RXM-GPS-FM-T
RXM-GPS-FM-T
    LINXTECHNOLOGIES(灵思)
    模块
RXM-GPS-FM-T 数据手册
GPS / GNSS Receiver Master Development System User's Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. Table of Contents 1 Introduction 2 Ordering Information 3 Receiver Development Board 3 Board Objects 4 Initial Setup 4 Troubleshooting 5 The Prototyping Area 6 The Receiver Section 7 The USB Section 8 The Display Section 9 Master Development Software 10 Schematics GPS/GNSS Master Development System User's Guide Figure 1: GPS / GNSS Master Development System Introduction The Linx GPS and GNSS modules offer a simple, efficient and cost-effective method of adding GPS or GNSS capabilities to any product. The Master Development System is intended to give a designer all the tools necessary to correctly incorporate the modules into an end product. The development boards themselves serve several important functions: • Rapid Module Evaluation: The boards allow the performance of the modules to be evaluated quickly in a user’s environment. • Application Development: An onboard prototyping area allows for the development of custom circuits directly on the development board. All signal lines are available on a header for easy access. • Design Benchmark: The boards provide a known benchmark against which the performance of a custom design may be judged. The Master Development System includes one assembled development board, one receiver module on an evaluation board, one spare receiver module for use on your first prototype, one SH Series active GPS antenna, 4 AAA batteries and full documentation. –1 – Revised 3/18/2015 Receiver Development Board Ordering Information 2 Ordering Information Part Number Description MDEV-GPS-R4 R4 Series Master Development System MDEV-GPS-F4 F4 Series Master Development System MDEV-GPS-RM RM Series Master Development System MDEV-GPS-FM FM Series Master Development System MDEV-GNSS-GM GM Series Master Development System MDEV-GNSS-TM TM Series Master Development System EVM-GPS-R4 R4 Series Evaluation Module EVM-GPS-F4 F4 Series Evaluation Module EVM-GPS-RM RM Series Evaluation Module EVM-GPS-FM FM Series Evaluation Module EVM-GNSS-GM GM Series Evaluation Module EVM-GNSS-TM TM Series Evaluation Module RXM-GPS-R4-x R4 Series GPS Receiver Module RXM-GPS-F4-x F4 Series GPS Receiver Module RXM-GPS-RM-x RM Series GPS Receiver Module RXM-GPS-FM-x FM Series GPS Receiver Module RXM-GNSS-GM-x GM Series GNSS Receiver Module RXM-GNSS-TM-x TM Series GNSS Receiver Module 8 4 Figure 2: Ordering Information –2 – 3 9 1 6 7 10 5 11 Figure 3: Receiver Development Board Board Objects 1. Four AAA Batteries (on back) 2. Power Switch 3. Voltage Regulator 4. USB Interface Module 5. Prototype Area 6. Break-Out Header 7. Receiver Evaluation Board 8. CR2032 Backup Battery (on back) 9. Module Data Routing Switch 10. OLED Display 11. OLED Display Power Switch –3 – Initial Setup The Prototyping Area Unpack the development system and install the AAA and coin-cell batteries. Connect the external GPS antenna. The power