TL.01.1F11W
TL.01.1F11W
    TAOGLASLIMITED
    TERMINAL ROBUST ANTENNA
TL.01.1F11W 数据手册
Underside of TL.01.1F11W with N type (M) connector TL.01.1F11W on ground plane Shockwave TL.01.1F11W Specification Part No. TL.01.1F11W Product Name Shockwave Ultra-Wideband Direct Mount antenna Covers all common 2G/3G/4G Cellular - ISM- Wi-Fi Bands Feature LTE / GSM / CDMA /DCS /PCS / WCDMA / UMTS/ HSDPA / GPRS / EDGE /GPS /Wi-Fi 698MHz to 960MHz, 1575.42MHz, 1710MHz to 2700Mhz, High Efficiency and Peak Gain – up to 90% N type (M) Connector White UV resistant housing (applied Dupont Imron 2.8HG coating) IP67 Waterproof and IP69K RoHS Compliant SPE-13-8-047/A/WY | page 1 of 25 1. Introduction The Shockwave TL.01 series is a new generation of antenna, one part number that is a highly efficient, high gain omni-directional permanent mount antenna designed for all common Cellular, Wi-Fi and ISM bands worldwide. It is specially designed for easy and cost effective vandal-proof and waterproof mounting requirements on meters, terminal boxes, and heavy equipment and vehicles. In installation the antenna connects to a N female connector jutting out from a metal panel. A unique indent tab on the base itself on the antenna allows a wrench to be used to solidly lock the antenna on top of its mounting location, thus preventing removal by hand later by vandals, but crucially allowing for a replacement antenna to be installed by qualified personnel in the future without the need to open the device or box it is mounted on itself. A waterproof O-ring around the bottom outer edge prevents water leaking under the antenna. The Shockwave TL.01 has been tested on a variety of mounting conditions as below specification, with excellent efficiency and gain measured in all typical common mounting conditions. Radiation patterns are consistent, and show very good stability in the azimuth on lower and upper bands. The antenna is IP67 waterproof and IP69K resistant against high pressure water jets in commercial cleaning environments, incorporating highest quality stainless steel mounting base ensuring corrosion resistance. It also has UV resistant housing (applied Dupont Imron 2.8HG coating). Housing, frequency application, mounting type and connector are customizable, subject to minimum order quantities. Please contact your local Taoglas sales office for more information. The antenna also comes in Black as standard. SPE-13-8-047/A/WY | page 2 of 25 2. Specification Electrical 698~800 824~960 1575.42 1710 ~ 1880 1850 ~ 1990 1710 ~ 2170 2400~2700 Free Space -1.7 -0.9 0.8 1.3 1.3 1.7 3.5 10x10cm GP center -1.3 0.1 0.3 0.1 0.4 0.5 2.3 30x30cm GP center 2.7 2.5 1.0 2.2 2.1 2.2 3.1 50x50cm GP center 2.6 2.5 1.2 3.1 3.2 3.1 2.8 Free Space -6.6 -5.1 -1.8 -1.5 -1.5 -1.3 -0.9 10x10cm GP center -3.1 -1.9 -1.9 -2.1 -2.0 -1.9 -1.4 30x30cm GP center -0.4 -1.1 -1.6 -1.7 -1.3 -1.3 -1.6 50x50cm GP center -0.3 -1.0 -1.6 -1.2 -0.8 -0.9 -1.6 Free Space 22% 31% 64% 69% 69% 72% 80% 10x10cm GP center 48% 63% 63% 60% 63% 63% 71% 30x30cm GP center 90% 76% 67% 67% 73% 73% 69% 50x50cm GP center 91% 78% 68% 75% 83% 81% 68% Impedance 50Ω Polarization Vertical Radiation Pattern Omni Frequency (MHz) Peak Gain (dBi) Average Gain (dBi) Efficiency Mechanical Casing PC+PBT Connector N Type Male Base Stainless Steel Environmental Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-13-8-047/A/WY | page 3 of 25 3. Antenna Characteristics 3.1 Return Loss 0 Free Space -5 (dB) -10 with 10 x 10cm Ground Plane -15 with 30 x 30cm Ground Plane -20 -25 with 50 x 50cm Ground Plane -30 500 1000 1500 2000 2500 3000   (MHz) 3.2 Maximum Gain 6 5 Free Space 4 3 with 10 x 10cm Ground Plane (dBi) 2 1 with 30 x 30cm Ground Plane 0 -1 with 50 x 50cm Ground Plane -2 -3 -4 500 1000 1500 2000 2500 3000 (MHz)   SPE-13-8-047/A/WY | page 4 of 25 3. Antenna Characteristics 3.3 Average Gain 0 -1 Free Space -2 -3 with 10 x 10cm Ground Plane (dBi) -4 -5 -6 with 30 x 30cm Ground Plane -7 -8 with 50 x 50cm Ground