RXM-GNSS-GM-T
RXM-GNSS-GM-T
    LINXTECHNOLOGIES(灵思)
    SMD20
RXM-GNSS-GM-T 数据手册
GM Series GNSS Receiver Module Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1 Description 1 Features 1 NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2 Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 5 Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 2 2 4 4 6 6 7 7 7 7 8 9 10 11 12 19 40 41 42 43 44 44 44 46 Applications Include Ordering Information Absolute Maximum Ratings Electrical Specifications Pin Assignments Pin Descriptions A Brief Overview of GNSS Time To First Fix (TTFF) Module Description Backup Battery Power Supply Requirements The 1PPS Output Hybrid Ephemeris Prediction (AGPS) Antenna Considerations Power Control Slow Start Time Interfacing with NMEA Messages NMEA Output Messages Input Messages Typical Applications Microstrip Details Board Layout Guidelines Pad Layout Production Guidelines Hand Assembly Automated Assembly Master Development System 47 Appendix A 54 Notes GM Series GNSS Receiver Data Guide Description 0.591 in (15.00 mm) The GM Series GNSS receiver module is a self-contained high-performance Global Satellite Navigation System receiver. Based on the MediaTek chipset, it can simultaneously acquire and track multiple satellite constellations. These include the United States GPS system, Europe’s GALILEO, Russia’s GLONASS and Japan’s QZSS. 0.512 in (13.00 mm) GNSS MODULE RXM-GNSS-GM LOT GRxxxx 0.087 in (2.20 mm) The module provides exceptional sensitivity, Figure 1: Package Dimensions even in dense foliage and urban canyons. It’s very low power consumption helps maximize runtimes in battery powered applications. Hybrid ephemeris prediction can be used to achieve cold start times of less than 15 seconds. The module outputs standard NMEA data through a UART interface. Housed in a compact reflow-compatible SMD package, the receiver requires no programming or additional RF components (except an antenna) to form a complete GNSS solution. This makes the GM Series easy to integrate, even by engineers without previous RF or GNSS experience. Features Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. • • • • • • MediaTek chipset High sensitivity (–161dBm) Fast TTFF at low signal levels Battery-backed SRAM 3-day ephemeris prediction No programming necessary • • • • • No external RF components needed (except an antenna) No production tuning UART serial interface Power control features Compact SMD package • • • Surveying Logistics Fleet Management Applications Include • • • Positioning and Navigation Location and Tracking Security/Loss-Prevention – 1 – Revised 10/20/2017 Ordering Information GM Series GNSS Receiver Specifications Ordering Information Symbol Min. Typ. Max. Units Part Number Description Parameter VOUT Output Voltage VOUT 2.7 2.8 2.9 VDC RXM-GNSS-GM-x GM Series GNSS Receiver Module VOUT Output Current IOUT 30 mA MDEV-GNSS-GM GM Series GNSS Receiver Master Development System Output Low Voltage VOL 0.4 VDC EVM-GNSS-GM GM Series Evaluation Module Output High Voltage VOH 2.4 Notes 2 3.3 x = “T” for Tape and Reel, “B” for Bulk Output Low Current IOL 2.0 mA Reels are 1,000 pieces. Quantities less than 1,000 pieces are supplied in bulk Output High Current IOH 2.0 mA Input Low Voltage VIL –0.3 0.8 VDC Figure 2: Ordering Information Input High Voltage VIH 2.0 3.6 VDC Absolute Maximum Ratings Input Low Current IIL –1 1 µA 4 IIH –1 1 µA 4 TRST 1 Input High Current Absolute Maximum Ratings Minimum RESET Pulse ms Supply Voltage VCC +4.3 VDC Receiver Section Input Battery Backup Voltage +4.3 VDC Receiver Sensitivity VOUT Output Current 50 mA Tracking –161 dBm Operating Temperature –40 to +85 ºC Cold Start –143 dBm Storage Temperature –40 to +85 ºC Acquisition Time Hot Start (Open Sky) 1 s Hot Start (Indoor) 30 s Cold Start 33 s Cold Start, AGPS 15 s 3 m 2.5 m Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. Figure 3: Absolute Maximum Ratings Position Accuracy Electrical Specifications Autonomous SBAS GM Series GNSS Receiver Specifications Parameter Symbol Min. Typ. Max. Units Notes Supply Current VCC 3.0 3.3 4.3 Velocity VDC Chipset lCC Peak 150 mA 1, 2 Acquisition 24 mA 2 Tracking 16 mA 2 Standby 0.365 mA 2 Backup Battery Voltage VBAT Backup Battery Current IBAT 7 µA 2.0 4.3 VDC RIN 50 Ω Antenna Port RF Impedance –11 Altitude Power Supply Operating Voltage 1PPS Accuracy – 2 – 3 11 ns 18,000 m 515 m/s 5 MediaTek MT3333 Frequency GPS, GALILEO, QZSS: L1 1575.42MHz, C/A code GLONASS: L1 1598.0625MHz ~ 1605.375MHz, C/A code Channels 99 Update Rate 1Hz default, up to 10Hz Protocol Support 1. 2. 3. 4. 5. NMEA 0183 ver 4.10 This is the current when dowloading AGPS data to the module VCC = 3.3V, without active antenna, ephemeris prediction is off VCC = 0V No pull-up or pull-down on the lines Relative to other GM Series modules, not to UTC time Figure 4: Electrical Specifications – 3 – Pin Assignments 1 2 3 4 5 21 6 7 8 9 10 A Brief Overview of GNSS NC NC 1PPS TX RX GND NC LCKIND RESET NC NC GND RFIN GND VOUT NC GND NC NC NC VCC VBACKUP 20 19 18 17 16 22 15 14 13 12 11 Global Navigation Satellite System is a generic term that covers any system of satellites that are used to determine location on Earth and have global coverage. As of 2013 there are two fully operational GNSS systems; NAVSTAR GPS operated by the United States and GLONASS operated by Russia. The European Union is building its satellite constellation for their Galileo system and China has started to expand their Beidou system into a global system called Compass. The United States has the original GNSS system consisting of a nominal constellation of 24 satellites orbiting the earth at about 12,000 nautical miles in height. The pattern and spacing of the satellites allow at least four to be visible above the horizon from any point on the Earth. Russia’s GLONASS system fell into disrepair after the collapse of the Soviet Union, but was recovered and fully restored in 2011. Figure 5: GM Series GNSS Receiver Pinout (Top View) The systems were originally intended for military applications such as ordinance delivery and troop movement. In 1994 when the NAVSTAR constellation was completed, the GPS signals were made available for civilian applications, primarily aircraft navigation. Pin Descriptions Pin Descriptions Pin Number Name I/O Description 1, 2, 6, 9, 10, 13, 14, 15, 16 NC − No electrical connection 3 1PPS O 1 Pulse Per Second (11nS accuracy) 4 TX O Serial output (default NMEA) 5 RX I Serial input (default NMEA) 7 LCKIND O Lock Indicator. Outputs a 50ms pulse every second when a GPS fix is available. 