switch selects between the battery pack or USB power if the board is plugged into a USB bus. To use the display, turn the OLED display power switch on. The development board is now ready for use. After turning on the power, the module determines its current position. Please note, the time required for an initial fix or after long periods of storage is considerably greater than in subsequent operation. Please refer to the module’s data guide for complete information regarding Time-To-First-Fix (TTFF). To protect the display and extend its life, turn off the display before turning off the board. In addition to its evaluation functions, the board may also be used for actual product development. It features a prototyping area to facilitate the addition of application-specific circuitry. The prototyping area contains a large area of plated through-holes so that external circuitry can be placed on the board. The holes are set at 0.100” on center with a 0.040” diameter, making it easy to add most industry-standard SIP and DIP packages. Troubleshooting If the boards fail to work out of the box, then try the following: • Check the batteries to make sure they are not dead • Check to make sure that the power switch is in the correct position • Check that the antenna is installed correctly • Check that the data routing switch is set appropriately If all of these appear to be in order, please call +1 800 736 6677 or e-mail techsupport@linxtechnologies.com for technical support. External circuitry can be easily interfaced with the receiver through the breakout header (J3) on the upper right of the prototyping area. A switch controls the routing of data into the receiver module. By default the switch is set for operation with the on-board USB module. When communicating with the module from the prototyping area this switch should be set to Prototype Control. At the bottom of the prototyping area is a row connected to ground and at the top is a row connected to the 3.3V power supply. Note: The on-board 3.3-volt regulator has approximately 300mA of headroom available for additional circuitry. If added circuitry requires a higher current, the user must add an additional regulator to the prototype area or power the board from an external supply. Data Routing Switch +3 Volt Bus Ground Bus Figure 4: The Development Board Prototyping Area –4 – –5 – The Receiver Section The USB Section The receiver module is mounted on an evaluation board which plugs into headers on the main development board. The evaluation board has an SMA antenna connector to allow the attachment of many different styles of GPS antennas, including the included SH Series active GPS antenna. Each receiver module has its own evaluation board, but all of them are designed to fit into the same socket on the main board. The development board features a Linx QS Series USB module for interface to a PC. This allows the board to be used with the supplied development software or with custom software developed by the user. Figure 6: The