RXM-315-KH3
RXM-315-KH3
    LINXTECHNOLOGIES(灵思)
    模块
    RXM-315-KH3
RXM-315-KH3 数据手册
KH3 Series Receiver Module Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1^ 1^ 1^ NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2^ Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 7^ Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 2^ 3^ 5^ 6^ 8^ 8^ 9^ 10^ 10^ 10^ 11^ 11^ 12^ 13^ 14^ 16^ 17^ 18^ 19^ 19^ 21^ 22^ 22^ 22^ Description Features Applications Ordering Information Absolute Maximum Ratings Electrical Specifications Typical Performance Graphs Pin Assignments Pin Descriptions Module Description Theory of Operation Decoder Operation Compatibility with the KH2 Series Setting the Receiver Address The Data Line Outputs Receiving Data Using the RSSI Line Input Type Selection Power Supply Requirements Typical Applications Antenna Considerations Helpful Application Notes from Linx Interference Considerations Pad Layout Board Layout Guidelines Microstrip Details Production Guidelines Hand Assembly Automated Assembly 24^ General Antenna Rules 26^ Common Antenna Styles 28^ Regulatory Considerations 30^ Notes KH3 Series Receiver Module Data Guide Description 1.43 in The KH3 Series is ideally suited for volume (36.32 mm) use in OEM applications such as remote 0.63 in control / command and keyless entry. It (16.00 mm) combines a high-performance RF receiver with an on-board decoder. When paired 0.106 in with a matching KH3 Series transmitter / encoder module, OEM transmitter, or LC (2.69 mm) or LR Series transmitter and DS Series Figure 1: Package Dimensions encoder combination, a highly reliable wireless link is formed that is capable of transferring the status of eight parallel inputs for distances of up to 3,000 feet (1,000m). Ten address lines provide 1,022 (210-2) different addresses for security and uniqueness. Housed in a compact SMD package, the KH3 module utilizes an advanced synthesized architecture to achieve an unmatched blend of performance, size, range and cost. No external RF components are required except an antenna, making design integration straightforward. Features • • • • • • • • Low cost Long range On-board encoder 8 parallel binary inputs 210 addresses for uniqueness Ultra-low power consumption Compact SMD package Advanced synthesized architecture Received data output Transmission validation No production tuning No external RF components required (except an antenna) • Pin-compatible with original KH and KH2 modules • • • • Applications • • • • Remote control / command Gate openers Lighting control Call systems • • • – 1 – Remote status monitoring Home / industrial automation Wire elimination Revised 3/18/2015 Ordering Information Electrical Specifications Ordering Information KH3 Series Receiver Specifications Part Number Description Parameter TXM-315-KH3 315MHz Transmitter / Encoder Power Supply TXM-418-KH3 418MHz Transmitter / Encoder Operating Voltage TXM-433-KH3 433MHz Transmitter / Encoder RXM-315-KH3 315MHz Receiver / Decoder RXM-418-KH3 RXM-433-KH3 EVAL-***-KH3 Symbol Min. Typ. Max. Units VCC 2.7 3.0 3.6 VDC 5.2 VDC 1,4 Supply Current lCC 4.0 5.9 7.0 mA 7 418MHz Receiver / Decoder Power Down Current lPDN 47 57 µA 4 433MHz Receiver / Decoder Receiver Section KH3 Series Basic Evaluation Kit Receive Frequency Range With Dropping Resistor *** = 315, 418 (Standard), 433MHz Receivers are supplied in tubes of 20 pcs. FC RXM-315-KH3 315 MHz RXM-418-KH3 418 MHz RXM-433-KH3 Figure 2: Ordering Information 433.92 Center Frequency Accuracy –50 LO Feedthrough Absolute Maximum Ratings IF Frequency Noise Bandwidth Absolute Maximum Ratings Supply Voltage Vcc −0.3 to +3.6 VDC Any Input or Output Pin −0.3 to +3.6 VDC RF Input 0 dBm Operating Temperature −40 to +70 ºC Storage Temperature −55 to +85 ºC Soldering Temperature +255ºC for 10 seconds Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. – 2 – kHz –80 dBm 2,4 10.7 MHz 5 N3DB 280 kHz Data Rate 100 10,000 bps Data Output Logic Low VOL 0.0 VDC 3 Logic High VOH 3.0 VDC 3 Power-Down Input Logic Low VIL Logic High VIH Receiver Sensitivity 0.4 VCC–0.4 –106 VDC VDC –112 –118 dBm RSSI / Analog 80 Analog Bandwidth Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. MHz +50 FIF Dynamic Range Figure 3: Absolute Maximum Ratings Notes 50 5,000 dB 4 Hz 4 Gain 16 mV/dB 4 Voltage With No Carrier 1.5 V 4 50 Ω 4 Antenna Port RF Input Impedance RIN Timing Receiver Turn-On Time Via VCC 3.0 7.0 10.0 ms 4,5 Via PDN 0.04 0.25 0.50 ms 4,5 – 3 – Typical Performance Graphs KH2 Series Receiver Specifications Continued Parameter Symbol Min. Typ. Max. Units Notes 1.2 mA 6 +70 °C 4 1V/div 2.00ms/div A ∆A-B = 4.2109 ms B Decoder Section TX Data Length 26 bits 3x Average Data Duty Cycle 50% Output Drive Current 0.6 1.0 Environmental Operating Temperature Range 1. 