8 RESET I Active low module reset. This line is pulled high internally. Leave it unconnected if it is not used. 11 VBACKUP P Backup battery supply voltage. This line must be powered to enable the module. 12 VCC P Supply Voltage 17 VOUT O 2.8V output for an active antenna 18, 20, 21, 22 GND P Ground 19 RFIN I GNSS RF signal input Figure 6: GM Series GNSS Receiver Pin Descriptions – 4 – Each satellite transmits low power radio signals which contain three different bits of information; a pseudorandom code identifying the satellite, ephemeris data which contains the current date and time as well as the satellite’s precise orbit information, and the almanac data which tells where each satellite should be at any time throughout the day and its status. A receiver times the signals sent by multiple satellites and calculates the distance to each satellite. If the position of each satellite is known, the receiver can use triangulation to determine its position anywhere on the earth. The receiver uses four satellites to solve for four unknowns; latitude, longitude, altitude, and time. If any of these factors is already known to the system, an accurate position (fix) can be obtained with fewer satellites in view. Tracking more satellites improves calculation accuracy. A faster Time To First Fix (TTFF) is possible if satellite information is stored in the receiver. If the receiver knows some of this information, then it can accurately predict satellite positions before acquiring an updated position fix. For example, aircraft or marine navigation equipment may have other means of determining altitude, so the GPS receiver would only have to lock on to three satellites and calculate three equations to provide the first position fix after power-up. – 5 – Time To First Fix (TTFF) Backup Battery TTFF is often broken down into three parts: The module is designed to work with a backup battery that keeps the SRAM memory and the RTC powered when the RF section and the main GPS core are powered down. This enables the module to have a faster Time To First Fix (TTFF) when it is powered back on. The memory and clock pull about 7µA. This means that a small lithium battery is sufficient to power these sections. This significantly reduces the power consumption and extends the main battery life while allowing for fast position fixes when the module is powered back on. Cold: A cold start is when the receiver has no accurate knowledge of its position or time. This happens when the receiver’s internal Real Time Clock (RTC) has not been running or it has no valid ephemeris or almanac data. In a cold start, the receiver takes up to 30 seconds to acquire its position. Warm: A typical warm start is when the receiver has valid almanac and time data and has not significantly moved since its last valid position calculation. This happens when the receiver has been shut down for more than 2 hours, but still has its last position, time, and almanac saved in memory, and its RTC has been running. The receiver can predict the location of the current visible satellites and its location; however, it needs to wait for an ephemeris broadcast (every 30 seconds) before it can accurately calculate its position. The backup battery must be installed for the module to be enabled. Power Supply Requirements Hot: A hot start is when the receiver has valid ephemeris, time, and almanac data. In a hot start, the receiver takes 1 second to acquire its position. The time to calculate a fix in this state is sometimes referred to as Time to Subsequent Fix or TTSF. The module requires a clean, well-regulated power source. While it is preferable to power the unit from a battery, it can operate from a power supply as long as noise is less than 20mV. Power supply noise can significantly affect the receiver’s sensitivity, therefore providing clean power to the module should be a high priority during design. Bypass capacitors should be placed as close as possible to the module. The values should be adjusted depending on the amount and type of noise present on the supply line. Module Description The 1PPS Output The GM Series GNSS Receiver module is based on the MediaTek MT3333 chipset, which consumes less power than competitive products while providing exceptional performance even in dense foliage and urban canyons. No external RF components are needed other than an antenna. The simple serial interface and industry standard NMEA protocol make integration of the GM Series into an end product extremely straightforward. The module’s high-performance RF architecture allows it to receive GNSS signals that are as low as –161dBm. The GM Series can track up to 33 satellites at the same time. Once locked onto the visible satellites, the receiver calculates the range to the satellites and determines its position and the precise time. It then outputs the data through a standard serial port using several standard NMEA protocol formats. The GNSS core handles all of the necessary initialization, tracking, and calculations autonomously, so no programming is required. The RF section is optimized for low level signals, and requires no production tuning. – 6 – The 1PPS line outputs 1 pulse per second on the rising edge of the GNSS second when the receiver has an over-solved navigation solution from five or more satellites. The pulse has a duration of 100ms by default with the rising edge on the GNSS second. This line is low until the receiver acquires a 3D fix. The pulse width can be adjusted with a serial command. The GNSS second is based on the atomic clocks in the satellites, which are monitored and set to Universal Time master clocks. This output and the time calculated from the satellite transmissions can be used as a clock feature in an end product with ±11ns accuracy. Hybrid Ephemeris Prediction (AGPS) AGPS is where the receiver uses the ephemeris data broadcast by the satellites to calculate models of each visible satellite’s future location. This allows the receiver to store up to 3 days’ worth of ephemeris data and results in faster TTFF. Having this data reduces the cold start time to less than 15 seconds. Contact Linx for details on this. – 7 – Antenna Considerations