Development Board USB Section Figure 5: The Development Board Receiver Section On the bottom of the main board is a CR2032 coin cell battery that provides power to the Real Time Clock (RTC) and SRAM when the receiver is powered down. This allows the receiver to start up and obtain a position fix faster. This cell provides about two years of operation. –6 – Drivers for the USB module are included on the software CD in the kit or may be downloaded from www.linxtechnologies.com. Additional information on using the QS Series USB module can also be found on the website. The USB connection also allows the board to be powered by the USB bus instead of batteries. This can be convenient during development to eliminate the need for frequent battery replacement. –7 – The Display Section Master Development Software The Master Development System features an OLED screen that displays the navigation information from the receiver module. This allows the development board to act as a stand-alone evaluation system without the need for any additional software. The development system is supplied with Windows-based software that communicates with the development board through the USB module. This software displays the information from the receiver module in the different NMEA formats and the satellite information, signal strength, and positions are displayed graphically. If the PC is connected to the internet, the software plots the current location on Google Maps. Full details are in the software’s User’s Guide. Figure 7: The Development Board Display Section The display is driven by an on-board microcontroller located under the display. Data from the receiver module is connected directly to this microcontroller. The microcontroller receives data at the receiver’s default 9,600bps. Note: If the receiver’s baud rate is changed, it will not be able to communicate with the microcontroller. The display and microcontroller pull about 100mA when fully powered, so a power switch is supplied to deactivate the display area when not in use, saving battery life. To protect the display and extend its life, be sure to turn the display section off before turning off the main power to the board. Figure 8: Master Development Software –8 – –9 – SW1 L2 D9 VCC U3 1 D5 EN GND 2 EN GND EN EN GND GND 10uH D5 SW5 Figure 13: Display Section Schematic 2 Figure 12: Power Supply Schematic GND – 10 – 49 50 R/W# 51 52 31 30 D/C#+ D/C# D/C# 29 + C14 10uF VCC GND 22 GND GND B1 VIN 49 OC2/RD1 VCC13 + VCC +GND C14 + C14 GND GND C12 4.7uF – 11 – TXM J6 1 2 3 4 GND VCC 5 3 J6 6 VCOMH GND J6 D6 4 VDDIO VCC C12 7 D7 C12 1 GND 5 VSL 1 8 J6 4.7uF D6GND 4.7uF 6 2 VCC13 VCC D6 VCC13 2 VCC 9 D5 C12 7 D7 VCOMH D7 3 GND 1 GND 3 VCOMH GND 10 D4 4.7uF D6 VDDIO 4 VCC VCC13 2 VCC 8 4 VDDIO VCC 11 D3 9 D5 5 VSL 3 VCOMH GND D7 5 VSL 12 D2 10 D4 R13 6 4 VDDIO VCC 6 D6 11 D3 13 D1 D651 7 D7 12 7 14 5 D2 D7D0 VSL R13 8 D6 13 8 15 6 D6 D1 D6E/RD# 51 9 D5 7 D7 14 9 D0 D5 D7 16 R/W# D7 10 D4 8 D6 15 10 D4 17 GNDE/RD# BS0 11 D3 GND 9 D5 16 11 R/W# D7 18 VCC