MTC-C2-B08-N3-KIT
MTC-C2-B08-N3-KIT
    MULTI-TECHSYSTEMS
    MODEM CDMA USB 800MHZ 1.9GHZ
MTC-C2-B08-N3-KIT 数据手册
MultiConnect® Cell 100 Series Cellular Modems now supporting LTE Cat 4 FEATURES ·· 4G (Cat 4, Cat 3 and Cat M1), NB-IoT and 3G models The MultiConnect® Cell 100 Series cellular modem is a compact ·· SSL/TLS support communications platform that provides cellular capabilities for fixed and ·· LTE and GSM models available mobile applications. It is intended for use in settings demanding reliable ·· Models with USB or RS-232 serial interfaces performance under rugged conditions, low power and long range such as remotely monitoring solar micro-inverters, power generators, tanks, pipelines, ·· Configured using AT commands meters, pumps and valves in any energy, utility, or industrial application. ·· FCC, PTCRB, Industry Canada, and RED certified The MultiConnect Cell 100 Series family has also been successfully deployed ·· Rugged, military and SAE tested by professionals in emergency services, vending, remote patient monitoring, ·· Two-year warranty, upgradable to five years renewable energy systems, End-of-Train system management and process automation. MultiConnect Cell 100 Series modems are fully certified for BENEFITS deployment in multiple geographies around the world, so you can get to ·· Quick deployments to shorten time to market market extremely fast. Designed specifically for M2M applications, they ·· Long and stable lifecycles provide a long, stable lifecycle and are durable, reliable and easy to deploy. ·· Certified and carrier approved Connecting Your Devices Your Devices & Data Insight + Action + Control Digital Signage Energy Alerts ATM/POS Vending Machines Financial / Retail Real-Time Management Healthcare Kiosks Wireless Service Provider Asset Management Platform Reports www.multitech.com/cell100 SPECIFICATIONS Model MTC-MAT1 Performance Frequency Band (MHz) Packet Data* MTC-MVW1 LTE Cat M1 3GPP Rel. 13 B2 (1900MHz), B4 (AWS1700MHz), B12 (700MHz) SMS NB-IoT 3GPP Rel. 13 B4 (AWS1700MHz) B13 (700MHz) MTC-LEU4 LTE Cat 4 3GPP Rel. 13 4G:700(B12/ B13)/850(B5)/ AWS1700(B4) 1900(B2) 3G AT&T only: 850(B5)/1900(B2) 3GPP Rel. 13 B8 (900MHz) B20 (800MHz) Up to 300 Kbps downlink Up to 375 Kbps uplink Up to 300 Kbps downlink Up to 375 Kbps uplink Diversity/MIMO MTC-LNA4 MTC-NEU1 3GPP Rel. 13 4G: B1 (2100)/ B3 (1800)/ B7 (2600)/ B8 (900)/ B20 (700) 3G: B1 (2100)/ B8 (900) 2G: B3 (1800)/ B8 (900) 3GPP Up to 150 Mbps downlink/ Up to 50 Mbps uplink (Category 4) N/A Rx Diversity and MIMO DL 2x2 Point-to-Point Messaging, Mobile-Terminated SMS, Mobile-Originated SMS N/A Point-to-Point Messaging, Mobile-Terminated SMS, Mobile-Originated SMS Windows XP/Vista/7/8/2007/2008 (32-bit/64-bit), 2003 (32-bit) Linux (2.6.x or greater) Operating System Support Power Requirements Voltage USB Models: USB powered – 5V RS-232 Models: 7 - 32VDC USB powered – 5V Connectors RF Antenna External 50 ohm SMA (female connector) SIM Mini SIM (2FF); 1.8 and 3V USB Type B mini USB RS-232 DE-9 (female connector) Power RS-232 Models: 2.5 mm miniature (screw-on) Physical Description Physical Dimensions (L x W x H) 3.17" x 2.45" x 1.16" (8.05 cm x 6.22 cm x 2.95 cm) Physical Weight 0.65 lbs (0.295 Kg) Chassis Type Aluminum Environmental Operating Temperature† -40° to +185° F (-40° to +85° C) Storage Temperature -40° to +185° F (-40° to +85° C) Relative Humidity 15% to 93% noncondensing Certifications Regulatory Compliance Safety Network Quality FCC Class B (US) IC (Canada) FCC Class B (US) RED (Pending) FCC Class B (US) IC (Canada) RED UL 60950-1 UL 60950-1 (US) IEC 60950-1 (Pending) UL 60950-1 (US), cUL 60950-1 (Canada) IEC 60950-1 N/A PTCRB, GCF approved module,
