Couplers with Connectors (H Type)
HDH Series
■Features
1.High Performance
The high frequency characteristics feature
extremely low loss, a high degree of matching, and
high isolation.
HDH-00803GHD(31)
HDH-01503GHD(31)
2.Power Uniform Distribution and
90˚Phase Difference Type
Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
This is a one input, two output (or two input, one
output) power uniform distribution type having a
90˚phase difference between the two outputs (or
two inputs).
HDH-01503GH(40)
HDH-03003GHD(31)
3.Miniature and Lightweight
Corrosion-resistant aluminum is used for the case
and the Hirose Electric original pattern design,
which uses a stripline triplate method, enables the
couplers to be miniature and lightweight.
HDH-12803CHD(31)
HDH-09003GHD(40)
4.Couplers with SMA Connectors
Use of SMA connectors (Hirose Electric HRM
Series) which feature stainless steel for the exterior
cladding make these couplers durable.
■Product Specifications
Ratings
Frequency range (Note)
Characteristic impedance
Maximum Input Power (Note)
0.5 to 14.5GHz
50ø
2 to 50 W
Operating temperature range
Operating relative humidity
-10ç to +65ç
95% Max.
Note : The frequency range and the maximum input power will differ depending on the products.
Item
1.Vibration
2.Shock
Standard
Conditions
Frequency of 10 to 2000Hz, overall amplitude of 1.52mm,
No electrical discontinuity of 1μs or more
acceleration of 98m/s2 for 2 hours in each of 3 directions
No damage, cracks, or parts dislocation
Acceleration of 490m/s2, sine half-wave waveform,
3 cycles in each of the 3 axis
Temperature : _55ç → +15ç to +35ç → +85ç → +15ç to +35ç
3.Temperature cycle No damage, cracks, or parts dislocation
Time : 30 → 15 max. → 30 → 15 max. (Minutes)
5 cycles
●The test method conforms to MIL-STD-202.
■Materials / Finish
Part
14
Material
Finish
Connector Body
Stainless steel
Passivated
Connector female contacts
Beryllium copper
Gold plating
Connector Insulator
PTFE
Case
Aluminum
Coating
Board
Dielectric
Gold plating
HDH Series●Couplers with Connectors (H Type)
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
HD H - 008 03 G H D (31)
1
2
3
4
5
1 Series Name : HD (Directional Couplers)
6
7
8
4 Coupling
03 : 3dB
2 Type of Connector
5 Frequency Relative Bandwidth
H : Indicates the HRM (SMA) Series
B : From 5% to below 10%
3 Center Frequency
C : From 10% to below 15%
008 : 0.75GHz
D : From 15% to below 20%
015 : 1.5GHz
G : From 30% to below 35%
017 : 1.7GHz
6 Form
020 : 2.0GHz
H : H Type
030 : 3.0GHz
7 D : With Termination
040 : 4.0GHz
090 : 9.0GHz
8 (31), (40) : RoHS Compliant
128 : 12.8GHz
■Specifications
Part Number
Frequency
Primary Line Secondary Line
Coupling Frequency Directivity
Range
V.S.W.R. V.S.W.R.
(dB)
Sensitivity (dB Min)
(GHz)
(Max)
(Max)
Weight
(g)
Power
(W)
HDH-00803GHD(31)
0.5∼1.0
3+0.2
±0.5
1.15
49
2
HDH-01503GH(40)
1.0∼2.0
3+0.2
±0.5
1.20
34
50
HDH-01503GHD(31)
1.0∼2.0
3+0.2
±0.5
1.20
34
2
HDH-01703CH(40)
1.5∼1.9
3+0.2
±0.3
1.20
34
50
HDH-01703CHD(31)
1.5∼1.9
3+0.2
±0.3
1.20
34
2
HDH-02003DHD(40)
1.7∼2.3
3+0.2
±0.3
18
1.20
1.20
34
2
HDH-03003GHD(31)
2.0∼4.0
3+0.2
±0.5
18
1.20
1.20
25
2
HDH-04003BH(40)
3.7∼4.2
3+0.2
±0.3
1.20
23
50
HDH-09003GHD(40)
8.0∼11.0
3+0.3
±0.5
15
1.30
1.30
31
2
HDH-12803CHD(31)
10.5∼14.5
3+0.6
±0.5
12
1.40
1.40
31
2
●Directivity have had the coupling (nominal value of 3 dB) subtracted.
●There is a phase difference of 90°between the output and the coupling.
