RXM-GPS-SR-B
RXM-GPS-SR-B
    LINXTECHNOLOGIES(灵思)
    模块
    SR RF Receiver GPS 1575.42MHz -159dBm On-Board, Patch, MMCX Module
RXM-GPS-SR-B 数据手册
RXM-GPS-SR WIRELESS MADE SIMPLE ® SR SERIES GPS RECEIVER MODULE DATA GUIDE DESCRIPTION The SR Series GPS receiver module is a selfcontained high-performance GPS receiver with an on-board antenna, LNA and SAW filter. Based on the SiRFstar III chipset, it provides exceptional GPS MODULE RXM-GPS-SR sensitivity, even in dense foliage and urban canyons. LOT GAxxxx The module’s very low power consumption helps maximize runtimes in battery powered applications. With over 200,000 effective correlators, the SR Series receiver can acquire and track up to 20 satellites simultaneously in just seconds, even at the lowest signal levels. Housed in a compact reflowcompatible SMD package, the receiver requires no Figure 1: Package Dimensions programming or additional RF components to form a complete GPS solution. These features, along with the module’s standard NMEA data output, make the SR Series easy to integrate, even by engineers without previous RF or GPS experience. 0.165±0.006 (4.20±0.15) 0.992 (25.20) 0.488 (12.40) 0.469 0.402 (11.90) (10.20) 0.087±0.006 (2.20±0.15) 0.402 (10.20) 0.071 (1.80) 0.047 (1.20) 0.909 (23.10) FEATURES n n n n n n n n SiRF Star III chipset 200,000+ correlators Low power consumption (46mW) High sensitivity (-159dBm) 20 channels Fast TTFF at low signal levels Battery-backed SRAM No programming necessary n n n n n n n n No external RF components needed Integral antenna No production tuning Direct serial interface Power down feature Compact surface-mount package Manual or reflow compatible RoHS compliant APPLICATIONS INCLUDE n n n n n n Positioning and Navigation Location and Tracking Security/Loss-Prevention Surveying Logistics Fleet Management ORDERING INFORMATION PART # DESCRIPTION RXM-GPS-SR-x GPS Receiver Module MDEV-GPS-SR Master Development System x = “T” for Tape and Reel, “B” for Bulk Reels are 250 pcs. Quantities less than 250 pcs. are supplied in bulk Revised 11/22/10 3.0 – 4.3 VDC – ICC 31 200mS and a multiple of 100 (if not, it is rounded up to the nearest multiple of 100). mS Must be an integer value > 1000 and
RXM-GPS-SR-B 价格&库存
很抱歉,暂时无法提供与“RXM-GPS-SR-B”相匹配的价格&库存,您可以联系我们找货
