MTCDT-H5-210L-US-EU-GB
    MULTI-TECHSYSTEMS
    HSPA+MLINUXPROGGATEWAYW/ACCY
MTCDT-H5-210L-US-EU-GB 数据手册
MultiConnect® Conduit™ Programmable Gateway for the Internet of Things BENEFITS MultiConnect® Conduit™ is the industry’s most configurable, manageable, and scalable cellular communications gateway for industrial IoT applications. Network engineers can remotely configure and optimize their Conduit performance and Australian 915 MHz ISM bands through DeviceHQ®, the world’s first IoT Application Store and Device Management platform. The Conduit features two accessory card slots that enable users to plug in MultiConnect® mCard™ accessory cards supporting their preferred wired or ·· GNSS module for location coordinate information of MultiConnect® mDot™ long range RF modules connected to remote sensors or appliances. Both IBM’s Node-RED, a graphical, drag-and-drop interface and mLinux™ Open Embedded/Yocto opens the complex world of IoT application development or Ethernet for cost effective global deployment differentiated services using the DeviceHQ easy to customize and manage, the Conduit communications gateway realizes IoT Application Store your IoT application. 3 Steps to Deploying your IoT Application Select Wide Area Network 4G LTE, 3G, 2G, Ethernet LoRa™ ·· Backhaul options include 4G-LTE, 3G, 2G cellular ·· Quick-to-deploy, manage and scale to a wider user group to monitor and control their assets. Quick-to-deploy and Ethernet ·· ISM band scanning for optimum LoRa ·· Listen Before Talk LoRa operating protocol Available options include a LoRaWAN™ mCard capable of supporting thousands GPIO ·· 27 dBm support for European region performance wireless interface to connect a wide range of assets locally to the gateway. 1 ·· Certified for Europe 868 MHz, North American 3 Select Development Platform 2 Select Local Connection Node-RED, mLinux™ Ethernet, Serial, GPIO, LoRaWAN™ Serial mCards www.multitech.com/Conduit HIGHLIGHTS Application Development Tailored to You Easily Deploy and Manage Assets Via DeviceHQ MultiConnect Conduit provides both the IBM Node-RED graphical, drag-and-drop interface and mLinux development environments, offering IT professionals, integrators and developers alike, programming choice and capability to utilize the distributed intelligence capabilities of the Conduit to provide analytics on incoming data and provide more actionable outgoing data. MultiTech DeviceHQ is the M2M industry’s first IoT online application store to enable customers to easily deploy and scale applications to their connected devices. Drag-and-drop tools easily allow customers to create and manage applications for in-field assets. The DeviceHQ application store gives your business the power to innovate operations management and create value-added services. For the Advanced Developer – Open mLinux Development Environment With a completely open Linux development environment, our mLinux distribution is based on the Open Embedded/Yocto project; providing hundreds of open source packages and extensive language support. This development path is recommended for those wanting to port existing applications, who have strong language preferences, or who need complete firmware control. The mLinux Distribution Includes: ··Operating System: Linux 3.12 Kernel, Yocto 1.6 ··Language Support: Java, Ruby, Perl, Python, C/C++, PHP, C# and JavaScript Benefits ··“Low Touch” asset deployment reduces costs, complexity and time ··Reduce truck-rolls using remote performance management and asset updates ··Easily scales to your network needs ··Browse and download a wide variety of custom applications tailored to your business needs ··Packages: SQLite (Database), Ligttpd (Web Server), BusyBox (Core Utilities) Fast and Intuitive Programming with Node.js and Node-RED Technologies Applications can be simply created and deployed by the click of a button based upon IBM’s Node-RED visual development tool. Incredibly user-friendly, Node-RED is an intuitive graphical programming tool ideal for rapid