RXM-315-LR
RXM-315-LR
    LINXTECHNOLOGIES(灵思)
    SMD16
    RXM-315-LR
RXM-315-LR 数据手册
LR Series Receiver Module Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1^ 1^ 1^ NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2^ Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 7^ Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 2^ 3^ 5^ 7^ 8^ 9^ 10^ 11^ 12^ 13^ 13^ 14^ 15^ 16^ 17^ 17^ 18^ 19^ 19^ 21^ 22^ 22^ 22^ 24^ Description Features Applications Ordering Information Absolute Maximum Ratings Electrical Specifications Typical Performance Graphs Pin Assignments Pin Descriptions Module Description Theory of Operation Using the RSSI Pin The Data Output Using the PDN Line Power Supply Requirements ESD Concerns Typical Applications Transferring Data Antenna Considerations Helpful Application Notes from Linx Protocol Guidelines Interference Considerations Pad Layout Board Layout Guidelines Microstrip Details Production Guidelines Hand Assembly Automated Assembly General Antenna Rules 26^ Common Antenna Styles 28^ Regulatory Considerations 30^ Notes LR Series Receiver Module Data Guide Description 0.812 in (20.6mm) The LR Receiver is ideal for the wireless transfer of serial data, control, or command information in 0.630 in the favorable 260 to 470MHz band. The receiver’s RXM-315-LR (16mm) LOT RRxxxx advanced synthesized architecture achieves an outstanding typical sensitivity of –112dBm, which 0.125 in provides a 5 to 10 times improvement in range over (3.12 mm) previous solutions. When paired with a compatible Figure 1: Package Dimensions Linx transmitter, a reliable wireless link is formed capable of transferring serial data at rates of up to 10,000bps at distances of up to 1.5 miles (2,500m). This range may be reduced depending on the regulations in the country of operation. Applications operating over shorter distances or at lower data rates also benefit from increased link reliability and superior noise immunity. Housed in a tiny reflow-compatible SMD package, no external RF components are required (except an antenna), allowing for easy integration, even for engineers without previous RF experience. Features • • • • • • Long range Low cost PLL-synthesized architecture Direct serial interface Data rates up to 10,000bps No external RF components required • Low power consumption • Low supply voltage (2.1 to 3.6VDC) • Compact surface-mount package • Wide temperature range • RSSI and Power-down function • No production tuning Applications • • • • • • Remote control Keyless entry Garage/gate openers Lighting control Medical monitoring/call systems Remote industrial monitoring • • • • • • – 1 – Periodic data transfer Home/industrial automation Fire/security alarms Remote status/position sensing Long-range RFID Wire elimination Revised 3/18/2015 Ordering Information Electrical Specifications Ordering Information LR Series Receiver Specifications Part Number Description Parameter TXM-315-LR 315MHz Transmitter Power Supply TXM-418-LR 418MHz Transmitter Operating Voltage TXM-433-LR 433MHz Transmitter RXM-315-LR 315MHz Receiver Supply Current RXM-418-LR 418MHz Receiver Power Down Current RXM-433-LR 433MHz Receiver Receiver Section EVAL-***-LR LR Series Basic Evaluation Kit Receive Frequency Range Symbol Min. Typ. Max. Units VCC 2.7 3.0 3.6 VDC 4.3 5.0 5.2 VDC lCC 4.0 5.2 7.0 mA lPDN 20.0 28.0 35.0 µA With Dropping Resistor *** = 315, 418 (Standard), 433MHz Receivers are supplied in tubes of 18 pcs. 315 MHz RXM-418-LR 418 MHz RXM-433-LR 433.92 MHz Center Frequency Accuracy Absolute Maximum Ratings –50 LO Feedthrough IF Frequency Absolute Maximum Ratings Noise Bandwidth Supply Voltage VCC −0.3 to +3.6 VDC Supply Voltage VCC, Using Resistor −0.3 to +5.2 VDC Any Input or Output Pin −0.3 to VCC + 0.3 VDC RF Input 0 dBm Operating Temperature −40 to +70 ºC Storage Temperature −40 to +85 ºC Soldering Temperature +260ºC for 10 seconds Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. FIF N3DB Data Rate +50 5 kHz –80 dBm 2,5 10.7 MHz 5 280 100 kHz 10,000 bps Data Output: Logic Low VOL 0.0 VDC 3 Logic High VOH 3.0 VDC 3 Power Down Input: Logic Low VIL Logic High VIH Receiver Sensitivity 0.4 VDC –118 dBm 4 dB 5 Hz 5 VCC–0.4 –106 VDC –112 RSSI / Analog Dynamic Range Figure 3: Absolute Maximum Ratings 1,5 FC RXM-315-LR Figure 2: Ordering Information Notes 80 Analog Bandwidth 50 5,000 Gain 16 mv / dB 5 Voltage with No Carrier 1.5 V 5 50 Ω 5 Antenna Port RF Input Impedance RIN Timing Receiver Turn-On Time – 2 – Via VCC 3.0 7.0 10.0 ms 5,6 Via PDN 0.04 0.25 0.50 nS 5,6 – 3 – Typical Performance Graphs LR Series Receiver Specifications Continued Parameter Symbol Min. Max. Time Between Transitions Typ. Max. 10.0 Units Notes ms 5 Supply Environmental Operating Temperature Range 1. 