HDH-01503GH(40)
HDH-01503GH(40)
    HRS(广濑)
    COUPLER H TYPE 1.5GHZ 3DB
HDH-01503GH(40) 数据手册
Couplers with Connectors (H Type) HDH Series ■Features 1.High Performance The high frequency characteristics feature extremely low loss, a high degree of matching, and high isolation. HDH-00803GHD(31) HDH-01503GHD(31) 2.Power Uniform Distribution and 90˚Phase Difference Type Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. This is a one input, two output (or two input, one output) power uniform distribution type having a 90˚phase difference between the two outputs (or two inputs). HDH-01503GH(40) HDH-03003GHD(31) 3.Miniature and Lightweight Corrosion-resistant aluminum is used for the case and the Hirose Electric original pattern design, which uses a stripline triplate method, enables the couplers to be miniature and lightweight. HDH-12803CHD(31) HDH-09003GHD(40) 4.Couplers with SMA Connectors Use of SMA connectors (Hirose Electric HRM Series) which feature stainless steel for the exterior cladding make these couplers durable. ■Product Specifications Ratings Frequency range (Note) Characteristic impedance Maximum Input Power (Note) 0.5 to 14.5GHz 50ø 2 to 50 W Operating temperature range Operating relative humidity -10ç to +65ç 95% Max. Note : The frequency range and the maximum input power will differ depending on the products. Item 1.Vibration 2.Shock Standard Conditions Frequency of 10 to 2000Hz, overall amplitude of 1.52mm, No electrical discontinuity of 1μs or more acceleration of 98m/s2 for 2 hours in each of 3 directions No damage, cracks, or parts dislocation Acceleration of 490m/s2, sine half-wave waveform, 3 cycles in each of the 3 axis Temperature : _55ç → +15ç to +35ç → +85ç → +15ç to +35ç 3.Temperature cycle No damage, cracks, or parts dislocation Time : 30 → 15 max. → 30 → 15 max. (Minutes) 5 cycles ●The test method conforms to MIL-STD-202. ■Materials / Finish Part 14 Material Finish Connector Body Stainless steel Passivated Connector female contacts Beryllium copper Gold plating Connector Insulator PTFE --------- Case Aluminum Coating Board Dielectric Gold plating HDH Series●Couplers with Connectors (H Type) ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HD H - 008 03 G H D (31) 1 2 3 4 5 1 Series Name : HD (Directional Couplers) 6 7 8 4 Coupling 03 : 3dB 2 Type of Connector 5 Frequency Relative Bandwidth Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. H : Indicates the HRM (SMA) Series B : From 5% to below 10% 3 Center Frequency C : From 10% to below 15% 008 : 0.75GHz D : From 15% to below 20% 015 : 1.5GHz G : From 30% to below 35% 017 : 1.7GHz 6 Form 020 : 2.0GHz H : H Type 030 : 3.0GHz 7 D : With Termination 040 : 4.0GHz 090 : 9.0GHz 8 (31), (40) : RoHS Compliant 128 : 12.8GHz ■Specifications Part Number Frequency Primary Line Secondary Line Coupling Frequency Directivity Range V.S.W.R. V.S.W.R. (dB) Sensitivity (dB