Power Control The GM Series module is designed to utilize a wide variety of external antennas. The module has a regulated power output which simplifies the use of GNSS antenna styles which require external power. This allows the designer great flexibility, but care must be taken in antenna selection to ensure optimum performance. For example, a handheld device may be used in many varying orientations so an antenna element with a wide and uniform pattern may yield better overall performance than an antenna element with high gain and a correspondingly narrower beam. Conversely, an antenna mounted in a fixed and predictable manner may benefit from pattern and gain characteristics suited to that application. Evaluating multiple antenna solutions in real-world situations is a good way to rapidly assess which will best meet the needs of your application. The GM Series GPS Receiver module offers several ways to control the module’s power. A serial command puts the module into a low-power standby mode that consumes only 365µA of current. An external processor can be used to power the module on and off to conserve battery power. For GNSS, the antenna should have good right hand circular polarization characteristics (RHCP) to match the polarization of the GNSS signals. Ceramic patches are the most commonly used style of antenna, but there are many different shapes, sizes and styles of antennas available. Regardless of the construction, they will generally be either passive or active types. Passive antennas are simply an antenna tuned to the correct frequency. Active antennas add a Low Noise Amplifier (LNA) after the antenna and before the module to amplify the weak GPS satellite signals. For active antennas, a 300 ohm ferrite bead can be used to connect the VOUT line to the RFIN line. This bead prevents the RF from getting into the power supply, but allows the DC voltage onto the RF trace to feed into the antenna. A series capacitor inside the module prevents this DC voltage from affecting the bias on the module’s internal LNA. Maintaining a 50 ohm path between the module and antenna is critical. Errors in layout can significantly impact the module’s performance. Please review the layout guidelines section carefully to become more familiar with these considerations. In addition, the module includes a duty cycle mode where the module will power on for a configurable amount of time to obtain a position fix then power off for a configurable amount of time. In this way the module can handle all of the timing without any intervention from the external processor. There are four times that are configured with duty cycle mode. The on time and standby times are the amount of times that the module is on and in standby in normal operation. There are also cold start on and standby times. These are used to keep the module on longer in the event of a cold start so that it can gather the required satellite data for a position fix. After this, the module uses the normal operation times. In the event that the module’s stored ephemeris data becomes invalid the module supports and extended receive time to gather the required data from the satellites. Figure 7 shows the power control times. Cold Start On Time Cold Start Standby Time On Time Standby Time On Time Extended RX Time ON Standby Figure 7: GM Series GNSS Receiver Power Control The module supports MediaTek’s proprietary AlwaysLocateTM mode. In this mode, the module automatically adapts the on and standby times to the current environmental conditions to balance position accuracy and power consumption. In this mode, any byte sent to the module triggers it to output the current position data. Standby mode is configured by command 161. Extended receive time is configured by command 223. Command 225 configures which duty cycle mode is used. Only enter standby mode after the module acquires a position fix. – 8 – – 9 – Slow Start Time Interfacing with NMEA Messages The most critical factors in start time are current ephemeris data, signal strength and sky view. The ephemeris data describes the path of each satellite as they orbit the earth. This is used to calculate the position of a satellite at a particular time. This data is only usable for a short period of time, so if it has been more than a few hours since the last fix or if the location has significantly changed (a few hundred miles), then the receiver may need to wait for a new ephemeris transmission before a position can be calculated. The GNSS satellites transmit the ephemeris data every 30 seconds. Transmissions with a low signal strength may not be received correctly or be corrupted by ambient noise. The view of the sky is important because the more satellites the receiver can see, the faster the fix and the more accurate the position will be when the fix is obtained. Linx modules default to the NMEA protocol. Output messages are sent from the receiver on the TX line and input messages are sent to the receiver on the RX line. By default, output messages are sent once every second. Details of each message are described in the following sections. If the receiver is in a very poor location, such as inside a building, urban canyon, or dense foliage, then the time to first fix can be slowed. In very poor locations with poor signal strength and a limited view of the sky with outdated ephemeris data, this could be on the order of several minutes. In the worst cases, the receiver may need to receive almanac data, which describes the health and course data for every satellite in the constellation. This data is transmitted every 15 minutes. If a lock is taking a long time, try to find a location with a better view of the sky and fewer obstructions. Once locked, it is easier for the receiver to maintain the position fix. The NMEA message format is as follows: . The serial data structure defaults to 9,600bps, 8 data bits, 1 start bit, 1 stop bit, and no parity. Each message starts with a $ character and ends with a . All fields within each message are separated by a comma. The checksum follows the * character and is the last two characters, not including the . It consists of two hex digits representing the exclusive OR (XOR) of all characters between, but not including, the $ and * characters. When reading NMEA output messages, if a field has no value assigned to it, the comma will still be placed following the