DC-ANT-DBMP
DC-ANT-DBMP
    DIGIINTERNATIONAL
    ANTENNA DUAL BAND
DC-ANT-DBMP 数据手册
Product Datasheet Digi Connect® WAN Family Cellular Gateways/Routers/VPN Devices Cellular routers, gateways and VPN devices provide high performance wireless TCP/IP data communications via cellular GSM/CDMA networks, for primary and backup connectivity to remote sites and devices. Corporate Office Remote Site Central Data Server ATM Wireless Telco Network AUX CON SOL E AL SIGN ENGTH STR ACT IVE LINK Ethernet Internet/VPN Dig iC onne ct N WA V DC 9-30 mA MAX 525 RES ET ERN ACT ETH LINK ET PWR TUS STA Ethernet or Serial Digi Connect® WAN VPN Router Features/Benefits • Hardware suite includes cellular gateways, routers and VPN devices • GSM GPRS/EDGE or CDMA 1xRTT network for high-speed wireless network connectivity • Unique Digi SureLinkTM “always-on” connection maintains wireless connection for rapid on-demand communications • 10/100Base-T Ethernet and serial connections • 9-30VDC for diverse power input • Web interface for easy centralized console configuration and statistics • Integrates with Digi Connectware Manager for seamless management and monitoring of hundreds or thousands of devices • Up to 256-bit AES security provides encryption and authentication for management communications via Digi Connectware Manager • Specialized model for industrial and synchrounous applications www.digi.com VPN Tunnel Overview The Digi Connect WAN family of commercial-grade Wireless WAN (WWAN) cellular routers, gateways and VPN appliances provides secure high-speed wireless connectivity to remote sites and devices. Digi Connect WAN cellular products can be used for reliable primary wireless network connectivity to equipment at remote locations, as well as for a backup to existing landline communications. They are also ideal for use where wired networks (e.g., leased line/frame relay, ISDN, DSL) are not feasible, or where alternative network connections are required. Digi Connect WAN products are able to provide a primary wireless WAN connection to remotes sites containing both Ethernet or serial devices. New construction locations, power utility substations, small retail/POS sites or temporary facilities without primary wired connections are examples of applications for this wireless connectivity solution. For backup network applications, Digi Connect WAN cellular products integrate with remote locations via a secondary Ethernet WAN port on an existing router. This provides a truly diverse network connection for remote locations requiring maximum uptime, such as retail/POS and financial applications. Digi SureLink is a unique feature that provides a "persistent connection" over wireless networks by utilizing a three-way client and server initiated scheme. All Digi Connect WAN cellular products seamlessly integrate with Digi Connectware® Manager, which provides easy setup, configuration and maintenance of large installations. Users can upgrade firmware or change settings on thousands of devices with only a few clicks. It also makes troubleshooting simple by reporting problems like identifying misbehaving devices or network issues. Features Comparison Digi Connect WAN Wireless WAN cellular router. Provides high performance wireless TCP/IP data communications via cellular GSM/CDMA networks, for primary and backup connectivity to remote locations and devices. Digi Connect WAN VPN Central Office Wireless WAN GSM/CDMA cellular router plus integrated VPN. Creates a secure WAN connection via an Ethernet-to-cellular interface. Ethernet Internet/ Frame Relay/ VPN Wireless Telco Network Digi Connect WAN IA Digi Connect WAN Sync Industrial-grade Wireless WAN GSM/CDMA router/gateway. Offers all of the functionality of Digi Connect WAN VPN plus an industrial-grade feature set. Wireless WAN cellular router with support for legacy synchronous