2. 3. 4. 5. 6. –40 +70 ºC 5 The LR can utilize a 4.3 to 5.2VDC supply provided a 330Ω resistor is placed in series with VCC. Into a 50Ω load. When operating from a 5V source, it is important to consider that the output will swing to well less than 5 volts as a result of the required dropping resistor. Please verify that the minimum voltage will meet the high threshold requirement of the device to which data is being sent. For BER of 10–5 at 1,200bps. Characterized, but not tested. Time to valid data output. RX Data Figure 4: Electrical Specifications Figure 5: Turn-On Time from VCC Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. PDN RX Data Figure 6: Turn-On Time from PDN – 4 – – 5 – Pin Assignments 5.40 1 2 3 4 5 6 7 8 Supply Current (mA) 5.35 5.30 5.25 With Dropping Resistor 5.20 5.15 5.10 2.7 2.8 2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 3.9 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5.0 5.1 5.2 NC NC NC GND VCC PDN RSSI DATA ANT GND NC NC NC NC NC NC 16 15 14 13 12 11 10 9 Supply Voltage (VDC) Figure 9: LR Series Receiver Pinout (Top View) Figure 7: Consumption vs. Supply Pin Descriptions Pin Descriptions RFIN > –35dBm No RFIN Figure 8: RSSI Response Time Pin Number Name I/O Description 1 NC — No Connection 2 NC — No Connection 3 NC — No Connection 4 GND — Analog Ground 5 VCC — Supply Voltage 6 PDN I Power Down. Pulling this line low will place the receiver into a low-current state. The module will not be able to receive a signal in this state. 7 RSSI O Received Signal Strength Indicator. This line will supply an analog voltage that is proportional to the strength of the received signal. 8 DATA O Digital Data Output. This line will output the demodulated digital data. 9 NC — No Connection 10 NC — No Connection 11 NC — No Connection 12 NC — No Connection 13 NC — No Connection 14 NC — No Connection 15 GND — Analog Ground 16 RF IN — 50Ω RF Input Figure 10: Pin Descriptions – 6 – – 7 – Module Description Theory of Operation The LR receiver is a low-cost, high-performance synthesized AM / OOK receiver, capable of receiving serial data at up to 10,000bps. Its exceptional sensitivity results in outstanding range performance. The LR’s compact surface-mount package is friendly to automated or hand production. LR Series modules are capable of meeting the regulatory requirements of many domestic and international applications. The LR Series receiver is designed to recover data sent by an AM Data or Carrier-Present Carrier-Absent (CPCA) transmitter, also referred to as CW or On-Off Keying (OOK). This Carrier type of modulation represents a logic low '0’ by the absence of a carrier and a logic high ‘1’ by the presence Figure 12: CPCA (AM) Modulation of a carrier. This modulation method affords numerous benefits. The two most important are: 1) cost-effectiveness due to design simplicity and 2) higher allowable output power and thus greater range in countries (such as the U.S.) that average output power measurements over time. Please refer to Linx Application Note AN-00130 for a further discussion of modulation techniques. The receiver's outstanding typical sensitivity of –112dBm enables system ranges of up to 1.5 miles (2,500m) when paired with an LR Series transmitter operating at full power and good antennas. Legal regulations in the various countries will require the transmitter output power to be reduced which will reduce range. Following the legal output limit for transmitters in the United States, systems based on the LR Series can achieve ranges of up to 3,000 feet (1,000m). 50Ω RF IN (Antenna) Band Select Filter 10.7MHz IF Filter 0˚ ∑ LNA 90˚ PLL Data Slicer Limiter Data Out + RSSI/Analog VCO XTAL Figure 11: LR Series Receiver Block Diagram – 8 – The LR receiver utilizes an advanced single-conversion superheterodyne architecture. Transmitted signals enter the module through a 50Ω RF port intended for single-ended connection to an external antenna. RF signals entering the antenna are filtered and then amplified by an NMOS cascode Low Noise Amplifier (LNA). The filtered, amplified signal is then down-converted to a 10.7MHz Intermediate Frequency (IF) by mixing it with a low-side Local Oscillator (LO). The LO frequency is generated by a Voltage Controlled Oscillator (VCO) locked by a Phase-Locked Loop (PLL) frequency synthesizer that utilizes a precision crystal reference. The mixer stage incorporates a pair of double-balanced mixers and a unique image rejection