Min) (GHz) (Max) (Max) Weight (g) Power (W) HDH-00803GHD(31) 0.5∼1.0 3+0.2 0 ±0.5 20 1.15 1.15 49 2 HDH-01503GH(40) 1.0∼2.0 3+0.2 0 ±0.5 20 1.20 1.20 34 50 HDH-01503GHD(31) 1.0∼2.0 3+0.2 0 ±0.5 20 1.20 1.20 34 2 HDH-01703CH(40) 1.5∼1.9 3+0.2 0 ±0.3 20 1.20 1.20 34 50 HDH-01703CHD(31) 1.5∼1.9 3+0.2 0 ±0.3 20 1.20 1.20 34 2 HDH-02003DHD(40) 1.7∼2.3 3+0.2 0 ±0.3 18 1.20 1.20 34 2 HDH-03003GHD(31) 2.0∼4.0 3+0.2 0 ±0.5 18 1.20 1.20 25 2 HDH-04003BH(40) 3.7∼4.2 3+0.2 0 ±0.3 20 1.20 1.20 23 50 HDH-09003GHD(40) 8.0∼11.0 3+0.3 0 ±0.5 15 1.30 1.30 31 2 HDH-12803CHD(31) 10.5∼14.5 3+0.6 0 ±0.5 12 1.40 1.40 31 2 ●Directivity have had the coupling (nominal value of 3 dB) subtracted. ●There is a phase difference of 90°between the output and the coupling. 15 HDH Series●Couplers with Connectors (H Type) Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■External Dimensions (31) (31) (31) (40) (40) (40) (31) (40) (40) (31) 16 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HDH Series●Couplers with Connectors (H Type) ■Typical Data (31) (31) 17 Couplers with Connectors (I Type) HDH Series ■Features 1.High Performance The high frequency characteristics feature. Extremely high degree of matching, and high isolation. HDH-00810GID(31) HDH-01510GID(31) 2.Miniature and Lightweight Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Corrosion-resistant aluminum is used for the case and the Hirose Electric original pattern design, which uses a stripline triplate method, enables the couplers to be miniature and lightweight. 3.Couplers with SMA Connectors HDH-09010GID(31) HDH-03020GID(31) Use of SMA connectors (Hirose Electric HRM Series) which feature stainless steel for the exterior cladding make these couplers durable. 4.Full Coupling Variations Full variations of coupling over 6 dB are available. HDH-12806CID(31) ■Product Specifications Ratings Frequency range (Note) Characteristic impedance Maximum Input Power (Note) 0.5 to 14.5GHz 50ø 4 to 50 W Operating temperature range Operating relative humidity -10ç to +65ç 95% Max. Note : The frequency range and the maximum input power will differ depending on the products. Item 1.Vibration 2.Shock Standard Conditions Frequency of 10 to 2000Hz, overall amplitude of 1.52mm, No electrical discontinuity of 1μs or more acceleration of 98m/s2 for 2 hours in each of 3 directions No damage, cracks, or parts dislocation Acceleration of 980m/s2, sine half-wave waveform, 3 cycles in each of the 3 axis Temperature : _55ç → +15ç to +35ç → +85ç → +15ç to +35ç 3.Temperature cycle No damage, cracks, or parts dislocation Time : 30 → 15 max. → 30 → 15 max. (Minutes) 5 cycles ●The test method conforms to MIL-STD-202. ■Materials / Finish Part 18 Material Finish Connector Body Stainless steel Passivated Connector female contacts Beryllium copper Gold plating Connector Insulator PTFE --------- Case Aluminum Coating Board Dielectric Gold plating