AT&T, T-Mobile,
EU carriers Pending: Rogers,
Bell, Telus, Telstra N/A PTCRB AT&T, T-Mobile, Verizon MIL-STD-810G: High Temp, Low Temp, Cold Dwell, Random Vibration and Sine Vibration SAE J1455: Random Vibration and Sine Vibration * Actual performance speeds may be affected by a variety of attributes such as cell tower distance, data loads, packet sizes, etc. † Device has been tested up to +85° C. UL Recognized @ 40° C, limited by AC power supply. UL Recognized @ 60° C when used with the fused DC power cable, part number FPC-532-DC. Note: The radio’s performance may be affected at the temperature extremes. This is considered normal. There is no single cause for this function. Rather, it is the result of an interaction of several factors, such as the ambient temperature, the operating mode and the transmit power. SPECIFICATIONS Model MTC-LAT1 MTC-LVW2 Performance Frequency Band (MHz) Packet Data* Diversity/MIMO SMS Operating System Support MTC-H5 LTE Cat 3 4G: 700(B17)/850(B5)/ AWS1700(B4) 1900(B2) 3G: 850(B5)/1900(B2) 2G: 850/1900 HSPA+ 4G: 700(B13)/ AWS1700(B4) Hepta-band 850/900/AWS 1700/1900/2100 Up to 100 Mbps downlink/ Up to 50 Mbps uplink (Category 3) Up to 21.0 Mbps downlink Up to 5.76 Mbps uplink Rx Diversity and MIMO DL 2x2 N/A Point-to-Point Messaging, Mobile-Terminated SMS, Mobile-Originated SMS Text & PDU, Point-to-Point Windows XP/Vista/7/8/2007/2008 (32-bit/64-bit), 2003 (32-bit) Linux (2.6.x or greater) Power Requirements Voltage USB Models: USB powered RS-232 Models: 5 - 32VDC USB Models: USB powered – 5V RS-232 Models: 7 - 32VDC Connectors RF Antenna External 50 ohm SMA (female connector) SIM Mini SIM (2FF); 1.8 and 3V USB Type B mini USB RS-232 DE-9 (female connector) Power RS-232 Models: 2.5 mm miniature (screw-on) Physical Description Physical Dimensions (L x W x H) 3.17" x 2.45" x 1.16" (8.05 cm x 6.22 cm x 2.95 cm) Physical Weight 0.65 lbs (0.295 Kg) Chassis Type Aluminum Environmental Operating Temperature† -40° to +185° F (-40° to +85° C) Storage Temperature -40° to +185° F (-40° to +85° C) Relative Humidity 15% to 93% noncondensing Certifications Regulatory Compliance FCC Class B (US), IC (Canada) Safety UL 60950-1 (US), cUL 60950-1 (Canada) Network Quality PTCRB, GCF approved module, AT&T, T-Mobile, EU carriers Pending: Rogers, Bell, Telus, Telstra FCC Class B (US) FCC Class B (US), IC (Canada), RED (EU Economic Area, RCM (Australia/NZ), and IFT (Mexico) UL 60950-1 (US) UL 60950-1 (US), cUL 60950-1 (Canada), IEC60950-1 (EU Economic Area), AS/NZS 60950-1 (Australia/NZ) Verizon PTCRB, GCF approved module, AT&T, T-Mobile, Rogers, Bell, EU carriers Pending: Telus, Telstra MIL-STD-810G: High Temp, Low Temp, Cold Dwell, Random Vibration and Sine Vibration SAE J1455: Random Vibration and Sine Vibration * Actual performance speeds may be affected by a variety of attributes such as cell tower distance, data loads, packet sizes, etc. † Device has been tested up to +85° C. UL Recognized @ 40° C, limited by AC power supply. UL Recognized @ 60° C when used with the fused DC power cable, part number FPC-532-DC. Note: The radio’s performance may be affected at the temperature extremes. This is considered normal. There is no single cause for this function. Rather, it is the result of an interaction of several factors, such as the ambient temperature, the operating mode and the transmit power. HIGHLIGHTS SERVICES & WARRANTY Applications The MultiConnect Cell 100 Series cellular modems are ideal for automated machineto-machine applications such as remote diagnostics and remote monitoring which periodically need to send or receive data over a wireless network. MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. Comprehensive Service and Support The MultiTech commitment to service means we provide a two year product warranty and service that includes free technical support, 24 hour website, and FTP support. ORDERING INFORMATION LTE Products Model MTC-LNA4-B01-US Description LTE Cat 4 Modem, RS-232 interface with Accessory Kit (AT&T - Verizon Dual mode cell) Bundle Available Yes Region US/Can MTC-LNA4-B03 LTE Cat 4 Modem, USB interface without Accessories (AT&T - Verizon Dual mode cell) Yes US/Can MTC-LNA4-B03-KIT LTE Cat 4 Modem, USB interface with USB Accessory Kit (AT&T - Verizon Dual mode cell) Yes US/Can MTC-LEU4-B01 LTE Cat 4 Modem, RS-232 interface without Accessories (Europe) Yes Europe MTC-LEU4-B03-KIT LTE Cat 4 Modem, USB interface with USB Accessory Kit (Europe) Yes Europe MTC-LAT1-B01-xx LTE Cat 3 Modem with fallback (RS-232 interface) - AT&T Yes US/Can MTC-LAT1-B02-xx LTE Cat 3 Modem with GPS and fallback (RS-232 interface) - AT&T Yes US/Can MTC-LAT1-B03-xx LTE Cat 3 Modem with fallback (USB interface) includes USB cable - AT&T Yes US/Can MTC-LVW2-B01-xx LTE Cat 3 Modem (RS-232 interface) - Verizon Yes US MTC-LVW2-B02-xx LTE Cat 3 Modem with GPS (RS-232 interface) - Verizon Yes US MTC-MAT1-B01-xx LTE Cat M1 Modem (RS-232 interface) - AT&T Yes US MTC-MAT1-B03-xx LTE Cat M1 Modem (USB interface) includes USB cable - AT&T Yes US MTC-MVW1-B01-xx LTE Cat M1 Modem (RS-232 interface) - Verizon Yes US MTC-MVW1-B03-xx LTE Cat M1 Modem (USB interface) includes USB cable - Verizon Yes US -xx Ordering Codes for MTC-LTE Models Blank Device only, no accessories -US Includes US style power supply, antenna(s) and RS-232 cable -KIT Includes antenna and USB cable (USB models only, USB powered) Narrow Band IoT (NB-IoT) Products Model MTC-NEU1-KIT Description NB-IoT (USB interface) Bundle Available Included Region EU Bundle Available Yes Region Global Yes Global INSTALLATION SUPPORT MultiTech’s Installation Support Service delivers priority service with the ability to work one-on-one with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. TECHNICAL SUPPORT SERVICES At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go -xx Ordering Codes for MTC-NB-IoT Models -KIT Includes antenna and USB HSPA+ Global Products Model MTC-H5-B01-xx Description HSPA+ Modem (RS-232 interface) MTC-H5-B03-xx HSPA+ Modem (USB interface) includes USB cable -xx Ordering Codes for MTC-H5 Models Blank Device only, no accessories -US-EU-GB Includes US, EU & UK style power supply, antenna(s) and RS-232 cable -KIT Includes antenna (USB models only, USB powered) -N16 For Aeris Communications Networks World Headquarters GPRS Products for Europe Model MTC-G3-B06-xx Description GPRS Modem (RS-232 interface) MTC-G3-B08-KIT GPRS Modem (USB interface) -xx Ordering Codes for MTC-G3 Models Blank Device only, no accessories -EU-GB Includes EU & UK style power supply, antenna(s) and RS-232 cable -KIT Includes antenna and USB cable (USB models only, USB powered) Use ordering codes for specific build options. Go to www.multitech.com for detailed product model numbers. Bundle Available Yes Included Region EU EU Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk
MTC-C2-B08-N3-KIT 价格&库存
很抱歉,暂时无法提供与“MTC-C2-B08-N3-KIT”相匹配的价格&库存,您可以联系我们找货