previous comma. For example, {,04,,,,,2.0,} shows four empty fields between values 04 and 2.0. When writing NMEA input messages, all fields are required, none are optional. An empty field will invalidate the message and it will be ignored. Reading NMEA output messages: • Initialize a serial interface to match the serial data structure of the GPS receiver. • Read the NMEA data from the TX pin into a receive buffer. • Separate it into six buffers, one for each message type. Use the characters ($) and as end points for each message. • For each message, calculate the checksum as mentioned above to compare with the received checksum. • Parse the data from each message using commas as field separators. • Update the application with the parsed field values. • Clear the receive buffer and be ready for the next set of messages. Writing NMEA input messages: • Initialize a serial interface to match the serial data structure of the GPS receiver. • Assemble the message to be sent with the calculated checksum. • Transmit the message to the receiver on the RX line. – 10 – – 11 – NMEA Output Messages The following sections outline the data structures of the various NMEA messages that are supported by the module. By default, the NMEA commands are output at 9,600bps, 8 data bits, 1 start bit, 1 stop bit, and no parity. Six messages are output at a 1Hz rate by default. The ZDA message is supported, but disabled by default. These messages are shown in Figure 8. NMEA Output Messages Name Description GGA Contains the essential fix data which provide location and accuracy GLL Contains just position and time GSA Contains data on the Dilution of Precision (DOP) and which satellites are used GSV Contains the satellite location relative to the receiver and its signal to noise ratio. Each message can describe 4 satellites so multiple messages may be output depending on the number of satellites being tracked. RMC Contains the minimum data of time, position, speed and course VTG Contains the course and speed over the ground ZDA Contains the date and time GGA – Global Positioning System Fix Data Figure 10 contains the values for the following example: $GPGGA,053740.000,2503.6319,N,12136.0099,E,1,08,1.1,63.8,M,15.2,M,,0000*64 Global Positioning System Fix Data Example Name Example Message ID $GPGGA UTC Time 053740.000 hhmmss.sss Latitude 2503.6319 ddmm.mmmm N/S Indicator N Longitude 12136.0099 E/W Indicator E E=east or W=west Position Fix Indicator 1 See Figure 11 Satellites Used 08 Range 0 to 33 HDOP 1.1 Horizontal Dilution of Precision MSL Altitude 63.8 meters Units M meters Geoid Separation 15.2 meters Units M meters Age of Diff. Corr. Figure 8: NMEA Output Messages Some of the message IDs can change based on which system is used for the position fix. Figure 9 shows the different message identifiers based on the system that is used. Units GGA protocol header N=north or S=south dddmm.mmmm second Diff. Ref. Station 0000 Checksum *64 Description Null fields when DGPS is not used End of message termination Figure 10: Global Positioning System Fix Data Example NMEA Output Message Identifiers System GGA GLL GSA GSV GPS GPGGA GPGLL GPGSA GNGSA GPS & GLONASS 1. GPGGA GNGLL RMC VTG GPGSV GPRMC GPVTG GPGSV GLGSV GPRMC or GNRMC1 GPVTG The RMC output is GPRMC before a 3D fix, then changes to GNRMC after a fix is locked. Position Indicator Values Value Fix not available or invalid 1 GPS SPS Mode, fix valid 2 Differential GPS, SPS Mode, fix valid 3–5 6 Figure 9: NMEA Output Message Identifiers Details of each message and examples are given in the following sections. – 12 – Description 0 Not supported Dead Reckoning Mode, fix valid (requires external hardware) Figure 11: Position Indicator Values – 13 – GLL – Geographic Position – Latitude / Longitude Figure 12 contains the values for the following example: $GPGLL,2503.6319,N,12136.0099,E,053740.000,A,A*52 Geographic Position – Latitude / Longitude Example Name Message ID Example Units Description GLL protocol header (GNGLL or GPGLL) $GPGLL Figure 14: Mode 1 Values $GPGSV,3,2,12,17,41,328,45,07,32,315,45,04,31,250,40,11,25,046,41*75 12136.0099 E/W Indicator E UTC Time 053740.000 Status A A=data valid or V=data not valid Mode A A=autonomous, D=DGPS, N=Data not valid, R=Coarse Position, S=Simulator Checksum *52 hhmmss.sss End of message termination Figure 12: Geographic Position – Latitude / Longitude Example GSA – GNSS DOP and Active Satellites Figure 13 contains the values for the following example: $GPGSA,A,3,24,07,17,11,28,08,20,04,,,,,2.0,1.1,1.7*35 GNSS DOP and Active Satellites Example Mode 1 Automatic – allowed to automatically switch 2D/3D E=east or W=west Longitude Message ID A $GPGSV,3,1,12,28,81,285,42,24,67,302,46,31,54,354,,20,51,077,46*73 ddmm.mmmm Units Manual – forced to operate in 2D or 3D mode dddmm.mmmm N Example Description M GSV – GNSS Satellites in View Figure 15 contains the values for the following example: 2503.6319 Name Value N=north or S=south Latitude N/S Indicator Mode 1 Values Description $GPGSV,3,3,12,08,22,214,38,27,08,190,16,19,05,092,33,23,04,127,*7B $GLGSV,2,1,07,76,71,201,44,65,57,041,40,75,48,028,39,72,27,108,39*68 $GLGSV,2,2,07,66,25,333,43,77,17,207,37,81,02,280,29*5C GNSS Satellites in View Example Name Message ID Example Units Description $GPGSV GSV protocol header (GPGSV for GPS and GLGSV for GLONASS) Total number of messages1 3 Range 1 to 6 (GPS) and 1 to 3 (GLONASS) Message number1 1 Range 1 to 6 (GPS) and 1 to 3 (GLONASS) Satellites in view 12 Satellite ID 28 Elevation 81 degrees Channel 1 (Range 00 to 90) Channel 1 (Range 01 to 196) Azimuth 285 degrees Channel 1 (Range 000 to 359) GSA protocol header (GPGSA for GPS or GNGSA for GLONASS) SNR (C/No) 42 dB–Hz Channel 1 (Range 00 to 99, null when not tracking) A See Figure 14 Satellite ID 20 $GPGSA Channel 2 (Range 01 to 196) Mode 2 3 1=No fix, 2=2D, 3=3D Elevation 51 degrees Channel 2 (Range 00 to 90) ID of satellite used 24 Sv on Channel 1 Azimuth 077 degrees Channel 2 (Range 000 to 359) ID of satellite used 07 Sv on Channel 2 SNR (C/No) 46 dB-Hz Checksum *73 ... ... ID of satellite used Sv on Channel N PDOP 2.0 Position Dilution of Precision HDOP 1.1 Horizontal Dilution of Precision VDOP 1.7 Vertical Dilution of Precision Checksum *35 Channel 2 (Range 00 to 99, null when not tracking. End of message termination 1. Depending on the number of satellites tracked, multiple messages of GSV data