DATASHEET
M10578-A2
M10578-A2
RADIONOVA®
Features
imple drop in solution GPS receiver
S
MediaTek MT3337-E ROM chip
SMD package; 9.0 x 9.0 x 1.8mm
Low current consumption
AIC, Active Interference Cancellation
EASY - Internally generated orbit predictions for faster time to first fix (TTFF)
a n t e n ova.com
DATASHEET: M10578-A2
M10578-A2-PS-3.02
Contents
1.
Description
2
13.
Quality and environmental specifications
2.
Applications
2
14.
Hazardous material regulation conformance 15
3.
Part number
2
15.
Packaging
4.
Functional block diagram
3
5.
Module specifications
3
14
15
1 5 . 1 . Optimal storage conditions
15
1 5 . 2 . Tape characteristics
16
1 5 . 3 . Reel dimensions
17
5 . 1. Absolute maximum ratings
3
1 5 . 4 . Box dimensions
17
5 . 2. Recommended operating conditions
3
1 5 . 5 . Bag properties
18
5 . 3. DC electrical characteristics
4
1 5 . 6 . Reel label information
18
5 . 4. RF specifications
4
5 . 5. Band rejection
4
5 . 6. Mechanical specifications
5
5 . 7. System specifications
5
6.
Module dimension
6
7.
Schematic symbol and pin definition
6
8.
Host PCB footprint
7
9.
Module subsystem feature
7
9 . 1. Host baud rate/protocol selection
7
9 . 2. Host interface
8
9 . 3. Power supply
8
9 . 4. TM (1PPS)
8
9 . 5. HRST (Hardware reset pin)
8
9 . 6. Power management
8
9 . 7. EPO (Extended Prediction Orbit) data service
10
9 . 8. EASY (Self-Generated Orbit Prediction)
10
9 . 9. AIC (Active Interference Cancellation)
11
10.
Module application
11
11.
Evaluation kit
12
12.
Reflow soldering
13
1 2 .1. Placement13
1 2 .2. Soldering paste
13
1 2 .3. Soldering13
1 2 .4. Multiple soldering
14
1 2 .5. Hand soldering
14
a n t e n ova.com
1
1.
M10578-A2-PS-3.02
Description
A compact GPS module receiver using the MediaTek MT3337-E ROM chip.
The M10578-A2 operates from a 2.8V-4.2V supply and includes low power
modes for battery operation.
A 0.5ppm TXCO helps to reduce TTFF (Time to first fix). Multi-path mitigation
algorithms improve position accuracy in inner-city environments. The onboard LNA improves performance for wearables such as fitness bands.
2.
3.
Applications
Wearable devices
Personal safety
Bike trackers
Asset tracking
Sports equipment
Cameras
Smart watches
Navigation devices
Part number
M10578-A2
Top view
Pin 1 marker
a n t e n ova.com
Bottom view
Pin 1 also defined
by SMD pad
2
4.
5.
5.1.
M10578-A2-PS-3.02
S Y M B OL
PARA METER
MIN
MAX
UNIT
VCC
Main supply voltage
-0.3
4.3
V
VIO
Supply voltage I/O ring
-0.3
3.6
V
VBCKUP
Backup supply voltage
-0.3
4.3
V
RFIN
Maximum RF input power
N/A
+10
dBm
TSTG
Storage temperature
-40
+85
°C
TOP
Operating temperature
-40
+85
°C
Exposure to absolute ratings may adversely affect
reliability and may cause permanent damage.
5.2.
S Y M B OL
PARA METER
MIN
TYP
MAX
UN I T
VCC
Main supply voltage
2.8
3.3
4.3
V
VBCKUP
2.8
3.3
4.3
V
TOP
-40
+85
°C
a n t e n ova.com
3
5.3.
M10578-A2-PS-3.02
Conditions: VCC = 3.3V, TOP = 25 °C
S Y M B OL
PARAM ETER
TYP
UNIT
ICC(ACQ)
Acquisition mode current
28
mA
ICC(TRK)
Tracking mode current
24.5
mA
ICC(STBY)
Standby (sleep) mode current
很抱歉,暂时无法提供与“M10578-A2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+145.267421+18.61607
- 10+126.3972310+16.19785
- 25+119.8666225+15.36095
- 100+110.90366100+14.21234
- 250+105.53866250+13.52482
- 500+102.17809500+13.09416
- 国内价格 香港价格
- 1000+98.191811000+12.58331