D3BS1 17 12 GND BS0D2 12 19 10 D2CS# D4 R13 GND R13 18 13 VCC BS1D1 11 D3 13 D1 51 51 19 14 20 12 CS#D0D/C#D2 D0RES# 21 R12R13 D/C# 20 14 15 E/RD# D1 13 E/RD# 51 IREF GND R12 21 15 22 RES# 16 R/W# D0 14 R/W# 560k 22 16 23 IREF GND GPIO1 17 GND GPIO1 BS0 15 E/RD# 23 17 560k GND BS0 GND 24 GPIO0 GND C11 18 VCC GPIO0 BS1 16 R/W# 24 18 VCC BS1 25 C11 19 CS# BS0 25 19 17 GND CS# 26 VDD GND GND 20 D/C# BS1 26 20 18 VCC VDD GND D/C# 27 VCI 21 RES# CS# 27 21 19 VCIRES# R12 1uF R12 28 VSS GND 1uF VSSIREF D/C# 28 22 GND GND 22 29 20 IREF GND 560k 23 GPIO1 RES# 29 23 21 VCCVCC 560k R12 GPIO1 30 GND 30 GND 24 GPIO0 IREF 22 24 GPIO0 C11 GND C11 560k 25 23 GPIO1 25 C13 C13 26 VDD GPIO0 GND 24 26 VDD GND C11 0.1uF 0.1uF 27 VCI 25 27 VCI 1uF 1uF 28 VSS VDD GND 26 GND 28 VSS GND GND 29 GND 27 VCI 29 VCC 1uF VCC 30 GND 28 VSS GND GND 30 29 VCC 30 GND C13 C13 0.1uF 0.1uF C13 0.1uF GND GND GND VCC VCC GND + C14GND VCC VCC GND 10uF VCC 10uF 10uF + CS# 33 GND VCC J6 VCOMH GND C12 1 GND VDDIO VCC 4.7uF 2 VCC13 VCC VSL 28 GND VCC GND VCC 10uF GND VCC 27 + C14 VCC 26 VCC GND 34 PMA8/U2TX/SCL2/CN18/RF5 VCC 10uH U3 53 GND VCC GND 32 VCC GND U1TX/SDO1/RF3 EN U1 2 B1 GND B1 5 54 33 33 U1TX/SDO1/RF3 U1RX/SDI1/RF2 U1TX/SDO1/RF3 15 PGD1/EMUD1/PMA6/VREF+/AN0/CN2/RB0 PGC1/EMUC1/VREF-/AN1/CN3/RB1 PGD1/EMUD1/PMA6/VREF+/AN0/CN2/RB0 16 PGD1/EMUD1/PMA6/VREF+/AN0/CN2/RB0 25 PGD GND U1TX/SDO1/RF3 24 16 PGC 16 VCC 45 U1RTS/BCLK1/SCK1/INT0/RF6 PGD1/EMUD1/PMA6/VREF+/AN0/CN2/RB0 GND R10 C9 C10 VCC13 C9 R10 1 C10 VCC13 SW 47.5k VIN 47.5k C8 2 10uF 0.1uF C8 U1 GND GND 2 VCC13 10uF 0.1uF 10uF 1 3 GND GND L2 10uH 10uF L2 10uH 1 3 R11 Vin Vout SW1 R11 Vin Vout 4 3 3 EN FB4 EN L2 10uH D5 FB R2 4.99k D9 D5 R2 U3 4.99k D9 U3 200 R10 1 5 200 C9 C10 R10 GND 5 C9 C10 + GND GND + GND SW 1 VIN GNDSW D5 VIN 47.5k VCC U3 C16 D9 C16 47.5k C5VCC C5 C8 U1 R10 2 1 5 GND 2 100uF 10uF C8 100uF10uF 10uF C90.1uF 0.1uF C10 U1 GND SW VIN 10uF D1 D1 GND GND 10uF 47.5k 1 3 GND VCC 10uF GND 1 R11 Vin Vout 3 GRN GRN R11 Vin Vout 4 C8 3 GNDGND GND U1 2 GND 10uF 0.1uF 4 3 EN FB GND GND EN FB 10uF 1 3 R2 4.99k R11 Vin Vout R2 GND 4.99k 4 3 GND 200 EN FB 200 GND GND + GND + R2 4.99k GND C16 C5 C16 C5 200 10uF 100uF GND GND + 10uF 100uF D1 D1 C16 GND C5 GND GRN GRN 10uF GND GND 100uF GND GND D1 GND GRN GND GND GND GND B1 GND SW1 SW1 VCCU D9 55 56 57 59 58 D0 EN D1 60 D2 61 D3 62 D4 D4 PMD4/RE4 63 63 D4 D3 D3 D4 PMD3/RE3 62 62 D3 D2 D2 D3 PMD2/RE2 61 61 D2 D1 D1 D2 PMD1/RE1 D1 60 60 D0 D0 D1 PMD0/RE0 D0 59 59 EN EN D0 EN RF1 58 58 64 64 PMD4/RE4 PMD3/RE3 PMD3/RE3 PMD4/RE4 PMD4/RE4 64 64 PGD PGD SW2 46 VCC VCC 46 IC2/U1CTS/INT2/RD9 46 47POWER SWITCH VCC OC1/RD0 46 SOSCI/CN1/RC13 SW2 VCC OC1/RD0 OC1/RD0 GND VCC 42 GND 45 IC1/RTCC/INT1/RD8 45 46 GND IC4/PMCS1/INT4/RD11 OC1/RD0 45 IC4/PMCS1/INT4/RD11 GND IC4/PMCS1/INT4/RD11 41 GND 44 VSS 44 45GND IC3/PMCS2/INT3/RD10 IC4/PMCS1/INT4/RD11 44 IC3/PMCS2/INT3/RD10 IC3/PMCS2/INT3/RD10 40 SW2 SW2SW2 43 OSC2/CLKO/RC15 44 43 43 IC2/U1CTS/INT2/RD9 POWER SWITCH IC3/PMCS2/INT3/RD10 IC2/U1CTS/INT2/RD9 POWER SWITCH IC2/U1CTS/INT2/RD9 