15
■External Dimensions
(31)
(31)
(31)
(40)
(40)
(40)
(31)
(40)
(40)
(31)
16
■Typical Data
(31)
(31)
17
Couplers with Connectors (I Type)
HDH Series
■Features
1.High Performance
The high frequency characteristics feature.
Extremely high degree of matching, and high
isolation.
HDH-00810GID(31)
HDH-01510GID(31)
2.Miniature and Lightweight
3.Couplers with SMA Connectors
HDH-09010GID(31)
HDH-03020GID(31)
4.Full Coupling Variations
Full variations of coupling over 6 dB are available.
HDH-12806CID(31)
Ratings
0.5 to 14.5GHz
50ø
4 to 50 W
-10ç to +65ç
95% Max.
Item
1.Vibration
2.Shock
Standard
Conditions
Acceleration of 980m/s2, sine half-wave waveform,
5 cycles
■Materials / Finish
Part
18
Material
Finish
Connector Body
Stainless steel
Passivated
Beryllium copper
Gold plating
Connector Insulator
PTFE
Case
Aluminum
Coating
Board
Dielectric
Gold plating
HDH Series●Couplers with Connectors (I Type)
HD H - 008 10 G I D (31)
1
2
3
4
5 6 7
8
1 Series Name : HD (Directional Couplers) 4 Coupling
2 Type of Connector
3 Center Frequency
008 : 0.8GHz
009 : 0.9GHz
015 : 1.5GHz
017 : 1.7GHz
030 : 3.0GHz
090 : 9.0GHz
128 : 12.8GHz
06 : 6dB
10 : 10dB
20 : 20dB
30 : 30dB
37 : 37dB
49 : 49dB
6 Form
I : I Type, H : H Type
Isolation port with termination is designated
as D at the end of each part No.
■Specifications
Part Number
Secondary
Frequency
Frequency Insertion
Primary Line
Coupling
Directivity
Line
Weight
Range
Sensitivity Loss
V.S.W.R.
(dB MIN)
(dB)
V.S.W.R.
(g)
(dB)
(GHz)
(dB MAX)
(MAX)
(MAX)
Power
(W)
HDH-0810GID(31)
0.5~1.0
10±1.0
±0.75
0.3
1.15
49
10
HDH-00820GID(31)
0.5~1.0
20±1.0
±0.75
0.3
18
1.15
1.15
50
50
HDH-01510GID(31)
1.0~2.0
10±1.2
±0.75
0.4
1.20
34
10
HDH-01520GID(31)
1.0~2.0
20±1.2
±0.75
0.4
18
1.20
1.20
34
50
HDH-01706CID(40)
1.5~1.9
6±1.0
±0.30
0.4
18
1.20
1.20
34
05
HDH-01710CID(40)
1.5~1.9
10±1.2
±0.30
0.4
1.20
34
10
HDH-01720CID(40)
1.5~1.9
20±1.2
±0.40
0.4
1.20
34
50
HDH-01730CID(40)
1.5~1.9
30±1.5
±0.40
0.4
18
1.20
1.20
34
50
HDH-03010GID(31)
2.0~4.0
10±1.2
±0.75
0.5
18
1.20
1.20
25
10
HDH-03020GID(31)
2.0~4.0
20±1.2
±0.75
0.5
18
1.20
1.20
25
50
HDH-09010GID(31) 8.0~11.0
10±1.2
±0.75
0.5
15
1.30
1.30
24
10
HDH-09020GID(31) 8.0~11.0
20±2.0
±0.75
0.5
13
1.30
1.30
24
10
HDH-12806CID(31) 10.5~14.5
6±1.0
±0.50
2.1π
15
1.30
1.35
28
04
HDH-12810CID(40) 10.5~14.5 10±1.25
±0.50
1.1π
15
1.30
1.35
28
10
HDH-12820CID(31) 10.5~14.5 20±1.25
±0.50
0.6
15
1.30
1.35
28
50
●The coupling loss component is not included in the insertion loss (unless the item is marked with an π symbol)
19
(31)
(31)
(31)
(40)
(31)
(31)
(40)
(31)
(40)
(31)
(31)
(40)
■Typical Data
HDH-03020GID(31)
HDH-09010GID(31)
HDH-01510GID(31)
Powered by TCPDF (www.tcpdf.org)
21
很抱歉,暂时无法提供与“HDH-00810GID(40)”相匹配的价格&库存,您可以联系我们找货
