CPL-5044-20-NNN-79
CPL-5044-20-NNN-79
    CINCH
    N型直插式模块
    COUPLER20DB0.5-1GHZ
CPL-5044-20-NNN-79 数据手册
Couplers • • • • 500 Watt High Performance Directional Couplers - N • TNC Types 500 MHz to 18.0 GHz Frequency Range Low VSWR - High Directivity 500 Watt High Power Capability Individually Calibrated Midwest Microwave's series of High Power Directional Couplers are useable for system or testing where flat frequency response over extended bandwidths is required. They possess high directivity and will withstand high input power under extreme environmental conditions. Standard units have stainless Note: Case Style 7 has two mounting holes. steel Type N female connectors but are also available with TNC connectors. ELECTRICAL SPECIFICATIONS Frequency R an g e (GH z ) .5-1.0 1.0-2.0 2.0-4.0 4.0-10.0 7.0-12.4 C oupling (dB ) (Incl Freq Sensitivity) Frequency Sensitivity (dB ) Insertion L o ss (dB ) max D irectivity (dB ) min VSWR max C PL-5044-10-N N N -79 10 + 1.0 + 0.75 0.20 30 1.15 200 50 10 1 C PL-5044-20-N N N -79 20 + 1.0 + 0.75 0.20 30 1.15 500 500 10 2 C PL-5044-30-N N N -79 30 + 1.0 + 0.75 0.20 30 1.15 500 500 10 3 C PL-5045-10-N N N -79 10 + 1.0 + 0.75 0.20 30 1.15 200 50 10 3 C PL-5045-20-N N N -79 20 + 1.0 + 0.75 0.20 30 1.15 500 500 10 4 C PL-5045-30-N N N -79 30 + 1.0 + 0.75 0.20 30 1.15 500 500 10 3 C PL-5046-10-N N N -79 10 + 1.0 + 0.75 0.20 25 1.15 200 50 10 3 C PL-5046-20-N N N -79 20 + 1.0 + 0.75 0.20 27 1.15 500 500 10 4 C PL-5046-30-N N N -79 30 + 1.0 + 0.75 0.20 27 1.15 500 500 10 5 C PL-5047-10-N N N -79 10 + 1.0 + 0.75 0.25 20* 1.20 200 50 10 5 C PL-5047-20-N N N -79 20 + 1.0 + 0.75 0.25 20* 1.20 500 500 10 6 C PL-5047-30-N N N -79 30 + 1.0 + 0.75 0.25 20* 1.20 500 500 10 7 C PL-5048-10-N N N -79 10 + .75 + 0.75 0.25 15 1.25 200 50 10 7 C PL-5048-20-N N N -79 20 + .75 + 0.75 0.25 15 1.25 500 500 10 7 C PL-5048-30-N N N -79 30 + .75 + 0.75 0.25 15 1.25 500 500 10 C ase Style Model N umber 1 C ASE STYLE MECHANICAL SPECIFICATIONS - Pow er (In) Avg Avg Avg In R ef P eak (W) (W) (kW) * Directivity is 17 dB from 8.0 - 10.0 GHz. INCHES (mm) WEIGH T Lbs Kg A B C D E F 6.25 (158.8) 3.00 (76.2) 0.51 (13.0) 2.13 (54.0) 0.87 (22.1) 1.687 (42.9) 1.2 3 6.25 (158.8) 3.00 (76.2) 0.51 (13.0) 2.13 (54.0) 0.69 (17.5) 1.687 (42.9) 1.2 0.52 4.10 (104.1) 1.09 (27.7) 0.50 (12.7) 2.13 (54.0) 0.87 (22.1) 1.687 (42.9) 1.0 0.45 5 4.10 (104.1) 1.09 (27.7) 0.50 (12.7) 2.13 (54.0) 0.69 (17.5) 1.687 (42.9) 1.0 0.45 5.10 (129.5) 2.00 (50.8) 0.66 (16.8) 2.13 (54.0) 0.57 (14.5) 1.687 (42.9) 1.1 0.50 5.10 (129.5) 2.00 (50.8) 0.57 (14.5) 2.13 (54.0) 0.69 (17.5) 1.687 (42.9) 1.1 0.50 2.50 (63.5) 1.13 (28.7) 0.60 (15.2) 1.50 (38.1) 0.60 (15.2) 1.093 (27.8) 0.8 0.40 1 2 4 6 7 0.52 Note: TNC or Type N output connectors are available by substituting "TNC" or "NNN" for "SMA" in the Model Number. 97
CPL-5044-20-NNN-79 价格&库存
很抱歉,暂时无法提供与“CPL-5044-20-NNN-79”相匹配的价格&库存,您可以联系我们找货