Plane -9 -10 500 1000 1500 2000 2500 3000   (MHz) 3.4 Efficiency 100 Free Space 90 80 70 with 10 x 10cm Ground Plane (%) 60 50 with 30 x 30cm Ground Plane 40 30 with 50 x 50cm Ground Plane 20 10 0 500 1000 1500 2000 2500 3000 (MHz) SPE-13-8-047/A/WY |   page 5 of 25 4. Antenna Radiation Patterns 4.1 Antenna Setup (Free Space)   SPE-13-8-047/A/WY | page 6 of 25 4.1.1 Radiation Patterns X XY Plane Y 704MHz 751MHz 824MHz 880MHz 960MHz   X Y 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 7 of 25 4.1.1 Radiation Patterns X XY Plane Y 2300MHz 2500MHz 2570MHz 2700MHz   SPE-13-8-047/A/WY | page 8 of 25 4.1.1 Radiation Patterns Z XZ Plane X 704MHz 751MHz 824MHz 880MHz 960MHz   Z X 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 9 of 25 4.1.1 Radiation Patterns XZ Plane Z X 2300MHz 2500MHz 2570MHz 2700MHz 4.2 Antenna Setup (10 x 10cm Metal Ground Plane)   Y X Z SPE-13-8-047/A/WY | page 10 of 25 4.2.1 Radiation Patterns X XY Plane Y 704MHz 751MHz 824MHz 880MHz 960MHz   X Y 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 11 of 25 4.2.1 Radiation Patterns X XY Plane Y 2300MHz 2500MHz 2570MHz 2700MHz   SPE-13-8-047/A/WY | page 12 of 25 4.2.1 Radiation Patterns Z XZ Plane X 704MHz 751MHz 824MHz 880MHz 960MHz   Z X 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 13 of 25 4.2 .1 Radiation Patterns XZ Plane Z X 2300MHz 2500MHz 2570MHz 2700MHz 4.3 Antenna Setup (30 x 30cm Metal Ground Plane)   Y X Z SPE-13-8-047/A/WY | page 14 of 25 4.3.1 Radiation Patterns X XY Plane Y 704MHz 751MHz 824MHz 880MHz 960MHz   SPE-13-8-047/A/WY | page 15 of 25 4.2.1 Radiation Patterns X XZ Plane Y 1710MHz 1880MHz 1990MHz 2170MHz   X Y 2300MHz 2500MHz 2570MHz 2700MHz   SPE-13-8-047/A/WY | page 16 of 25 4.2.1 Radiation Patterns Z XZ Plane X 704MHz 751MHz 824MHz 880MHz 960MHz   Z X 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 17 of 25 4.3.1 Radiation Patterns XZ Plane Z X 2300MHz 2500MHz 2570MHz 2700MHz 4.4 Antenna Setup (50 x 50cm Metal Ground Plane)   Y X Z SPE-13-8-047/A/WY | page 18 of 25 4.4.1 Radiation Patterns X XY Plane Y 704MHz 751MHz 824MHz 880MHz 960MHz   X Y 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 19 of 25 4.4.1 Radiation Patterns X XY Plane Y 2300MHz 2500MHz 2570MHz 2700MHz   SPE-13-8-047/A/WY | page 20 of 25 4.4.1 Radiation Patterns Z XZ Plane X 704MHz 751MHz 824MHz 880MHz 960MHz   Z X 1710MHz 1880MHz 1990MHz 2170MHz   SPE-13-8-047/A/WY | page 21 of 25 4.4.1 Radiation Patterns Z XZ Plane X 2300MHz 2500MHz 2570MHz 2700MHz   SPE-13-8-047/A/WY | page 22 of 25 5. Drawing Name Material Finish QTY 1 Antenna Top PC+PBT White 1 2 Antenna Bottom SST Ni Plated 1 3 O-Ring NBR Red 1 SPE-13-8-047/A/WY | page 23 of 25 6. Installation Ø16 Recommended torque for mounting is 95Nm or 70ft lbs Maximum torque for mounting is 135.6Nm or 100ft lbs SPE-13-8-047/A/WY | page 24 of 25 5.1 每個小 PE 袋放置 1 天線,上下套入 2 個 EPE 泡棉 如下圖所示 【1pcs antennas per PE bag and EPE 2 pcs foam by up and bottom.】 5.2 每個盒子裝入 1PCS 天線 【1pcs antennas per Box.】 5.3 封口時須注意不可壓到天線,裝入需平整不可雜亂 【Antenna should be placed flat and neat in the PE bag. Hot seal the PE bag without pressing or damage the antenna.】 5.4 7. 清點每袋數量不可短缺 Packaging 【Confirm the quantity in each PE bag.】 1 pcs antenna per PE bag 2 pcs EPE foam on top and bottom 1 pcs antenna per box EPE 泡棉 TL.01 PE 袋 BOX EPE 泡棉 UNLESS OTHER SPECIFIED TOLERANCES ON: X=± X.XX= Taoglas X.X=± makes no warranties based on the product descriptions at any time accuracy or completeness of the contents without notice. Taoglas reserves all ANGLES=± HOLEDIA=± of this document and reserves the right to rights to this document and the SCALE: xxxx UNIT:mm make changes to specifications and information contained herein. DRAWN BY: Jason CHECKED BY: Wayne DESIGNED BY: Wayne APPROVED BY: Wayne TITLE: TL.01 Antenna Assembly DOCUMENT NO. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. PAGE 25 of REV. 25 SPE-13-8-047/A/WY | page TL.01.1F11 D01
TL.01.1F11W 价格&库存
很抱歉,暂时无法提供与“TL.01.1F11W”相匹配的价格&库存,您可以联系我们找货