2. 3. –40 The KH3 can utilize up to a 5.2VDC supply provided a dropping resistor is placed in series with VCC. However, it is recommended to use a 3.0 - 3.3V supply. Into a 50Ω load When operating from a 5V source, it is important to consider that the output will swing to well less than 5 volts as a result of the required dropping resistor. Please verify that the minimum voltage will meet the high threshold requirement of the device to which data is being sent. 4. 5. 6. 7. Characterized, but not tested Time to valid data output Maximum drive capability of data outputs At 25°C Figure 5: KH3 Series Receiver Turn-On Time from VCC 1V/div A 100µs/div ∆A-B = 101.83 µs B Figure 4: Electrical Specifications Figure 6: KH3 Series Receiver Turn-On Time from PDN 6.60 85°C RX Current (mA) 6.40 25°C 6.20 -40°C 6.00 5.80 5.60 5.40 2.7 2.8 2.9 3 3.1 3.2 3.3 Input Voltage (V) Figure 7: KH3 Series Receiver Current Consumption vs. Supply Voltage – 4 – – 5 – 3.4 3.5 3.6 Pin Descriptions 2.20 RSSI Voltage (V) 2.00 Pin Descriptions Pin Number Name I/O Description 1 NC — No Connection. For physical support only. 1.60 2, 3, 7, 8, 9, 12, 13, 14 D0–D7 O Data Output Lines. Upon a valid transmission, these lines are set to replicate the state of the transmitter’s data lines. 1.40 4 GND — Analog Ground 5 VCC — Supply Voltage 6 PDN I Power Down. Pulling this line low places the receiver into a low-current state. The module is not able to receive a signal in this state. 10 DATA O Data output of the receiver prior to the decoder. 11 VT O Valid Transmission. This line goes high when a valid transmission is received. 15–24 A0–A9 I Address Lines. The state of these lines must match the state of the transmitter’s address lines in order for a transmission to be accepted. These lines are pulled to VCC internally. 25 RSSI 26 1.80 1.20 -100 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 Input Power (dBm) Figure 8: KH3 Series Receiver RSSI Response Time Pin Assignments 28 2 D0 GND 27 3 D1 NC 26 4 GND RSSI 25 5 VCC A9 24 6 PDN A8 23 7 D2 A7 22 8 D3 A6 21 9 D4 A5 20 10 DATA A4 19 11 VT A3 18 12 D5 A2 17 13 D6 A1 16 14 D7 A0 15 29 30 A_CFG1 ANT A_CFG0 NC D_CFG 1 O Received Signal Strength Indicator. This line outputs an analog voltage that is proportional to the strength of the received signal. NC — No Connection. For physical support only. 27 GND — Analog Ground 28 RF IN I 50-ohm RF Input 29 D_CFG I Data Line Configuration. Determines whether a low on a data line is interpreted as a zero bit or an open bit. See the Input Type Selection section. This line is pulled to GND internally. 30, 31 A_CFG0 I Address Configuration 0. With A_CFG1, determines the address bit type interpretation. See the Input Type Selection section. This line is pulled to GND internally. 31 A_CFG1 I Address Configuration 1. With A_CFG0, determines the address bit type interpretation. See the Input Type Selection section. This line is pulled to VCC internally. Figure 10: KH3 Series Receiver Pin Descriptions 31 Figure 9: KH3 Series Receiver Pinout (Top View) – 6 – – 7 – Module Description Decoder Operation The KH3 Series module combines the popular Linx LR Series receiver with a decoder IC in a convenient SMD package. The module is ideal for general-purpose remote control and command applications. When paired with a matching Linx KH3 Series transmitter / encoder, OEM transmitter, LC, or LR Series transmitter and DS Series encoder combination, a highly reliable RF link is formed, capable of transferring control and command data over line-of-sight distances in excess of 3,000 feet. The on-board receiver / decoder combination provides eight switched outputs that correspond to the state of the data lines on the transmitter’s encoder. Ten address lines are also provided to allow up to 1,022 (210 - 2) unique identification codes. The KH3 Series receiver utilizes the DS Series decoder. When the decoder receives data, it compares the address in the received packet to its local address lines. If the addresses match, then the data is stored and a second packet is received. The decoder compares the two packets to each other. If the packets match, then the received data bits are output on the data lines and the VT line is pulled high. It then looks for