. : GSA.8825.051N11 Product Name : I-Wand Penta-Band GSM Antenna Works with AMPS 850MHz/GSM 900/DCS 1800MHz/PCS 1900MHz/UMTS 3G Features : Easy installation – Adjustable Clip Fully customized cable and connector Standard = Length 0.5M with SMK connector RoHS Compliant Photo : SPE-11-8-042/C/SS Page 1 of 7 1. Introduction The GSA.8825 I-Wand Penta-band GSM Antenna is flexible and robust. Its Omni-directional gain across all bands ensures constant reception and transmission. It is a high gain, high efficiency solution. Cables and connectors are fully customizable. 2. Antenna Specifications Communication System Penta-band Cellular AMPS GSM DCS PCS UMTS 824 ~ Frequency (MHz) Impedance 896 880~960 1710~1880 1850~1990 1710~2170 50 Ohm Radiation Pattern Omni-directional Polarization Linear (Vertical) Gain Input Connection VSWR Dimensions (mm) 2dBi Coaxial Cable - RG174 Standard, Fully customizable < 2.0 : 1 140 x 25.2mm Weight 48g Casing Engineering Plastic - Black Temperature Range -40°C to +85°C SPE-11-8-042/C/SS Page 2 of 7 3. Antenna Electrical Characteristics 3.1 Return Loss & VSWR – GSA.8825– 1M RG-174 FME(F) SPE-11-8-042/C/SS Page 3 of 7 3.2 Return Loss & VSWR – GSA.8825.101N11 – 1M RG-174 SMK(M) SPE-11-8-042/C/SS Page 4 of 7 4. Mechanical Drawing (unit:mm) SPE-11-8-042/C/SS Page 5 of 7 4.1 Connector Drawing SPE-11-8-042/C/SS Page 6 of 7 5. Packaging SPE-11-8-042/C/SS Page 7 of 7
GSA.8825.A.051N11 价格&库存
很抱歉,暂时无法提供与“GSA.8825.A.051N11”相匹配的价格&库存,您可以联系我们找货