POWER SWITCH VCC 39 SW2 VCC VCC 42 OSC1/CLKI/RC12 43 42 42 IC1/RTCC/INT1/RD8 IC2/U1CTS/INT2/RD9 POWER SWITCH IC1/RTCC/INT1/RD8 IC1/RTCC/INT1/RD8 GND VCC 38 GND GND 41 41 41 VDD 42VCC GNDGND VSS GND VSS IC1/RTCC/INT1/RD8 VSS GND 40 40 37 41 RES# SCL1/RG2 OSC2/CLKO/RC15 40 OSC2/CLKO/RC15 GND VSS OSC2/CLKO/RC15 39 39 36 40 CS# SDA1/RG3 OSC1/CLKI/RC12 39 OSC1/CLKI/RC12 OSC2/CLKO/RC15 OSC1/CLKI/RC12 38 35 VDD 38VCC 39 U1RTS/BCLK1/SCK1/INT0/RF6 38 VCC VDD OSC1/CLKI/RC12 VCC VDD 37 34 RES# SCL1/RG2 37 TXM U1RX/SDI1/RF2 38 37 RES# SCL1/RG2 VDD VCC RES# SCL1/RG2 36 33 CS# SDA1/RG3 36 U1TX/SDO1/RF3 36 37 CS# RES# SDA1/RG3 SCL1/RG2 CS# SDA1/RG3 35 ++ /FAULT /FAULT /FAULT /FAULT /FAULT PGD 47 35 36 U1RTS/BCLK1/SCK1/INT0/RF6 SDA1/RG3 34 35 U1RTS/BCLK1/SCK1/INT0/RF6 TXM U1RX/SDI1/RF2 34 35 TXM U1RX/SDI1/RF2 33 34 TXM U1RTS/BCLK1/SCK1/INT0/RF6 U1RX/SDI1/RF2 VCC13 VCCU 48 IC4/PMCS1/INT4/RD11 48 SOSC0/T1CK/CN0/RC14 SOSC0/T1CK/CN0/RC14 C2IN-/AN2/SS1/CN4/RB2 23 GSHD GSHD 5 6 GSHD 5 PGC PGC OC1/RD0 48 48 44 SOSC0/T1CK/CN0/RC14 47 IC3/PMCS2/INT3/RD10 47 48 SOSCI/CN1/RC13 SOSC0/T1CK/CN0/RC14 SW2 SOSCI/CN1/RC13 SW2 SW2 47 43 SW2 SOSCI/CN1/RC13 13 C2IN-/AN2/SS1/CN4/RB2 C2IN+/AN3/CN5/RB3 15 C2IN-/AN2/SS1/CN4/RB2 PGC1/EMUC1/VREF-/AN1/CN3/RB1 14 PGC1/EMUC1/VREF-/AN1/CN3/RB1 C2IN-/AN2/SS1/CN4/RB2 16 PGC1/EMUC1/VREF-/AN1/CN3/RB1 VCC13 SW1 L2 B1 VCCU VCCU 15 15 GND Figure 11: USB Section Schematic VCCU 14 14 22 GSHD GSHD 5 6 GSHD GSHD GSHD GSHD GSHD 55 6 66 1 5 D5 PGC GND2 C15 C15 + 10uF VCC +VCC10uF PMA5/SCK2/CN8/RG6 PMD5/RE5 PMD5/RE5 1 PMD5/RE5 2 1PMA4/SDI2/CN9/RG7 2 D6 PMD6/RE6 D5 PMD5/RE5 R14D6 PMD6/RE6 VCC 100k 6 2 D6 PMD6/RE6 VCC 3 PMA3/SDO2/CN10/RG8 2 VCC 3 D7 PMD7/RE7 D6 PMD6/RE6 D7 PMD7/RE7 3 VCC D7 PMD7/RE7 7 U5 4 VPP 3MCLR D8 4 D8 PMA5/SCK2/CN8/RG6 PMD7/RE7 4 D8 D7 PMA5/SCK2/CN8/RG6 PMA5/SCK2/CN8/RG6 8 5 4PMA2/SS2/CN11/RG9 D8 5 PMA4/SDI2/CN9/RG7 PMA5/SCK2/CN8/RG6 5 PMA4/SDI2/CN9/RG7 PMA4/SDI2/CN9/RG7 R14 R14 R14 9 100k 6 100k 100k GND 6 65VSS PMA4/SDI2/CN9/RG7 PMA3/SDO2/CN10/RG8 PMA3/SDO2/CN10/RG8 PMA3/SDO2/CN10/RG8 R14 10 7 U5U5 100k VCC 7 76VDD PMA3/SDO2/CN10/RG8 U5 VPP MCLR VPP MCLR VPP MCLR 11 8 87C1IN+/AN5/CN7/RB5 U5 PMA2/SS2/CN11/RG9 PMA2/SS2/CN11/RG9 VPP 8 MCLR PMA2/SS2/CN11/RG9 12 9 9 8C1IN-/AN4/CN6/RB4 9 GND GND VSS VSS PMA2/SS2/CN11/RG9 GND VSS 13 10 10 9C2IN+/AN3/CN5/RB3 VCC 10 VCC GND VDD VDD VSS VCC VDD 14 11 C1IN+/AN5/CN7/RB5 11 10C2IN-/AN2/SS1/CN4/RB2 11 C1IN+/AN5/CN7/RB5 VCC VDD C1IN+/AN5/CN7/RB5 12 15 C1IN-/AN4/CN6/RB4 12 PGC 11PGC1/EMUC1/VREF-/AN1/CN3/RB1 12 C1IN-/AN4/CN6/RB4 C1IN+/AN5/CN7/RB5 C1IN-/AN4/CN6/RB4 16 13 C2IN+/AN3/CN5/RB3 13 PGD 12PGD1/EMUD1/PMA6/VREF+/AN0/CN2/RB0 13 C2IN+/AN3/CN5/RB3 C1IN-/AN4/CN6/RB4 C2IN+/AN3/CN5/RB3 14 D5 D5 U4 16 USBDP RI 15 DCD USBDM C3 14 GND10pF R5 10 GND C6 3 GND DSR GND USB-B 10pF 13 4 C3 TXM DATA IN VCC C3 J2 C6 U4 4 12 5 L1 GND J2 C6 R4GND 10pF 10 RXM USB DATA OUT SUSP IND SUSP IND 10pF USB-B 16 3 1 10pF 11 6 USB-B 10pF DAT+ USBDP RI C3 RTS TX IND 15 2 C4 + U4 RX IND 2 USBDM 4 J2 C6 C7 10 7 U4 4 DCD DATGND R4 110pF 10 CTS 16 C2 RX IND 