the next packet. RF Stage Decoder Stage Address Inputs A0-A9 50Ω RF IN (Antenna) 10.7MHz IF Filter 0° LNA Data Slicer - Σ Band Select Filter 90° PLL Limiter VT Data In + RSSI Parallel Outputs D0-D7 VCO Power On Sleep Wake on interrupt Once no valid data is received (there is a mismatch of address, of data, or of bit timings), the data and VT lines are pulled low and the decoder goes to sleep until more data is received. NO Data received? YES NO Valid data received? YES NO Address match? YES NO 1st valid packet? YES 2nd packet received? YES D_CFG D_CFG0 D_CFG1 XTAL Figure 11: KH3 Series Receiver Block Diagram Theory of Operation The KH3 Series receiver module is designed to receive transmissions from a matching KH3 Series transmitter module or other compatible Linx transmitter product. When transmitted data is received, the data is presented to the onboard decoder. If the incoming address matches the local address settings, the decoder’s outputs are set to replicate the states of the transmitter’s data lines. The RF section of the KH3 module utilizes the LR Series receiver, which is an advanced single-conversion superhet design with a synthesized architecture, high IF frequency, and multilayer ceramic filters. The exceptional accuracy of the crystal-based synthesized architecture in the KH3 receiver module allows the receiver’s pass band to be quite narrow, thus increasing sensitivity and reducing susceptibility to near-band interference. The decoder compares two packets Data match NO previous data? and, if they match, sets the outputs. If a data line is toggled during a transmission YES (for example D1 is activated while D0 Activate outputs and VT is already activated) then the received packet will not match the previous packet Clear outputs and and the output lines will be pulled low until VT the next packet arrives. This causes all of Figure 12: KH3 Series Receiver / Decoder the outputs to briefly cut out when a line is Flowchart toggled. Encoder Transmit Enable Encoder Data Out Decoder VT < 1 Word 3 Words Transmitted Continuously 2 Words Check Check Decoder Data Out Figure 13: Encoder / Decoder Timing Diagram – 8 – – 9 – 3 Words NO Compatibility with the KH2 Series Receiving Data The Legacy KH2 Series used encoders and decoders from Holtek® and the KH3 migrates to the Linx DS Series encoder and decoder. The protocol and functionality are compatible. There is some difference in the hardware set-up for the address lines and the data lines. The legacy Holtek® products used tri-state lines, so high, low and floating were each valid states. The DS Series has bi-state lines; high and low only. Three lines have been added to the KH3 module to allow for the selection of how the address and data line states are interpreted. Please see the Input Type Selection section for more details. Although the internal decoder handles all of the decoding and output for transmissions from a KH3 Series transmitter or an OEM transmitter, the KH3 Series receiver outputs the raw received data on the DATA line. The output of this line is the actual received data stream from the receiver and is always active regardless of address line status. It is made available for troubleshooting or monitoring internal data flow. It can also be used in mixed-mode systems where data may come from another source in addition to a KH3 Series transmitter module. This data can then be channeled to an external processor for decoding. The KH3 receiver has been designed to be compatible with legacy systems. The module has been configured for the most common use of the KH2 so that it can be placed on existing boards without modification. This makes the KH3 a drop-in replacement for most applications. When using the KH3 for custom data transmissions, it is up to the designer to implement a noise-tolerant protocol to ensure the integrity of the data. Application Note AN-00160 provides some suggestions and guidelines. Setting the Receiver Address The module has ten address lines. This allows the formation of up to 1,022 (210 – 2) unique transmitter-receiver relationships. Note: All address lines high or all low is not allowed, so at least one line must be different from the others. Because the address inputs have internal pull-up resistors these pins can be left floating or tied to GND. These pins may be hardwired or configured via a microprocessor, DIP switch or jumpers. The receiver’s address line states must match the transmitter’s exactly for a transmission to be recognized. If the transmitted