prototyping, designed for IT professionals to optimize and scale the edge behavior of their IoT network. ACCESSORIES MultiConnect Conduit Accessories – From the Gateway to the Endpoint MultiConnect Conduit is the center of an integrated IoT platform and comes with the following options: MultiConnect mCard MultiConnect mCards provide the flexibility needed to manage diverse infrastructures, supporting a wide range of interfaces and communication protocols including: GPIO LoRa™ Ethernet Serial ··Multi-Function Serial GPIO ··LoRa LPWAN • Ethernet MultiConnect mDot – Connecting the “Things” MultiConnect mDots are inexpensive RF radio modules able to connect low data-rate M2M devices to the internet through the Conduit IoT gateway using the LoRa Alliance™ LoRaWAN specification, a long-range, Low-Power Wireless Access Network (LPWAN) technology. mDots bring intelligence, reduced cost and complexity to the very edge of the network by running the ARM® mbed™ OS on a low power ARM Cortex®-M4 processor. With support for multiple interfaces, just about any “Thing” can now be cost effectively connected to the Conduit and choice of cloud data provider. SPECIFICATIONS Model MTCDT-Lxxx MTCDT-H5 HSPA+ LTE 3GPP Release 9 (100 Mbps peak downlink/50 Mbps peak uplink) AT&T/T-Mobile Europe Verizon with HSPA+ 21/GPRS fallback with HSPA+ 42/GPRS fallback (No fall back) AT&T/T-Mobile Europe Verizon 4G: 700(B17)/ 850(B5)/ AWS1700(B4)/ 1900(B2) 3G: 850(B5)/ 1900(B2) 2G: 850/1900 4G: 800(B20)/ 1800(B3)/2600(B7) 3G: 850(B5)/ 900(B8)/2100(B1) 2G: 900/1800 700(B13)/AWS1700(B4) Performance Frequency Bands (MHz) Processor & Memory Packet Data Radio Frequency LoRa 3G: 850/900/1700 (AWS)/1900/2100 2G: 850/900/1800/1900 ARM9 processor with 32-Bit ARM & 16-Bit Thumb instruction sets • 400 MHz • 16K Data Cache • 256 MB Flash Memory • 16K Instruction Cache • 128X16M DDR RAM 21 Mbps downlink, 5.76 Mbps uplink Up to 100 Mbps downlink, Up to 50 Mbps uplink LoRa 868 or 915 MHz – a proprietary Digital Spread Spectrum technique Storage Micro SD Input Voltage 9V to 32VDC Connectors Ethernet 1 RJ-45 Ethernet 10/100 port USB 2 USB Ports: USB Host (Type-A), USB Device (Micro-B) Serial Antenna 1 Debug Serial: USB Micro-B Female SMA, Cell 2dBi (Qty 2) GPS (Qty 1) and WIFI/BT (Qty 1) SIM SIM/USIM Physical Description Dimensions (L x W x H) 6.35" x 4.23" x 1.69" (161.3 mm x 107.4 mm x 42.8 mm) Weight 1.01 lbs (16.2 oz) with two accessory cards installed Chassis Type Metal Environmental Operating Temperature -30° to +70° C* Storage Temperature -40° to +85° C Relative Humidity 20% to 90%, non-condensing Certifications EMC Compliance US: FCC Part 15 Class B. EU: EN 55022 Class B, EN 55024. Canada: ICES-003 Radio Compliance Safety Network Approvals Quality FCC Part 22,24,27 UL 60950-1 2nd Ed., cUL 60950-1 2nd Ed., IEC 60950-1 2nd Ed PTCRB, GCF certified module, AT&T, T-Mobile Pending: Rogers, Bell, Telus, Verizon & Sprint MIL-STD-810G: High Temp, Low Temp, Random Vibration. SAE J1455: Transit Drop & Handling Drop, Random Vibration, Swept-Sine Vibration. IEC68-2-1: Cold Temp. IEC68-2-2: Dry Heat * UL Listed @ 40° C, limited by AC power supply. UL Recognized @ 70° C when used with the fused DC power cable, part number FPC-532-DC. Installation in outdoor locations or ambient temperature above 40° C or 70° C has not been evaluated by UL. UL Certification does not apply or extend to use in outdoor applications. Optional power must be UL Listed ITE power supply marked LPS or Class 2 rated 12VDC, 5A. Certification does not apply or extend to voltages outside certified range, and has not been evaluated by UL for operating voltages beyond tested range. SOFTWARE SPECIFICATIONS mLinux Open source embedded Linux distro based on the Yocto Project Tool chain for creating custom images LoRa network server & packet forwarder WAN connection via Ethernet or cellular Cellular PPP, DHCP client & server Firewall configuration via iptables MTAC-GPIO, MTAC-MFSER, MTAC-ETH and MTAC-LORA opkg package manager with limited package feed Basic