1R5 10 TX IND GND 14 3 3 USB-B R4 10 10pF DSR GND 5V GND 16 9 1 8 USBDP DAT+ 3 RI 13 4 485 TX DTR 0.01uF DAT+ USBDP RI 15 2 2 U4 4 TXM VCC 4.7uF L1 0.1uF 15 DATA IN 12 2 2 DCD DATUSBDM GND 5 R4 10 DCD IND14DATA 16 R1 DAT- 1 3 USBDM 1 3 1 IND RXM USB OUT SUSP SUSP SDM-USB-QS 14 3 R5 10 DSR GND 5V GND 11 6 USBDP RX RI R5 10 GND DSR GND 5V DAT+ 2 0 13 4 RTS IND TX IND 15 2 GND GND GND 13 4 C7 7DATA C4 + TXM 10 DATA INR7 DCD VCC DATUSBDM 200 14 TXM VCC CTS TX IN IND C2 RX IND 12 5 L1 R3 3 1 L1 12 RXM USB9 5 SUSP IND 8 DATA OUT SUSP IND GND R5 10 GND 5V TXUSB IND /FAULT 485 TX DSR DTR 0.01uF DATA OUT IND SUSP IND 11 RXM 6 SUSP 13 4.7uF U2 0.1uF 11 6 RTS RX 4IND INDVCC TX IND IND TXM DATA R1 100k RTS TX C7 10IN 12 7 RX C4 ++ 5IND L1 C4 D2SDM-USB-QS TX_IND C7 VCCU GND 10 CTS TX C2 RX IND INDSUSP7 INDTX RXM USB DATA OUT 0 IND SUSP INDCTS C2 RX 8 9 11 6 GND GND GND 1 6 TX IND 8 485 TX RX IND DTR 9 0.01uF R7 200 RTS INC4R30.1uF R8 200 4857TX DTR 0.01uF C7 4.7uF + OUT 10 + C17 0.1uF TX IND /FAULT CTS TX IND C2 4.7uF R1 U25 RX IND SDM-USB-QS R1 SDM-USB-QS 8 9 RX IND C1 100k 485 TX VCCU DTR 0.01uF 2GND 0 D2 TX_IND GND ILIM GND GND 0 GND GND 4.7uF RX_IND 0.1uF 0.1uF 100uF D3 GND GND GND R7 200 200 R3 R1 1 6 SDM-USB-QS R7 R3 IN OUT 3 4 TXR8IND IND200 /FAULT 0 + C17 /FAULT R9 200 TX SUSP IND /FAULT U2 EN GND GND GND RX IND GND GND 100k R3 U2 C1 2 5 R6 100k D2 TX_IND TX_IND R7 200 /FAULT VCCU GND GND ILIM GND D2 VCCU GND 0.1uF 100uF D3 RX_IND TX IND /FAULT 53.6k 1 6 U2 D4 Over Current 1 INTPS2553OUT 3 6 4 R8 200 100k C17 R9 200 EN /FAULT SUSP IND IN OUT R8 200 D2 TX_IND + VCCU GND GND GND + C17 RX IND IND R6 /FAULT RX C1 2 5 1 6 C1 GND 2 5 53.6k GND ILIM OUT GND IN ILIM 200 Current D3 RX_IND RX_IND R8 GND 0.1uF GND 100uF D4 Over TPS2553 + C17 D3 0.1uF 100uF RX IND C1 3 4 2 5 3 EN R9 200 /FAULT 4ILIM SUSP IND IND GND GND D3 RX_IND 200 EN /FAULT SUSP 0.1uF GND GND GND 100uF R9 R6 GND GND /FAULT R6 /FAULT 3 4 53.6k R9 200 /FAULT 53.6k SUSP INDTPS2553EN D4 Over Over Current Current GND GND D4 TPS2553 R6 /FAULT 53.6k D4 Over Current GND TPS2553 GND 3 2 J2 1 1 1 4 10uF 10uF SOSCI/CN1/RC13 21 RXMUSB D8 PMD7/RE7 GND C15 GNDC15 + VCC + VCC SOSC0/T1CK/CN0/RC14 20 RXM SW3 RXMHDR RXMHDR SW3 RXMUSB RXMUSB RXMHDR RXMUSB RXMHDR RXM D7 PMD6/RE6 19 SW3 SW3 RXM RXM 3 PMD5/RE5 18 10 RXMHDR RXMUSB VCC 2 D6 GND GND PMD4/RE4 63 PMD3/RE3 PMD2/RE2 PMD2/RE263 PMD3/RE3 62 PMD2/RE2 PMD1/RE1 PMD1/RE1 62 PMD2/RE2 61 PMD1/RE1 PMD0/RE0 PMD0/RE061 60 PMD1/RE1 PMD0/RE0 RF1 RF1 60 59 PMD0/RE0 RF1 RF0 RF0 58 59 RF0 EN RF1 RF0 57 57 ENVREG ENVREG 57 58 ENVREG RF0 ENVREG 56 56 VCAP/VDDCORE VCAP/VDDCORE56 57 VCAP/VDDCORE ENVREG VCAP/VDDCORE 55 55 55 CN16/RD7 CN16/RD7 CN16/RD7 56 VCAP/VDDCORE CN16/RD7 54 54 54 CN15/RD6 CN15/RD6 CN15/RD6 55 CN16/RD7 CN15/RD6 53 53 53 E/RD# PMRD/CN14/RD5 E/RD# PMRD/CN14/RD5 E/RD# PMRD/CN14/RD5 54 CN15/RD6 PMRD/CN14/RD5 52 52 52 PMWR/OC5/IC5/CN13/RD4 PMWR/OC5/IC5/CN13/RD4 R/W# PMWR/OC5/IC5/CN13/RD453 R/W#R/W# E/RD# PMRD/CN14/RD5 PMWR/OC5/IC5/CN13/RD4 51 51 51 PMBE/OC4/RD3 PMBE/OC4/RD3 PMBE/OC4/RD352 50 