address does not match the receiver’s local address, then the receiver takes no action. The Data Line Outputs When data is received and the incoming address data matches the local address settings, the module’s eight data output lines are set to replicate the state of the transmitter’s data lines. In addition, the valid transmission line (VT, Pin 11) goes high to indicate reception and decoding of the data. The output have a drive level suitable for powering small LEDs and similar circuits, but anything more than 10mA should be buffered. – 10 – The KH3 Series receiver module contains the LR Series receiver, which has a CMOS-compatible output capable of directly driving a microprocessor, an RS-232 level converter, or a Linx QS Series USB module. The LR Series receiver manual can be consulted for more details on the operation of the receiver itself. Using the RSSI Line The receiver’s Received Signal Strength Indicator (RSSI) line serves a variety of functions. This line has a dynamic range of 80dB (typical) and outputs a voltage proportional to the incoming signal strength. It should be noted that the RSSI levels and dynamic range vary slightly from part to part. It is also important to remember that the RSSI output indicates the strength of any in-band RF energy and not necessarily just that from the intended transmitter; therefore, it should be used only to qualify the level and presence of a signal. The RSSI output can be utilized during testing or even as a product feature to assess interference and channel quality by looking at the RSSI level with all intended transmitters shut off. The RSSI output can also be used in direction-finding applications, although there are many potential perils to consider in such systems. Finally, it can be used to save system power by “waking up” external circuitry when a transmission is received or crosses a certain threshold. The RSSI output feature adds tremendous versatility for the creative designer. – 11 – The KH3 Series receiver incorporates the DS Series remote control decoder, which is designed to be operable with previous generation products based on Holtek® encoders and decoders. The Holtek® encoders and decoders have tri-state input lines but the DS has bi-state lines. Tri-state inputs are connected to ground for zero bits, VCC for one bits, or left unconnected for open bits. Since the DS cannot match this operation the D_CFG, A_CFG0 and A_CFG1 lines are provided to select the desired interpretation. The settings must match on both ends. Pulling the D_CFG line high configures the data bits as one and zero. A high on a data line on the transmitter is interpreted as a one bit and a low on the line is interpreted as a zero bit. Pulling D_CFG low configures the data bits as one and open. A high on a data line is interpreted as a one bit and a low on the line is interpreted as an open bit. The decoder outputs open data bits as logic low. This is shown in Figure 14. D_CFG Configuration Configuration Bit Interpretation D_CFG High Low 0 One Open 1 One Zero This configuration matches the Linx OEM products and the most common implementation of the legacy KH2 Series. This enables customers using the KH2 Series to populate the KH3 Series without any PCB modifications since pins 25, 26 and 27 can be left unconnected. Power Supply Requirements The module does not have an internal voltage regulator; therefore it requires Vcc TO a clean, well-regulated power source. While it MODULE is preferable to power the unit from a battery, it can also be operated from a power supply 10Ω as long as noise is less than 20mV. Power Vcc IN supply noise can affect the receiver sensitivity; 10µF therefore, providing a clean power supply for the module should be a high priority during design. + Input Type Selection Figure 16: Power Supply Filter A 10-ohm resistor in series with the supply followed by a 10µF tantalum capacitor from VCC to ground will help in cases where the quality of supply power is poor. These values may need to be adjusted depending on the noise present on the supply line. Note that operation up to 5.2 volts requires the use of an external resistor placed in series with the supply to prevent VCC from exceeding 3.6 volts, this dropping resistor can take the place of the 10-ohm resistor in the supply filter. Figure 14: D_CFG Configuration A_CFG0 and A_CFG1 are used to select the bit type for the address lines. These are shown in Figure 15. A_CFGO and A_CFG1 Configuration Configuration Bit Interpretation A_CFG1 