serial devices. Connects to remote synchronous devices, such as ATMs, using standard GSM/CMDA networks. Digi Connect® WAN AU CO NS OL Serial X L NA TH SIG RENG ST E LIN Dig iC K AC ec onn TIV E AN tW RESE ET RN T ETHE K AC LIN DC X 0V 9-3 5mA MA 52 R PW TUS T STA Ethernet Digi Connect® WAN Digi Connect® WAN VPN Digi Connect® WAN IA Digi Connect® WAN Sync Interfaces Serial Port Type RS-232/422/485 RS-232/422/485 RS-232/422/485 Synchronous 10/100 Ethernet • • • • GSM GPRS 12/EDGE 10 -or- CDMA 2000 1xRTT • • • • • • • • • • • • • • • Built-in Web Interface • • • • Digi Connectware® Manager • • • • Digi SureLink™ • • • • RealPort® Virtual COM Ports • • • • Routing NAT, Port Forwarding, DHCP Server/Client, VPN Pass-Through, Firewall - IP Filtering Integrated IPsec VPN Security SSL, SSHv2, FIPS 197, HTTPS Management Special Features • Bisync Protocol with 3270/3275 Emulation DIN Rail Mountable Terminal Block for Power, Modbus Support, Class 1, Div 2 • • • Kit Included • • Features/Specifications FEATURES • Easily accessible SIM module • Network protocols - UDP/TCP, DHCP • Status LEDs - Ethernet, power on, cellular link/activity, signal strength • Patented RealPort for COM ports and RFC 2217 Router/Firewall Features • • • • NAT Port forwarding VPN pass-through Access control lists (IP filtering) Security • SSL, SSHv2, FIPS 197 VPN Features – Digi Connect WAN VPN, Digi Connect WAN IA, Digi Connect WAN Sync • IPsec with IKE/ISAKMP • Multiple tunnel support • DES, 3DES and AES up to 256-bit encryption IA Features – Digi Connect WAN IA • • • • DIN rail mounting kit included Class 1, Div 2 rating Terminal block for power Modbus to ModbusTCP protocol conversion Sync Features FEATURES (CONT.) WIRELESS CARRIER CERTIFICATIONS Management GSM GPRS/EDGE • HTTP and CLI for web management • Optional secure enterprise management via Digi Connectware Manager ETHERNET INTERFACE • • • • Connector: RJ-45 Standard: IEEE 802.3 Physical Layer: 10/100Base-T Data rate: 10/100 Mbps (auto-sensing) • Mode: full or half duplex (auto-sensing) SERIAL INTERFACE • RS/232/422/485 • Sync/Bisync port (Digi Connect WAN Sync only) • Throughput up to 230 Kbps • Full signal support for TXD, RXD, RTS, CTS, DTR, DSR and DCD • Hardware and software flow control • Can provide diverse out-of-band console management for network devices like routers and switches ENVIRONMENTAL – Digi Connect WAN Sync • Bisynch protocol with 3270/3275 emulation RF Features – GSM Models • Network: Quadband 1900/850 and 1800/900 MHz GSM GPRS/EDGE • Transmit frequency: 1850-1910 MHz and 824-849 MHz • Receiver frequency: 1930-1990 MHz and 869-894 MHz • EDGE multi-slot class 10 • GPRS multi-slot class 12 • Throughput up to 240 Kbps, 100-130 Kbps typical • RF antenna connector: 50 Ohm SMA • Attached swivel dipole antenna RF Features – CDMA Models • Network: 800 MHz CDMA cellular: 1900 MHz CDMA PCS 1xRTT • Transmit frequency: 18511909 MHz and 824-849 MHz • Receiver frequency: 19311989 MHz and 869-894 MHz • Throughput up to 153 Kbps, 60-80 Kbps typical • RF antenna connector: 50 Ohm SMA • Attached swivel dipole antenna • Operating temperature: -30° C to 70° C (-22° F to 158° F) for GSM models • Operating temperature: -30° C to 60° C (-22° F to 140° F) for CDMA models • Relative humidity: 5% to 95% (non-condensing) • Ethernet isolation: 1500VAC min per IEEE802.3/ANSI X3.263 • Serial port protection (ESD): +15 kV Air 6 AP and +8 kV contact discharge per IEC 1000-4-2 POWER REQUIREMENTS • Power input: 9-30VDC • 12VDC power supply for 0° C to 60° C (32° F to 140° F) included; extended temperature available • DC power consumption - Idle: 1.2 W - Max: 3.4 W • AC power consumption - Idle: 2.0 W - Max: 5.8 W • Surge protection (with included power supply) - 4 kV burst (EFT) per-4-4 - 2 kV surge per EN61000-4-5 (non-condensing) • Cingular • Rogers Wireless CDMA 1xRTT • • • • • Sprint