M10382-A1
M10382-A1
    ANTENOVA(安诺亚)
    模块
    UB GPS MODULE
M10382-A1 数据手册
GPS RADIONOVA® RF Antenna Module Part No. M10382 Product Specification Applications • Personal Navigation Devices (PNDs) • Feature phones / Smart phones • Portable Media Players (PMPs) • Tablet PCs / eReaders • Personal Digital Assistants (PDAs) • Asset Tracking / Personal Safety Features • Low cost single package GPS RF antenna module • u-blox 6 GPS Position Engine • Low 3.9mm height for thin devices • Low current consumption • Easy to use ‘drop-in solution’ • Novel external matching ensure easy tuning for each platform • Anti-jamming technology Functional Block Diagram Product Description Package Style Antenova M2M’s GPS RADIONOVA® M10382 is a single package solution that combines a full GPS engine and antenna on a small SMD module. The M10382 is a highly integrated GPS RF Antenna Module suitable for L1-band GPS and A-GPS systems. The device combines the high performance ublox 6 GPS position engine with Antenova’s high efficiency antenna technology in a small SMD module. M10382 also benefits from novel external matching that ensures easy tuning for each platform. 24.2 x 9.9mm RF Antenna Module All front-end and receiver components are contained in a single package laminate base module, providing a complete GPS receiver for optimum performance. The M10382 operates on 1.8V or 3.3V positive supply with low power consumption and several low power modes for further power savings. An accurate 0.5ppm TCXO and very low noise LNA ensures high sensitivity and short TTFF. The M10382 is supported by u-blox stand alone software and is compatible with UART, SPI, DDC, I2C and USB host processor interfaces. Top View Component side view (w/o shielding can) Bottom View Antennas for Wireless M2M Applications 1 Product Specification 11MD-0043-5-PS GPS RADIONOVA® RF Antenna Module Part No. M10382 Absolute Maximum Ratings Symbol Parameter Min Max Unit VCC Main Supply Voltage -0.5 3.6 V V_BCKP Battery backup voltage -0.5 3.6 V VIO Supply voltage I/O ring -0.5 3.6 V VDD_USB Supply voltage USB -0.5 3.6 V V_TH Input Voltage Reset Threshold level -0.5 3.6 V VI Input Voltage on any digital I/O pin with respect to ground -0.5 3.6 V -25 dBm +125 °C DC Current through any digital I/O pin (except supplies) 10 mA P Total Power Dissipation 500 mW ESD Electrostatic Discharge Immunity (HBM) +2.0 kV DIG LNA_IN RF Input Power at ANT_IN T Storage Temperature I STG PIN TOT -40 -2.0 * Exposure to absolute ratings may adversely affect reliability and may cause permanent damage. Recommended Operating Conditions . Symbol Parameter Min Typ Max Unit Ta Ambient Temperature -40 +25 +85 °C VCC (1V8) 1V8 Supply Voltage Mode 1.75 1.8 1.89 V VCC (3V3) 3V3 Supply Voltage Mode 2.5 3.3 3.6 V VCC (USB) USB Supply Voltage Mode 2.5 3.3 3.6 V V-BCKP Battery backup voltage 1.4 3.6 V VIO Supply voltage I/O ring 1.65 3.3 3.6 V VDD_USB Supply voltage