A_CFG0 High Low 0 0 One Zero 0 1 One Open 1 0 Open Zero 1 1 One Zero Figure 15: A_CFG0 and A_CFG1 Configuration D_CFG is pulled low internally so that a high on a data line is transmitted as a one bit and a low on the line is transmitted as an open bit. A_CFG0 is pulled low and A_CFG1 is pulled high internally so that a high on an address line is interpreted as an open bit and a low as a zero bit. – 12 – – 13 – Typical Applications Figure Figure 17 shows an example of a basic remote control transmitter utilizing the KH3 Series receiver. VCC 4 5 6 7 8 GND 9 10 11 12 13 NC D1 GND RSSI VCC A9 PDN A8 D2 A7 D3 A6 D4 A5 DATA A4 VT A3 D5 A2 D6 D7 29 14 GND A_CFG1 GND D0 A_CFG0 GND ANT A1 A0 28 27 GND 26 25 24 23 22 21 20 19 1 2 3 4 5 6 7 8 9 10 20 19 18 17 16 15 14 13 12 11 18 17 GND 16 15 Figure 18: Linx Remote Control Transmitters 31 3 NC D_CFG 2 RXM-XXX-KH3 30 1 Figure 17: KH3 Series Receiver Typical Application Circuit The data line outputs are used to drive external circutry required by the application. In this example, when line D0 is activated on the transmitter line D0 on the receiver goes high and activates a buzzer. Likewise line D1 is used to activate an LED. The rest of the lines are not used in this example. A ten-position DIP switch is used to set the address to either ground or VCC. Since the address lines are internally pulled up to VCC, no pull-up resistors are needed. The KH3 Series receiver / decoder module is also suitable for use with Linx OEM handheld transmitters. These transmitters are FCC certified, making product introduction extremely quick. Information on these transmitters can be found on the Linx website at www.linxtechnologies.com. – 14 – – 15 – Antenna Considerations Helpful Application Notes from Linx The choice of antennas is a critical and often overlooked design consideration. The range, performance and legality of an RF link are critically dependent upon the antenna. While adequate antenna performance can often be obtained by trial and error methods, antenna Figure 19: Linx Antennas design and matching is a complex task. Professionally designed antennas such as those from Linx (Figure 19) help ensure maximum performance and FCC and other regulatory compliance. It is not the intention of this manual to address in depth many of the issues that should be considered to ensure that the modules function correctly and deliver the maximum possible performance. We recommend reading the application notes listed in Figure 20 which address in depth key areas of RF design and application of Linx products. These applications notes are available online at www.linxtechnologies.com or by contacting Linx. Linx transmitter modules typically have an output power that is higher than the legal limits. This allows the designer to use an inefficient antenna such as a loop trace or helical to meet size, cost or cosmetic requirements and still achieve full legal output power for maximum range. If an efficient antenna is used, then some attenuation of the output power will likely be needed. This can easily be accomplished by using the LADJ line. Helpful Application Note Titles Note Number Note Title AN-00100 RF 101: Information for the RF Challenged AN-00126 Considerations for Operation Within the 902–928MHz Band AN-00130 Modulation Techniques for Low-Cost RF Data Links AN-00140 The FCC Road: Part 15 from Concept to Approval AN-00150 Use and Design of T-Attenuation Pads AN-00300 Addressing Linx OEM Products AN-00500 Antennas: Design, Application, Performance AN-00501 Understanding Antenna Specifications and Operation Figure 20: Helpful Application Note Titles It is usually best to utilize a basic quarter-wave whip until your prototype product is operating satisfactorily. Other antennas can then be evaluated based on the cost, size and cosmetic requirements of the product. Additional details are in Application Note AN-00500. – 16 – – 17 – Interference Considerations Pad Layout The RF spectrum is crowded and the potential for conflict with unwanted sources of RF is very real. While all RF products are at risk from interference, its effects can be minimized by better understanding its characteristics. The pad layout diagram in Figure 21 is designed to facilitate both hand and automated assembly. Interference may come from internal or external sources. The first step is to eliminate interference from noise sources on the board. This means paying careful attention to layout, grounding, filtering and bypassing in order to eliminate all radiated and conducted interference paths. For many products, this is straightforward; however, products containing components such as switching power supplies, motors, crystals and other potential sources of noise must be approached with care. Comparing your own design with a Linx evaluation board can help to determine if and at what level design-specific interference is present. 