may be required. Figure 15: GNSS Satellites in View Example End of message termination Figure 13: GNSS DOP and Active Satellites Example – 14 – – 15 – RMC – Recommended Minimum Specific GNSS Data Figure 16 contains the values for the following example: VTG – Course Over Ground and Ground Speed Figure 17 contains the values for the following example: $GPRMC,053740.000,A,2503.6319,N,12136.0099,E,2.69,79.65,100106,,,A*53 $GPVTG,79.65,T,,M,2.69,N,5.0,K,A*38 Recommended Minimum Specific GNSS Data Example Name Message ID Example Units RMC protocol header (GNRMC or GPRMC) $GPRMC UTC Time 053740.000 Status A Latitude 2503.6319 N/S Indicator N Longitude 12136.0099 E/W Indicator E Speed over ground 2.69 knots Course over ground 79.65 degrees Date 100106 Magnetic Variation hhmmss.sss A=data valid or V=data not valid ddmm.mmmm A Checksum *53 Message ID $GPVTG Course over ground 79.65 Reference T Course over ground Units VTG protocol header degrees Measured heading TRUE degrees Measured heading (N/A, null field) M Units N Speed over ground 5.0 Units K Kilometer per hour Mode A A=autonomous, D=DGPS, N= Data not valid, R=Coarse Position, S=Simulator E=east or W=west (not shown) Checksum *38 A=autonomous, D=DGPS, E=DR, N= Data not valid, R=Coarse Position, S=Simulator TRUE ddmmyy Magnetic knots Measured speed Knots km/hr Not available, null field Measured speed End of message termination Figure 17: Course Over Ground and Ground Speed Example End of message termination Figure 16: Recommended Minimum Specific GNSS Data Example – 16 – Description 2.69 E=east or W=west Example Reference dddmm.mmmm degrees Name Speed over ground N=north or S=south Variation Sense Mode Description Course Over Ground and Ground Speed Example – 17 – ZDA – Universal Time and Date Figure 18 contains the values for the following example: PMTKLSC - Leap Second Change Figure 10 contains the values for the following example: $GPZDA,183746.000,22,08,2014,,*56 $PMTKLSC,17,0,17*42 Universal Time and Date Example Leap Second Change Example Name Example Units Description Message ID $GPZDA UTC Time 183746.000 Day 22 01 to 31 Month 08 01 to 12 Year 2014 ZDA protocol header hhmmss.sss Name Example Message ID $PMTKLSC Current 17 Current leap second Indicator 0 Leap indicator, 1 = updated from broadcast data Next leap second Next 17 Local Zone Hour Offset from UTC; set to null Checksum *42 Local Zone Minutes Offset from UTC; set to null Checksum 1980 to 2079 Units Description Leap Second Change protocol header End of message termination *56 End of message termination Figure 20: Leap Second Change Example Figure 18: Universal Time and Date Example Once the leap second has been updated from the satellite transmissions, the indicator field changes to 1. At this point, the indicator is accurate. Start-up Response The module outputs a message when it starts up to indicate its state. The normal start-up message is shown below and the message formatting is shown in Figure 19. $PMTKLSC,17,1,17*43 $PMTK010,001*2E Start-up Response Example Name Example Message ID $PMTK010 Message MSG Checksum CKSUM End Sequence Description Message header System Message 0 = Unknown 1 = Start-up 2 = Notification for the host supporting EPO 3 = Transition to Normal operation is successful End of message termination Figure 19: Start-up Response Example – 18 – – 19 – Input Messages The following outlines the serial commands input into the module for configuration. There are 3 types of input messages: commands, writes and reads. The module outputs a response for each input message. The commands are used to change the operating state of the module. The writes are used to change the module’s configuration and the reads are used to read out the current configuration. Messages are formatted as shown in Figure 21. All fields in each message are separated by a comma. Serial Data Structure Name Description 101 Hot Re-start 102 Warm Re-start 103 Cold Re-start 104 Restore Default Configuration 161 Standby Mode 220 Position Fix Interval 223 Extended Receive Time 225 Receiver Duty Cycle 251 Serial Port Baud Rate 255 Sync 1PPS and NMEA Messages 256 Set Timing Product Name Example Start Sequence $PMTK Message ID Message Identifier consisting of three numeric characters. Payload DATA Message specific data. 257 Set Tunnel Scenario 1PPS Configuration CKSUM CKSUM is a two-hex character checksum as defined in the NMEA specification, NMEA-0183 Standard for Interfacing Marine Electronic Devices. Checksums are required on all input messages. 285 286 Enable Active Interference Cancellation 875 Enable Leap Second Change Message Each message must be terminated using Carriage Return (CR) Line Feed (LF) (\r\n, 0x0D0A) to cause the receiver to process the input message. They are not printable ASCII characters, so are omitted from the examples. Checksum End Sequence Description Input Commands Figure 21: Serial Data Structure Figure 22 shows the input commands. Figure 22: Input Commands The write and read messages are shown in Figure 23. A write message triggers an acknowledgement from the module. A read message triggers a response message containing the requested information. Input Write and Read Messages Description Write ID Read ID Response ID DGPS Source 301 401 501 SBAS Enable 313 413 513 NMEA Output Messages 314 414 514 Set Datum 330 430 530 GNSS Search System 353 — — Static Navigation Threshold 386 447 527 Enable Ephemeris Prediction 869 869 869 Figure 23: Input Write and Read Messages – 20 – – 21 – The module responds to commands with response messages. The acknowledge message is formatted as shown in Figure 24. Acknowledge Message Name Example Start Sequence $PMTK Message ID 001 Acknowledge Identifier Command CMD The command that triggered the acknowledge Flag Flg Flag indicating the outcome of the command 0 = Invalid Command 1 = Unsupported Command 2 = Valid command, but action failed 3 = Valid command and action succeeded CKSUM CKSUM is a two-hex character checksum as defined in the NMEA specification, NMEA-0183 Standard for Interfacing Marine Electronic Devices. Checksums are required on all input messages. Each message must be terminated using Carriage Return (CR) Line Feed (LF) (\r\n, 0x0D0A) to cause the receiver to process the input message. They are not printable ASCII characters, so are omitted from the examples. Checksum End Sequence Description 104 – Restore Default Configuration