USB 3.0 3.3 3.6 V DC Electrical Characteristics Conditions: Ta = 25 °C Symbol Parameter ICC Total Supply Current - Acquisition Mode 52 † mA Tracking - Max Performance Mode 45 † mA Tracking - Eco Mode 42 † mA Tracking - Power Save Mode 22 † † mA 25 µA ICC I ACQ TRK BCKP Battery backup current Min Typ Max † Current consumption is very dynamic and can peak at 100mA. The value given is the average over 1 minute. †† At 1fix/s Antennas for Wireless M2M Applications Unit 2 Product Specification 11MD-0043-5-PS GPS RADIONOVA® RF Antenna Module Part No. M10382 RF Specifications Conditions: VCC = 1.8V, TA = 25 °C Symbol Parameter Typ Unit G LNA Gain 20 dB LNA Noise Figure 0.7 dB -15.5 dBm Antenna Return Loss >10 dB Antenna Bandwidth at 10dB return loss 20 MHz Antenna Total Efficiency >40% % Antenna RHCP Efficiency >30% % Typ* Unit LNA NF LNA P In band 1dB Compression Point 1dB ANT ANT ANT ANT RL BW EFF EFF_RHCP Band Rejection* Frequency Standard 698-798 LTE700 50 dB 824-849 Cellular CDMA 55 dB 869-894 GSM850 55 dB 880-915 GSM900 60 dB 1710-1785 GSM1800/DCS 33 dB 1850-1910 GSM1900/PCS 30 dB 1920-1980 WCDMA 30 dB 2400-2492 WLAN, BT and WiMAX 30 dB 2500-2690 LTE2600 30 dB *Rejection before LNA. Does not include antenna rejection. Digital I/O Symbol Paramater I Leakage current input pins leak Condition Min Typ Max = 3.0V 2.0 VDD_USB V V Low Level Output Voltage RL = 14.25 kΩ to VDD_USB, VDD_ USB > = 3.0V, 22 Ω external series resister 0.3 V V High Level Output Voltage RL = 14.25 kΩ to VDD_USB, VDD_ USB > = 3.0V, 22 Ω external series resister IL IH OL OH R R 2.8 V PUI Pull-up resistor, Idle State 900 1200 1575 Ω PUO Pull-up resistor, Operational State 1425 1925 3090 Ω Mechanical Specifications Parameter Module exterior dimensions (L x W x H) Module support and connection Typ Unit 24.2 (+/-0.1) x 9.9 (+0.3 / -0.0) x 3.8 (+0.2 / - 0.0) mm Suface mounted, 36 pin - 1.1 g Module mass System Specifications Communication Data Output Protocol Specification NMEA 0183 (2.3, compatible to 3.0) and/or UBX (u-blox Binary) UART (4.8 kb/s to 115 kb/s) USB 2.0 FS (12Mb/s) Host Interfaces SPI (slave) DDC (I2C compatible) Default data rate on UART 9.6kb/s Serial port settings 8 Data bits, No Parity, 1 Stop bit Antennas for Wireless M2M Applications 4 Product Specification 11MD-0043-5-PS GPS RADIONOVA® RF Antenna Module Part No. M10382 Accuracy of Time Pulse signal RMS 30 ns 99%
M10382-A1
物料型号: - 型号为Part No. M10382,是Antenova M2M的GPS RADIONOVA® RF Antenna Module。
器件简介: - M10382是一个集成了完整GPS引擎和天线的单包解决方案,适用于L1频段GPS和A-GPS系统。它结合了高性能的u-blox 6 GPS定位引擎和Antenova的高效天线技术。
引脚分配: - 提供了详尽的引脚功能描述和对应u-blox完整名称及描述,包括电源域、I/O复位和电源关闭等状态。
参数特性: - 文档列出了绝对最大额定值、推荐操作条件、直流电气特性和射频规格等详细参数。
功能详解: - 包括GPS引擎、时间脉冲信号精度、主动干扰消除器、A-GPS支持、SBAS等附加功能的描述。
应用信息: - 适用于个人导航设备、功能手机/智能手机、便携式媒体播放器、平板电脑/电子阅读器、个人数字助理、资产跟踪/个人安全等。
封装信息: - 提供了模块的外部尺寸、安装和连接方式、模块质量等机械规格,以及系统规格中的通信协议和主机接口信息。
M10382-A1 价格&库存
很抱歉,暂时无法提供与“M10382-A1”相匹配的价格&库存,您可以联系我们找货