0.07 in (1.78 mm) 0.053 in (1.35 mm) 0.096 in (2.44 mm) 0.065 in (1.65 mm) 0.10 in (2.54 mm) 0.274 in (6.96 mm) 0.61 in (15.49 mm) 0.14 in (3.56 mm) 0.10 in (2.54 mm) External interference can manifest itself in a variety of ways. Low-level interference produces noise and hashing on the output and reduces the link’s overall range. Figure 21: Recommended PCB Layout High-level interference is caused by nearby products sharing the same frequency or from near-band high-power devices. It can even come from your own products if more than one transmitter is active in the same area. It is important to remember that only one transmitter at a time can occupy a frequency, regardless of the coding of the transmitted signal. This type of interference is less common than those mentioned previously, but in severe cases it can prevent all useful function of the affected device. The module’s design makes integration straightforward; however, it is still critical to exercise care in PCB layout. Failure to observe good layout techniques can result in a significant degradation of the module’s performance. A primary layout goal is to maintain a characteristic 50-ohm impedance throughout the path from the antenna to the module. Grounding, filtering, decoupling, routing and PCB stack-up are also important considerations for any RF design. The following section provides some basic design guidelines. Although technically not interference, multipath is also a factor to be understood. Multipath is a term used to refer to the signal cancellation effects that occur when RF waves arrive at the receiver in different phase relationships. This effect is a particularly significant factor in interior environments where objects provide many different signal reflection paths. Multipath cancellation results in lowered signal levels at the receiver and shorter useful distances for the link. Board Layout Guidelines During prototyping, the module should be soldered to a properly laid-out circuit board. The use of prototyping or “perf” boards results in poor performance and is strongly discouraged. Likewise, the use of sockets can have a negative impact on the performance of the module and is discouraged. The module should, as much as reasonably possible, be isolated from other components on your PCB, especially high-frequency circuitry such as crystal oscillators, switching power supplies, and high-speed bus lines. When possible, separate RF and digital circuits into different PCB regions. – 18 – – 19 – Make sure internal wiring is routed away from the module and antenna and is secured to prevent displacement. Do not route PCB traces directly under the module. There should not be any copper or traces under the module on the same layer as the module, just bare PCB. The underside of the module has traces and vias that could short or couple to traces on the product’s circuit board. The Pad Layout section shows a typical PCB footprint for the module. A ground plane (as large and uninterrupted as possible) should be placed on a lower layer of your PC board opposite the module. This plane is essential for creating a low impedance return for ground and consistent stripline performance. Use care in routing the RF trace between the module and the antenna or connector. Keep the trace as short as possible. Do not pass it under the module or any other component. Do not route the antenna trace on multiple PCB layers as vias add inductance. Vias are acceptable for tying together ground layers and component grounds and should be used in multiples. Microstrip Details A transmission line is a medium whereby RF energy is transferred from one place to another with minimal loss. This is a critical factor, especially in high-frequency products like Linx RF modules, because the trace leading to the module’s antenna can effectively contribute to the length of the antenna, changing its resonant bandwidth. In order to minimize loss and detuning, some form of transmission line between the antenna and the module should be used unless the antenna can be placed very close (
RXM-315-KH3 价格&库存
很抱歉,暂时无法提供与“RXM-315-KH3”相匹配的价格&库存,您可以联系我们找货
