NJG1544HC3-TE1#
NJG1544HC3-TE1#
    NJR(新日本无线)
    WFDFN10_EP
    IC MMIC SWITCH ANTENNA 2X2 10USB
NJG1544HC3-TE1# 数据手册
NJG1544HC3 2x2 Antenna SWITCH GaAs MMIC QGENERAL DESCRIPTION NJG1544HC3 is a 2x2 antenna switch IC designed for the IEEE 802.11b or 802.11g (2.4GHz band) wireless LAN application. This device includes logic decoder function, and can be operated by 2 bits signal to control Tx/Rx and ANT1/ANT2 switching. This switch features high isolation and low loss. The ultra small & ultra thin USB10-C3 package is adopted. QFEATURES OSingle low voltage control OLow insertion loss OHigh isolation OHandling power (TX port) OLow current consumption OUltra small & ultra thin package QPACKAGE OUTLINE NJG1544HC3 +2.5~+5.5V 0.35dB typ. @TX-ANT2,f=2.5GHz, PIN=20dBm 0.50dB typ. @RX-ANT1,RX-ANT2,f=2.5GHz, PIN=10dBm 23dB typ. @f=2.5GHz, PIN=20dBm 28dBm max. @f=2.5GHz, VDD=2.7V 120uA typ. @f=2.5GHz USB10-C3 (Package size: 1.5x2.0x0.75mm) QPIN CONFIGURATION USB10-C3 Type (TOP VIEW) 5 6 4 D E C O D E R 7 8 9 3 2 1 1 2 3 4 5 6 7 8 9 10 ANT1 CTL1 CTL2 ANT2 GND TX GND VDD RX GND 10 QTRUTH TABLE "H"=VCTL(H) "L"=VCTL(L) "X"="H" or "L" (Don't care) PASS RX-ANT2 RX-ANT1 TX-ANT2 CONTROL SIGNAL CTL1 CTL2 L L L H H X -1- NJG1544HC3 QABSOLUTE MAXIMUM RATINGS PARAMETER Input Power SYMBOL Pin CONDITIONS RATINGS UNITS TX, ANT2 Terminal, VDD=2.7V, VCTL=0/2.7V 30 dBm RX, ANT1 Terminal, VDD=2.7V, VCTL=0/2.7V 25 dBm Supply Voltage VDD VDD Terminal 7.5 V Control Voltage VCTL CTL1, CTL2 Terminal 7.5 V At on PCB board 135 mW Power Dissipation PD Operating Temp. Topr -40~+85 °C Storage Temp. Tstg -55~+125 °C QELECTRICAL CHARACTERISTICS General conditions: VDD=2.7V, VCTL=0/2.7V, ZS=Zl=50Ω, Ta=25°C Tested on PCB circuit as shown below. Insertion loss of each connectors, striplines, and capacitors are excluded. PARAMETERS SYMBOL Supply voltage VDD Operating current IDD CONDITIONS f=2.5GHz MIN TYP MAX UNITS 2.5 2.7 5.5 V - 120 150 uA Control voltage (LOW) VCTL (L) 0 - 0.8 V Control voltage (HIGH) VCTL (H) 2.0 - VDD V f=2.5GHz - 30 40 uA TX-ANT2, f=2.5GHz, PIN=20dBm - 0.35 0.65 dB - 0.5 0.8 dB 20 23 - dB 20 23 - dB 26 28 - dBm f=0.1~2.5GHz, ON State - 1.1 1.3 f=0.1~2.5GHz - 200 300 Control current ICTL Insertion loss 1 LOSS1 Insertion loss 2 LOSS2 Isolation 1 ISL1 Isolation 2 ISL2 Pin at 1dB compression point P-1dB VSWR Switching time -2- VSWR TSW RX-ANT1, RX-ANT2, f=2.5GHz, PIN=10dBm TX-ANT2, f=2.5GHz, Pin=20dBm RX-ANT1, RX-ANT2, f=2.5GHz, Pin=10dBm TX-ANT2, f=2.5GHz ns NJG1544HC3 QTERMINAL INFORMATION No. 1 SYMBOL ANT1 DESCRIPTION RF receiving port. An external capacitor of around 56pF is required to block DC voltage (VDD). 2 CTL1 Control voltage input terminal. This terminal is set to High-Level (+2V~VDD) or Low-Level (0~+0.8V). 3 CTL2 Control voltage input terminal. This terminal is set to High-Level (+2V~VDD) or Low-Level (0~+0.8V). 