USB300U
USB300U
    ENOCEAN(易能森)
    Module
    TRANSCEIVER ENOCEAN USB
USB300U 数据手册
DATA SHEET USB Gateway USB 300 / USB 400J / USB 500U USB 300/400J/500U is a small USB stick which connects gateways and smart home servers to the world of EnOcean based radio products. The USB stick is equipped with the TCM transceiver gateway module. The USB stick receives and sends all EnOcean radio telegrams according to the specified EnOcean Equipment Profiles (EEP). Radio telegrams are converted to a serial interface (EnOcean Serial Protocol 3) and transferred via USB interface. Sample image: USB 300 / USB 500U (white housing) Sample image: USB 400J (transparent housing) Features: • Full ESP3 feature set • Power, Rx and Tx LED • Optimized PCB antenna • Integrated security handling • Virtual COM Port driver (FTDI) The USB stick is designed and produced as white label OEM product. Labels and housing can be changed to specific requirements of OEM manufacturers (original distributors). TYPE ORDERING CODE USB 300 USB 400J S3004-K300 white S3064-K400 transparent USB 500U S3054-K500 white Features overview Frequency/antenna Data rate Modulation type USB 300: 868.300 MHz / PCB antenna USB 500U: 902.875 MHz / PCB antenna USB 400J: 928.350 MHz / PCB antenna 125 kBit/s USB 300: ASK 868 MHz1) USB 500U: FSK 902 MHz1) USB 400J: FSK 928 MHz1) USB 300: typ. –96 dBm2) USB 500U: typ. -98 dBm2) USB 400J: typ. -95 dBm2) 2 (standard performance) Receiver Sensitivity (at 25°C)2) Receiver Category (RED, EN 300 220) Output Power Dimensions (incl. cap) USB 300: max. 6,7 dBm (radiated) USB 500U: typ. 1 dBm (conducted) USB 400J: typ. 0 dBm (conducted) 70 x 23 x 9 mm OEM label size USB connector Operating temperature Radio Regulations 39 x 12 mm Typ A -20°C to +50°C (max. 90% r.h.) USB 300: CE (EU) / UKCA (UK) USB 500U: FCC (US) / ISED (CA) USB 400J: MIC/ARIB (Japan) 1) According to ISO/IEC 14543-3-1x 2) 0.1% telegram error rate (based on the combination of 3 received sub-telegrams). USB extension cable is recommended for best performance. © EnOcean | www.enocean.com Datasheet - Subject to modifications | April 2022
USB300U 价格&库存
很抱歉,暂时无法提供与“USB300U”相匹配的价格&库存,您可以联系我们找货