This command instructs the module to conduct a cold re-start and return all configurations to the factory default settings. $PMTK104*37 161 – Standby Mode This command instructs the module to enter a low power standby mode. Any activity on the RX line wakes the module. Only enter standby mode after the module acquires a position fix. $PMTK161,0*28 The module outputs the startup message when it wakes up. $PMTK010,001*2E 220 – Position Fix Interval This command sets the position fix interval. This is the time between when the module calculates its position. Position Fix Interval Command and Response Command Figure 24: Acknowledge Message 101 – Hot Re-start This command instructs the module to conduct a hot re-start using all of the data stored in memory. Periodic mode and static navigation settings are returned to default when this command is executed. Start Msg ID Interval Checksum End $PMTK 220 ,Ival *Cksum Start Msg ID CMD Flag Checksum End $PMTK 001 ,220 ,Flg *Cksum Response Figure 25: Position Fix Interval Command and Response $PMTK101*32 102 – Warm Re-start This command instructs the module to conduct a warm re-start that does not use the saved ephemeris data. Periodic mode and static navigation settings are returned to default when this command is executed. $PMTK102*31 103 – Cold Re-start This command instructs the module to conduct a cold re-start that does not use any of the data from memory. Periodic mode and static navigation settings are returned to default when this command is executed. $PMTK103*30 – 22 – Ival = the interval time in milliseconds. The interval must be larger than 100ms. Faster rates require that the baud rate be increased, the number of messages that are output be decreased or both. The module automatically calculates the required data bandwidth and returns an action failed response (Flg = 2) if the interval is faster than the module can output all of the required messages at the current baud rate. The following example sets the interval to 1 second. $PMTK220,1000*1F It is recommended to use interval rates of 100ms, 200ms, 500ms, 1,000ms and 2,000ms. Although permissible, non-standard intervals are not guaranteed or recommended. – 23 – 223 – Extended Receive Time This command extends the amount of time that the receiver is on when in duty cycle mode. This allows the module to refresh its stored ephemeris data by staying awake until it received the data from the satellites. Extended Receive Time Command and Response 225 – Receiver Duty Cycle This command places the module into a duty cycle where it stays on for a period of time and calculates it position then goes to sleep for a period of time. This conserves battery power without the need for an external microcontroller to manage the timing. Receiver Duty Cycle Command and Response Command Start Msg ID SV On Time Extend Time Extend Gap Checksum End $PMTK 223 ,SV ,SNR ,EXT ,EXG *Cksum Response Start Msg ID CMD Flag Checksum End $PMTK 001 ,223 ,Flg *Cksum Command Start Msg ID Mode On Time Standby Time Cold On Cold Sleep Checksum End $PMTK 225 ,Mde ,TO ,TS ,CO ,CS *Cksum Start Msg ID CMD Flag Checksum End $PMTK 001 ,225 ,Flg *Cksum Response Figure 26: Extended Receive Time Command and Response Figure 28: Receiver Duty Cycle Command and Response Extended Receive Time Fields Field Description Receiver Duty Cycle Fields The minimum number of satellites required to have valid ephemeris data. The extend time triggers when the number of satellites with valid ephemeris data falls below this number. The value is 1 to 4. Field Description SV The minimum SNR of the satellites used for a position fix. The module will not wait for ephemeris data from any satellites whose SNR is below this value. Mde SNR Operation Mode 0 = Normal Mode 2 = Duty Cycle Mode 8 = AlwaysLocateTM EXT The extended time in ms to stay on to receive ephemeris data. This value can range from 40000 to 180000. TO Receiver on time (ms) TS Receiver standby time (ms) EXG The minimum time in ms between a subsequent extended receive period. This value can range from 0 to 3600000. CO Receiver on time in the event of a cold start (ms). Allows more time for the module to receive ephemeris data in the event of a cold start. CS Receiver off time in the event of a cold start (ms). Allows more time for the module to receive ephemeris data in the event of a cold start. Figure 27: Extended Receive Time Fields CO and CS can be null values. In this case the module uses the TO and TS values. The following example configures an extended on time to trigger if less than 1 satellite has valid ephemeris data. The satellite must have a signal to noise ratio higher than 30dB–Hz in order to be used. The module will stay on for 180,000ms and will have a gap time of 60,000ms. Figure 29: Receiver Duty Cycle Fields $PMTK223,1,30,180000,60000*16 $PMTK225,2,3000,12000,18000,72000*15 This example sets the mode to duty cycle with an on time of 3s, and off time of 12s, a cold start on time of 18s and a cold start off time of 72s. The following example sets the mode to normal operation. $PMTK225,0*2B The following example sets the module into AlwaysLocateTM mode. $PMTK225,8*23 – 24 – – 25 – 251 – Serial Port Baud Rate This command sets the serial port baud rate. 255 – Sync 1PPS and NMEA Messages This command enables or disables synchronization between the 1PPS pulse and the NMEA messages. When enabled, the beginning of the NMEA message on the UART is fixed to between 465 and 485ms after the rising edge of the 1PPS pulse. The NMEA message describes the position and time as of the rising edge of the 1PPS pulse. Serial Port Baud Rate Command and Response Command Start Msg ID Rate Checksum End $PMTK 251 ,Rate *Cksum Start Msg ID CMD Flag Checksum End $PMTK 001 ,251 ,Flg *Cksum Sync 1PPS and NMEA Messages Command and Response Response Command Msg ID Enable Checksum End 255 ,Enable *Cksum Start Msg ID CMD Flag Checksum End $PMTK 001 ,255 ,Flg *Cksum Response Figure 30: Serial Port Baud Rate Command and Response Rate = serial port baud rate 0 = default setting 4800 9600 14400 19200 38400 57600 115200 Start $PMTK Figure 31: Sync 1PPS and NMEA Messages Command and Response UTC 12:00:00 UTC 12:00:01 1PPS TX The following example sets the serial port baud rate to 57,600bps. UTC 12:00:00 UTC 12:00:01 465ms ~ 485ms Figure 32: 1PPS and NMEA Message Synchronization $PMTK251,57600*2C This is only supported at a 1Hz NMEA message rate. It is disabled by default. If all six NMEA messages are output, the serial port baud rate should be between 19,200 and 115,200bps to ensure stable synchronization. The following examples show the use of this command. Enable Sync: $PMTK255,1*2D Disable Sync: $PMTK255,0*2C – 26 – – 27 – 256 – Set Timing Product This command enables or disables the timing product. The timing product improves the accuracy of the 1PPS pulse relative to other modules. 