circuit. This circuit, along with the high IF frequency and ceramic IF filters, reduces susceptibility to interference. The IF frequency is further amplified, filtered, and demodulated to recover the baseband signal originally transmitted. The baseband signal is squared by a data slicer and output to the DATA pin. The architecture and quality of the components utilized in the LR module enable it to outperform many far more expensive receiver products. – 9 – Using the RSSI Pin The Data Output The receiver’s Received Signal Strength Indicator (RSSI) line outputs a voltage that is proportional to the incoming signal strength. This line has a dynamic range of 80dB (typical) and can serve a variety of functions. It should be noted that the RSSI levels and dynamic range will vary slightly from part to part. It is also important to remember that RSSI output indicates the strength of any in-band RF energy and not necessarily just that from the intended transmitter; therefore, it should be used only to qualify the level and presence of a signal. The CMOS-compatible data output is normally used to drive a digital decoder IC or a microprocessor that is performing the data decoding. It does not have a large current drive capability so is intended to drive high impedance loads, such as microprocessor inputs or digital logic gates. The RSSI output can be utilized during testing or even as a product feature to assess interference and channel quality by looking at the RSSI level with all intended transmitters shut off. The RSSI output can also be used in direction-finding applications, although there are many potential perils to consider in such systems. Finally, it can be used to save system power by “waking up” external circuitry when a transmission is received or crosses a certain threshold. The RSSI output feature adds tremendous versatility for the creative designer. The receiver’s output may appear to switch randomly in the absence of a transmitter. This is a result of random noise in the environment. This noise can be handled in software by implementing a noise-tolerant protocol as described in Application Note AN-00160. If a software solution is not appropriate, the squelch circuit in Figure 13 can be used. This circuit uses a potentiometer to set a voltage reference. If the RSSI level falls below this reference then a comparator turns off the DATA line and stops the random switching. This circuit is good for reducing the amount of random noise that the microcontroller must deal with, but it also reduces the sensitivity of the receiver since the received signal level must now be higher. This reduction in sensitivity also reduces the system range. By using a potentiometer the designer can make a compromise between noise level and range. VCC R5 1M VCC R2 500k R6 1M 2 D1 3 RSSI + C1 0.1µ U1 LMV393 6 1 5 + - U1 LMV393 7 + R4 100k R1 2M DATA R3 5M Figure 13: LR Series Receiver Squelch Circuit – 10 – VCC – 11 – R7 2M R8 10k Squelched Data Using the PDN Line Power Supply Requirements The Power Down (PDN) line can be used to power down the receiver without the need for an external switch. This line has an internal pull-up, so when it is held high or simply left floating, the module is active. The module does not have an internal Vcc TO MODULE voltage regulator, therefore it requires a clean, well-regulated power source. While 10Ω it is preferable to power the unit from a Vcc IN battery, it can also be operated from a 10µF power supply as long as noise is less than 20mV. Power supply noise can significantly affect the receiver sensitivity, therefore; providing clean power to the module should Figure 14: Supply Filter be a high priority during design. The PDN line allows easy control of the receiver state from external components, like a microcontroller. By periodically activating the receiver, checking for data, then powering down, the receiver’s average current consumption can be greatly reduced, saving power in battery-operated applications. Note: The voltage on the PDN line should not exceed VCC. When used with a higher voltage source, such as a 5V microcontroller, an open collector line should be used or a diode placed in series with the control line (anode toward the module). Either method avoids damage to the module by preventing 5V from being placed on the PDN line while allowing the line to be pulled low. + When the PDN line is pulled to ground, the receiver enters a low-current (
RXM-315-LR 价格&库存
很抱歉,暂时无法提供与“RXM-315-LR”相匹配的价格&库存,您可以联系我们找货
RXM-315-LR
    • 1+290.49840
    • 200+115.91640
    • 500+112.03920
    • 1000+110.12760