R/W# PMWR/OC5/IC5/CN13/RD4 PMBE/OC4/RD3 OC3/RD2 50 50 OC3/RD2 OC3/RD2 51 49 PMBE/OC4/RD3 OC3/RD2 OC2/RD1 49 49 OC2/RD1 OC2/RD150 OC3/RD2 OC2/RD1 64 RXM 1 2 3 4 5 6 7 8 9 10 C6 10pF 10pF R4 SW3 J3 1 D5 17 GND DAT+ DAT5V J5 VBACKUP VBACKUP 1 GND VBACKUP VBACKUP 2 B2 B2 3 BATHLD-001 BATHLD-001 4 B2 B2 5 BATHLD-001 BATHLD-001 6 7 GND GND 8 GND GND 9 10 C15 10uF VCC + PGC2/EMUC2/AN6/OCFA/RB6 PGC2/EMUC2/AN6/OCFA/RB6 17 PGC2/EMUC2/AN6/OCFA/RB6 17 PGC2/EMUC2/AN6/OCFA/RB6 PGD2/EMUD2/AN7/RB7 PGD2/EMUD2/AN7/RB7 18 PGC2/EMUC2/AN6/OCFA/RB6 PGD2/EMUD2/AN7/RB7 18 19 19 AVDD AVDD PGD2/EMUD2/AN7/RB7 19 PGD2/EMUD2/AN7/RB7 AVDD 19 20 20 AVDD AVSS AVSS 20 AVDD 20 AVSS AVSS 21 21 U2CTS/C1OUT/AN8/RB8 U2CTS/C1OUT/AN8/RB8 21 AVSS 21 U2CTS/C1OUT/AN8/RB8 U2CTS/C1OUT/AN8/RB8 22 22 PMA7/C2OUT/AN9/RB9 PMA7/C2OUT/AN9/RB9 22 22 U2CTS/C1OUT/AN8/RB8 PMA7/C2OUT/AN9/RB9 PMA7/C2OUT/AN9/RB9 23 23 TMS/PMA13/CVREF/AN10/RB10 TMS/PMA13/CVREF/AN10/RB10 23 23 TMS/PMA13/CVREF/AN10/RB10 PMA7/C2OUT/AN9/RB9 TMS/PMA13/CVREF/AN10/RB10 24 24 TDO/PMA12/AN11/RB11 TDO/PMA12/AN11/RB11 24 24 TDO/PMA12/AN11/RB11 TMS/PMA13/CVREF/AN10/RB10 TDO/PMA12/AN11/RB11 25 25 VSS VSS 25 VSS25 TDO/PMA12/AN11/RB11 VSS 26 26 26 VDD VDD VDD26 VSS VDD 27 27 27 TCK/PMA11/AN12/RB12 TCK/PMA11/AN12/RB12 TCK/PMA11/AN12/RB12 27 VDD TCK/PMA11/AN12/RB12 28 28 28 TDI/PMA10/AN13/RB13 TDI/PMA10/AN13/RB13 TDI/PMA10/AN13/RB13 28 TCK/PMA11/AN12/RB12 TDI/PMA10/AN13/RB13 29 29 29 PMA1/U2RTS/BCLK2/AN14/RB14 PMA1/U2RTS/BCLK2/AN14/RB14 PMA1/U2RTS/BCLK2/AN14/RB14 29 TDI/PMA10/AN13/RB13 PMA1/U2RTS/BCLK2/AN14/RB14 30 30 30 D/C# PMA0/AN15/OCFB/CN12/RB15 PMA0/AN15/OCFB/CN12/RB15 PMA0/AN15/OCFB/CN12/RB15 31D/C# 30 PMA1/U2RTS/BCLK2/AN14/RB14 PMA0/AN15/OCFB/CN12/RB15 PMA9/U2RX/SDA2/CN17/RF4 31 31 PMA9/U2RX/SDA2/CN17/RF4 PMA9/U2RX/SDA2/CN17/RF4 31 32 PMA0/AN15/OCFB/CN12/RB15 PMA9/U2RX/SDA2/CN17/RF4 PMA8/U2TX/SCL2/CN18/RF5 32 32 PMA8/U2TX/SCL2/CN18/RF5 PMA8/U2TX/SCL2/CN18/RF5 32 PMA9/U2RX/SDA2/CN17/RF4 PMA8/U2TX/SCL2/CN18/RF5 J2 USB-B Figure 10: Header Section Schematic 4 B2 BATHLD-001 18 18 Figure 9: Receiver Section TXM 1 2 Schematic RXMHDR 1PPS 3 RFPWRUP 4 J3 5 J3 ON_OFF GPIOE 6 J3 TXM 1 TXM 1 TXM GPIOD RXMHDR 2 7 RXMHDR RXMHDR 2 GPIOCTXM 3 1PPS 8 1 1PPS 1PPS 3 RXMHDRRFPWRUP GPIOB RFPWRUP 4 9 2 RFPWRUP 4 1PPS GPIOA ON_OFF ON_OFF 5 10 3 ON_OFF RFPWRUP 5 GPIOE 6GPIOE4 GPIOE 6 ON_OFF GPIOD 7GPIOD5 GPIOD 7 GPIOC GPIOE 6 GPIOC 8 GPIOC 8 GPIOB GPIOBGPIOD 9 9GPIOA7 GPIOB GPIOC 8 GPIOA 10 GPIOA GPIOB 10 9 GND 10 C3 GPIOA VBACKUP 17 17 Schematics D4 1 2 3 VCC 4 J5 5 J5 VBACKUP GND 1 6 J5 GND 1 J4 GPIOC 2 7 2 GPIOBGND 8 1 1 3GND 3 2 GPIOA VCC 4 9 2 VCC 4 3 GND 5 10 3 5 4 6VCC 4 VBACKUP VCC 6 5 VBACKUP 5 GPIOC 7 GPIOC 7 VBACKUP 6 6 VBACKUP GPIOB 8 GPIOB 8 GPIOC 7 GPIOC 7 GPIOA 9 GPIOB 8 GPIOA 9 GPIOB 8 GND 10 GPIOA 9 GND 10 GPIOA 9 GND 10 GND 10 J3 63 GND GND 1 GPIOD 2 GPIOE 3 TXM 4 J4 5 J4 RXM 1PPS GND 1 6 J4 GND 1 RESET GPIOD 2 7 GPIOD 2 GND 1 RFPWRUP GPIOE 3 8 GND GPIOEGPIOD 3 2 ON_OFF TXM 4 9 GPIOD TXM 4 GPIOE 3 GPIOE GND 10 RXM 5 RXM 5 TXM 4 1PPS TXM 6 6 1PPS RXM RXM 5 RESET 7 RESET 