257 – Set Tunnel Scenario This command enables a fast time to first fix or high position accuracy when emerging from a tunnel. Set Timing Product Command and Response Set Tunnel Scenario Command and Response Command Command Start Msg ID Enable Checksum End $PMTK 256 ,Enable *Cksum Response Start Msg ID Type Checksum End $PMTK 257 ,Type *Cksum Response Start Msg ID CMD Flag Checksum End Start Msg ID CMD Flag Checksum End $PMTK 001 ,256 ,Flg *Cksum $PMTK 001 ,257 ,Flg *Cksum Figure 33: Set Timing Product Command and Response Figure 34: Set Tunnel Scenario Command and Response This command needs to be sent again after hot, warm or cold starts or after waking from standby mode. Type = Type of position fix 0 = Fast TTFF 1 = High Accuracy (default) The following examples show the use of this command. The following examples show the use of this command. Enable Timing Product: $PMTK256,1*2E Disable Timing Product: $PMTK256,0*2F Enable fast TTFF: $PMTK257,0*2E Enable high accuracy: $PMTK257,1*2F The set timing protocol configuration returns to the default values after a reset or restart. – 28 – – 29 – 285 – 1PPS Configuration This command configures the 1PPS output. 286 – Enable Active Interference Cancellation This command enables or disables active interference cancellation. This feature helps remove jamming and narrow-band interference to enable a position fix. 1PPS Configuration Command and Response Command Start Msg ID Type Pulse Width Checksum End $PMTK 285 ,Type ,Width *Cksum Response Start $PMTK Msg ID 001 CMD Flag ,285 Checksum ,Flg *Cksum End Figure 35: 1PPS Configuration Messages Command and Response Figure 36 shows the Type values. Disable 1 After the first fix 2 3D fix only (default) 3 2D/3D fix only 4 Always Start Msg ID Enable Checksum End $PMTK 286 ,Enable *Cksum Start Msg ID CMD Flag Checksum End $PMTK 001 ,286 ,Flg *Cksum Response By default, this is enabled after the first fix is acquired. Description 0 Command Figure 37: Enable Active Interference Cancellation Messages Command and Response 1PPS Configuration Type Values Value Enable Active Interference Cancellation Command and Response The following examples show the use of this command. Enable: $PMTK286,1*23 Disable: $PMTK286,0*22 Figure 36: 1PPS Configuration Type Values The Width field is the width of the 1PPS pulse in milliseconds. The max width is 900ms at a 1Hz NMEA message rate. The default is 100ms. These configurations are maintained during hot and warm starts, but are lost on cold starts and restore to factory defaults. Set the 1PPS to activate after a 3D fix and have a 10ms pulse width. $PMTK285,2,10*0E Set the 1PPS to activate after a 3D fix and have a 900ms pulse width. $PMTK285,2,900*36 – 30 – – 31 – 875 – Enable PMTKLSC Message This command enables or disables the Leap Second Change message. DGPS Source This enables or disables DGPS mode and configures its source. Enable PMTKLSC Message Command and Response DGPS Souce Command and Response Command Write Message Start $PMTK Msg ID 875 CmdType ,CmdType Enable Checksum ,Enable *Cksum End Start Msg ID Mode Checksum End $PMTK 301 ,Mode *Cksum Acknowledge Response Message Set Response Start Msg ID CMD Flag Checksum End $PMTK 001 ,875 ,Flg *Cksum $PMTK Msg ID 875 Msg ID CMD Flag Checksum End $PMTK 001 ,301 ,Flg *Cksum Read Message Query Response Start Start CmdType ,2 Enable Checksum ,Enable *Cksum End Start Msg ID Checksum End $PMTK 401 *37 Response Message Figure 38: Sync 1PPS and NMEA Messages Command and Response CmdType Values Value Query 1 Set 2 Result of the Query Operation Figure 39: CmdType Values Description Message Disabled 1 Message Enabled Mode Checksum End $PMTK 501 ,Mode *Cksum Mode = DGPS source mode 0 = No DGPS source 1 = RTCM 2 = WAAS Differential Global Positioning System (DGPS) enhances GPS by using fixed, ground-based reference stations that broadcast the difference between the positions indicated by the satellite systems and the known fixed positions. The Radio Technical Commission for Maritime Services (RTCM) is an international standards organization that has a standard for DGPS. Wide Area Augmentation System (WAAS) is maintained by the FAA to improve aircraft navigation. This setting automatically switches among WAAS, EGNOS, MSAS and GAGAN when detected in covered regions Enable Values 0 Msg ID Figure 41: DGPS Source Command and Response Description 0 Value Start Figure 40: CmdType Values The following example sets the DGPS source to RTCM. The following examples show the use of this command. $PMTK301,1*2D Enable PMTKLSC: $PMTK875,1,1*38 Disable PMTKLSC: $PMTK875,1,0*39 Query PMTKLSC: $PMTK875,0*24 Query Response: $PMTK875,2,0*3A (Message disabled) The following example reads the current DGPS source and the module responds with the DGPS source as RTCM. $PMTK401*37 $PMTK501,1*2B – 32 – – 33 – SBAS Enable This enables and disables SBAS. NMEA Output Messages This configures how often each NMEA output message is output. SBAS Enable Command and Response NMEA Output Messages Command and Response Write Message Write Message Start Msg ID Mode Checksum End $PMTK 313 ,Mode *Cksum Start Msg GLL RMC VTG GGA GSA GSV ID DATA ZDA 0 CK End $PMTK 314 ,GLL ,RMC ,VTG ,GGA ,GSA ,GSV ,0,0,0,0,0,0,0,0,0,0,0 ,ZDA ,0 *CK Acknowledge Response Message Start Msg ID CMD Flag Checksum End $PMTK 001 ,313 ,Flg *Cksum Read Message Acknowledge Response Message Start Msg CMD Flag ID CK End $PMTK 001 ,314 ,Flg *CK Start Msg ID Checksum End $PMTK 413 *34 Read Message Start Response Message Start Msg ID Mode Checksum End $PMTK 513 ,Mode *Cksum End $PMTK 414 *33 Response Message Start Figure 42: SBAS Enable Command and Response Msg CK ID Msg GLL RMC VTG GGA GSA GSV ID DATA ZDA 0 CK End $PMTK 514 ,GLL ,RMC ,VTG ,GGA ,GSA ,GSV ,0,0,0,0,0,0,0,0,0,0,0 ,ZDA ,0 *CK Mode = SBAS Mode 0 = disabled 1 = enabled Figure 43: NMEA Output Messages Command and Response A satellite-based augmentation system (SBAS) sends additional