CPL-5210-30-SMA-79
CPL-5210-30-SMA-79
    CINCH
    SMA单排模块
    COUPLER30DB0.5-1GHZ
CPL-5210-30-SMA-79 数据手册
Couplers Directional Couplers • Octave Bandwidth SMA Miniature High Performance • • • • Full Octave Frequency Band Performance Low VSWR - High Directivity Small Lightweight Meets Mil-E-5400 and Mil-E16400 Midwest Microwave's SMA miniature series of high performance directional couplers are small, lightweight, ruggedly constructed stripline units that posses inherently low insertion loss and VSWR with high directivity Units are available in octave frequency bandwidths covering the entire range of 0.5-18.0 GHz. ELECTRICAL SPECIFICATIONS FREQUENCY RANGE (GHZ) 0.5 - 1.0 1.0 - 2.0 2.0 - 4.0 2.6 - 5.2 4.0 - 8.0 7.0 - 12.4 7.0 - 18.0 12.4 - 18.0 CASE STYLE COUPLING (dB) (incl Freq Sensitivity) FREQUENCY SENSITIVITY INSERTION LOSS (dB) max DIRECTIVITY (dB) max VSWR max Input Avg (W) CPL-5210-10-SMA-79 10 ± 1.0 ± 0.75 0.15 25 1.10 50 10 CPL-5210-30-SMA-79 30 ± 1.0 ± 0.75 0.15 25 50 50 ± 0.75 0.20 MODEL NUMBER 4 CPL-5210-06-SMA-79 4 CPL-5210-20-SMA-79 4 4 3 3 3 3 CPL-5211-06-SMA-79 6 ± 1.0 20 ± 1.0 6 ± 1.0 CPL-5211-10-SMA-79 10 ± 1.0 CPL-5211-30-SMA-79 30 ± 1.0 CPL-5211-20-SMA-79 2 CPL-5212-06-SMA-79 2 CPL-5212-20-SMA-79 20 ± 1.0 6 ± 1.0 CPL-5212-10-SMA-79 10 ± 1.0 2 CPL-5212-30-SMA-79 30 ± 1.0 1 CPL-5213-10-SMA-79 10 ± 1.0 CPL-5213-30-SMA-79 30 ± 1.0 2 1 1 5 1 1 1 5 1 1 1 5 1 1 1 5 1 1 1 5 CPL-5213-06-SMA-79 CPL-5213-20-SMA-79 CPL-5214-06-SMA-79 20 ± 1.0 6 ± 1.0 20 ± 1.0 6 ± 1.0 CPL-5214-10-SMA-79 10 ± 1.0 CPL-5214-30-SMA-79 30 ± 1.0 CPL-5214-20-SMA-79 CPL-5215-06-SMA-79 20 ± 1.0 6 ± 1.0 CPL-5215-10-SMA-79 10 ± .75 CPL-5215-30-SMA-79 30 ± 1.0 CPL-5215-20-SMA-79 CPL-5216-06-SMA-79 20 ± .75 6 ± 1.0 CPL-5216-10-SMA-79 10 ± 1.0 CPL-5216-30-SMA-79 30 ± 1.0 CPL-5216-20-SMA-79 CPL-5217-06-SMA-79 20 ± 1.0 6 ± 1.0 CPL-5217-10-SMA-79 10 ± 1.0 CPL-5217-30-SMA-79 30 ± 1.0 CPL-5217-20-SMA-79 20 ± 1.0 ± 0.60 ± 0.75 ± 0.60 ± 0.75 ± 0.75 ± 0.60 0.15 015 0.20 0.20 0.20 0.20 ± 0.75 0.20 ± 0.75 0.20 ± 0.75 ± 0.60 ± 0.75 ± 0.75 ± 0.75 ± 0.50 ± 0.50 ± 0.50 ± 0.50 ± 0.40 ± 0.50 ± 0.50 ± 0.50 ± 0.50 ± 0.50 ± 0.75 ± 0.75 ± 0.40 ± 0.50 ± 0.75 ± 0.75 0.20 0.25 0.25 0.25 0.25 0.35 0.35 0.35 0.35 0.40 0.40 0.30 0.30 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 25 25 25 25 25 25 22 22 22 22 20 20 20 20 20 20 20 20 17 17 17 17 15 15 15 15 15 15 15 15 1.10 1.10 1.10 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.35 1.35 1.35 1.35 1.35 1.40 1.45 1.45 1.35 1.45 1.45 1.45 50 50 50 INPUT Refl Peak Avg Avg (W) (W) 4 4 50 4 4 50 10 50 50 50 50 50 4 50 10 50 50 50 50 50 4 50 10 50 50 50 50 50 4 50 10 50 50 50 50 50 4 50 10 50 50 50 50 50 50 50 50 50 4 0 50 50 4 50 10 50 50 50 50 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 3 3 3 2 2 2 2 Note: TNC or Type N output connectors are available by substituting "TNC" or "NNN" for "SMA" in the Model Number. See next page for dimensions. 91
CPL-5210-30-SMA-79
物料型号:文档中列出了多个型号,例如CPL-5210-06-SMA-79、CPL-5211-10-SMA-79等,这些型号代表不同的耦合器。
器件简介:Midwest Microwave的SMA微型高性能定向耦合器是小型、轻便、坚固的带状线单元,具有固有的低插入损耗和VSWR以及高方向性。这些单元在0.5-18.0 GHz的整个范围内提供倍频带宽。
引脚分配:文档中没有明确提到引脚分配,但提到了输入和输出端口的典型值,例如输入平均功率(W)和反射平均功率(W)。
参数特性:耦合值、频率灵敏度、插入损耗、方向性、VSWR等参数在文档中有详细说明,例如耦合值从6±1.0 dB到30±1.0 dB不等,频率灵敏度从±0.40到±0.75不等。
功能详解:文档没有提供详细的功能解释,但可以推断这些耦合器用于在特定频率范围内传输和测量信号。
应用信息:文档指出这些耦合器符合Mil-E-5400和Mil-E16400标准,适用于军事和商业应用。
封装信息:文档提到了TNC或N型输出连接器的可用性,可以通过在型号编号中替换"SMA"为"TNC"或"NNN"来选择。
CPL-5210-30-SMA-79 价格&库存
很抱歉,暂时无法提供与“CPL-5210-30-SMA-79”相匹配的价格&库存,您可以联系我们找货