7 1PPS 1PPS 6 RFPWRUP 8 RESET RFPWRUP 8 RESET 9 7 ON_OFF RFPWRUP ON_OFF 9 RFPWRUP 8 GND 10ON_OFF GND ON_OFF 10 GND 9 GND 10 E/RD# GND J5 J4 Linx Technologies 159 Ort Lane Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com Disclaimer Linx Technologies is continually striving to improve the quality and function of its products. For this reason, we reserve the right to make changes to our products without notice. The information contained in this Data Guide is believed to be accurate as of the time of publication. Specifications are based on representative lot samples. Values may vary from lot-to-lot and are not guaranteed. “Typical” parameters can and do vary over lots and application. Linx Technologies makes no guarantee, warranty, or representation regarding the suitability of any product for use in any specific application. It is the customer’s responsibility to verify the suitability of the part for the intended application. NO LINX PRODUCT IS INTENDED FOR USE IN ANY APPLICATION WHERE THE SAFETY OF LIFE OR PROPERTY IS AT RISK. Linx Technologies DISCLAIMS ALL WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL LINX TECHNOLOGIES BE LIABLE FOR ANY OF CUSTOMER’S INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING IN ANY WAY FROM ANY DEFECTIVE OR NON-CONFORMING PRODUCTS OR FOR ANY OTHER BREACH OF CONTRACT BY LINX TECHNOLOGIES. The limitations on Linx Technologies’ liability are applicable to any and all claims or theories of recovery asserted by Customer, including, without limitation, breach of contract, breach of warranty, strict liability, or negligence. Customer assumes all liability (including, without limitation, liability for injury to person or property, economic loss, or business interruption) for all claims, including claims from third parties, arising from the use of the Products. The Customer will indemnify, defend, protect, and hold harmless Linx Technologies and its officers, employees, subsidiaries, affiliates, distributors, and representatives from and against all claims, damages, actions, suits, proceedings, demands, assessments, adjustments, costs, and expenses incurred by Linx Technologies as a result of or arising from any Products sold by Linx Technologies to Customer. Under no conditions will Linx Technologies be responsible for losses arising from the use or failure of the device in any application, other than the repair, replacement, or refund limited to the original product purchase price. Devices described in this publication may contain proprietary, patented, or copyrighted techniques, components, or materials. Under no circumstances shall any user be conveyed any license or right to the use or ownership of such items. ©2015 Linx Technologies. All rights reserved. The stylized Linx logo, Wireless Made Simple, WiSE, CipherLinx and the stylized CL logo are trademarks of Linx Technologies.
RXM-GPS-FM-T 价格&库存
很抱歉,暂时无法提供与“RXM-GPS-FM-T”相匹配的价格&库存,您可以联系我们找货
RXM-GPS-FM-T
    • 1+584.01000
    • 200+233.02080
    • 500+225.24480
    • 1000+221.38920