router functionality built-in with Linux Full root console access via SSH and serial debug port RS-232, RS-485 Out of the box support for C, C#, C++, Java, Perl, Python, Javascript, Node.js, Ruby Software configurable USB device port Five configurable LEDs Lighttpd web server AEP Enhanced closed source embedded Linux platform LoRa network server & packet forwarder Static routing Router/Modem management Node-RED integration Graphical web interface for configuration and management WAN Connection Built-in Node-RED application development environment, Cellular PPP, Dynamic DNS, DHCP Server/Client Node modules for
MTAC-GPIO, MTAC-MFSER and MTAC-LORA WAN connection via Ethernet or cellular RS-232, RS-485 LAN/WAN Security Language Support Secure firewall with NAT and port forwarding C, C++, Python, Javascript, node.js, bash Remote Access Configuration backup & restore Easy firmware upgrade through graphical web interface Seamless integration with DeviceHQ, MultiTech’s device management platform System and network statistics ORDERING INFORMATION SERVICES & WARRANTY Non-cellular Models Model Description MTCDT-210L-US-EU-GB mLinux Programmable Gateway w/US/EU/UK Accessory Kit MTCDT-210A-US-EU-GB Application Enablement Gateway w/US/EU/UK Accessory Kit Region Global Global HSPA+ Models Model Description MTCDT-H5-210L-US-EU-GB HSPA+ mLinux Programmable Gateway w/US/EU/UK Accessory Kit MTCDT-H5-210A-US-EU-GB HSPA+ Application Enablement Gateway w/US/EU/UK Accessory Kit Region Global Global LTE Models Model Description MTCDT-LAT1-210L-US LTE mLinux Programmable Gateway w/US Accessory Kit MTCDT-LAT1-210A-US LTE Application Enablement Gateway w/US Accessory Kit MTCDT-LVW2-210L-US LTE mLinux Programmable Gateway w/US Accessory Kit (Verizon) MTCDT-LVW2-210A-US LTE Application Enablement Gateway w/US Accessory Kit (Verizon) MTCDT-LEU1-210L-EU-GB LTE mLinux Programmable Gateway w/EU/UK Accessory Kit MTCDT-LEU1-210A-EU-GB LTE Application Enablement Gateway w/EU/UK Accessory Kit Region NAM NAM NAM NAM EMEA EMEA RECOMMENDED ACCESSORIES MultiConnect mCard Model Description MTAC-GPIO GPIO Accessory Card, GPIO Cable Sold Separately MTAC-MFSER-DTE Multi-Function Serial Accessory Card - DTE Interface MTAC-MFSER-DCE Multi-Function Serial Accessory Card - DCE Interface MTAC-LORA-868 868 MHz LoRa Accessory Card, Antenna Sold Separately MTAC-LORA-915 915 MHz LoRa Accessory Card, Antenna Sold Separately Region Global Global Global EMEA NAM MultiConnect mDot Model Description MTDOT-868-X1-SMA 868 MHz XBee LoRa SMA MTDOT-868-X1P-SMA 868 MHz XBee LoRa SMA w/Programming Header MTDOT-868-X1-UFL 868 MHz XBee LoRa UFL MTDOT-868-M1-UFL 868 MHz SMT LoRa UFL MTDOT-868-M1-TRC 868 MHz SMT LoRa RF Pad MTDOT-915-X1-SMA 915 MHz XBee LoRa SMA MTDOT-915-X1P-SMA 915 MHz XBee LoRa SMA w/Programming Header MTDOT-915-X1-UFL 915 MHz XBee LoRa UFL MTDOT-915-M1-UFL 915 MHz SMT LoRa UFL MTDOT-915-M1-TRC 915 MHz SMT LoRa RF Pad Region Euro Euro Euro Euro Euro NAM NAM NAM NAM NAM MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. INSTALLATION SUPPORT MultiTech’s Installation Support Service delivers priority service with the ability to work one-on-one with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. TECHNICAL SUPPORT SERVICES At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go Developer Kit and Accessories Model Description MTUDK2-ST-MDOT Developer Kit, includes SMA antenna and USB cable, mDots sold separately AN868-915A-1HRA 868-915 MHz RP-SMA Antenna, 8" (3.0dBi) CARSMA-UFL Reverse SMA-to-UFL Coax RF Cable, 6" CA-MTAC-GPIO GPIO Cable for MTAC-GPIO (2.5 ft) CA9-9-D DE9M-DE9F Serial Cable (6 ft) CA-USB-A-MICRO-B-3 USB Cable Type A to Type B Micro (3ft) Go to www.multitech.com for detailed product model numbers. The LoRa® name and associated logo are trademarks of Semtech Corporation or its subsidiaries. Region Global Global Global Global Global Global World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk
MTCDT-H5-210L-US-EU-GB 价格&库存
很抱歉,暂时无法提供与“MTCDT-H5-210L-US-EU-GB”相匹配的价格&库存,您可以联系我们找货