information in the satellite transmissions to improve accuracy and reliability. Ground stations at accurately surveyed locations measure the satellite signals or other environmental factors that may impact the signal received by users. Correction information is then sent to the satellites and broadcast to the users. Disabling this feature also disables automatic DGPS. Each field has a value of 1 through 5 which indicates how many position fixes should be between each time the message is output. A 1 configures the message to be output every position fix. A value of 2 configures the message to be output every other position fix and a value of 5 configures it to be output every 5th position fix. This along with message 220 sets the time between message outputs. A value of 0 disables the message. The following example enables SBAS. The example below sets all of the messages to be output every fix. $PMTK313,1*2E $PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,1,0*29 The following example reads the current SBAS configuration and the module responds with SBAS is enabled. The following example reads the current message configuration and the module responds that all supported messages are configured to be output on every position fix. $PMTK413*34 $PMTK513,1*28 $PMTK414*33 $PMTK514,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,1,0*2F – 34 – – 35 – Set Datum This configures the current datum that is used. GNSS Search System This configures the GNSS systems used to calculate position fixes. Set Datum Command and Response GNSS Search System Command and Response Write Message Write Message Start $PMTK Msg ID Datum 330 Checksum ,Datum *Cksum Start Msg ID GPS GLNS GAL GALF End $PMTK 353 BEI Checksum ,GPS ,GLNS ,GAL ,GALF ,BEI End *Cksum Acknowledge Response Message Acknowledge Response Message Start Msg ID CMD Flag Checksum End $PMTK 001 ,330 ,Flg *Cksum Start Msg ID CMD $PMTK 001 ,353 Flag GPS GLNS GAL GALF BEI Checksum End ,Flg ,GPS ,GLNS ,GAL ,GALF ,BEI *Cksum Read Message Start Msg ID Checksum End $PMTK 430 *35 Figure 45: GNSS Search System Command and Response Response Message Start Msg ID Datum Checksum End $PMTK 530 ,Datum *Cksum Figure 44: Set Datum Command and Response Datum = the datum number to be used. Reference datums are data sets that describe the shape of the Earth based on a reference point. There are many regional datums based on a convenient local reference point. Different datums use different reference points, so a map used with the receiver output must be based on the same datum. WGS84 is the default world referencing datum. GPS = Search GPS satellites 0 = disabled, do not search GPS satellites 1 = enabled GLNS = Search GLONASS satellites 0 = disabled, do not search GLONASS satellites 1 = enabled GAL = Search GALILEO satellites (not supported, set to 0) GALF = Search GALILEO full mode satellites (not supported, set to 0) BEI = Search Beidou satellites (not supported, set to 0) The following example configures the module to only use GLONASS satellites. The module supports 223 different datums. These are listed in Appendix A. $PMTK353,0,1,0,0,0*2A The following example sets the datum to WGS84. The following example configures the module to only use GPS satellites. $PMTK330,0*2E $PMTK353,1,0,0,0,0*2A The following example reads the current datum and the module replies with datum 0, which is WGS84. The following example configures the module to use GPS and GLONASS satellites. $PMTK430*35 $PMTK530,0*28 $PMTK353,1,1,0,0,0*2B Note: The Galileo and Beidou fields are added to modules with date code 1605 and later. – 36 – – 37 – Static Navigation Threshold This configures the speed threshold to trigger static navigation. If the measured speed is below the threshold then the module holds the current position and sets the speed to zero. Write Message Start Msg ID Thold Checksum End 386 ,Thold *Cksum Start Msg ID CMD Flag Checksum End $PMTK 001 ,386 ,Flg *Cksum Read Message Start Msg ID Checksum End 447 *35 Start Msg ID CMD Enable Checksum End $PMTK 869 ,1 ,Enable *Cksum Acknowledge Response Message Acknowledge Response Message $PMTK Enable Ephemeris Prediction Command and Response Write Message Static Navigation Threshold Command and Response $PMTK Enable Ephemeris Prediction This enables or disables the module’s built-in ephemeris prediction. Start Msg ID CMD Flag Checksum End $PMTK 001 ,869 ,Flg *Cksum Read Message Start Msg ID CMD Enable Checksum End $PMTK 869 ,0 ,Enable *Cksum Response Message Response Message Start Msg ID Thold Checksum End $PMTK 527 ,Thold *Cksum Figure 46: Static Navigation Threshold Command and Response Thold = speed threshold, from 0 to 2.0m/s. 0 = disabled. The following example sets the threshold to 1.2m/s. $PMTK386,1.2*3E The following example reads the static navigation threshold and the module responds with 1.2m/s Start Msg ID CMD Enable Checksum End $PMTK 869 ,2 ,Enable *Cksum Figure 47: Enable Ephemeris Prediction Command and Response This message is formatted slightly differently from the other messages. The same Message ID is used for the read, write and response and the first payload field (CMD) indicates which type of message it is. A 0 is a read, a 1 is a write and a 2 is a response to a read. Enable = enable ephemeris prediction 0 = disabled 1 = enabled The following example enables prediction. $PMTK447*35 $PMTK527,1.20*03 $PMTK869,1,1*35 The static navigation threshold configuration returns to the default values after a reset or restart. The following example reads the configuration. $PMTK869,0*29 The module responds with the first example if prediction is disabled and the second if it is enabled. $PMTK869,2,0*37 $PMTK869,2,1*36 – 38 – – 39 – Typical Applications Microstrip Details Figure 48 shows the GM Series GNSS receiver in a typical application using a passive antenna. A transmission line is a medium whereby RF energy is transferred from one place to another with minimal loss. This is a critical factor, especially in high-frequency products like Linx RF modules, because the trace leading to the module’s antenna can effectively contribute to the length of the antenna, changing its resonant bandwidth. In order to minimize loss and detuning, some form of transmission line between the antenna and the module should be used unless the antenna can be placed very close (
RXM-GNSS-GM-T 价格&库存
很抱歉,暂时无法提供与“RXM-GNSS-GM-T”相匹配的价格&库存,您可以联系我们找货