4 ANT2 5 GND 6 TX 7 GND 8 VDD RF transmitting/receiving port. An external capacitor of 56pF is required to block DC voltage (VDD) . Ground terminal. Please connect this terminal with ground plane as close as possible for excellent RF performance. RF transmitting port. An external capacitor of around 56pF is required to block DC voltage (VDD). Ground terminal. Please connect this terminal with ground plane as close as possible for excellent RF performance. Positive voltage supply terminal. The positive voltage (+2.5~+5.5V) have to be supplied. Please connect a bypass capacitor with GND terminal for excellent RF performance. 9 10 RX GND RF receiving port. An external capacitor of around 56pF is required to block DC voltage (VDD) . Ground terminal. Please connect this terminal with ground plane as close as possible for excellent RF performance. -3- NJG1544HC3 QELECTRICAL CHARACTERISTICS (f=0.1~3.0GHz, with Application circuit, Losses of external circuit are excluded) RX-ANT2 Isolation vs. Frequency RX-ANT2 Insertion Loss vs. Frequency (TX-ANT2 ON, VDD=2.7V, Pin=0dBm) (RX-ANT2 ON, VDD=2.7V, Pin=0dBm) 0 -10 -0.5 Isolation (dB) Insertion Loss (dB) 0.0 -1.0 -20 -30 -1.5 -40 -2.0 0.0 0.5 1.0 1.5 2.0 2.5 -50 0.0 3.0 Insertion Loss (dB) 1.5 2.0 2.5 Frequency (GHz) RX-ANT1 Insertion Loss vs. Frequency RX-ANT1 Isolation vs. Frequency 3.0 (RX-ANT2 ON, VDD=2.7V, Pin=0dBm) 0 0.0 -10 -0.5 -20 -1.0 -30 -1.5 -40 -2.0 0.0 0.5 1.0 1.5 2.0 2.5 -50 0.0 3.0 0.5 1.0 1.5 2.0 2.5 Frequency (GHz) Frequency (GHz) TX-ANT2 Insertion Loss vs. Frequency TX-ANT2 Isolation vs. frequency (TX-ANT2 ON, VDD=2.7V, Pin=0dBm) 3.0 (RX-ANT2 ON, VDD=2.7V, Pin=0dBm) 0.0 0 -10 -0.5 Isolation (dB) Insertion Loss (dB) 1.0 Frequency (GHz) (RX-ANT1 ON, VDD=2.7V, Pin=0dBm) -1.0 -20 -30 -1.5 -40 -2.0 0.0 0.5 1.0 1.5 2.0 Frequency (GHz) -4- 0.5 2.5 3.0 -50 0.0 0.5 1.0 1.5 2.0 Frequency (GHz) 2.5 3.0 NJG1544HC3 QELECTRICAL CHARACTERISTICS (f=0.1~3.0GHz, with Application circuit, Losses of external circuit are excluded) RX-ANT2 VSWR vs. Frequency Switching Speed (RX-ANT2 ON, ANT2 port, VDD=2.7V) (RX-ANT2 ON, VDD=2.7V) 2.0 VSWR 1.8 209ns 1.6 1.4 1.2 1.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 Frequency (GHz) 50ns/div RX-ANT1 VSWR vs. Frequency Switching Speed (RX-ANT1 ON, ANT1 port, VDD=2.7V) (RX-ANT1 ON, VDD=2.7V) 2.0 VSWR 1.8 192ns 1.6 1.4 1.2 1.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 50ns/div Frequency (GHz) TX-ANT2 VSWR vs. Frequency Switching Speed (TX-ANT2 ON, TX port, VDD=2.7V) (TX-ANT2 ON, VDD=2.7V) 2.0 VSWR 1.8 189ns 1.6 1.4 1.2 1.0 0.0 0.5 1.0 1.5 2.0 Frequency (GHz) 2.5 3.0 50ns/div -5- NJG1544HC3 QELECTRICAL CHARACTERISTICS (f=0.1~3.0GHz, with Application circuit, Losses of external circuit are excluded) RX-ANT2 Isolation vs. Frequency Output Power, IDD vs. Input