HDH Series●Couplers with Connectors (I Type) ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HD H - 008 10 G I D (31) 1 2 3 4 5 6 7 8 1 Series Name : HD (Directional Couplers) 4 Coupling 2 Type of Connector Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. H : Indicates the HRM (SMA) Series 3 Center Frequency 008 : 0.8GHz 009 : 0.9GHz 015 : 1.5GHz 017 : 1.7GHz 030 : 3.0GHz 090 : 9.0GHz 128 : 12.8GHz 06 : 6dB 10 : 10dB 20 : 20dB 30 : 30dB 37 : 37dB 49 : 49dB 5 Frequency Relative Bandwidth C : From 10% to below 15% G : From 30% to below 35% 6 Form I : I Type, H : H Type 7 D : With Termination Isolation port with termination is designated as D at the end of each part No. 8 (31), (40) : RoHS Compliant ■Specifications Part Number Secondary Frequency Frequency Insertion Primary Line Coupling Directivity Line Weight Range Sensitivity Loss V.S.W.R. (dB MIN) (dB) V.S.W.R. (g) (dB) (GHz) (dB MAX) (MAX) (MAX) Power (W) HDH-0810GID(31) 0.5~1.0 10±1.0 ±0.75 0.3 20 1.15 1.15 49 10 HDH-00820GID(31) 0.5~1.0 20±1.0 ±0.75 0.3 18 1.15 1.15 50 50 HDH-01510GID(31) 1.0~2.0 10±1.2 ±0.75 0.4 20 1.20 1.20 34 10 HDH-01520GID(31) 1.0~2.0 20±1.2 ±0.75 0.4 18 1.20 1.20 34 50 HDH-01706CID(40) 1.5~1.9 6±1.0 ±0.30 0.4 18 1.20 1.20 34 05 HDH-01710CID(40) 1.5~1.9 10±1.2 ±0.30 0.4 20 1.20 1.20 34 10 HDH-01720CID(40) 1.5~1.9 20±1.2 ±0.40 0.4 20 1.20 1.20 34 50 HDH-01730CID(40) 1.5~1.9 30±1.5 ±0.40 0.4 18 1.20 1.20 34 50 HDH-03010GID(31) 2.0~4.0 10±1.2 ±0.75 0.5 18 1.20 1.20 25 10 HDH-03020GID(31) 2.0~4.0 20±1.2 ±0.75 0.5 18 1.20 1.20 25 50 HDH-09010GID(31) 8.0~11.0 10±1.2 ±0.75 0.5 15 1.30 1.30 24 10 HDH-09020GID(31) 8.0~11.0 20±2.0 ±0.75 0.5 13 1.30 1.30 24 10 HDH-12806CID(31) 10.5~14.5 6±1.0 ±0.50 2.1π 15 1.30 1.35 28 04 HDH-12810CID(40) 10.5~14.5 10±1.25 ±0.50 1.1π 15 1.30 1.35 28 10 HDH-12820CID(31) 10.5~14.5 20±1.25 ±0.50 0.6 15 1.30 1.35 28 50 ●The coupling loss component is not included in the insertion loss (unless the item is marked with an π symbol) 19 HDH Series●Couplers with Connectors (I Type) ■External Dimensions Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (31) (31) (31) (40) (31) (31) (40) (31) 20 (40) (40) (31) (31) (40) HDH Series●Couplers with Connectors (I Type) ■Typical Data HDH-03020GID(31) HDH-09010GID(31) Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HDH-01510GID(31) Powered by TCPDF (www.tcpdf.org) 21
HDH-01503GH(40)
1. 物料型号:文档列出了多种型号的耦合器,例如HDH-00803GHD(31)、HDH-01503GH(40)等。
2. 器件简介:耦合器具有一个输入两个输出(或两个输入一个输出)的功率均匀分配类型,两个输出(或输入)之间有90度的相位差。产品采用小型轻量设计,使用耐腐蚀的铝合金材料和Hirose Electric原创的stripline triplate方法。
3. 引脚分配:文档中没有提供具体的引脚分配图,但提到了使用SMA连接器(Hirose Electric HRM系列)。
4. 参数特性:耦合器的工作频率范围是0.5至14.5GHz,特征阻抗为50欧姆,工作温度范围是-10°C至+65°C。还提供了详细的振动、冲击和温度循环测试条件。
5. 功能详解:耦合器具有高性能的高频特性,包括极低的损耗、高匹配度和高隔离度。
6. 应用信息:文档中没有明确提供应用信息,但根据耦合器的特性,它们可能用于需要功率分配和相位差的高频通信设备。
7. 封装信息:文档提供了耦合器的外部尺寸和重量信息。
HDH-01503GH(40) 价格&库存
很抱歉,暂时无法提供与“HDH-01503GH(40)”相匹配的价格&库存,您可以联系我们找货