Centennial Wireless Alltel Wireless Verizon Midwest Wireless REGULATORY APPROVALS Mobile Certifications – GSM Models • PTCRB, NAPRD.03 • GCF-CC • R&TTE, EN 301 511 Mobile Certifications – CDMA Models • CDG TIA/EIA-690 • CDG TIA/EIA-98-E Safety • UL 60950 • CSA 22.2 No. 60950 • EN60950 Emissions/Immunity • CE • FCC Part 15, Class A (FCC identifier GGL-R1902G) • AS/NZS CISPR 22 • EN55024 • EN55022, Class A DIMENSIONS • • • • Width: 3.35 in (8.51 cm) Height: 0.97 in (2.47 cm) Length: 5.25 in (13.34 cm) Weight: 1.00 lb (0.45 g) Digi Connectware Manager Manage many devices at the same time with just a few clicks Easy, web based configuration Digi Connectware Manager is an enterprise remote device management software that runs on a customer's central server and can be managed via web interface from anywhere. Administrators have access to one or thousands of devices for management, monitoring, alerts and troubleshooting. Includes built-in Dynamic DNS server for mapping an Internet host name to a dynamic/public IP address. Builit-in web user interface provides simple access for local configuration or one-to-one remote access. Digi Connect WAN, Digi Connect WAN VPN, Digi Connect WAN, Sync- Front MODEL......................PART NUMBERS GSM Models North America International Digi Connect WAN GSM Digi Connect WAN VPN GSM Digi Connect WAN IA GSM Digi Connect WAN Sync GSM CDMA Models - North America Only DC-WAN-GE10A DC-VPN-GE10A DC-WAN-F501 DC-WAN-K401 Sprint DC-WAN-GE10A-W DC-VPN-GE10A-W DC-WAN-F501 N/A Verizon Alltel Digi Connect WAN CDMA Digi Connect WAN VPN CDMA Digi Connect WAN IA CDMA Digi Connect WAN Sync CDMA DC-WAN-S1XA DC-VPN-S1XA DC-WAN-G510 DC-WAN-M410 DC-WAN-D111 DC-WAN-D311 DC-WAN-G511 TBD DC-WAN-D116 DC-WAN-D316 TBD TBD Antennas North America International Power LED Dual Band Wireless 2" Monopole Antenna DC-ANT-DBMP Dual Band Wireless Desktop 2.8" DC-ANT-DBDT Antenna with 8 ft. Cable Dual Band Wireless High Gain 14" DC-ANT-DBHG Antenna with Magnetic Mount DC-ANT-DBMP-W DC-ANT-DBDT Accessories Worldwide Extended Temperature Power Supply 12VDC Locking Barrel Extended Temperature Hardened Power Supply DB-9F to DB-9F Crossover Cable (4 ft.) DIN Rail Mounting Bracket 48VDC to 12VDC Power Converter 76000717 76000652 Ethernet Antenna Reset Status Power Connector Button LED Input 9-30VDC Digi Connect WAN IA - Front Power LED Ethernet DC-ANT-DBHG Reset Status Terminal Button LED Block Antenna Connector All Models - Back 76000642 76000682 76000696 Auxiliary Port* DB-9M *Digi Connect WAN IA and Digi Connect WAN Sync do not include an auxiliary port DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 11001 Bren Road E. Minnetonka, MN 55343 U.S.A. PH: 877-912-3444 952-912-3444 FX: 952-912-4952 email: info@digi.com Digi International France Digi International KK Digi International (HK) Limited 31 rue des Poissonniers 92200 Neuilly sur Seine PH: +33-1-55-61-98-98 FX: +33-1-55-61-98-99 www.digi.fr NES Building South 8F 22-14 Sakuragaoka-cho, Shibuya-ku Tokyo 150-0031, Japan PH: +81-3-5428-0261 FX: +81-3-5428-0262 www.digi-intl.co.jp Suite 1703-05, 17/F., K Wah Centre 191 Java Road North Point, Hong Kong PH: +852-2833-1008 FX: +852-2572-9989 www.digi.cn WHEN MATTERS™ Digi International, the leader in device networking for business, develops reliable products and technologies to connect and securely manage local or remote electronic devices over the network or via the web. With over 20 million ports shipped worldwide since 1985, Digi offers the highest levels of performance, flexibility and quality. www.digi.com © 2005-2007 Digi International Inc. Digi, Digi International, the Digi logo, the When Reliability Matters logo, Digi Connect, Digi Connectware, RealPort and Digi SureLink are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. 91001371 A5/207
DC-ANT-DBMP 价格&库存
很抱歉,暂时无法提供与“DC-ANT-DBMP”相匹配的价格&库存,您可以联系我们找货