Power (TX-ANT2 ON, VDD=2.7V, Pin=0dBm) 160 25 150 0 -10 20 140 15 IDD (uA) Isolation (dB) Output Power (dBm) (TX-ANT2 ON, fin=2.5GHz) 30 -20 -30 130 -40 10 -50 0.0 120 14 16 18 20 22 24 26 28 30 0.5 1.0 1.5 2.0 2.5 3.0 Frequency (GHz) Input Power (dBm) Insertion Loss vs. Input Power Output Power, IDD vs. Input Power (TX-ANT2 ON, fin=960MHz) (TX-ANT2 ON, fin=960MHz) 0.0 160 30 140 20 130 15 Insertion Loss (dB) 150 25 IDD (uA) Output Power (dBm) -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 120 10 16 18 20 22 24 26 28 30 16 32 18 Output Power, IDD vs. Input Power 20 300 15 200 10 100 24 26 28 Input Power (dBm) -6- 30 32 34 Insertion Loss (dB) 400 22 30 32 -0.5 500 25 20 28 0.0 IDD (uA) Output Power (dBm) VDD=2.5V VDD=2.7V VDD=3.0V VDD=3.5V VDD=4.5V VDD=5.5V 18 26 (TX-ANT2 ON, fin=2.5GHz) 600 16 24 Insertion Loss vs. Input Power (TX-ANT2 ON, fin=2.5GHz) 35 14 22 Input Power (dBm) Input Power (dBm) 30 20 -1.0 -1.5 -2.0 VDD=2.5V VDD=2.7V VDD=3.0V VDD=3.5V VDD=4.5V VDD=5.5V -2.5 -3.0 14 16 18 20 22 24 26 28 Input Power (dBm) 30 32 34 NJG1544HC3 QAPPLICATION CIRCUIT GND 5 TX C1 ANT2 C3 6 4 D E C O D E R GND 7 VDD(2.7V) 8 CTL2(0V/2.7V) 3 C6 CTL1(0V/2.7V) 2 C5 C7 ANT1 RX 9 1 C4 C2 10 GND NJG1544HC3 Parts List Parts number C1~C4 C5~C7 List 1 56pF 10pF Notes GRM36 MURATA GRM36 MURATA Q RECOMMENDED PCB DESIGN C6 C7 PCB SIZE=26x26 mm PCB:FR4 t=0.5mm CAPACITOR: size 1005 Microstrip Line Width=1.0mm (Zo=50ohm) PRECAUTIONS [1] The DC blocking capacitors have to be placed at RF terminal of Tx, Rx, ANT1 and ANT2. Please choose appropriate capacitance values to the application frequency. [2] To reduce stlipline influence on RF characteristics, please locate bypass capacitors (C5) close to VDD terminals. [3] For good isolation, the GND terminal (7th pin) must be placed possibly close to ground plane of substrate, and through holes for GND should be placed near by the pin connection. -7- NJG1544HC3 QPACKAGE OUTLINE (USB10-C3) (TOP VIEW) (SIDE VIEW) 1pin INDEX 0.038±0.01 0.14±0.05 0.75 0.8±0.05 2.0±0.05 0.5±0.1 0.5±0.1 0.5±0.1 :Au :FR5 : Epoxy resin :mm :7mg R0.075 0.2±0.1 4 0.3±0.05 10 5 9 8 7 0.2±0.05 6 0.2±0.05 (BOTTOM VIEW) Cautions on using this product This product contains Gallium-Arsenide (GaAs) which is a harmful material. • Do NOT eat or put into mouth. • Do NOT dispose in fire or break up this product. • Do NOT chemically make gas or powder with this product. • To waste this product, please obey the relating law of your country. This product may be damaged with electric static discharge (ESD) or spike voltage. Please handle with care to avoid these damages. -8- 3 0.2±0.1 TERMINAL TREAT PCB Molding material UNIT WEIGHT 2 0.3±0.1 1.5±0.05 1 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including
NJG1544HC3-TE1# 价格&库存
很抱歉,暂时无法提供与“NJG1544HC3-TE1#”相匹配的价格&库存,您可以联系我们找货
